Forum » Pomoč in nasveti » Sredi start up-a računalnik zmrzne
gofra ::
Ob zagonu računalnika mi tam, kjer se prvič pojavi Windows logo (XP) na črnem ozadju zadeva dostikrat zmrzne. Po številnih poskusih mi rata. Potem pa pogledam v error log, ki pravi dvoje:
"Volume Shadow Copy Service error: Unexpected error calling routine CoCreateInstance. hr = 0x80040206.
For more information, see Help and Support Center at..."
...in pa:
"The COM+ Event System detected a bad return code during its internal processing. HRESULT was 8007043C from line 44 of d:\nt\com\com1x\src\events\tier1\eventsystemobj.cpp. Please contact Microsoft Product Support Services to report this error.
Ker nisem ravno doma na tem področju vljudno prosim koga za pomoč. Hvala!
...in pa:
Lith ::
fajn, samo napiši še kaj imaš v računalniku takega posebnega, XPje si napisal, katero ploščo, procesor, diske (ali imaš RAID), CD-RW, modemi, grafične, USB, v glavnem vse kar imaš priključeno, ker se nekaj zgleda tepe pri zagonu, ko preverja nek gonilnik (bogve kater)
¤ black holes rule; I like the speed, speed kills ¤
gofra ::
Tole je celoten sistem (upam, da se boš znašel - drugače ne znam):
Local Disk (partitioned) IBM-DTLA-307045
(C:) Capacity - 7.80 GB
Used: 5.84 GB
Free: 1.95 GB
(D:) Capacity - 35.13 GB
Used: 20.43 GB
Free: 14.69 GB
Display
Type: Default Monitor
Color: True Color (32 Bit)
Resolution: 1280 x 1024
Screen Saver: Not Active
Modem
Manufacturer: Unknown
Model: Motorola SM56 PCI Fax Modem
Driver: Unknown
USB Controller
Manufacturer: VIA Technologies
Model: VIA Rev 5 or later USB Universal Host Controller
Driver: usbuhci.sys
Friday, August 17, 2001
Supported
USB Controller
Driver: usbuhci.sys
Supported
CD-ROM Drive (E:)
Manufacturer: (Standard CD-ROM drives)
Model: SONY CD-RW CRX140E
Driver: cdrom.sys
Supported
Video Card
Model: NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Driver: nv4_mini.sys
Monday, October 06, 2003
Supported
Sound Card
Manufacturer: VIA Technologies, Inc.
Model: VIA AC'97 Audio Controller (WDM)
Driver: ac97via.sys
Tuesday, April 29, 2003
Supported
Network Card
Model: WAN (PPP/SLIP) Interface
Driver: ndiswan.sys
Tuesday, January 01, 1980
Supported
Network Card
Driver: Unknown
Floppy Drive (A:)
Installed
Memory (RAM)
Capacity: 127.48 MB
Printers
Default Printer
HP DeskJet 930C/932C/935C
Driver: unidrv.dll
Supported
hp deskjet 930c series
Driver: hpz2ku04.dll
Wednesday, December 12, 2001
Supported
Specifications
VIA694
System Model: AWRDACPI
BIOS Version: VIA694 - 42302e31
Operating System
Microsoft Windows XP Professional
Version: 5.1.2600
Service Pack: 0.0
PID: 55274-640-0000356-23145
Hot Fix: KB823980
Memory (RAM)
Capacity: 127.48 MB
Processor
AMD Athlon(tm) Processor
Version: x86 Family 6 Model 4 Stepping 2
Speed: 650 MHz
General Computer Info
System Name: HAHA-DZCMRGB0D8
Domain: WORKGROUP
Time Zone: Central Europe Standard Time
Connection: Workstation (standalone)
Proxy Server: None
IP Address: 217.72.90.226
217.72.90.226
IPX Address: Not Enabled
Local Disk
Total Capacity: 42.93 GB
Sum of Hard Disks: (C: D: )
Used: 26.28 GB
Free: 16.65 GB
Hvala za karkoli! Če je tole preveč se opravičujem - povej mi kaj konkretno naj vnesem...
Used: 5.84 GB
Free: 1.95 GB
Used: 20.43 GB
Free: 14.69 GB
Display
Modem
Driver: Unknown
USB Controller
Driver: usbuhci.sys
Supported
USB Controller
Driver: usbuhci.sys
Supported
CD-ROM Drive (E:)
Driver: cdrom.sys
Supported
Video Card
Supported
Sound Card
Driver: ac97via.sys
Supported
Network Card
Driver: ndiswan.sys
Supported
Network Card
Driver: Unknown
Floppy Drive (A:)
Installed
Memory (RAM)
Capacity: 127.48 MB
Printers
Default Printer
Driver: unidrv.dll
Supported
Supported
Specifications
VIA694
Operating System
Version: 5.1.2600
Service Pack: 0.0
Hot Fix: KB823980
Memory (RAM)
Capacity: 127.48 MB
Processor
Speed: 650 MHz
Domain: WORKGROUP
Proxy Server: None
217.72.90.226
Local Disk
Used: 26.28 GB
Free: 16.65 GB
Lith ::
uh, na Microsoftu na tej strani - support.microsoft.com/default.aspx?scid=kb;en-us;823772 piše,
da je v takem primeru napake krivi poškodovane datoteke windowsov XP in se lahko reši samo s XP instalacijo/popravilo obstoječe konfiguracije (čisto spodaj pač piše kako postopek poteka)
pa uspešno popravilo ti želim...
gofra ::
Nah saj se mi je kar zdelo. Hehe, stran sem obiskal že včeraj pa se mi dogaja, da noče boot-at iz CDja. V biosu je nastavljeno pravilno potegne pa ga ne. V primeru, da računalnik zmrzne moram najprej narest uspešen zagon, da se lahko vrnem na začetek. In ko potem tik po zagonu vstavim XP CD mi sicer ponudi možnost boot from CD a po pritisku tipke enter gre dalje vse tako kot se je dogajalo prej. Zakaj hudiča ne zagrabi CDja nimam pojma. Lp!
tony ::
Vas bom prijavu na APZ.Hemmm... tudi jast mam piratskega.
OK sory ,sory ,..
OK sory ,sory ,..
- spremenil: tony ()
| » | Igre zamrznejo računalnik, zvok gre na mini loop ali na ton, slika freezne !Oddelek: Pomoč in nasveti | 1760 (1724) | delfinus |
| » | Linux internet povezava problemOddelek: Operacijski sistemi | 2500 (2115) | dr.J |
| » | BIOS upgradeOddelek: Pomoč in nasveti | 2021 (1851) | Dead_Eye |
| » | CRC failed pri vseh rar/zip fajlih!Oddelek: Pomoč in nasveti | 1874 (1607) | PapaDOc |
| » | What the HellOddelek: Pomoč in nasveti | 1795 (1600) | DarkHand |
