Forum » Operacijski sistemi » New Debian install 2025 december
HotBurek ::
Dobro jutro.
Evo, danes sem dobil "nov" Debian. In so se pojavile 2, 3 novitete.
1. APT sources list
Po novem debian source-i nosi več v /etc/apt/ ampak v /etc/apt/sources.list.d/. Kar je za nas, stare navajene ne-sprememb, en mal moteče.
Poleg tega se uporablja drugi format.
Kako modernizirat je napisal uporanik Denny tule: https://slo-tech.com/forum/t844436/p857...
Jst imam še kar star sources.list v /etc/apt/ in zaenkrat dela.
Tole je config:
2. syslog
Po novem tega fajla ne vidim v /var/log.
Sem pa sedajle preveril, da ko se preko VNC-ja prijavim, se mi kar tam prikazujejo eventi, ki bi načeloma morali it v fajl. Polsedično se ne da prijavit v sistem, ker stalno skačejo eventi v konzolo.
Krneki.
Verjetno je kaj v kontekstu logrotate/rsyslog.
3. interfaces
V /etc/network/ ni fajla interfaces. Čeprav network ima. Krneki.
Let's the hacking begin.
1. APT sources list
Tole je config:
deb http://deb.debian.org/debian trixie main contrib non-free non-free-firmware deb-src http://deb.debian.org/debian trixie main contrib non-free non-free-firmware deb http://deb.debian.org/debian-security/ trixie-security main contrib non-free non-free-firmware deb-src http://deb.debian.org/debian-security/ trixie-security main contrib non-free non-free-firmware deb http://deb.debian.org/debian trixie-updates main contrib non-free non-free-firmware deb-src http://deb.debian.org/debian trixie-updates main contrib non-free non-free-firmware deb http://deb.debian.org/debian trixie-backports main contrib non-free non-free-firmware deb-src http://deb.debian.org/debian trixie-backports main contrib non-free non-free-firmware # 05.07.2023 # The following packages have unmet dependencies: # mariadb-server-core : Depends: liburing1 (>= 0.7) but it is not installable deb http://deb.debian.org/debian bullseye main contrib non-free
2. syslog
Krneki.
3. interfaces
root@debian:/# iptraf-ng
Please resize your window
HotBurek ::
Pod točko dva zgleda, da je rsyslog rešitev za to reč.
HotBurek ::
Pod točko tri mislim, da sem našel: namesto ifupdown je systemd-networkd.
HotBurek ::
Evo, zadeva še ni čist porihtana.
Če naredim reboot, server ne pride online na mrežo. Je treba preko vnc in naredit ifdown eth01 in ifup eth01.
Problem je service systemd-networkd, ker se ob reboot-u še kar zažene.
Druga stvar pa je logging v console. Tam se mi še kar prikazuje vse sorte (večinoma log-i od nftables). Začasno se da izklopit z ukazom dmesg -n 1.
Ampak to ni to. Treba je naredit tako, da ti logi sploh ne grejo v console ampak samo v fajle.
root@debian:/# service systemd-networkd stop Stopping 'systemd-networkd.service', but its triggering units are still active: systemd-networkd.socket
- spremenilo: HotBurek ()
HotBurek ::
Tole me matra:
Kako ta dva service-a spravit iz enabled-runtime na disabled.
systemd-networkd-persistent-storage.service static - systemd-networkd-wait-online.service enabled-runtime enabled systemd-networkd-wait-online@.service disabled enabled systemd-networkd.service enabled-runtime enabled
HotBurek ::
ChatGPT to the rescue.
Zdej pa še, da ne bo log pisal v console.
systemctl mask systemd-networkd.service systemctl mask systemd-networkd-wait-online.service
HotBurek ::
Treba je bilo editirat file: /etc/default/grub
Nastavit: GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Ter pognat: update-grub in reboot
Well done.
Well done.
HotBurek ::
Sem do sedajle razkopaval po sistemu... nek exim4 je predinštaliran, pa cloud-init software.
Na koncu mi ni uspelo najti po dependeci tree-ju, da bi prišel do vira, kdo požene service ob zagonu (enabled-runtime), in sem obstal pri "mask" (service abc disable pač ne reši take situacije).
Naslednjič si bom sam inštaliral sistem iz nule.
Čeprav, glede na to, da še ni nič gor, in da vem network nastaviteve... Maybe.
Grep pogledat, če lahko kako zmountam iso.
Ales78 ::
Ne bi vedel, uporabljam FreeBSD in Fedora, tako, da so mi vse te novitete bolj nekaj kar nočem.
systemd je tako ali tako napačna izbira nečesa kar nihče ne rabi, argument za hitrejši boot je joke. Kolikokrat pa dejansko rebootate mašino?
Ko pa še "glavni" developer pobegne k Microsoftu...
- spremenilo: Ales78 ()
HotBurek ::
Kateri pa so kvalitetni nadomestki za systemd?
Systemd je sedaj industry standard, to da je dev šel k MS je pa povsem irelevantno.
Če se ti ne da prebrati manuala in bi rad ostal v preteklosti, lahko pa poizkusiš srečo z Devuan.
tony1 ::
Ko so se začele te smešnice s systemd-networkd v RHEL7 so zdaj prišle še do Debiana? Je sploh še kaj, česar niso sfukali?
solatko ::
In potem navijate za odprto kodo. Sem mislil, da ste se uporabniki že kaj spremenili v prid pomoči in sodelovanja pri tem pa še vedno vidim samo vzvišenost in svojeglavost.
