MIŠKA NA SMART TV
MIŠKA NA SMART TV
ticom ::
Imam nov Philips TV, 75PUS8818/12 in ob priklopu miške se pojavi napis, da je priključena nova naprava, pokaže se kurzor, vendar na miški dela samo tipka nazaj, isto se dogaja z drugo miško in miško priključeno preko kabla. Kaj narediti.
Hvala
fpbs ::
ticom je izjavil:
Prodaj Philipsa, in kupi LGeja, ki ima airmiško vgrajeno v telekomandi.
A. Smith ::
Preveri, če ima TV posodobljen FW. Sicer so pa tukaj ukrepi.
Ensure that:
o The software on the TV is up to date
Answer
Use a normal plug & play mouse or keyboard with the following functionalities:
o At least a USB 2.0 connection
o Without special functions (like additional buttons, keyboards with touchpad or scroll functions)
o Conform the HID standard (usually this is mentioned on the box and/or in the manual)
"Be professional, be polite,
- General James Mattis
ticom ::
Hvala. Zadeva ni delala zaradi posodobitve.
Katero brezžično miško kupiti? (strani: 1 2 3 )
10033484 (15091) Kayzon
Nekdo mi nekako vdira (strani: 1 2 )
7615969 (11228) Mare2
Počasen računalnik
295994 (5576) Berserker
Windows 7 postane popolnoma neodziven ob priklopu miške
133165 (2939) SLO_Matej
zakaj miska ne deluje??
389474 (8760) ecstasy
