Iran - Vojna
Iran - Vojna
Goran10 ::
Legon je izjavil:
Goran10 je izjavil:
Zdaj bodo vsi začeli kupovati zavarovanja za Hormuz oziroma bodo hedgal tveganja.
When Hormuz closed, the Gulf didn't stop.
It improvised.
This map shows you how.
Route 1: Saudi Arabia's East-West Pipeline (Petroline)
Built exactly for this scenario. Pumps oil 1,200km from Gulf fields to Yanbu on the Red Sea completely bypassing Hormuz.
Capacity:~5 million barrels per day.
Hormuz was moving 17-20 mb/d before the war.
The bypass covers less than 30%
Route 2: UAE's Khor Fakkan
The UAE's east coast port sits outside the strait in the Gulf of Oman. ADNOC used it for ship to ship transfers, loading tankers that never entered Hormuz.
Remember those 30 million barrels ADNOC just sold to Asia? Many came out this way.
Route 3: The TIR All-Road Route
Trucks. Actual trucks carrying oil overland Saudi Arabia -> Jordan -> Israel -> Lebanon -> Turkey -> Europe.
Slow.
Expensive.
A fraction of sea volume.
But it ran.
Route 4: Around the Peninsula
The long way. Gulf of Aden -> Red Sea -> SUMED pipeline in Egypt -> Mediterranean.
Adds weeks of transit and thousands of miles.
Here's the brutal math?
All these routes combined can handle maybe 7-8 million barrels per day.
Hormuz was doing 17-20.
The gap 10+ mb/d simply didn't move.
This is why workarounds exist but don't work at scale.
Hormuz isn't bypassed.
It's merely partially patched.
To je samo Zzačetek trenda -v prihodnosti bo Hormuz vedno manj pomemben.
To bi treba se videt. Ker tukaj sta dva problema. Te alternstive a. Niso poceni, b. Niso varne. Ena od stvari, ki jo je Iran jasno demonstriral je to, da brez tezav doseze vse te alterative in jim nihce ne more preprecit, da jih sesujejo.
Gibanje cene nafte je treba primarno gledat skozi zaloge, ki jo drzave imajo in te znasajo nekje med 60 in 90 dni, odvisno od posamezne drzave. Zato ni cudno, da smo videli kapitulacija ZDA, ko smo presegli te mejnike in bi dejansko lahko prisli v situacijo, ko izpadov ne bi bilo mogoce pokrtivat z rezervami. Seveda je informacija o tem koliko so posamezne drzave crpale rezerv zaupna, ampak juzna azija in pacifik sta po stevilnih ocenah ze dihala na skrge. To so tudi drzave ki po vecini niso konkurencne zahodu ce bi do resne krize prislo.
Je pa na tem mestu vprasanje zate. Ce je hormuz ze v tem trenutku tako malo pomemben, zakaj potem dogovor kot je? Zakaj bi se ZDA strinjale z vsem kar je napisano, ce Hormuz v bistvu ni nek omembe vreden argument? Ker ce umaknes Hormuz iz te enacbe, bi ZDA lahko mirno spakirale in sle domov, brez da so si naredili novo sramoto s kapitulacijo. Ce se ni slo za hormuz, zakaj bi se karkoli rabili pogajat?
mislim, da tukaj ni treba izbirati med hormuz je nepomemben in hormuz je absolutno nenadomestljiv. resnica je vmes.
hormuz je še vedno izjemno pomemben, ker ga obvozne poti ne morejo v celoti nadomestiti. ampak hkrati ni več enak vzvod kot v sedemdesetih ali devetdesetih. danes obstajajo obvozne kapacitete, večja fleksibilnost kupcev, strateške rezerve, drugačni tokovi iz atlantika in tudi precej bolj sofisticiran trg, ki ne ceni samo šoka, ampak predvsem verjetnost, koliko časa bo šok trajal.
zato cena nafte ni eksplodirala tako, kot bi pričakovali pri preprosti tezi hormuz zaprt = konec sveta. trg očitno ne kupuje scenarija dolgotrajne popolne blokade. ceni dogovor, ceni vračanje tankerjev, ceni možnost dodatne iranske ponudbe in ceni dejstvo, da se je poraba že začela prilagajati.
strateške rezerve so del razlage, niso pa cela razlaga. to ni neka čarobna karta, ki rešuje problem za vedno. so samo most čez krizo. če bi hormuz ostal zaprt mesece in mesece, bi ta most postal vedno krajši in cena bi šla verjetno precej višje. ampak ravno zato je pomembno, da trg očitno pričakuje politični izhod prej, preden začasni blažilci odpovejo.
