Forum » Loža » USB 3.2 ključ samo USB 2.0
Rad21 ::
Imam USB ključ Patriot Supersonic Rage Pro, 128 GB, 420/400 MB/s, USB 3.2. Problem je, da ga zazna samo kot USB 2.0.
Testiral na drugemu računalniku z USB 3.0, Steam Deck-u, USB 3.0 HUB-u, USB 3.1 Gen 2 HUB-u in povsod deluje samo z USB 2.0.
Imam isti USB ključ 256 GB in ga normalno zazna kot USB 3.0.
- spremenilo: Rad21 ()
crniangeo ::
Daj pokazi output iz usbtree https://m.majorgeeks.com/files/details/...
Convictions are more dangerous foes of truth than lies.
Rad21 ::
Delujoči 256 GB:
=========================== USB Port1 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 2-21-1
Properties : 0x01
IsUserConnectable : yes
PortIsDebugCapable : no
PortHasMultiCompanions : no
PortConnectorIsTypeC : no
ConnectionIndex : 0x01 (Port 1)
CompanionIndex : 0
CompanionHubSymLnk : USB#VID_2109&PID_2813#5&260b46e3&1&6#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber : 0x01 (Port 1)
-> CompanionPortChain : 2-6-1
========================== Summary =========================
Vendor ID : 0x090C (Silicon Motion, Inc. - Taiwan)
Product ID : 0x3282
USB Version : 3.2 Gen 1
Port maximum Speed : SuperSpeed
Device maximum Speed : SuperSpeed
Device Connection Speed : SuperSpeed
Self powered : no
Demanded Current : 304 mA
Used Endpoints : 5
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB Attached SCSI (UAS) Mass Storage Device
Device Path 1 : \\?\USB#VID_090C&PID_3282#MSFT30AA00000000017406#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Device Path 2 : \\?\USB#VID_090C&PID_3282#MSFT30AA00000000017406#{2accfe60-c130-11d2-b082-00a0c91efb8b} (GUID_DEVINTERFACE_STORAGEPORT)
Kernel Name : \Device\USBPDO-10
Device ID : USB\VID_090C&PID_3282\MSFT30AA00000000017406
Hardware IDs : USB\VID_090C&PID_3282&REV_1100 USB\VID_090C&PID_3282
Driver KeyName : {4d36e97b-e325-11ce-bfc1-08002be10318}\0006 (GUID_DEVCLASS_SCSIADAPTER)
Driver : \SystemRoot\System32\drivers\uaspstor.sys (Version: 10.0.22621.608 Date: 2022-10-12)
Driver Inf : C:\Windows\inf\uaspstor.inf
Legacy BusType : PNPBus
Class : SCSIAdapter
Class GUID : {4d36e97b-e325-11ce-bfc1-08002be10318} (GUID_DEVCLASS_SCSIADAPTER)
Service : UASPStor
Enumerator : USB
Location Info : Port_#0001.Hub_#0003
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(21)#USB(1), ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(SS05)#USB(1)
Container ID : {973a086f-81c1-528a-aebe-0ae6fe579cc6}
Manufacturer Info : USB Attached SCSI (UAS) Compatible Device
Capabilities : 0x14 (Removable, UniqueID)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
HcDisableSelectiveSuspend: 0
EnableSelectiveSuspend : 0
SelectiveSuspendEnabled : 0
EnhancedPowerMgmtEnabled : 0
IdleInWorkingState : 0
WakeFromSleepState : 0
Power State : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
Child Device 1 : Patriot Rage Pro SCSI Disk Device (Disk drive) (Disk4)
Device Path : \\?\SCSI#Disk&Ven_Patriot&Prod_Rage_Pro#7&2b6b3f96&1&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} (GUID_DEVINTERFACE_DISK)
Kernel Name : \Device\000000aa
Device ID : SCSI\DISK&VEN_PATRIOT&PROD_RAGE_PRO\7&2B6B3F96&1&000000
Class : DiskDrive
Driver KeyName : {4d36e967-e325-11ce-bfc1-08002be10318}\0006 (GUID_DEVCLASS_DISKDRIVE)
Service : disk
