Forum » Zvok in slika » MIŠKA NA SMART TV
MIŠKA NA SMART TV
ticom ::
Imam nov Philips TV, 75PUS8818/12 in ob priklopu miške se pojavi napis, da je priključena nova naprava, pokaže se kurzor, vendar na miški dela samo tipka nazaj, isto se dogaja z drugo miško in miško priključeno preko kabla. Kaj narediti.
Hvala
Hvala
fpbs ::
Prodaj Philipsa, in kupi LGeja, ki ima airmiško vgrajeno v telekomandi.
A. Smith ::
Preveri, če ima TV posodobljen FW. Sicer so pa tukaj ukrepi.
Ensure that:
o The software on the TV is up to date
Answer
Use a normal plug & play mouse or keyboard with the following functionalities:
o At least a USB 2.0 connection
o Without special functions (like additional buttons, keyboards with touchpad or scroll functions)
o Conform the HID standard (usually this is mentioned on the box and/or in the manual)
Ensure that:
Answer
"Be professional, be polite,
- General James Mattis
| » | Katero brezžično miško kupiti? (strani: 1 2 3 )Oddelek: Kaj kupiti | 33483 (15090) | Kayzon |
| » | Nekdo mi nekako vdira (strani: 1 2 )Oddelek: Informacijska varnost | 15969 (11228) | Mare2 |
| » | Počasen računalnikOddelek: Pomoč in nasveti | 5994 (5576) | Berserker |
| » | Windows 7 postane popolnoma neodziven ob priklopu miškeOddelek: Pomoč in nasveti | 3165 (2939) | SLO_Matej |
| » | zakaj miska ne deluje??Oddelek: Strojna oprema | 9474 (8760) | ecstasy |