kar se tiče ameriškega dogovora, meni se ne zdi nujno, da je razlog samo hormuz. bolj verjetno je kombinacija več stvari: zda nimajo interesa vleči vojne v nedogled, nimajo želodca za kopensko avanturo, menjava režima iz zraka ni realna, boljši deal od jcpoa je težko izsiliti, hkrati pa bi dolgotrajna energetska kriza udarila tudi po ameriški in svetovni ekonomiji.
zato bi rekel takole: hormuz ni nepomemben, ampak njegov pomen se relativno zmanjšuje. ne zato, ker ga je danes mogoče elegantno nadomestiti, ampak zato, ker bodo vsi po tej krizi še bolj hedgali tveganja, gradili alternative, preusmerjali logistiko in zmanjševali odvisnost od ene same ožine. kratkoročno je hormuz še vedno močan vzvod. dolgoročno pa ravno vsaka takšna kriza pospeši proces, zaradi katerega bo ta vzvod manj absoluten.
Legon ::
Iranci so jedrsko orozje prakticno ze imeli (visoko obogaten uran). Zdaj se bodo Iranci do zadnjega oklepali tistega urana ter poskusali izvleci cim vec. Zacelo se je obdobje iranskega zavlacevanja.
Trust me bro, sam se 14 dni, ze zadnjih 30 let...
Res si pomilovabja vredem s svojo slaboumno cionisticno propagando.
Saj vem da te rit pece, ker te je Trump tako grdo nategnil, ampak se res lahko nehas smesit.
nic od tega kar nastevas ni zahtevalo da se Trump tako osmesi in kapitulira. Vse ostalo, razen odprtjs Hormuza, bi se zgodilo ce bi se americani umakjili brez da bi izpolnili novo letne zelje Irana.
  • spremenilo: Legon ()
Legon ::
Najboljs, da Lady citiras. Izvolio:
https://www.iaea.org/sites/default/file...
A je probelem v tvojem neznanju anglescine, al si upal, da ker je dolg dokument ne bo nihce videl, da notri ni porditive tvojih lazi?
BTW. Kaj se je pa zgodilonz pravljicami tvojega idola in brata b demenci, da so bile vse iranske jedrske kapacitete unicene junija 2025?
Notri dobesedno pise kaksne kolicine in koliko obogatenega urana je imel iran. Ter do katerih objektov niso imeli dostopa. Edina mozna razlaga je, da so zeleli imeti moznost hitre pridobitve jedrskega orozja. Druge ni.
Legon je izjavil:
Ti me samo citiraj. Seveda me ne bos, ker kaj takega nisem izjavil. Saj razumes, da se s takimi izjavami samo blamiras?
A ni bil pogoj tega sporazuma, da se takoj prenehajo boji v Libanonu? Ali pa je bilo mišljeno v roku 60 dni?
https://siol.net/novice/svet/v-napadih-...
kamiKaZaA ::
Vprašanje št. 1 je, če se bo sporazum sploh podpisal? Vprašanje št. 2 je, če se bo Američani in židi držali dogovora? Srečo imamo, da imajo v Ameriki vmesne volitve in da se bo do takrat gasil ta požar. Potem pa, če idioti (republikanci) spet dobijo večino se bo verjetno to njihovo sranje nadaljevalo...
Misliš, da bo kaj drugače, ko izvolijo demokrate? Oboji so za Izrael in neprestane vojne.
Poldi112 je izjavil:
Demokrati so načeloma bolj pristaši mehkih ukrepov, ki gredo v vojno če ne vidijo drugega izhoda. Republikanci so zgodovinsko gledano začeli več oboroženih konfliktov.
  • spremenil: Zmajc ()
Povej ni enega demokrata, ki ni bombardiral suverene države?
Propaganda takrat je že bila, da bodo demokrati vsepovsod začenjali vojne, trump je pa bil njegov prvi mandat takšen miroljubček.
Pa je kot stekel pes.
Se pravi se strinjaš, da z demokrati na čelu ne bo nič drugače?
Jaz bi jih sodil po dejanjih, ne pa po nekem upanju, da bi demokrati bili kaj boljši. Čeprav si težko predstavljam, da bi bil kdo kos bedastemu trumpu.
In smo nazaj pri vprašanju, kateri USA demokrat ni bombardiral suverene države?
Trump je sicer katastrofa, a vsaj razume, da je zajebal. Predhodniki so 20 let vztrajali v Iraku in Afganistanu, tako da boš težko argumentiral, da Trump opazno izstopa iz povprečja.
Vztrajali že (vse do Bidna), začeli pa niso teh vojn.
Ampak jaz sem imel v mislih hipotetične demokrate, ki bi vladali namesto Trumpa.
AMpak ko ima oblast v rokah najmočnejšo vojsko na svetu, neomejeno denarja in moči, potem se kaj dobrega iz tega ne more izcimiti. Absolutna moč pokvari absolutno.
Do Bidna? Aja, točno, Biden ni popolnoma nič pripomogel k vojni z rusi, ker vsi vemo, da so rusi napadli brez kakršnegakoli razloga?