Delo krepa človeka
Kdo navija - večini se nam gladko jebe, kaj kdo uporablja.
Ter od kje ideja oziroma pričakovanje, da je naš življenski cilj aktivizem odprte kode?
- spremenil: Poldi112 ()
Kateri pa so kvalitetni nadomestki za systemd?Init system vojne si zamudil za več kot 10 let. Če ti je dolgčas, lahko še vedno najdeš kaj na SysV init, OpenRC, Runit ... pick your poison. Tudi DJB mislim da še vedno fura svoj daemontools. Če pa želiš konsistenen in pregleden sistem brez presenečenj, pa vzameš OpenBSD.
HotBurek ::
Evo, zadeva se je nadaljevala.
Naredil sem reinstall in pustil network manager, kot je.
Odstranil sem systemd-resolvd (to mislim, da je DNS server, ker je bil viden v netstat) in dodal file /etc/resolve.conf z DNS serverji.
Kar set tiče pa networka je v tej zgodbi še software, ki sliši na ime netplan.
Service systemd-networkd dobi config file v /run/systemd/netwworkd/10-netplan-eth0.network
Ta file se ob restartu prepiše iz configa /etc/netplan/50-cloud-init.yaml
In v tem fajlu sem odstranil IPv6, ker ne uporabljam.
Potem pa ukaz netplan apply in je to to.
Ja, OpenBSD je verjetno tisto, kar bi prišlo prav. Tak soliden stabilen sistem. Nimam pa znanja, da bi se to šel.
Kaj pa misliš delat z njim? Ker je precej podoben Linux-u.
Stabilna sta pa oba, tako Linux, kot BSD.
HotBurek ::
Vse, kar uporabljam, je:
nginx
uwsgi
mariadb
Ter python interpreter.
Tele tri stvar (bind9, postfix, dovecot) so pa toliko zraven, da jih omenim. Kaj več pa niti ne.
Plus, firewall (nftables), ki ima dokaj simple config (source/destination ip/udp/tcp).
nginx
uwsgi
mariadb
To bi vse moralo laufati tudi na BSD. Drug FW in packet manager, ostalo pa dosti podobno.
LiquidAI ::
Linux je bolša izbira, ker copyleft zagotavlja da bo katerakoli sprememba v kodi kernela in derivatov kernela vedno na voljo javnosti.
BSD kodo pa najrajši uporabljajo firme in korporacije, ki jo prosto spreminjajo, kodo pa ni obvezno da jo objavijo javnosti.
Ales78 ::
Mislim, da si FreeBSD "majčkeno" narobe predstavljaš, licenca ni še niti začetek
https://unixdigest.com/articles/technic...
Ales78 ::
BSD VS Linux... kot da smo leta 1997/98 :lol:
Pa veš, v čem je bil problem takrat? :) (ne, ne veš) Počasi tudi "šalabajzerji" spoznavajo, da linux paradigma "move fast, break things" ni nekaj kar bi si pri OSu želel in je stabilnost lahko mnogo bolj pomembna. Samo za okus, FreeBSD na mojem serverju teče od verzije 8.0 (danes 14.3, latest je 15) in je bil samo upgradan, hardware pa je bil vmes zamenjan 2x. Niti enkrat nisem imel težav, ne z ZFSjem, ne z OSom. Koliko se vas upa to trditi za linux, osebno še za minor release na linuxu vsakič znova trepetam, kaj mi bodo razsuli.
Meni je ZFS na FreeNAS, ki je efektivno FreeBSD, že odletel, in to sredi belega dne, brez kakršnekoli nadgradnje, po letih brezhibnega delovanja. In ko sem pogledal v manual, mi je za tisti error rekel samo - restore from backup. Resda je sicer bil v virtualki (ESXi), a je imel svoj privat (fizični) HBA čez SRV-IO.
Major verzij ne update-am. Ne vidim razloga, da bi jih, itak jih deploya configuration manager, tako da ni nekega dodatnega dela s tem.
Minor verzija mi je pa zgolj enkrat zaribala pri RHEL, medtem ko se z Debianom ne spomnim, da bi imel kadarkoli problem pri nadgradnji.
Ales78 ::
To ti pa težko kaj rečem, v vmjih gre lahko marsikaj narobe. Za scrub verjetno veš, smartd je pa tudi nuja vedno,...
Varnostni popravki? :)
Malo nerodno sem se izrazil. Upgrade-e delam le znotraj minor verzije, se pravi security update-i, ne delam pa dist-upgrade, ker nočem, da mi update-i nameščajo nove featurje, ki še niso bili potestirani z aplikacijami, ki jih uporabljajo.
Scrub in smartd sta privzeto vklopljena v FreeNAS, je pa res, da nisem imel zunanjega monitoringa. Šlo je za domači server, kjer sem se primarno spoznaval z FreeNAS.
tony1 ::
Reklama ni slaba
"Debian GNU/Linux has incorporated systemd yet at the same time the default networking part is Debian specific. Sometimes you have to disable and remove Debian specific things to get systemd specific things to work. All of this is the result of a system that has been put together by many mismatching components from many different projects."
| » | Python - pošlji aplikacijo na serverOddelek: Programiranje | 1982 (1217) | HotBurek |
| » | Postavitev mySQLOddelek: Programiranje | 2886 (2464) | M01O |
| » | Debian in nvidiaOddelek: Operacijski sistemi | 3129 (2854) | Icematxyz |
| » | Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Operacijski sistemi | 128307 (43981) | RedDrake |
| » | APT mi dela problemOddelek: Operacijski sistemi | 1691 (1495) | Bug |
