Evropa je v civilizacijskem zatonu
1 2
3
Ker je lažje za to okriviti ameriško zunanjo politiko kot priznati, da obstajajo države v EU, ki so temu zelo dolgo nasprotovale.
EU cuts back sustainability law opposed by US
The law forces companies to root out and address environmental and social abuses within their supply chains and had become a lightning rod for opposition to the EU's ambitious climate agenda from foreign trade partners, notably oil and gas exporters such as the US and Qatar.
EU lawmakers and diplomats agreed in the early hours of Tuesday morning that only European companies with more than 5,000 employees and €1.5bn in annual turnover worldwide, as well as non-EU companies with over €1.5bn in turnover within the EU, would have to adhere to the law.
Originally the directive stated that EU companies with more than 1,000 employees and over €450mn in annual turnover would have to comply, as well as non-EU companies with more than €450mn of turnover in the EU.
The new agreement also reduced the penalties for non-compliance from up to 5 per cent to up to 3 per cent of global turnover. Further, it abolished the need for companies to draft mandatory climate transition plans that would set out how they planned to decarbonise in line with attempts to limit the global temperature increase to 1.5C as set out in the 2015 Paris Agreement.
The rules will also be delayed by a year, coming into force from July 2029.
Oil and gas majors had lobbied hard against the climate transition plans. In a letter to the European Commission in October, the Qatari and US energy secretaries had argued that the climate transition plans and the extraterritorial jurisdiction of the law threatened the EU's energy security and could "disrupt trade and investments across nearly all the EU's partner economies".
ExxonMobil, the US oil and gas major, had described the legislation as "bone-crushing".
In a statement on Tuesday morning, the company said the EU had managed to "remove some of the most irrational and harmful parts of CS3D but they didn't go nearly far enough. The ability of Brussels to regulate a US company's operations anywhere in the world remains and this is completely unacceptable.
The law has also been heavily contested by right-wing lawmakers within the bloc, who see it as emblematic of the EU's administratively burdensome and overly ambitious climate laws.
Jörgen Warborn, the conservative lawmaker who led negotiations for the parliament, described the agreement as "delivering historic cost reductions for businesses".
EU countries and the European parliament also agreed to reduce the number of companies that must comply with the EU's corporate sustainability reporting rules, which came into force in 2024, and exempted financial holding companies that hold stakes in other financial entities from the scope.
SuperJet je izjavil:
Evropa nima toliko prostega prostora in ljudi kot države v vzponu, za širjenje. Dosegli smo nek nivo, za katerega je pomembno da ga vzdržujemo, saj neskončna rast nekako ni realna.
Zadel si bistvo. Evropejci so postali popolnoma brez vsake ambicije in dejansko verjamejo kar si napisal zgoraj. Zato smo tudi v zatonu. Vsaka civilizacija, ki verjame da je prihodnost boljsa, nikoli ne bi pristala na taksno razmisljanje.
V EU se nekaj premika tudi na "bolje". Npr. odloki o vozilih z notranjim zgorevanjem. Zeleni pa v jok in na drevo.
Sedaj bo se moralo premakniti samo še to, da države članice same urejajo imigracijsko politiko in EU bo rešena.
Migrantsko politiko so sprejele posamezna vlade clanic in ne EU komisija.
So se sicer poenotile, ker pac ce Nemcija sprejme migranta lahko da potem posredno pride v Slovenijo in obratno, ker imamo pac prost pretok ljudi.. Tak da edina resitev je zabremzati migrante na EU nivoju, nic ti ne bo pomagalo ce jih na Slo nivoju.
Saj neki se premika je govora o tem da se azila vec ne de ce prides iz varne dezave, kar naceloma pomeni vsi migranti. Sam treba se zacet vracat, to ke veliki blocker trenutno. Ze ce malo vracas se vsaj pretok novih zmanjsa.
EU komisija razglablja o 20000 EUR kazni na migranta, ki ga država noče sprejeti...
Eh, kmalu bo tako, da bo država članica šengena plačala 20000€ na migranta, ki se bo izmuznil.
