težave z noron ghostom
iro ::
Probleme imam z kloniranim diskom ko pač prvi disk odklopim ,dam drugega na master mi pri zagonu javi da nemore bootat z diska v čem je problem
Daedalus ::
Probaj takole - novi disk priklopi kot master, starega (kerga image češ dat na novega ) kot slave, pol pa z ghost disketo kloniraj in bi moglo delat.
[J.P.Sartre]
asskicker ::
Problem je verjetno v tem, da particija s polkni ni aktivna. Zbutaj z diskete kakšen Partition Magic in particijo s polkni na novem disku aktivitraj (set active). Potem bo zbutal tudi z novega diska. Pozdrav!8-)
Heaven is on the next door!
iro ::
sem naredu kot si rekel dal novi disk na master in active pa mi napiše da ni nekaj vredu t ARC??
to sam našel v pomoči za kaj se gre?
Displays a mapping of drive letters to physical device names. This information is useful when you run the fixboot and fixmbr commands. The map command is only available when you are using the Recovery Console.
Map [arc]
Parameter
arc
Instructs the map command to display Advanced RISC Computing (ARC) device names instead of device names. An example of an ARC device name is:
multi(0)disk(0)rdisk(0)partition(1)
The equivalent device name is:
\Device\HardDisk0\Partition1
Example
The following example maps the physical device names to the drive letters using ARC device names:
map arc
Notes
If you do not use the arc parameter, the map command displays device names.
The map command also displays the type of file system and the size of each disk in megabytes (MB).
ToniT ::
Preberi to temo. Mogoče bo kaj pomagalo.
usb bootable image windows
82128 (2042) T-Mac
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485666 (4214) Gray_Warden_
trdi disk hitachi
282532 (2167) kerrigh
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
7110035 (8457) Tilen
"snemanje" iger
Oddelek: Igre
51518 (451) (sic)
