Forum » Problemi človeštva » Stavka zdravnikov 2024
![](https://static.slo-tech.com/stili/avatar_gray.gif)
Pri dežurtvih čez noč je pa tako da delajo 12ur čez noč, 19h-7h in če sta dva zdravnika in ni preveč čakajočih, gre lahko vmes en zdravnik spat za dve uri. Zakaj? Zato ker imajo nočne čez normalni zdraviki, ki delajo tudi čez dan... Dej da vidim tebe bit pokonci 8h + 12h brez vsaj nekaj spanca. Sem takoj za ukinitev te prakse, samo bomo zdravnike potegnili iz neke riti, ker jih ni. Prijave na specalizacije urgentne medicine in družinske so nekje na 30% razpisanih. Tako da nas "lepi" časi šele čakajo.
- spremenil: Magic1 ()
Jure14 ::
Brez skrbi. Bo AI vse nadomestila.
Malo lepila v rano ali na pico, ni problema.
"Glede na podane simptome imate 70% možnosti za prehlad, 25% za stres in 5% za tumor. Priporočamo vam lekadol, počitek in kemoterapijo."
![](https://static.slo-tech.com/stili/bel_non_grata.png)
PrihajaNodi ::
ChatGPT
The patient has a surgical indication for vertebral osteosynthesis (L5S1) with screws and cage. Lumbar arthrodesis L5S1 was operated: screws on the right side and cage (Globus). Lumbar radiculopathy with bilateral sciatica. Vertebral syndrome with bilateral sciatica. MRI and CT: incomplete vertebral fusion at L5S1. Spondylolisthesis in the lumbosacral region - M43.17, unspecified dorsalgia with unspecified location - M54.99
What is the statistic of improvment with the surgery
The success and improvement rates for lumbar spinal fusion surgery, particularly for conditions like spondylolisthesis at the L5S1 level, vary but are generally favorable. Key statistics include:
Pain Relief: Around 60-80% of patients experience significant pain relief following the surgery.
Functional Improvement: Many studies report that approximately 70-90% of patients show functional improvement, meaning they can return to normal or near-normal activities.
Fusion Rates: The fusion rate (successful bone healing) is high, often cited between 85-95%.
Patient Satisfaction: Patient satisfaction rates are generally high, with about 75-85% of patients reporting they are satisfied with the results of their surgery.
Factors influencing the success rates include the patient's overall health, the severity of the condition, adherence to post-operative rehabilitation, and the surgeon's experience. It is crucial to discuss individual risks and benefits with the healthcare provider to understand the likely outcomes in a specific case.
AI bo zemenjal enkarjevo zeno pa se en kup dohtarjev ki niso kirurgi, zobozdravniki oz specialisti.
#StaiAcasa
#SpikajmoSEvsi
- spremenilo: PrihajaNodi ()
PrihajaNodi ::
Torej cakalnih vrst ni, zdravniki (splosni$) ne delajo, da te dajo naprej je pa evtanazija. Torej je cirkus popoln in vsi plesejo
Ps AI (chatgbt) je super kot orodje sploh ker ti vrzi podatke ki so relevantni google je pa postal gnojnica reklam in kot tak neuporaben, razen google maps, recimo.
#StaiAcasa
#SpikajmoSEvsi
Jure14 ::
?Kje je tle AI kakšno diagnozo/terapijo postavil? Nametal je neke statistične razpone, kaj se lahjko zgodi. Tako kot stranski učinki pri aspirinu.
S tem, da je že obstoječa diagnoza zelo natančna. In povprečen pacient kaj takega niti v sanjah ne spravi skup, da v AI napiše.
Predvsem pa upam, da bo v prihodnosti na voljo kakšen obrazec za pacienta za podpisat: "AI mi je predlagal, da mi naredite X. S podpisom zahtevam, da to naredite."