Rusofili pač veste nekaj več.>:D
mojsterleo ::
karafeka je izjavil:
Izrael krši sporazum o prekinitvi ognja v Libanonu. Vojska IDF sicer ne strelja, ampak rušijo pa naprej z buldožerji. Hezbolah se na to odziva in potem Izrael brutalno odgovarja.
Skratka ena stran drugo obtožuje kršenja.
V bistvu je ta problem zelo slabo predstavljen v medijih. Večina kavč žurnalistov pač agitira za eno ali drugo stran.
Izrael nic ne krsi. Saj ni nic podpisal. Izrael ima seveda pravico rusiti hezbolahovo vojasko infrastrukturo. Ker je polno tunelov itd. Je edini nacin, da pac z buldozerji rusis.
Legon ::
In Iran ima po enaki logiki pravico blikirat hormuz, raketirat ladje in nenazadnje kupit jedrsko, da jo vrze na Izral, al kako tocno tvoja psihopatska logika deluje? Al ima v tvoji pravljici samo izbrano ljudstvo pravico sistematicno pobijat karkoli jim zapase?
Logika ni tvoja mocna stran.
mtosev je izjavil:
https://www.rtvslo.si/svet/bliznji-vzho...
Da. Vse kar si bral nekaj dni prej, je bil fake news, da izrael krsi dogovore itd.
Izrael je definitivno izgubil medijsko vojno.
V novici lahko preberes: "Iranski zunanji minister Abas Aragči je ob tem dejal, da bo vsakršna kršitev zavez iz sporazuma pripisana ZDA."
Upam, da clovek razume implikacijo. Vsaka krsitev zavez Hezbolaha, Hutijev ali Hamasa, se potem lahko pripise Iranu.
Kolega, ponovno projicirate. Če nekdo reče, da je sonce rumeno, tudi prepisuje od proruskih influencerjev? Ali zgolj vidi in opisuje isto objektivno realnost?
Objektivna realnost je da je sonce belo.
Tako da ja, kdor reče da je rumeno ali direkt laže, ali pa prepisuje od nekoga ki direkt laže.
Hvala za potrditev... kolega.
Kolegica, sonce je belo samo za vesoljce, medtem ko je na zemlji kar lepo rumeno.
Morda vam ne bi škodilo, da se malo - prizemljite.
  • spremenil: Poldi112 ()
Torej je belo. Lepo da priznaš.
enavlaka ::
Sonce ni belo niti rumeno temveč seva tako barvo.
Je plinski objekt, ki nima fiksne površine in brez definiranega vira svetlobe
Sveti vroč plin, podobno kakor v žarnici na nitko po Štefanovem zakonu
Barva, ki jo vidimo pa se spremnija glede na atmosfero.
Irelevantno za temo, ker se lažejo obe (vse) strani in je treba iz vsake novice izluščiti bistvo.
mojsterleo ::
Meni je to kar jasno. Sem že v eni od prejšnjih objav navedel, da memorandum ni pravno zavezujoč in da je za pričakovati kršitve. Je pa res, da Izrael obtožuje Hezbolah da so oni iniciatorji kršitve “premirja” ki da jo narekuje Iran, in nekateri “kavč” mediji grejo celo tako daleč, da Iran obtožujejo zavlačevanja.
Zato je potrebno omeniti, da Izrael v Libanonu sistematično podira objekte in ruši cele vasi z oklepljenimi buldožerji, ki so v praksi orožje, kar je blatantna kršitev premirja in na nek način provocirajo da se Hezbolah odzove. Ker treba je vedeti, da vse prebivalstvo v Libanonu ni naklonjeno Hezbolahu. Se pa oni imajo za neko odporniško / osvobodilno organizacijo in je pač za pričakovati, da se bodo ob izraelskih provokacijah odzvali. Tako da bi rekel, da bo moral Trump Bibija glede Libanona konkretno prijeti za jajca. Iran dobro ve kaj se dogaja, samo Izrael hoče zdaj iz tega narediti nek politični spin, ki mu še predsednik zda ne verjame več.
enavlaka ::
Pregovarjaš se z Izrelskim trolom, tratiš svoj čas...
celje ::
enavlaka je izjavil:
po pisanju je po narodnosti žid
T440 ::
Da le na kratko ponovimo, zakaj se apologeti Irana zavzemajo v tej temi:
https://www.dnevnik.si/novice/svet/kaze...
29-letno iransko pevko Parastoo Ahmadi so oblasti zaradi objave posnetka, na katerem poje z razkritimi lasmi, obsodile na kazen 74 udarcev z bičem.
enavlaka ::
Pač ne zna pet pa slab glas ma :D
T440 je izjavil:
Kolega, ponovno se grdo lažete.
