Tale tweak res pomaga?
RookY ::
A nice little tweak for XP. Microsoft reserve 20% of your available bandwidth for their own purposes (suspect for updates and interrogating your machine etc..)
Here's how to get it back:
QUOTE
Click Start-->Run-->type "gpedit.msc" without the "
This opens the group policy editor. Then go to
CODE
Local Computer Policy-->Computer Configuration-->Administrative Templates-->Network-->QOS Packet Scheduler-->Limit Reservable Bandwidth
Double click on Limit Reservable bandwidth. It will say it is not configured, but the truth is under the 'Explain' tab :
"By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default."
So the trick is to ENABLE reservable bandwidth, then set it to ZERO. This will allow the system to reserve nothing, rather than the default 20%.
Have fun.
Best,Regards
Cris_Cr0ss
Lots of Thanks to FunkMeister
New Note: This Doesnt Work with Windows Xp Home.
This post has been edited by Cris_Cr0ss: Today, 08:25 PM
Stolen from the 707 forum
http://www.700mb.net/index.php?showtopi...
Juhu juhu spet bom bruhu
Matek ::
Mja, potem bi uporabniki 1 mbit adslja lahko downloadali z največ dobrih 100 KB/s, kako to, da jaz lahko z 121 KB/s max?
marjanX ::
Zato, dragi MadManMato, ker imaš doma (predvidevam) 100Mbps kartico. Kar pomeni, da si je M$ postavil limit na 80Mbps. Ne na 1Mbps.
Za 10Mbps kartico pa pomeni to 8Mbps. Kar je tudi nekaj več kot 1Mbps.
Matek ::
20% mrežmega bandwidtha ti rezervira? Če je pa internet bottleneck, sej potem pri meni nič ne profitirajo, za update in vohunjenje po moji mašini rabijo internetno povezavo.
Kaj ima MS od tega, da ti 20% upočasni mrežo?
Sicer pa eni še vedno mislijo, da MS ne vem kako hudo snifa po mašinah. Zakaj ni bilo nikoli prej v forumu debate o 20% manjk bandwidtha, navsezadnje je to zajeten kos, WinXP pa so že kar dolgo časa zunaj.
Matek ::
Evo, malo sem pobrskal po Black Viperjevem Services configu in on pravi takole:
Take note: Some people (as I did before I completed extensive research on this) reported that QoS uses 20% of your bandwidth and does not allow any activity, regardless. This is false. For more information, please view this KB article from Microsoft (I normally do not post links to them, but this warrants it):
http://support.microsoft.com/default.as...
Regardless, if you uninstall the packet scheduler, no "bandwidth" is still reserved.
Bakunin ::
Verjetno to ne deluje, ce izklopis QoS servis, mar ne? :D
elasto_mania ::
meni je opazno zvišalo
četudi mam 100mbit kartico
in naročnino za 1mbit
Izi ::
Tale "tweak" ne pomaga popolnoma nič.
QoS je odlična zadeva in izklaplajti jo je popolnoma brez pomena oz. je zelo slabo za hkratno uporabo bandwidtha med več programi ali računalniki.
Tudi z vklopljenim QoS imaš vedno na razpolago 100% bandwidth.
Brez QoS ti bo že prvi program pobral vseh 100% in ko bo drugi program ali drug računalnik v mreži poskusil uporabiti isti bandwidth ga ne bo mogel.
Z QoS pa si tudi ob 100% zasedenosti tvojega bandwidtha vsak program ali računalnik v mreži zase pribori do 20% od celotnega prenosa.
Dobi seveda samo toliko kolikor rabi oz. največ 20%. Tisti hip ko prenosa ne rabi več se ves prenos vrne prvemu programu in ta ima zopet 100% bandwidth na razpolago.
Nikoli ni nekaj rezerviranega in neizkoriščenega, kar so se na začetku nekateri bali.
Torej če imaš sharing tvojega bandwitha med več računalniki ali če uporabljaš hkrati več programov ki hkrati dostopajo do lokalne mreže ali interneta potem je QoS obvezen.
Če torej ugasneš QoS se ti bo zgodilo, da boš na tvojem računalniku zagnal P2P program, ki bo seveda pobral ves bandwith, in ko bo v drugi sobi na drugem računalniku tvoja sestra ali mama hotela nekaj pobrskati na internetu, ne bo mogla ji tvoj P2P program ne bo hotel odstopiti tistih par procentov prenosa, ki bi jih potem takoj dobil nazaj.
Tudi če imaš samo en računalnik je QoS uporaben, ko lahko hkrati goniš Bittorent in Mulo brez skrbi, da bo eden ali drugi ostal čisto brez prenosa.
Torej, QoS je odlična zadeva in mora biti vedno vklopljen.
Drugič se malo pozanimajte preden širite krivo vero.
V Windows ni nobene nastavitve, ki bi bila kakorkoli v škodo uporabnika.
Seveda so pri nekaterih nastavitvah potrebni kompromisi in MS je default vedno nastavil tako, da bo koristil največjemu številu uporabnikov.
Če imaš torej "normalen" računalnik, ki v ničemer močno ne izstopa od povprečja potem boš z kakršnimkoli "Tweakanjem" vedno naredil več škode kot koristi.
Zapomnite si to :D
  • spremenil: Izi ()
Bakunin ::
| QoS je odlična zadeva in izklaplajti jo je popolnoma brez pomena oz. je zelo slabo za hkratno uporabo bandwidtha med | več programi ali računalniki.
Seveda le ce si QoS tudi nastavil.
Jaz ga raje izklopim ter nastavljam prepustnost v vsakem (p2p) programu posebaj.
Tisti, ki tega ne delajo, si tudi QoS ne bodo nastavili.
