pygame problem 2
pygame problem 2
dejco_h ::
dober dan spet jaz.
Skratka delam enako igrico kot pred parimi tedni in sem naletel na problem...in sicer problem je ta da ko collidam playera in fllor in hočem pritisnit tipko space(za skok mi player kar izgine) in tudi ni picture perfect collison saj player pristane rahlo pod florom in ne čisto na njem...mi lahko kdo pomaga razrešit nastal problem?? hvala vsem za odgovore ter sugestije
import pygame
import random
import math
import os
from os import listdir
from os.path import isfile,join
pygame.init()
pygame.display.set_caption("platformer game")
WIDTH,HEIGTH=1000,800
win=pygame.display.set_mode((WIDTH,HEIGTH))
FPS=60
Player_Vel=3
def flip(sprites):
    return [pygame.transform.flip(sprite,True,False)for sprite in sprites]
def load_sprite_sheet(dir1,dir2,width,heigth,direction=False):
    path=join("Assets",dir1,dir2)
    images=[f for f in listdir(path) if isfile(join(path,f))]
    all_sprites={}
    for image in images:
        sprite_sheet=pygame.image.load(join(path,image)).convert_alpha()
        sprites=[]
        for i in range(sprite_sheet.get_width()//width):
            surface=pygame.Surface((width,heigth),pygame.SRCALPHA,32)
            rect=pygame.Rect(i*width,0,width,heigth)
            surface.blit(sprite_sheet,(0,0),rect)
            sprites.append(pygame.transform.scale2x(surface))
            if direction:
                all_sprites[image.replace(".png","")+"_right"]=sprites
                all_sprites[image.replace(".png", "") + "_left"] = flip(sprites)
            else:
                all_sprites[image.replace(".png","")]=sprites
    return all_sprites
def load_block(size):
    path=join("Assets","Terrain","terrain.png")
    image=pygame.image.load(path).convert_alpha()
    surface=pygame.Surface((size,size),pygame.SRCALPHA,32)
    rect=pygame.Rect(96,0,size,size)
    surface.blit(image,(0,0),rect)
    return pygame.transform.scale2x(surface)
class Object(pygame.sprite.Sprite):
    def __init__(self,x,y,width,heigth,name=None):
        super().__init__()
        self.rect=pygame.Rect(x,y,width,heigth)
        self.image=pygame.Surface((width,heigth),pygame.SRCALPHA)
        self.width=width
        self.heigth=heigth
        self.name=name
    def draw(self,win):
        win.blit(self.image,(self.rect.x,self.rect.y))
class Block(Object):
    def __init__(self,x,y,size):
        super().__init__(x,y,size,size)
        block=load_block(size)
        self.image.blit(block,(0,0))
        self.mask=pygame.mask.from_surface(self.image)
def get_background(name):
    image=pygame.image.load(join("Assets","Background",name))
    _,_,width,height=image.get_rect()
    tiles=[]
    for i in range(WIDTH//width+1):
        for j in range(HEIGTH//height+1):
            pos=(i*width,j*height)
            tiles.append(pos)
    return tiles,image
def draw(win,backGround,backg,player,objects):
    for bckg in backGround:
        win.blit(backg,bckg)
    for obj in objects:
        obj.draw(win)
    player.draw(win)
    pygame.display.update()
class Player(pygame.sprite.Sprite):
    GRAVITY=1
    COLOR = 255, 0, 255
    DELAY=3
    SPRITES=load_sprite_sheet("MainCharacters","MaskDude",32,32,True)
    def __init__(self,x,y,width,heigth):
        super().__init__()
        self.x_vel=0
        self.y_vel=0
        self.mask=None
        self.direction='left'
        self.animation_count=0
        self.fall_count=0
        self.jump_count=0
    def jump(self):
        self.y_vel=-self.GRAVITY*6
        self.jump_count+=1
        if self.jump_count==1:
            self.fall_count=0
    def move(self,dx,dy):
        self.rect.x+=dx
        self.rect.y+=dy
    def move_left(self,Vel):
        self.x_vel-=Vel
        if self.direction!='left':
    def move_right(self,VEL):
        self.x_vel+=VEL
        if self.direction!='right':
            self.direction='right'
    def update_sprite(self):
        sprite_sheet = "idle"
        if self.y_vel < 0:
            if self.jump_count == 1:
                sprite_sheet = "jump"
            elif self.jump_count == 2:
                sprite_sheet = "double_jump"
        elif self.y_vel > self.GRAVITY * 2:
            sprite_sheet = "fall"
        elif self.x_vel != 0:
            sprite_sheet = "run"
        if self.x_vel != 0:
        sprite_sheet_name = sprite_sheet + "_" + self.direction
        sprites = self.SPRITES[sprite_sheet_name]
        sprite_index = (self.animation_count // self.DELAY) % len(sprites)
        self.sprite = sprites[sprite_index]
        self.animation_count += 1
        self.update()
    def update(self):
        rect=self.sprite.get_rect(topleft=(self.rect.x,self.rect.y))
        self.mask=pygame.mask.from_surface(self.sprite)
    def loop(self,FPS):
        self.y_vel+=min(1,(self.fall_count/FPS)*self.GRAVITY)
        self.move(self.x_vel,self.y_vel)
        self.fall_count+=1
        self.update_sprite()
    def landed(self):
        self.fall_count=0
        self.y_vel=0
        self.jump_count=0
    def hit_head(self):
        self.fall_count=0
        self.y_vel*=-1
    def draw(self,win):
        win.blit(self.sprite,(self.rect.x,self.rect.y))
def handle_move(player,object):
    player.x_vel=0
    keys=pygame.key.get_pressed()
    if keys[pygame.K_LEFT]:
        player.move_left(Player_Vel)
    if keys[pygame.K_RIGHT]:
        player.move_right(Player_Vel)
    handle_vertical_collison(player,object,player.y_vel)
def handle_vertical_collison(player,object,dy):
    collided_objects=[]
    for obj in object:
        if pygame.sprite.collide_mask(player,obj):
            if dy>0:
                player.rect.bottom=obj.rect.top
                player.landed()
            elif dy<0:
                player.rect.top=obj.rect.bottom
                player.hit_head()
            collided_objects.append(obj)
    return collided_objects
def main():
    run = True
    clock = pygame.time.Clock()
    background,backg=get_background("Purple.png")
    player=Player(100,100,50,50)
    block_size=96
    floor = [Block(i * block_size, HEIGTH - block_size, block_size) for i in
             range(-WIDTH // block_size, (WIDTH * 2) // block_size)]
    while run:
        clock.tick(FPS)
        for event in pygame.event.get():
            if event.type==pygame.QUIT:
                run=False
                break
            if event.type==pygame.KEYDOWN:
                if event.key==pygame.K_SPACE and player.jump_count<2:
                    player.jump()
        player.loop(FPS)
        handle_move(player,floor)
        draw(win,background,backg,player,floor)
if __name__ == '__main__':
    main()
Return ne deluje[python]
Oddelek: Programiranje
81402 (1266) Jonatan
[Python3] Izvajanje ukazov po določenem času
211903 (1513) noraguta
Predstavitev dvojiškega drevesa z seznamom
142594 (2194) ktka
[Python]Naloga z razredi in dedovanjem
101500 (1252) ktka
python -slovar
223728 (2707) Valex86
