Forum » Konzole » Call od duty Vanguard problem!
krco77 ::
lep pozdrav,
Obujam staro temo.. včeri kupu vanguard za ps 4 pro. dam cd not instaliram tko kot vedno... pol se pa zacnejo težave baje sploh ni spila da cd-ju ampak moras downloadat iz ps stora 2x za campain mode igrat in ko kliknem v igri na kvadratek mi vrže v ps storu da "this content could not be selected at this time" in to je to! zdej sploh ne morem downloadat single player! Prosim za pomoč? kako se da to rešit? Hvala vam za odgovore!
https://postimg.cc/gallery/ySRzH5B/7123...
djabi ::
Če so vsebino, ki jo omenjaš, umaknili iz strežnika, bo bolj težko ...
Možno pa, da je samo začasen problem.
Tu imaš nekaj morebitnih (standardni) rešitev, npr. ponovni zagon konzole:
Še nekaj dodatnih informacij, če kaj pomaga:
https://windowsreport.com/this-content-...
Skratka, piše, da moraš počakati, da to mine, oziroma problem reši sam od sebe (?).
Ta ima podoben problem, sicer na PS5:
https://www.reddit.com/r/playstation/co...
Tu pa je še nekaj nasvetov:
https://www.vg247.com/call-of-duty-vang...
Sicer je vse to bolj bla-bla, kot prava rešitev.
All things considered, if you encounter the This content cannot be selected at this time error, don't fret. More often than not, the error is purely regional, meaning you'll need to wait for it to pass. Other times, merely powering off your PS4 and switching it back on can save you from a lot of headaches.
Call of Duty: Vanguard campaign won't install If your connection isn't stable, it's possible that the download has paused, so take the time to check your downloads to see if the campaign has stopped downloading mid-way through. You should also make sure you have adequate hard drive space on your platform of choice!
- spremenilo: djabi ()
| » | Call of Duty : Modern Warfare [4] (2019) (strani: 1 2 3 4 5 )Oddelek: Igre | 41050 (2529) | ZiedRieke |
| » | Battlefield 7 (strani: 1 2 3 4 5 )Oddelek: Igre | 24644 (1083) | Skyman |
| » | Call of Duty: Vanguard (2021)Oddelek: Igre | 3682 (943) | krco77 |
| » | Call of Duty: Infinite Warfare (Call of Duty 13) (strani: 1 2 3 4 5 6 7 )Oddelek: Igre | 98316 (66081) | oo7 |
| » | Call of Duty: Black Ops 3 (Call of Duty 12 (2015) Treyarch) (strani: 1 2 3 4 5 )Oddelek: Igre | 52613 (38255) | oo7 |