PrihajaNodi ::
Ti statistični razponi so zelo pomebni, probaj jih poiskati z googlovim iskalnikom kjer ti bo google dal goro reklam in podatkov, ki so neuporabni plus neke metode izvajalcev (jaz jim pravim guru skamerji) ki so nepreverjene in lahko tudi škodljive oz za pacienta nevarne! Ne mi rečt da to ni konkreten preboj.
Jasno boste zagovorniki splošne medicne nabijal pa iskal napake, ki jih AI dela, kot poskušajo preprečiti samovozeča vozila, čepreav na kitajskem lepo funkcionirajo.
#StaiAcasa
#SpikajmoSEvsi
Bi ti verjel, če ne bi bil sam priča temu, da smo od enih ponoči, v prazni čakalnici, čakali, da bo ura 6:00 zjutraj, ker sestra zdravnika ni upala zbuditi. Luči ugasnjene in WCji zaklenjeni.
Tvoje zgodbice ti prodajaj komu drugemu.
- spremenilo: FireSnake ()
Sredi noči ne vstaneš in greš v bolnišnico, ane?
Slika je postala jasna, ko se je 6:10 cel zaliman primajal.
Gnoj!
PrihajaNodi je izjavil:
Diagnoza je bila postavljena glede na analizo mrn-a on jih je samo lepo interpretiral.Primer ChatGPT odgovora ki si ga dal je vezan na terciarni nivo, nima nobene veze z primarnim ali sekundarnim nivojem. Da prides do tvojega inputa za ChatGPT je moral primarni/sekundarni nivo ze prej opravit delo.
Skratka dal si primer kako lahko ChatGPT pomaga zdravniku na terciarnem nivoju.
- spremenil: Lonsarg ()
solatko ::
V ponedeljek sem bil na rednem pregledu pri svoji družinski zdravnici (enkrat letno) in ni bilo nobenega v čakalnici in tako je skoraj vsakokrat. Dela 4 ure za zunanje in 4 ure za stanovalce DOS-a. Bila pa je gneča v laboratoriju in prava zmeda, ker so spremenili način in imaš ure za priimke po abecedi. Moj je od 9-930 in sem brez veze čakal več kot uro, ker tega nisem vedel. Imel sem številko nekaj čez 260, torej so štiri ambulante vzele kar nekaj krvi. V isti stavbi je tudi kar nekaj družincev pa ni bilo kakšne posebne gužve 2-3-je na ambulanto.
PrihajaNodi - Daj malo se umiri. Sem imel v zadnjih šestih letih kar nekaj zdravstvenih problemov (predvsem s pokojno ženo) in moram rečt popolnoma nasprotno, da so naši zdravniki odlični pa tudi pomožno osebje, glede na to, kar jim nudi sistem. Torej še ni tako strašno, se pa v vsakem sistemu najdejo posamezniki, ki močno odstopajo od povprečja in praviloma zaradi takih, kritiziramo cel sistem, kar pa ni prav pa naj gre za zdravstvo, policijo, gasilce, gorske reševalce,..... V državah s kapitalistično preteklostjo je tega entuziazma veliko manj in se povsod gleda samo na denar, če ga imaš, dobiš dobro obravnavo, če ga nimaš, ni nobenega problema, če te pobere par let prej. Je pa nevarnost, da bo pogoltnost in požrešnost starih, na pol odsluženih doktorjev, ki so glavni nergači, razširila na mlajši zdravniški kader, ki pa je res, če pogledaš objektivno, v sistemu hebena stranka in s tem tudi mi, uporabniki. Pusti Romunijo in ostale vzhodno evropske države, ker ima vsaka svoj sistem z dobrimi in slabimi stranmi. Kar tako pljuvat čez vse je malo bolano, sploh, če našega zdravstva sploh ne uporabljaš. To je tako, kot kritiziranje sindikatov pa sploh nisi član.
FireSnake - To je ena ogromna laž! Sicer pa pod kazensko odgovornostjo za obrekovanje povej, kje in na katerem oddelku se je to zgodilo!
