izenačevalnik zvoka
izenačevalnik zvoka
togo ::
Naredil bi si glasbo na USB in bi rad, da je vsa glasba enake jakosti.
Ali kdo pozna kak program, ki ti to naredi?
Nadleženo je ves čas spreminjat jakost glasbe.
Hvala za pomoč
Ghost7 ::
Hitro vprašanje chatgptju. Izbral sem Linux,ker je večja verjetnost, da dobiš orodje brezplačno + sam ga uporabljam.
1 opcija je zapis v metadata fajla, če ga tvoj predvajalnik zna brati.
2. opcija je seveda poseg v mp3, kar on poimenjuje destruktiven poseg, ker lahko boljšemu komadu zniža kvaliteto.
To make all your MP3s sound equally loud, you'll need an application that can perform audio normalization. This process adjusts the volume of audio files so they all reach a consistent perceived loudness, rather than strictly equalizing bitrate. While bitrate affects quality, it doesn't directly control loudness.
Here are a few excellent command-line and GUI options commonly used on Linux:
1. ReplayGain (Command Line: mp3gain)
ReplayGain is a standard that analyzes the perceived loudness of audio files and then stores this information as metadata in the files themselves. Compatible players can then use this metadata to adjust playback volume on the fly without altering the audio data directly. This is often the preferred method as it's non-destructive.
mp3gain: This command-line tool is specifically designed for MP3s and implements the ReplayGain standard. It can analyze and apply ReplayGain tags.
Installation (example for Debian/Ubuntu-based systems):
Bash
sudo apt update
sudo apt install mp3gain
Usage Example (to analyze and apply gain to all MP3s in a directory):
Bash
mp3gain -r *.mp3
The -r flag applies track gain (adjusting each track individually). You can also use -a for album gain (adjusting all tracks in an "album" together based on the average loudness).
2. SoX (Sound eXchange - Command Line)
SoX is a highly versatile command-line utility for audio manipulation. While more complex, it offers powerful normalization capabilities by directly modifying the audio data. This is a destructive process, so it's a good idea to back up your files first.
Bash
sudo apt update
sudo apt install sox libsox-fmt-mp3
Usage Example (to normalize an MP3 to a target loudness):
Bash
sox input.mp3 output.mp3 norm
This command applies a general normalization. For more precise control over the target loudness (e.g., to a specific decibel level like -3dBFS peak):
Bash
sox input.mp3 output.mp3 gain -n -3
The -n flag normalizes to 0 dBFS peak before applying the gain, ensuring consistency.
3. Audacity (GUI Application)
Audacity is a free, open-source, and powerful graphical audio editor available for Linux. It's excellent for visual editing and also includes a robust Normalize effect. This method is interactive and allows you to preview changes.
Bash
sudo apt update
sudo apt install audacity
How to use the Normalize effect:
Open Audacity.
Go to File > Import > Audio... and select your MP3s. You can import multiple files at once.
Select all tracks (Ctrl+A or Cmd+A).
Go to Effect > Normalize...
In the Normalize dialog box, you can set options like "Remove DC offset" and "Normalize maximum amplitude to" (e.g., -1.0 dB).
Click OK. Audacity will process all selected tracks.
Export your normalized files: File > Export > Export Multiple... to export them back to MP3 (or another format).
Which one should you choose?
For simple, non-destructive volume adjustment based on perceived loudness, mp3gain (ReplayGain) is usually the best and easiest option for MP3s. It doesn't re-encode the audio, preserving original quality.
For more advanced, destructive normalization and general audio processing, SoX is incredibly powerful but has a steeper learning curve.
For a visual, interactive, and comprehensive audio editing experience, Audacity is your go-to. It's great if you prefer a GUI and might want to do other edits.
Remember that normalizing audio files by directly modifying them (like with SoX or Audacity's export) will re-encode the MP3s. If your original MP3s are already high quality, this re-encoding might introduce a slight generational loss in quality, though for most listeners, it will be imperceptible. ReplayGain, on the other hand, avoids this by only adding metadata.
  • spremenilo: Ghost7 ()
floyd1 ::
Če je v MP3 formatu potem "MP3 gain". Ne naredi čudeža, je pa zagotovo veliko boljše pol.
Pa naslov te teme bi moral biti bolj v stilu "SW za izenačevanje glasnosti pesmi" ali kaj podobnega. Ker izenačevalnik je (malo neposrečeno) naš prevod za EQ.
  • spremenil: floyd1 ()
Ales ::
Ghost7 je izjavil:
Hitro vprašanje chatgptju...
Ker so zgleda vsi ostali ljudje tolikšni idioti, da ne znajo sami vprašati nek LLM, moraš ti. Si to misliš, ko lepiš ta drek nakoli?
Če že, si še vzemi toliko časa, da strneš ta 100x predolg tekst v tisti relevanten odstavek ali dva. Boš vmes še ugotovil, ali je čisto falil ali ne.
  • spremenil: Ales ()
Ijus ::
togo, si ti že uspel kaj zrihtat?
daj poglej kako se to dela s foobar2000 playerjem.
FB2K player je freeware. ima not podporo za replaygain.
gledat moraš za replaygain.
ta player je widely podprt pa respectan če tko rečem.
nimaš kaj falit.
ti moraš vnest info v vsak komad tko kot ID tage se vnaša za replaygain.
pol naprej pa ne vem.
če boš usb ključek uporabljal v avtu pol mogoče je to to če ti avto radio podpira replaygain informacije.
isto velja za prenosne party boxe.
če pa ti ne podpirajo te replaygain informacije ... pol boš moral pa narest export komadov v nov folder ... torej preko FB2K playerja ... kjer bodo novi komadi fizično, če tko rečem, vsi enako na glas.
za ta slednji scenarij pa poglej kak tutorial. ni pa to nek kunšt. nisem to sicer še delal vem pa da bi to moralo it b.p.
PS/EDIT: da bi pa obstajal kak namenski programček izključno samo za to pa ne vem. to pa naj drugi povedo.
  • spremenil: Ijus ()
togo ::
najprej hvala za predloge
Linux pri meni ne gre - niti nimam nikjer instaliranega žal sem še vedno na windovsih
foobar2000 sicer predvaja a ne znam naštimat - sem probaval pa ni ne gre
mp3gain mi je všeč tudi hitro dela tako da bo kar ta obveljal
še enkrat hvala za vaš trud
Audio glasnost različnih pesmi
81605 (1128) gumby
Izravnava nivoja glasnosti
Oddelek: Programska oprema
71493 (1216) matichy
mp3-povečava zvoka
102154 (1975) ST-777
[Hi-Fi] Glasnost izhoda na zvočni kartici
Oddelek: Zvok in slika
92076 (1993) mte
Winamp 5.06
353195 (3195) tha_man
