Kako isklopiti oblačke v XP-jih
Bevcan ::
Ali se da popolnoma izklopit te nadležne oblačke v Windowsih XP?
  • zavaroval slike: Gandalfar ()
blblb ::
To Disable The Notification Area Balloon Tips
Click Start, click Run, type regedit, and then press ENTER.
Navigate to the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
Right-click the right pane, create a new DWORD value, and then name it EnableBalloonTips.
Double-click this new entry, and then give it a hexadecimal value of 0.
Quit Registry Editor. Log off Windows, and then log back on.
These steps disable all Notification Area balloon tips for this user. There is no way to disable balloon tips for specific programs only.
Help and Support je tvoj prijatelj :)
nicjasno ::
Se bolse pa ce uporabis TWEAKUI, ki pride v sklopu microsoftove zbirke "powertoys for winxp", za dol potegnit na ms domaci strani.
Bevcan ::
Najlepša ti hvala. Sej bi si verjetn znou sam najdt če bi se bi sanjal kako se tem presnetim oblačkom reče v angleščini.
Oživljanje starih računalnikov
457071 (4991) krneki0001
Težave s Language pack pri xp
61368 (1233) polde66
Trajen izklop windows opozoril v oblačkih ob zagonu
102180 (1799) Ursus
pohitritev dsl ali kabelskega neta v win xp
Oddelek: Omrežja in internet
62194 (1932) BlueRunner
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
7110035 (8457) Tilen