PrihajaNodi ::
Se ne strinjam. Sem imel opravka s slo javnim sistemo in ga ne zelim imeti nikoli vec
#StaiAcasa
#SpikajmoSEvsi
solv ::
PrihajaNodi ::
Strinjam se da se začasno (do začetka 2025) izplačuje dodatke. Mladim zdravnikom 3500€ bruto, ostalim 3000€ bruto.
Ampak zakaj? Da pijejo kavo?
Ne. Naj odidejo. Svico, Avstrijo, zasebno al pa Italijo
#StaiAcasa
#SpikajmoSEvsi
Buggy ::
Golobova vlada zeli tocno temu narediti konec!
- spremenil: Buggy ()
Dimnik ::
Govoriš o abecednem redu, potem pa o številki na vrstomatu..
solatko ::
- spremenil: solatko ()
nejc_nejc ::
meni, se zdi logično, da je dežurni spal, ča ni bilo nikogar, da ga pa sestra ne zbudi, haloo, to si pa resno premalo robantil....
Dimnik ::
Jaz hodim okrog pol11, če bi po abecedi bi moral bit takoj znjtraj med prvimi. In to 6,7 krat na leto
111111111111 ::
To celih 8 ur.
Ne 2 uri in potem afne guncati ostalih 6 ur, kot je to navada v javnem sektorju.
Spanje ponoči: kaj je to? Tega na privat klinikah ni.
Še tole: kar govoriš je laž, ker v JS ne klicarijo za pregled. Samo obvestijo. Če nekoga ni, ga pač ni. V privat klinikah se pa vse luknje pofilajo. Tako, da ne laži!
Zakaj pa ni spanja ponoči? Ker zasebnike boli ku... za urgenco. Boš prišel zjutraj. Ukini urgence in dežurstva, pa mi verjemi, da ne bo nihče spal čez noč na šihtu. SAm tut na telefon se ti ne bodo javili v 2 minutah.
Ti jaz povem, da kličejo, luknje se pa pofilajo in napolnijo s padalci tipa: imam drisko, bom umrl?
Hja, če kašljaš že 3 tedne, boš pa še 5 ur.
- spremenilo: 111111111111 ()
111111111111 ::
Sploh ne vem kaj letaš s kuvertami okoli Romunskih zdravnikov. Saj imaš ChatGPT. :D
Nodi pa še samo za tvojo bolezen odgovor ChatGPT-ja:
While there's no actual vaccine for "stupidity," there are numerous ways to improve one's knowledge, critical thinking skills, and overall intelligence. Here are some suggestions:
Education: Enroll in courses, whether online or at a local institution, on topics you're interested in or areas where you feel you need improvement.
Reading: Regularly read books, articles, and research papers. Focus on a variety of subjects to broaden your understanding.
Critical Thinking: Engage in activities that require problem-solving and analytical thinking, such as puzzles, chess, or other strategic games.
Continuous Learning: Take up new hobbies or learn new skills. Websites like Coursera, edX, and Khan Academy offer a plethora of courses for free or at a low cost.
Stay Informed: Keep up with current events and scientific advancements through reputable news sources and journals.
Discussion and Debate: Engage in thoughtful discussions and debates with others. This can help you see different perspectives and refine your own views.
Mindfulness and Reflection: Practice mindfulness and regularly reflect on your actions and thoughts. This can help you understand yourself better and make more informed decisions.
Improving one's intellect and critical thinking is a lifelong journey, and dedicating time to personal development can yield significant benefits.
PrihajaNodi ::
Ja in je uporaben za razliko od splošnega zdravnika, ki na "primarnem" nivoju ni. Predpisovanje napotnic lahko dela AI prav tako te zaradi simptomov pošlje do specialista, ki diganosticira bolezen.
#StaiAcasa
#SpikajmoSEvsi
111111111111 ::
Razen če AI zariba in moraš k naslednjemu "pravemu" specialistu. :D
Golob bo naredil konec zdravstvu kot ga poznamo. Se strinjam.
