Kako naštimam mojo mrežno da je v promiscuous modu?
shock ::
Kako naštimam v WIN XP-ju, da da mojo mrežno v promiscuous mode?
Gapi ::
Iz helpa v windowsih velja za windows XP
Bridge May Not Work With a Non-Promiscuous Mode Network Adapter
Applies To
This article was previously published under Q302348
SYMPTOMS
Some network interface cards (NICs) may not work after you try to create a network bridge. Specifically, the bridge seems to be created but it does not work (traffic is not passed).
CAUSE
This problem occurs because some NICs do not automatically enter into Promiscuous mode to create a successful network bridge.
RESOLUTION
To work around this behavior, force the adapter into Compatibility mode:
At a command prompt, type netsh bridge show adapter.
Locate the identification number of the NIC that is not responding.
If the NIC is not in Compatibility mode, you can change it manually if you type the following command, where 1 is the number of the NIC that is displayed in the first step:
netsh bridge set adapter 1 forcecompatmode=enable
Run the netsh bridge show adapter command again to verify that the ForceCompatabilityMode field for the NIC is displayed as Enabled.
No person is rich enough,to buy back his past.
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485620 (4168) Gray_Warden_
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820202 (17042) arrigo
pohitritev dsl ali kabelskega neta v win xp
Oddelek: Omrežja in internet
62177 (1915) BlueRunner
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
719950 (8372) Tilen
115 k
141607 (1388) Boky