Saj so volitve v Evropski parlament vsake toliko, sedaj že enooki vidijo problem, nekdo mora razložiti samo še slepim.
Temu smeti bodo dodatno obdavčene?:)
  • spremenil: endelin ()
Nisem šel v detajle, zakaj se Italija boji, da bodo bankriji pobrali njihovo zlato.
"Italy cannot run the risk of private investors claiming rights over the Italian gold reserves," Meloni's party said in an internal document. It insisted that gold reserves belong to "the Italian people" who have accumulated the precious metal over the decades.
ECB jih je dvakrat opomnila, da še malo razmislijo.
Trias ::
Kdor je volil Ursulo naj dvigne roko
  • spremenilo: Trias ()
Dvignejo jo lahko le tisti, ki jo ne bi.
Kakih 500 milijonov je takih.
Ti ze ves. Ursula se zdi precej bolj sposobna kot pijanec Juncker ali prefarbani marksist Barroso. Ampak ja, volitev ni.
mr_chai ::
Ja tok sposobna, da so jo v Bruselj nagnal iz lastne države in to zarad korupcije.
Najhujš so taki ex zdravniki, ki dobijo apetit za politiko.
Evropa je ena umetna tvorba, najbolš da čimprej razpademo in se posebi meddržavno dogovarjamo kako bomo sodelovali.
Vse, kar presega rodovno-plemenske okvire, je umetna tvorba. Samo res, ne moreš z EU upravljati tako, da zbujaš nezadovoljstvo pri precej "slabovidnih", da bi EU kar ukinili. Korak nazaj, potem dva naprej itd.
"Slabovidne" omenjam zato, ker jim očitno ni jasna geopolitična situacija in haranje po manjših državah.
Eni pa bi tako, da bi še klirinško menjavo uvedli, če bi Euro poginil.
Ursula sam predlaga pa koordonira, to je tajnica.
Tecimo to zamrznitev RU sredstev za nedolocen cas so izglasovali na Svetu EU kjer so vlade posameznih drzav ne pa EU poslanci.
Skratka izvoljene vlade vseh drzav razen dveh so bile za.
  • spremenil: Lonsarg ()
Lonsarg je izjavil:
Laž, uporabili so izredno sredstvo in preglasovanje, namesto soglasja, kar je bilo v praksi do sedaj.
Namen tudi šteje.
Moj point ni bil kak tip glasovanja je bil, moj point je bil samo da ne glasuje EU komisija ali EU predsednica, ampak vlade posameznih drzav za vecino pomembnih zadev.
Veto bi blo pa itak za ukinit ce hoce EU kdaj postati mocna kot ZDA. Ce se bomo jajcali vsak posebaj pac ne bomo imeli geopoliticne moci. To da Zelenski posebaj klice Macrona in Mertza namesto EU pogajalce pac pomeni da EU nima moci. In to pomeni da smo vsi Evropejci bolj podvrzeni vplivom zunanjih sil ce te moci nimamo.
Unilseptij ::
Nočemo biti močni kot ZDA, to je z napadanjem in ustrahovanjem drugih, razvejanim sistemom vojaških baz po vsem svetu, izvažanjem orožja in "demokracije" v države, kjer potekajo notranji in tudi zunanji spori, podpiranjem genocida, itd... Če res hočemo postati taki, potem je bolje, da gre v EU v franže, ker svet res ne rabi še enega takega bullyja kot so ZDA.
matobeli ::
Sej mamo že tri take bullije, in se res ne obnese najbolje.
Sploh pa je v vseh treh življenje veliko lepše /s
Evropa nažalost rabi zeleni prehod, oziroma prehod na energijo brez nafte, šele ko vsaj v osnovi ne bomo odvisni od tujih energentov bomo lahko koga odjebal.
SuperJet ::
Vsaka civilizacija do sedaj je še propadla. Ni važno kako napredna. Fast burn, fast death.
Poznavanje zgodovine in fizike, ti pove da nič ni brezmejno. Samo vesolje in človeška neumnost...
