gonilnik za kontroler
polozweii ::
https://retrounit.com.au/products/adapt...
Se da še kje dobit gonilnik za kontroler na linku?
Zimonem ::
Za katero reč pa bi pognjača?
polozweii ::
HDD in CD-pekač
Han ::
Sem naložil iz svojega arhiva - KLIK za prenos, poteče čez 7 dni.
  • spremenil: Han ()
polozweii ::
Han je izjavil:
prazno je
Han ::
polozweii ::
https://ibb.co/39W9jkbc
Po dobljenih informacijah bi moral za kontroler uporabiti 2902 gonilnik označen z rdečim kvadratkom. Ti si poslal 2906.
Han ::
Najprej testiraj in potem jokaj...
polozweii ::
Han je izjavil:
V kišto sem namestil SCSI disk in kontroler. Med inštalacijo Win7 vpraša za gonilnik. Ta ki si ga poslal ni pravi.
To mora delat na vseh linuxih iz prejšnjega desetletja.
Vanadium ::
kixs ::
Kaj imas to zaeno retro zadevo? Ce nima plata, pa raje kupi SATA kontroler in vse vrzi na njega - dobis HDD in CD-ROM za dzabe.
polozweii ::
Vanadium je izjavil:
To si kaj pogledal?
https://www.savagetaylor.com/2018/02/11...
Sem poskusil ob inštalaciji Win10 in ga ni ga sprejelo.
...čeprav SCSI naj bi delal do Win7 zato poskušam predvsem z Win7.
Vanadium ::
Preberi še tole če že nisi:
https://www.sevenforums.com/drivers/105...
polozweii ::
Ne gre. Šlo bo v škatlo in adijo.
Han ::
Jaz imam Adaptec AHA-2940AU, ki deluje s šoferji, katere sem delil pred dvema mesecema. V txt datoteki so navodila, kako pripraviti ini datoteko, da bo Windows sprejel in namestil gonilnik za kartico...
This has been tested only with the Adaptec 2906. However, you may be able to adjust the driver to support other 78XX based devices.
Here is how you may get other Adaptec devices to work with this driver since I found that there is a driver for the Adaptec 7870 chip included in Vista 64, which is done through emulation. The driver name is "djsvs.sys"
1. Search Vista for both "djsvs.ini" and djsvs.sys" and copy them to a folder called "Adaptec 2906"
2. Under Device Manager, Look at the SCSI Controller that is missing the drivers. Right click on it and go to Properties, then click on the "Details" tab and finally selected the "Hardware ID" property.
From there, find the appropriate ID for your Adaptec card (in my case):
PCI\VEN_9004&DEV_5078&SUBSYS_78509004
3. Open the file "djsvs.ini" with notepad.exe and locate the entry:
[ADAPTEC.NTamd64]
%PCI\VEN_9004&DEV_7078&SUBSYS_70781414.DeviceDesc% = aic78xx_Inst, PCI\VEN_9004&DEV_7078&SUBSYS_70781414
Copy and paste the line and then change the Device ID for your device as shown below.
[ADAPTEC.NTamd64]
%PCI\VEN_9004&DEV_5078&SUBSYS_78509004.DeviceDesc% = aic78xx_Inst, PCI\VEN_9004&DEV_5078&SUBSYS_78509004
Do the same at the end of the file:
FLOPPY_DESCRIPTION="ADAPTEC SCSI Adapters - Microsoft Disk"
PCI\VEN_9004&DEV_7078&SUBSYS_70781414.DeviceDesc = "Adaptec AIC-7870 PCI SCSI Controller (Emulated)"
PCI\VEN_9004&DEV_5078&SUBSYS_78509004.DeviceDesc = "Adaptec AIC-7850 PCI SCSI Controller (Emulated)"
Save the file and close
4. Now from the Device Manager, right click on the SCSI controller that is missing the drivers and hit update driver. Select the lower option to locate the driver manually. Browse to the folder "Adaptec 2906" or whicever name you chose and select the driver from there. You will get a screen telling you that Windows cannot verify the publisher of the driver. Just keep the appropriate button to continue and install.
5. Reboot your computer to make sure it will boot up correctly. If it fails to boot and you have driver issues, you will need to select the option to boot "Last Known Good configuration".
I take no responsibility for anything that may happen to your computer by using this method. Enjoy it if it works, go buy a new supported card if it does not.
Če zgoraj opisan postopek ne deluje, lahko poskusiš še tole:
In device manager select the SCSI adapter, click "Update driver", "Browse my computer for driver software", "let me pick from a list of device drivers on my computer", uncheck "show compatible hardware", and select "Adaptec" as Manufacturer and "Adaptec AIC-7870 PCI SCSI Controller (emulated)"
  • spremenil: Han ()
Han ::
Na povezavi je gonilnik, pripravljen za 2902i kartico.
https://limewire.com/d/XXUUt#zmsfgtQTlQ
Slipstream Sata gonilnikov v XP inštalacijski CD
Oddelek: Operacijski sistemi
121917 (1728) -Jani-
kje dobit ata na s-ata konverter
191608 (1247) -Jani-
Linux na SCSI diskih
121940 (1716) civic_
Lag pri filmčkih v špilih
Oddelek: Igre
103129 (2991) Matev
gentoo,grub čaka minuto ob zagonu
51394 (1327) potepuh