Volume : \\?\Volume{00012a76-0000-0000-0000-100000000000}\
Kernel Name : \Device\HarddiskVolume15
Mountpoint : H:\
+++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\090C32821100
osvc : REG_BINARY 00 00
---------------- Connection Information ---------------
Connection Index : 0x01 (Port 1)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01 (Configuration 1)
Device Address : 0x0B (11)
Is Hub : 0x00 (no)
Device Bus Speed : 0x02 (High-Speed) -> not true, see below in Connection Information V2
Number Of Open Pipes : 0x04 (4 pipes to data endpoints)
Pipe[0] : EndpointID=1 Direction=OUT ScheduleOffset=0 Type=Bulk wMaxPacketSize=1024 bInterval=0
Pipe[1] : EndpointID=2 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=1024 bInterval=0
Pipe[2] : EndpointID=3 Direction=OUT ScheduleOffset=0 Type=Bulk wMaxPacketSize=1024 bInterval=0
Pipe[3] : EndpointID=4 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=1024 bInterval=0
Data (HexDump) : 01 00 00 00 12 01 20 03 00 00 00 09 0C 09 82 32 ...... ........2
00 11 01 02 03 01 01 02 00 0B 00 04 00 00 00 01 ................
00 00 00 07 05 01 02 00 04 00 00 00 00 00 07 05 ................
82 02 00 04 00 00 00 00 00 07 05 03 02 00 04 00 ................
00 00 00 00 07 05 84 02 00 04 00 00 00 00 00 ...............
--------------- Connection Information V2 -------------
Connection Index : 0x01 (1)
Length : 0x10 (16 bytes)
SupportedUsbProtocols : 0x04
Usb110 : 0 (no, port not supports USB 1.1) -> but Companion Port 2-6-1 does
Usb200 : 0 (no, port not supports USB 2.0) -> but Companion Port 2-6-1 does
Usb300 : 1 (yes, port supports USB 3.0)
ReservedMBZ : 0x00
Flags : 0x03
DevIsOpAtSsOrHigher : 1 (Device is operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 1 (Device is SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Device is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
Data (HexDump) : 01 00 00 00 10 00 00 00 04 00 00 00 03 00 00 00 ................
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x320 (USB Version 3.2)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x09 (9 bytes)
idVendor : 0x090C (Silicon Motion, Inc. - Taiwan)
idProduct : 0x3282
bcdDevice : 0x1100
iManufacturer : 0x01 (String Descriptor 1)
Language 0x0409 : "Patriot Memory"
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "Rage Pro"
iSerialNumber : 0x03 (String Descriptor 3)
Language 0x0409 : "AA00000000017406"
bNumConfigurations : 0x01 (1 Configuration)
Data (HexDump) : 12 01 20 03 00 00 00 09 0C 09 82 32 00 11 01 02 .. ........2....
03 01 ..
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0079 (121 bytes)
bNumInterfaces : 0x01 (1 Interface)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0x80
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x26 (76 mA)
Data (HexDump) : 09 02 79 00 01 01 00 80 26 09 04 00 00 02 08 06 ..y.....&.......
50 00 07 05 01 02 00 04 00 06 30 08 00 00 00 07 P.........0.....
05 82 02 00 04 00 06 30 08 00 00 00 09 04 00 01 .......0........
04 08 06 62 00 07 05 01 02 00 04 00 06 30 08 02 ...b.........0..
00 00 04 24 04 00 07 05 82 02 00 04 00 06 30 08 ...$..........0.
02 00 00 04 24 03 00 07 05 03 02 00 04 00 06 30 ....$..........0
00 00 00 00 04 24 01 00 07 05 84 02 00 04 00 06 .....$..........