Tako da ja, sem mnenja da počasnejši tempo in tek na dolge proge veliko bolj smiseln.
Biti prvi na cilju, pri čimer ti nima več kdo podeliti medalje je neumno.
Če si misliš da smo v Evropi tako v zatonu, se lahko vedno odseliš na lepše. Kolikor vem boš plaval proti toku, ker se večina priseljuje nazaj v Evropo zaradi slabših stanj v tujini.
Unilseptij ::
matobeli je izjavil:
edina kratkoročno uresničljiva strategija za to je par let nazaj vključevala plin in jedrsko energijo, nedavno je tudi sodišče EU potrdilo ta akt:
https://www.reuters.com/sustainability/...
Problem je samo, da plina zdaj nimamo, jedrske energije pa zaradi Nemcev tudi ne. Tako, da ostanejo sanje o soncu in vetru, elektrika pa pač bo ali pa ne, kakor bo že kazalo vreme.
https://www.youtube.com/shorts/qaSqb1ck...
Franz21 ::
Scaramouche3 ::
redtech je izjavil:
Kje pa je kolonizacija Evrope s strani muslimanov? Je vse samo white guilt?
matobeli ::
Ja za otomansko cesarstvo in mavre moraš pa kam drugam pogledat ane.
Ampak dvomim da doseže 1% tistega kar se je v evropo zvlačil iz evropskih kolonij.
Scaramouche3 ::
To je res, samo Evropa ni homogen sistem ali država, tako da se ne more govoriti o evropskem kolonializmu, ampak o posameznih državah.
Slovenija nima moralno ali kapitalno kaj plačevati za grozote držav,ki so določene celo nas lastile..
matobeli ::
Kaj pa slovenija tako zelo moralno ali kapitalno plačuje?
Poceni delavce smo si sami navozil, pol so pa kle ostal. Pa ni to od včeraj.
Aja, jasno, tudi v velikih imperijih kot so bili britanci so imeli bogastvo zgolj 0.001% ostali so bili v buli.
In ker nočmo met več takega "suženjstva" kot so ga nad nami izvajali vladajoči v preteklosti smo nekak rekli da tud mi ne bomo več uvažal čistih sužnjev, čeprav se vsake toliko še najde novica ob kateri si kaj dosti drugega ne moreš mislit.
  • spremenilo: matobeli ()
Scaramouche3 ::
Če ustaviš migracije, plačaš Bruslju 1 milijon € dnevno, vprašaj Madžare!
In to niso dobre migracije ampak nasilne,ki ti jih EU predpiše, ko pride nov val ekonomskih migrantov!
matobeli ::
Mi imamo vsaj zastonj vrtce ker tega ne plačujemo.
Smo pač ekonomsko odvisni od DE in moramo spustit skoz. Jebiga, tud mi smo črnci.
KG-348 ::
Brez migrantov = degrowth. Ne vem kdo je to že predlagal, neki naravovarstveniki pa se je sploh konzervativcem naredil skoraj kratek stik v glavi. Odločite se kaj bi radi
gen Maister ::
Odločijo naj se kaj bi radi!?? :))
Mislim, da jim ni razumljiva ta matematična enačba!!?
Aja!?? UI jih bo rešila? :))
In humanoidni roboti! :D
gen Maister ::
Seveda!! Bog in suprejet bo obvaroval Evropo! ;) Okrog nje bosta postavila nevidno in neprebojno ograjo, kamor zadeve iz zunanjega sveta ne bodo pljusknile!! :D
Mi smo na varnem!! 8-) Zvečer kar mirno zaspite!! ;)
1 2
3
EU volitve 2024 (strani: 1 2 3 4 … 23 24 25 26 )
Oddelek: Problemi človeštva
1280170833 (143452) arnecan1
Imigrantski val 2.0 (strani: 1 2 3 4 … 44 45 46 47 )
2332444735 (342939) Slopek
Imperij vrača udarec (strani: 1 2 3 4 5 )
21156426 (52054) vostok_1
