Forum » Operacijski sistemi » (x) ubuntu internet nehal delat
Blinder ::
Pozdravljeni,
Na svojem racunalniku imam dual boot, xubuntu(ubuntu z xfce..) in win xp. Do uceraj je vse delalo normalno, zdaj pa mi na xubuntu net ne dela več
Na windowsih pa dela normalno.
Internet imam amis adsl brez routerja. Mislim da dela brez da je treba naštimat dns-je.
Ukaz lspci -v je odgovoril tole:
00:07.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 10) (prog-if 8a [Master SecP PriP])
Subsystem: VIA Technologies, Inc. VT82C586/B/VT82C686/A/B/VT8233/A/C/VT8235 PIPC Bus Master IDE
Flags: bus master, medium devsel, latency 32
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [size=1]
I/O ports at d000 [size=16]
Capabilities: < access denied>
00:07.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 10) (prog-if 00 [UHCI])
Subsystem: First International Computer, Inc. VA-502 Mainboard
Flags: bus master, medium devsel, latency 32, IRQ 5
I/O ports at d400 [size=32]
00:07.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 10) (prog-if 00 [UHCI])
I/O ports at d800 [size=32]
00:07.4 Bridge: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI] (rev 30)
Subsystem: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI]
Flags: medium devsel, IRQ 9
00:07.5 Multimedia audio controller: VIA Technologies, Inc. VT82C686 AC97 Audio Controller (rev 20)
Subsystem: Sigmatel Inc Onboard Audio
Flags: medium devsel, IRQ 11
I/O ports at dc00 [size=256]
I/O ports at e000 [size=4]
I/O ports at e400 [size=4]
00:13.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RT8139
Flags: bus master, medium devsel, latency 32, IRQ 11
I/O ports at e800 [size=256]
Memory at d9000000 (32-bit, non-prefetchable) [size=256]
[virtual] Expansion ROM at 20000000 [disabled] [size=64K]
01:00.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15) (prog-if 00 [VGA])
Subsystem: PROLINK Microsystems Corp Unknown device 1061
Flags: bus master, 66MHz, medium devsel, latency 248, IRQ 10
Memory at d6000000 (32-bit, non-prefetchable) [size=16M]
Memory at d4000000 (32-bit, prefetchable) [size=32M]
[virtual] Expansion ROM at d7000000 [disabled] [size=64K]
Vnesite tukaj
Kaj bi blo narobe? Na win dela normalno..
Vnesite tukaj
Blinder ::
Reinstall pa bo
G-man ::
Bah, reinstall???
Povej, če ti lučke na omrežni kartici svetijo in kaj ti izpiše ukaz "ifconfig"?
MasterMind ::
ifconfig <-- Če tukaj najde nekaj v stilu eth# (kjer # je cifra) in ima veljaven IP naslov, poskusi pingat 193.2.1.66 (Arnes IP)
Če zgornje velja, poglej če je kaj napisano v /etc/resolv.conf. Če ni nič, probi noter napisati "nameserver 193.2.1.66" (Arnes DNS). ("echo nameserver 193.2.1.66 > /etc/resolv.conf" kot root napiš, da ti ne bo potrebno odpirati datoteke v tekstovnih urejevalnikih itd.)
V primeru, da eth# nima veljavnega IP-ja (ti ne pinga tisti IP, in ne routerja), pa poskusi ročno zagnat dhcp odjemalec (točno katerega uporabla tvoja distribucija, ne vem).
Gentoo, KDE uporabnik.
Blinder ::
Hvala za odgovore, sicer tokrat mi niso pomagali, bom pa vejretno še kdaj mel probleme z netom na linuxu
No net mi je po nekaj dneh sam od sebe spet zacel delat. Na win seveda je cel čas delal normalno
jebeni linux
Dri3r ::
jebeni linux
Če ne znaš naštimat neta še ne pomen d je z Linuxom nek narobe
včasih pomaga že /etc/init.d/network restart
dri3r
Blinder ::
Oh ja seveda je nekaj z njim narobe ce se sam od sebe odloci, da ne bo vec delal net, pol pa sam od sebe odloci, da ga bo spet omogocil. linux jebeni²
SkIDiver ::
No jaz pa imam ubuntu. Mam pa mal drugačno težavo z mrežo. Ker moram zaradi kabla do routerja uporabljat hitrost 10Mbit/s namesto 100Mbit/s moram pri vsakem zagonu ubuntuja v konzoli pognat ukaz sudo ethtool -s eth0 speed 10 duplex full autoneg off in nato dhclient (tole vrjetno nardi nek "refresh" adapterja).
Vse tole početje pa zaradi tega, ker si ubuntu ne zapomne novo nastavljene hitrosti. Lahko nekdo svetuje kako dopovedat, da je hitrost 10Mbit/s in ne 100Mbit/s?
Dri3r ::
Preberi si "man mii-tool". Potem pa uporabi ukaz "sudo mii-tool -F 10baseT-FD" in "sudo /etc/init.d/network restart" oz "sudo /etc/init.d/networking restart, če uporabljaš Hardy Heron.
dri3r
motorc ::
Če imaš realtekovo kartico je lahko problem podoben kot je bil pri meni.
Imel sem nameščen winxp, in sem v dualboot instaliral ubuntu, kjer internet ni delal (lučka na net kartici sploh ni gorela, čeprav mi je kartico ubuntu zaznal). No, po dolgotrajnem googlanju sem ugotovil, da je rešitev v tem, da pod windowsi v device managerju pod lastnostmi mrežne kartice enablaš "wake on lan after shutdown" oz. neki podobnega (ne spomnem se točno).
| » | [linux] branje registrov na pci karticiOddelek: Operacijski sistemi | 1970 (1587) | AndrejO |
| » | stari prdec in graficne karticeOddelek: Kaj kupiti | 3160 (2326) | GenZNPC |
| » | [Audacity] Težave z zajemanjem zvokaOddelek: Programska oprema | 2133 (1837) | CCfly |
| » | mrežna karticaOddelek: Omrežja in internet | 1869 (1694) | ta_pridna |
| » | Gentoo setup problemOddelek: Operacijski sistemi | 2198 (2022) | G2 |