  • spremenil: Bakunin ()
Izi ::
Bakunin, motiš se :8) . Nič ga ni treba nastavljat.
To je del zapisa iz okenčka Explain:
If you disable this setting or do not configure it, the system uses the default value of 20 percent of the connection.
Se pravi, če pustiš na "Not configure" (kar je default) ali če daš na "Disable" bo Windows uporabljal QoS z prednastavljeno vrednostjo 20% celotne povezave.
Zato je tudi v opisu "tweaka" na začetku tega topica omenjeno, da lahko QoS izklopiš samo na en način in sicer da ga nastaviš na "Enable" in nato vneseš vrednost nič.
V Bistvu se QoS sploh ne da ugasniti, samo če ga nastviš na vrednost nič, je učinek isti kot da ga ga ne bi bilo.
Torej, Bakunin, tudi ti QoS še vedno uporabljaš razen, če nisi vrednosti nastavil na nič.
Lahko pa ga izklopiš tudi za vsako mrežno povezavo posebej, če zbrižeš kljukico pri "QoS Packet Scheduler"
Bakunin ::
za svoje "background transfer" ter 'automatic update" ipd.
A poznas kaksen "navaden" program, ki bi znal uporabljati ta QoS servis ?
fizicne povezave naprave (100/10Mb ethernet kartica ) ali resnicne (4M ADSL) ?
Saj verjetno ni jasnovidec....
Poleg tega ne maram, ce nek program misli, da ve vec o racunalniku/povezavi kot jaz....
nimam tega pri "network connections". PS: nimam XP 0:)
Izi ::
Vsi programi.
V Win2000 in WinXP si vsak program, ki dostopa do mreže (lokalne ali internetne) lahko zase rezervira določen bandwith v primeru, da je le ta zapolnjen do konca.
>>fizicne povezave naprave (100/10Mb ethernet kartica ) ali resnicne (4M ADSL) ? Saj verjetno ni jasnovidec....
Resnične povezave.
Računalnik stalno spremlja bandwidth za vsak program posebej dokler ta narašča in ko se ustali na neki vrednosti.
Ko bandwidth nekaj časa stoji na mestu, kljub temu, da novo odprti programi dajejo zahtevo po prenosu podatkov, pač ugotovi, da več ne gre.
Ali je treba biti jasnovidec za to?
In potem ta celoten bandwidth razdeljuje glede na zahteve programov in neporabljeni bandwidth takoj daje nazaj v skupno uporabo.
Preberi si link, ki ga je dal MadManMato. Tam je vse bolj podrobno razloženo.
To pa ne spada več v to temo :D
Programi ne mislijo. Misliš ti in zato imaš probleme >:D
Bakunin ::
in ce npr. dolocen program v dolocenem trenutno porablja samo 50% resnicne povezave ?
To on oznaci kot maksimum ? torrent/seeds...
ne vem...ne vem...
se popravljam.
programi domnevajo.
homo sapiens. kaj ces....
antonija ::
Ti laufas mulo (50% bandwitha). Pol laufas se torrent-thingy(recimo 40% bandwitha). Pol tvoja sestra surfa po netu in zasede se 10% bandwitha. Zdej se majo vsi trije programi lepo in si bratsko delijo celoten bandwith. QOS to vidi in ne dela sranja. Pol pa ti priklopis svoj najljubsi online spil ki bi tud rad mal bandwitha mel. Pa QOS vidi da ga nima nic in sklepa, da je to zato ker mula, torrent in sestra kurijo 100%. Ker pa ti res hoces igrat se QOS odloci da bo tud tvoja igra dobila svoj del in prvim trem zniza porabo bandwitha in ga nameni tebi.
In vse to brez da bi poznal podrobnosti tvojega ADSL paketa. Amazing, huh!!>:D
kixs ::
antonija:
ce je pa to res... sem pa js papez 8-O
Najvecjo prioriteto ima vedno najmocnejsa povezava, torej, ce ti mula zasede celoten bandwidth, ti QoS ne bo nic pomagal, da bos lahko spilal on-line... vsaj po mojih izkusnjah NE!
antonija ::
Ce ti mula zasede celoten bandwith ji ga QOS "odsede" do 20% zato, da drugi programi delajo. Kaksna je njihova odzivnost in kaksen bo ping je druga zgodba, bandwith bojo pa mel.
Izi ::
Ni res.
Najvišjo prioriteto ima prva vzpostavljena povezava. Tukaj velja kdor prvi pride, prvi melje :D
Če imaš pet porabnikov tvojega bandwidtha, potem bo vsak imel na razpolago 20%. Čim eden ne bo izkoristil vseh 20%, jih bo dobil nazaj program, ki je prvi vzpostavil povezavo.
Nikar pa ne pozabit, da je upload daleč bolj pomemben kot download. Če zapolneš celotni upload potem ne bo nobeden več mogel downloadati popolnoma nič več, ker za vsak download je potrebno najprej uploadati podatke, oz. svoje naročilo, kaj sploh hočeš downloadati.
Imaš lahko še 90% prostega downloada pa ne bo noben program mogel več nič downloadati, če bo upload na 100%.
Ker imamo večinoma vsi ADSL povezave, kjer je upload hudo majhen, je treba bolj paziti na upload, da se ta ne zapolne. Downloada imamo ponavadi vsi več kot dovolj.
Omejevanje hitrosti interneta
Oddelek: Omrežja in internet
235660 (4829) Bakunin
Nadzor omrezja
253825 (3100) SmeskoSnezak
pohitritev dsl ali kabelskega neta v win xp
62192 (1930) BlueRunner
JOJ pa ta PING
111707 (1597) Hux
QoS???
231711 (1510) andrej
