Forum » Operacijski sistemi » Kako naštimam mojo mrežno da je v promiscuous modu?
Gapi ::
Iz helpa v windowsih velja za windows XP
Bridge May Not Work With a Non-Promiscuous Mode Network Adapter
Applies To
This article was previously published under Q302348
SYMPTOMS
Some network interface cards (NICs) may not work after you try to create a network bridge. Specifically, the bridge seems to be created but it does not work (traffic is not passed).
CAUSE
This problem occurs because some NICs do not automatically enter into Promiscuous mode to create a successful network bridge.
RESOLUTION
To work around this behavior, force the adapter into Compatibility mode:
At a command prompt, type netsh bridge show adapter.
Locate the identification number of the NIC that is not responding.
If the NIC is not in Compatibility mode, you can change it manually if you type the following command, where 1 is the number of the NIC that is displayed in the first step:
netsh bridge set adapter 1 forcecompatmode=enable
Run the netsh bridge show adapter command again to verify that the ForceCompatabilityMode field for the NIC is displayed as Enabled.
Applies To
SYMPTOMS
CAUSE
RESOLUTION
No person is rich enough,to buy back his past.
| » | Mac OS Snow Leopard na PCOddelek: Operacijski sistemi | 5620 (4168) | Gray_Warden_ |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20202 (17042) | arrigo |
| » | pohitritev dsl ali kabelskega neta v win xpOddelek: Omrežja in internet | 2177 (1915) | BlueRunner |
| » | Valve & STEAM & On-Line gaming (strani: 1 2 )Oddelek: Igre | 9950 (8372) | Tilen |
| » | 115 kOddelek: Omrežja in internet | 1607 (1388) | Boky |