30 08 02 00 00 04 24 02 00 0.....$..
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00 (Interface 0)
bAlternateSetting : 0x00
bNumEndpoints : 0x02 (2 Endpoints)
bInterfaceClass : 0x08 (Mass Storage)
bInterfaceSubClass : 0x06 (SCSI transparent command set)
bInterfaceProtocol : 0x50 (Bulk-Only Transport)
iInterface : 0x00 (No String Descriptor)
Data (HexDump) : 09 04 00 00 02 08 06 50 00 .......P.
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x01 (Direction=OUT EndpointID=1)
bmAttributes : 0x02 (TransferType=Bulk)
wMaxPacketSize : 0x0400 (max 1024 bytes)
bInterval : 0x00 (never NAKs)
Data (HexDump) : 07 05 01 02 00 04 00 .......
------ SuperSpeed Endpoint Companion Descriptor -------
bLength : 0x06 (6 bytes)
bDescriptorType : 0x30 (SuperSpeed Endpoint Companion Descriptor)
bMaxBurst : 0x08 (up to 9 packets per burst)
bmAttributes : 0x00 (The bulk endpoint does not define streams)
wBytesPerInterval : 0x0000
Data (HexDump) : 06 30 08 00 00 00 .0....
bEndpointAddress : 0x82 (Direction=IN EndpointID=2)
Data (HexDump) : 07 05 82 02 00 04 00 .......
bAlternateSetting : 0x01
bNumEndpoints : 0x04 (4 Endpoints)
bInterfaceProtocol : 0x62 (USB Attached SCSI - UAS)
Data (HexDump) : 09 04 00 01 04 08 06 62 00 .......b.
bmAttributes : 0x02 (4 streams supported)
Data (HexDump) : 06 30 08 02 00 00 .0....
------------- UAS Pipe Usage Descriptor ---------------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x24 (UAS Pipe Usage Descriptor)
bPipeID : 0x04 (Pipe ID=4)
bReserved : 0x00
Data (HexDump) : 04 24 04 00 .$..
bPipeID : 0x03 (Pipe ID=3)
bReserved : 0x00
Data (HexDump) : 04 24 03 00 .$..
bEndpointAddress : 0x03 (Direction=OUT EndpointID=3)
Data (HexDump) : 07 05 03 02 00 04 00 .......
bMaxBurst : 0x00 (up to 1 packets per burst)
Data (HexDump) : 06 30 00 00 00 00 .0....
bPipeID : 0x01 (Pipe ID=1)
bReserved : 0x00
Data (HexDump) : 04 24 01 00 .$..
bEndpointAddress : 0x84 (Direction=IN EndpointID=4)
Data (HexDump) : 07 05 84 02 00 04 00 .......
bPipeID : 0x02 (Pipe ID=2)
bReserved : 0x00
Data (HexDump) : 04 24 02 00 .$..
---------- Binary Object Store (BOS) Descriptor -----------
bLength : 0x05 (5 bytes)
bDescriptorType : 0x0F (Binary Object Store)
wTotalLength : 0x0016 (22 bytes)
bNumDeviceCaps : 0x02
Data (HexDump) : 05 0F 16 00 02 .....
------------- USB 2.0 Extension Descriptor ------------
bDescriptorType : 0x10 (Device Capability Descriptor)
bDevCapabilityType : 0x02 (USB 2.0 Extension)
bmAttributes : 0x02
LPMCapable : 1 (Link Power Management protocol is supported)
BESLAndAlternateHIRD : 0 (BESL & Alternate HIRD definitions are not supported)
BaselineBESLValid : 0 (not valid)
DeepBESLValid : 0 (not valid)
BaselineBESL : 0
DeepBESL : 0
Data (HexDump) : 07 10 02 02 00 00 00 .......