PrihajaNodi ::
#StaiAcasa
#SpikajmoSEvsi
- predlagal izbris: Dimnik ()
111111111111 ::
Ker nimate pojma kaj danes pomeni biti družinski zdravnik. Zjutraj te pričaka 50+ mailov v mailboxu, nekateri 1 uro po odprtju ambulante pišejo še enkrat s tonom: "Zakaj ne odgovorite". Ljudje telefonirajo... in vpijejo da se nihče ne oglaša. Obenem pa drugi ljudje capljajo okoli ambulante in jambrajo, da ni nobene gužve oni pa čakajo. :D
ENKAR ODID ŽE. TI IN TVOJA ŽENA NA NORVEŠKO
En Romunski cigan nam že ne bo diktiral, kako bomo živeli mi v Sloveniji, ki dejansko delamo za doborobit državljanov in plačujemo davke.
Preberi si nasvete ChatGPT-ja, sem vpisal tvoje zdravstveno stanje in je dal res dobro diagnozo.
Stay in Romania.
PrihajaNodi ::
Upam da ga tudi ženi prebereš preden greš spat.
Sedaj pa odidte v svet, Slovenija ne potrebuje (takšnih) packastih zdravnikov oz dvoživk
Tvoja žena pa na sprehodu na pohorju afne gunca. Ja ni čudno da kličejo če noben nč ne deal! Dodatke bi pa vlekl
#StaiAcasa
#SpikajmoSEvsi
Buggy ::
Glede na to kar pravi Golob je tocno to tudi nacrt. Idealno za presejat slabo od dobrega.
Reforma pac prihaja, to kar se je s figo v zepu pricakovalo 30let, nihce pa ni imel jajc se upreti lobijem in struktiuram moci. Po svoje bi rekel da je FIDES s to stavko sam sebi obril rit
![:))](https://static.slo-tech.com/smeski/icon_lol.gif)
PrihajaNodi ::
#StaiAcasa
#SpikajmoSEvsi
Buggy ::
111111111111 ::
A pridemo v Romunijo, da dvignemo nivo zdravstva. :D
Kaksen egoist si pa ti. Moja sociala ti gre v nos ne pa to koliko je enkarjeva zena pokasirala od dodatkov? Zlobno
Cvili Nodi cvili...
NAceloma me moti oboje isto...samo stoenkarjeva nima jajc da bi sla kam drugam, ceprav gre vsak dan s tezavo v sluzbo, ima neskoncno moznosti za novo kariero, pa vseeno vztraja, ceprav je zgubila veselje do dela s pacienti za kar smo jo solali. Si zgleda iz tega stalisca bolj sposoben izkoriscat sistem, naj ti ploskam?
... in BUggy pomaga cviliti Nodiju. :D
Buggy ::
111111111111 ::
Vseeno je lazje cmerat pa dobivat konkretno placo ter zeleti se vec za dodanih nic efforta, kot pa se soocit z realnostjo poraznega zdravstevenega sistema zadnjih par desetletij in da so potrebne radikalne spremenmbe...a ne stoenkar. Tvoji sem preprican pase da ostane vse tako kot je + povisanje za N razredov....vse kul...to delamo ze koliko N let![]()
Popolnoma se strinjam. Zdravniki morajo rešit ta sistem. ZZZS in vlada nimata s tem prav nič. Ko pa se bodo že lotili, pa morajo izposlovat višje plače še za ostale zdravstvene delavce, pridobiti več pravic pacientom in najmanj 80 ur na mesec oddelati brezplačno.
Aja kar se bajne plače tiče, reševalec z diplomo dobi na urgenci več kot moja žena, pa je ona vodja tima. :D Se strinjam, še znižat ji je treba plačo.
PrihajaNodi ::
VI BOSTE SPREJELI EVTANAZIJO BO ŠLA LAHKO TVOJA ŽENA NA POGREBNI ZAVOD KASIRAT DODATKE. TAM BO VEČ STRANK.
