Kako preverit katere naprave so trenutno povezane v WLAN omrežje?
sejalecx ::
Zelo osnovno vprašanje, kje na strani Telekomovega modema/routerja G68_10 se da videt, katere naprave so trenutno povezane v WLAN omrežje?
DHCP Leases -- zlista vse naprave, ni omejen na trenutno povezane
Device info -- Network info poda info o Wifi clientih, ki pa ni aktualen.
Wireless -- radar vidi omrežja, ne pa clientov
Wireless -- radar -- metrics in chanell statistics oba kažeta tudi cliente, ki niso v tem trenutku povezani
Mene zanimajo samo aktualni clienti, je edini način reboot routerja?
Edit: našel Station info pri posameznem kanalu.
  • spremenil: sejalecx ()
mihagr ::
za windowse že enih 20 let obstaja aplikacija od "NirSoft-a".
Windows users can download a free program called Wireless Network Watcher. Scroll down to the Feedback section, then click Download Wireless Network Watcher (In Zip file) to install the program. It will provide a list of every device currently connected to the network, so you can identify the ones that belong to you.
https://www.nirsoft.net/utils/wireless_...
malo bolj podrobna navodila so tudi tu: https://www.pcmag.com/how-to/see-whos-o...
To use Wireless Network Watcher, just launch the program to immediately begin scanning. This will take a minute or two--you'll know it's working if the bottom-left corner reads "Scanning..." Once it's done, that message will disappear, and a full list of connected devices will be presented.
  • spremenilo: mihagr ()
tp-link TL-WA730RE kot Wireless Range Extender
Oddelek: Omrežja in internet
315999 (4680) Mikec17
SecureW2; Žična in brezžična povezava na istem laptopu (strani: 1 2 )
5710104 (9450) ArchNem
Diagnostično orodje za WD
Oddelek: Programska oprema
145049 (4909) clovk
netgear WGR614 kot AP na T-2 ?
202693 (2494) trnvpeti
Belikn Wireless G Router
155644 (5484) MitkoVIP
