Forum » Pomoč in nasveti » Kernel power event critical 41 vzroki in fix
L1nK ::
Se da iz tega kaj razbrati, kaj je vzrok eventa? Cold shutdown playing doom eternal, 5-30 min into gaming. Po sensor reading se nič ne pregreva. En mesec sem tudi po več ur igral mass effect 3 LE in Andromedo, pa nisem dobil niti enega. Ohišje imam odprto, PSU je samo mlačen na otip. Windows 11 so updatani, DSIM restore narejen na sourcu z USB ključka, sfc /scannow pognan...Pač marsikaj sem preveril. Grafična je sicer OCjana oz. undervoltana, ampak dvomim, da je to vzrok, enako sem dobil na stock nastavitvah. CPU je ryzen 3600 in stock, PBO je ON, C-states so ON, XMP 2.0 profile on, RAM se že testiral z memtestom in je ok. Pojma nimam. Nisem pa še preizkusil drugega PSUja. Power settings so OK, no fast startup, high performance scheme...Razne sintentične teste na max load lahko ženem precej časa, ni mi še crashal nobeden računala, recimo cinebench, Unigine benchmarki...
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 05/11/2022 06:04:03
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: desktop-stojan
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>9</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2022-11-05T05:04:03.8060889Z" />
<EventRecordID>23590</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>desktop-stojan</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
<Data Name="LidReliability">false</Data>
<Data Name="InputSuppressionState">0</Data>
<Data Name="PowerButtonSuppressionState">0</Data>
<Data Name="LidState">3</Data>
</EventData>
</Event> https://www.facebook.com/link.zhizhekian
Bios imaš up to date?
L1nK ::
Ja, se mi zdi, da sem našel problem. Imam namreč dve različni palčki rama, obe crucial ballistix 8gb, ena je ddr4-3200 spec, ena pa 3000. Timinge imata drugačne in po mojem plata ne zna tega shandlati in prihaja do napak. XMP 2.0 profile itak ne dela. Ga vklopim in mi recimo takoj cold shutdowna PC pri cinebench 23 benchmarku. Skušal bom uskladiti obe palčki ročno in potem testiral za stabilnost.
Nastavi timinge za 3000 ram ali zamenjaj počasen ram z 3200.
- spremenilo: sbawe64 ()
L1nK ::
Žal nič. Sem se kar igral s timingi. Memtest86 test pade zelo hitro. XMP je na auto, kar je najbrž disabled, ker sta samo dve opciji v asrock uefi biosu (xmp 2.0 in auto), hitrost imam na ddr4-3000, kot je počasnejši modul. Voltage je 1.350, kot je XMP value za oba sticka. Sem probal tudi več, pa se mi niti boota ne comp. CL mi sploh sprejeti noče 15, kot je en modul (3000), ampak avtomatsko vedno nastavi vrednost 16.
Tu so info o modulih:
slot1: https://ibb.co/6YMzBNw
slot2: https://ibb.co/VqCRs7F
MEM info cpuz, zadnji set, crash v nekaj sekundah: https://ibb.co/5M4GdyK
- spremenil: L1nK ()
L1nK ::
ja, ravno se spravljam k temu, ker mi je zdaj še na default nastavitvah (ddr4-2400) padel memtest86, tako da sumim, da je ena palčka zanič.
L1nK ::
Ni mi uspelo, mi lahko kdo pomaga z nastavitvijo? Pri večini nastavitev mi sploh boota ne sistem, potreben je cmos reset. Tudi na stock oz. auto 2400 memtest86 crasha.
Bios pics, plata je asrock b450m HDV-r4, cpu ryzen 3600
https://drive.google.com/file/d/1JspRvV...
https://drive.google.com/file/d/1JqeSeh...
https://drive.google.com/file/d/1JhOn7I...
A pri 2133Mhz je vse stable?
L1nK ::
Kaže, da bo pri 2400 :/ pri timingih za 3000 modul, šele takrat mi pusti cl na 15, višje pa ne. Infinity fabric imam na 1200, voltage pa malo višji za vsak slučaj. Res me zanima, kaj je narobe. FSB DRAM clock razmerje mi cpuz povsem zmešano kaže. Šele pri 2400 mi pokaže pravilno, 1:12, takoj ko grem višje, mi začne z nekimi čudni 3:40 in podobno. Kaže, da bo delalo, vsaj cinebench ne crasha več. Me zanima, koliko performanca bo izgubil pri tem, Če bo precej, grem raje menjat ram povsem. Katerega mi priporočate, 2x8 gb kit, solidna cena? je corsair vengeance LPX 3200 cl16 18 18 v redu?
| » | Internet ne delaOddelek: Strojna oprema | 1576 (1258) | Han |
| » | kaminOddelek: Loža | 1261 (982) | fikus_ |
| » | slaba slika monitorja (strani: 1 2 )Oddelek: Pomoč in nasveti | 9983 (9249) | musicfreak |
| » | Ram TežaveOddelek: Pomoč in nasveti | 1124 (975) | eko_2k4 |
| » | Čudno obnašanje mašine - zagonOddelek: Pomoč in nasveti | 5711 (5223) | akulp |