Ste pa seveda dobrodošli, da nam razložite, kako smo prebivalcem Irana pomagali s klanjem malih šolark ter uničevanjem infrastrukture? In to ravno v času, ko so bili na tem, da zamenjajo svoj režim?
enavlaka ::
Da le na kratko ponovimo, zakaj se apologeti Izraela zavzemajo v tej temi:
“I was raped twice by female recruits … once by them and once by a dog.”.
A Palestinian detainee recounts repeated abuse he says he endured in Israeli detention.
https://www.facebook.com/aljazeera/vide...
Trump se je odločil, da bo raje kar sam podpisal MOU, in to kar v Versailles-u, da bo simbolika ameriškega poraza še bolj epska.
enavlaka ::
Očitno se je preveč zameril vrhovnim bankirjem
JanBrezov ::
Koliko je resnice v tem?
Did AI Make Us Lose The Iran War
enavlaka ::
Igračke za prelivanje javnega denarja v zasebne žepe delajo v redu
Če misliš, da so vplivale na potek vojne pa niso
Vojna se zmaga na tleh, ne v zraku
asdf_jklc ::
Bolj kot beres, bolj razumes razseznosti epske razseznosti ameriskega poraza v Iranu. Najkrajso v tej zgodbi pa bo potegnila Evropa.
PovemVfaco ::
Prebral na nekm rando kanalu, nism šu preverjat:
I've collected some truly remarkable quotes from Israeli officials:
• “A ceasefire being in effect does not prevent us from continuing operations.”
• “A ceasefire does not mean ceasing fire. It means not escalating the attacks.”
• “If Hezbollah tries to confront Israeli advances in southern Lebanon, we will defend ourselves and retaliate.”
enavlaka ::
asdf_jklc je izjavil:
Azijske države je stolklo najbolj (pomanjkanje plina in derivatov) - sploh tiste, ki so na otokih in si ne morejo privoščit rezerve. Taiwan je pripiral lastno porabo, da so tovarne obratovale.
Evropa je imela težave zaradi povišanja cen, vendar smo dovolj bogati, da si to lahko privoščimo in imamo dovolj rezerv že od prejšnjih ameriških-ruskih rabot, ko so nas na suho.
Amerika je totalno zgubila primat in ugled na savdskem polotoku. Njim se sicer ni zgodilo nič, razen višjih cen na pumpi.
Via Euronews: Iran recloses Strait of Hormuz, citing Israeli strikes on Lebanon
https://www.euronews.com/2026/06/20/ira...
enavlaka ::
Pa smo spet na začetku ;((
Zimonem ::
Misliš priložnost za nove zmage?
  • spremenilo: Zimonem ()
enavlaka ::
To ja :D
Legon je izjavil:
Troll or stupid? Pri Kow. Both.
Legon je izjavil:
CIA je bila jasna, da Iran ni na dosegu jederskega orozja? Mogoce pa zGolj niso tako sposobni, kot ti. Verjetno obratno.
  • spremenilo: tikitoki ()
Za fanatike je znacilo, da ne sprejemate dejstev. V dokumentu lepo pise koliko obogatenega urana ima iran in kam inspektorji niso imeli dostopa. Edini razlog, da bogatis uran do taksne stopnje, pa je zelja imeti jedrsko orozje.
Podzavestno itak razumete, da imam prav, zato takoj neko projeciranje in zmerjanje.
Goran10 ::
Poanta je da je poldi primerjal svoja geopolitična spoznanja z eksaktno znanostjo. To se pravi se njegov proces spoznanja kosa z znanstveno metodo. Kar je seveda smešno ker branje proruskih influencerjev na internetu je daleč od znanstvene metode.
  • spremenilo: Goran10 ()
Legon ::
Torej si spet slaboumni lagal in v dokumentu popolnoma nic ne pise o tem, da je Iran tik pred razvijem jedrskega orozja?
Pomilivanja vredno, ampak hvala da si vsaj priznal kaksen laznivec si.
Pozavestno in zavestni je jasno da pojma nimas kaj govoris in samo slepo ponavljas izraelsko propagando.
Bolj se delas neumnega, bolj prepricljivo lahko zakljucimo, da si propagandist.
Vprašaj se, koliko in na koliko so imeli Iranci obogaten uran, koliko so ga imeli preden je Trump enostransko odstopil od JCPOA in se inspektorji so imeli dostop.
Vse to je bilo dogovorjeno, kontrolirano,.... ampak je tvoj najlubsi politik zminiral.
Za kontra stran , IL režim pa se ne ve niti ne dovolijo kontrole njihovega jedrskega programa, ne ve se koliko jedrskega orozja imajo,....
Ene bi radi tepli, drugim se pa gleda skozi prste, pac hinavsčina in dvojna merila.
Lepo, da se fikus strinja z mano o iranskem jedrskem programu. Res je redko.