POHLEP JE SMRTNI GREH
#StaiAcasa
#SpikajmoSEvsi
111111111111 ::
Ha, ha, ha... Pravzaprav se ti moram opravičiti Nodi. ChatGPt te je zadel v nulo. :D
Vprašanje: Katere tablete priporočaš človeku, ki po forumu piše z velikimi tiskanimi črkami?
Če nekdo na forumu piše z velikimi tiskanimi črkami, to pogosto velja za kričanje ali neprijazno komunikacijo. Ni tablet, ki bi neposredno rešile to težavo, saj gre bolj za vprašanje netiketnega vedenja ali morebitne potrebe po izboljšanju komunikacijskih veščin. Vendar pa lahko razmislimo o nekaj možnih razlogih in rešitvah:
1. **Zdravstvene težave:**
- **Težave z vidom:** Če oseba slabo vidi, ji lahko priporočamo obisk oftalmologa za pregled vida. Morda potrebuje očala ali kontaktne leče.
- **Težave s fine motoriko:** Lahko gre za težave pri tipkanju ali uporabi tipkovnice. Fizioterapevt ali ergoterapevt lahko pomaga pri prepoznavanju in reševanju teh težav.
2. **Tehnične težave:**
- **Napačne nastavitve tipkovnice:** Morda ima uporabnik težave s tipkovnico ali nastavitvami računalnika. Priporočamo, da preveri, ali ima vključeno funkcijo Caps Lock.
3. **Neznanje ali nepoznavanje netikete:**
- **Izobraževanje o spletnem bontonu:** Uporabnika lahko opozorimo na osnovne principe netikete in pomen uporabe malih črk pri pisanju na spletu.
4. **Stres ali psihološki dejavniki:**
- **Težave z obvladovanjem stresa:** Oseba morda doživlja stres ali anksioznost. V tem primeru bi lahko pomagala posvet s psihologom ali terapevtom.
Za specifična zdravstvena ali psihološka stanja je najbolje, da se oseba posvetuje s strokovnjakom (zdravnikom, oftalmologom, psihologom ipd.), ki bo lahko ocenil, ali so potrebna zdravila ali terapije.
Pomembno je pristopiti k tej osebi s potrpežljivostjo in razumevanjem, saj morda ni seznanjena z vplivom svojega pisanja na druge ali ima upravičene razloge za takšno pisanje.
Ej, Nodi, morda pa imaš tehnične težave? Caps Lock si izklopil?
Buggy ::
Tvoja je druzinski zdranik, ce sem prav razbral in dejansko je bolj kot ne proxy dohtar, to kar se je debatiralo. Zalostno da se s svojo komoditeto v ordinaciji s sestro upa primerjat z nekim resevalcem na terenu, ki se izpostavlja in nosi neprimerno vecjo odgovornost. Ze tukaj je razbrati da je v vsamem zdravstvenem cehu veliko tezav. No take imamo. Pol pa naj si vsak misli svoje!
111111111111 ::
Ha, ha, ha... Imamo še enega poznavalca. Ko je žena na urgenci, je ona VODJA urgence. Ona je odogvorna za delo urgence. Ona sprejema klice na 112 in gre na teren, sredi noči, dneva... Prometne, padci, infarkti... Ona oskrbi pacienta in ga poskuša živega pripeljat, do bolnice, helikopterja...
Ne vem v katerem vzporednem svetu živiš. A nisi vedel da ima družinski zdravnik DELOVNO obveznost na urgenci. A si mislil, da tam delajo samo urgentni zdravniki?
Iz tvojih in Nodijevih zapisov se lepo vidi nepoznavanje dela družinskega zdravnika.
Jure14 ::
Hmmm, zdravnik.
Ponekod "namenski" urgentni, ponavadi pa družinski, ki enkrat ali dvakrat mesečno pride na vrsto za dežurstvo.
PrihajaNodi ::
Prekvalificira naj se v reševalca, al pa reševalca iz vode al pa naj ODIDE V TUJINO!
#StaiAcasa
#SpikajmoSEvsi
Buggy ::
PrihajaNodi ::
Torej hoces povedat, da takrat redko, ko dezura naurgenci in za to dobi konkretne dodatke, mora celo delati isto kot v svojem rednem casu..zanimivo![]()
BINGO! In potem ti kričiš nad socialno. Nejprej je treba poštimat da se zdravnikom da plačo glede na delo ne pa pitje kave. Jaz bi jim dal nadzornika kjer bi morali pisati kaj so počeli v delovnem času, dal bi jim OBVEZNO štempljanje ob in izhodu iz dela, pisanje poročil pa še kup drugih ukrepov.
Hudiča, bom poslal tole idejo na
https://predlagam.vladi.si
#StaiAcasa
#SpikajmoSEvsi
Buggy ::
Kot je razbrati si vsi zelimo reform, pocakajmo po desetletjih nov sistem in potem nadlajujemo debato, FIDES politicne pizdune pa verjamem da ignorira marsikdo tudi v zdravstvu, vsaj del tistih, ki so tam za paciente.
111111111111 ::
Reševalec ima že 7 let delovne dobe več od nje in je napredoval že nekaj plačilnih razredov. Saj razumem, da ne razumeš. :D
Ti konkretni dodatki... Niso konkretni. Nočne se štejejo od 0:00 - 6:00, nedeljsko in praznično delo se najbolj splača. Sobota pa je največje sranje. :D
Kar piši. Vidim da si upošteval nasvete ChatGPT-ja in ugotovil kako zmanjšati črke. :D
PrihajaNodi ::
Si upošteval moje predloge o prekvalifikaciji? Ja vem, manj je treba delat sedaj, manjša odgovornost itd sam tole jamranje o denarju je pa čista ZLOBA!
NE BOSTE DOBILI VEČ DENARJA. GOLOB BO UVEDEL NADZOR NAD VAŠIM DELOM
#StaiAcasa
#SpikajmoSEvsi
Buggy ::
torej moraj zgolj delati za kar je postavljena na polozaj, po doloceni uri pa dobi se extra, kar se ji seveda vse steje v placo. Ce pustiva tukaj denarno sfero. A to predstavlja za tvojo zeno tezavo? Zakaj je v tem poklicu, se enkrat vprasam...da je za ene to easy money (fajrsnejk je govoril o enih zaspancih) in lezerno delo vemo, lahko dodas pa dodadeten razlog zakaj vztraja v javnem zdravstvu in ne gre privat?
PrihajaNodi ::
Vi kar nabijajte. Sej jo bo s časom uspel prepričat, da je "poslanstvo" za naše zdravstvo en k. Vas bo potem privat pregledovala lepo ležerno ene 35min, vi pa boste pohlevno plačali kolikor bo pač potrebno. Po tem ležernem privat delovniku pa bo šla mal poštukat honorarno v ambulanto za neopredeljene, 100EUR/h neto. Sej veste, ker težko dobijo zdravnike za neopredeljene ambulante. So preveč spočiti družinci v javnem, da bi šli dodatno delat za 100EUR/h...
ODIDE NAJ. SAJ NI MARIJA TEREZIJA. ALI PA V TUJINO KJER SE CEDITA MED IN MLEKO!
Narodu je dovolj cuzanja državne malhe dohtarjev
#StaiAcasa
#SpikajmoSEvsi
Jure14 ::
A dobijo zdravniki pri nas veliko denarja za malo dela, al ne?
Menda dobijo več kot v tujini, pa za manj dela.
In zdaj tisti del, ki mi ni jasen: če je temu tako, zakaj ne hodijo k nam avstrijski in nemški zdravniki? Še bosanski nočejo. Pa imajo vse paprije urejene, pa si premislijo.
Al mogoče kaj narobe sklepam?