----- SuperSpeed USB Device Capability Descriptor -----
bLength : 0x0A (10 bytes)
bDevCapabilityType : 0x03 (SuperSpeed USB Device Capability)
bmAttributes : 0x00
Bit 0 Reserved : 0x00
Bit 1 LTM Capable : 0x00 (no)
Bit 7:2 Reserved : 0x00
wSpeedsSupported : 0x0C (High-Speed, SuperSpeed)
bFunctionalitySupport : 0x02 (lowest speed with all the functionality is 'High-Speed')
bU1DevExitLat : 0x04 (less than 4 us)
wU2DevExitLat : 0x0004 (less than 4 us)
Data (HexDump) : 0A 10 03 00 0C 00 02 04 04 00 ..........
-------------------- String Descriptors -------------------
------ String Descriptor 0 ------
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
Data (HexDump) : 04 03 09 04 ....
------ String Descriptor 1 ------
bLength : 0x1E (30 bytes)
Data (HexDump) : 1E 03 50 00 61 00 74 00 72 00 69 00 6F 00 74 00 ..P.a.t.r.i.o.t.
20 00 4D 00 65 00 6D 00 6F 00 72 00 79 00 .M.e.m.o.r.y.
------ String Descriptor 2 ------
Data (HexDump) : 12 03 52 00 61 00 67 00 65 00 20 00 50 00 72 00 ..R.a.g.e. .P.r.
6F 00 o.
------ String Descriptor 3 ------
bLength : 0x22 (34 bytes)
Data (HexDump) : 22 03 41 00 41 00 30 00 30 00 30 00 30 00 30 00 ".A.A.0.0.0.0.0.
30 00 30 00 30 00 30 00 31 00 37 00 34 00 30 00 0.0.0.0.1.7.4.0.
36 00 6.
128 GB:
Port Chain : 2-6-1
Properties : 0x01
CompanionIndex : 0
CompanionHubSymLnk : USB#VID_2109&PID_0813#5&260b46e3&1&21#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
-> CompanionPortChain : 2-21-1
Product ID : 0x3282
USB Version : 2.1
Port maximum Speed : High-Speed (Companion Port 2-21-1 supports SuperSpeed)
Device Connection Speed : High-Speed
Self powered : no
Demanded Current : 300 mA
Used Endpoints : 3
Device Description : USB Mass Storage Device
Device Path : \\?\USB#VID_090C&PID_3282#AA00000000017477#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Device ID : USB\VID_090C&PID_3282\AA00000000017477
Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0036 (GUID_DEVCLASS_USB)
Driver : \SystemRoot\System32\drivers\USBSTOR.SYS (Version: 10.0.22621.1 Date: 2022-05-07)
Driver Inf : C:\Windows\inf\usbstor.inf
Class : USB
Class GUID : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service : USBSTOR
Enumerator : USB
Location Info : Port_#0001.Hub_#0005
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(6)#USB(1), ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS06)#USB(1)
Container ID : {bd590d12-fbf4-5168-9e07-379f6825b9c8}
Manufacturer Info : Compatible USB storage device
Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Problem Code : 0
Address : 1
Child Device 1 : Patriot Rage Pro USB Device (Disk drive) (Disk4)
Device Path : \\?\USBSTOR#Disk&Ven_Patriot&Prod_Rage_Pro&Rev_1100#AA00000000017477&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} (GUID_DEVINTERFACE_DISK)
Kernel Name : \Device\000000ad
Device ID : USBSTOR\DISK&VEN_PATRIOT&PROD_RAGE_PRO&REV_1100\AA00000000017477&0
Class : DiskDrive
Driver KeyName : {4d36e967-e325-11ce-bfc1-08002be10318}\0005 (GUID_DEVCLASS_DISKDRIVE)
Service : disk
Volume : \\?\Volume{a7f5e794-1c32-5768-43c2-2f1de15b4f3a}\
Kernel Name : \Device\HarddiskVolume16
Mountpoint : H:\
Device Address : 0x0C (12)
Is Hub : 0x00 (no)
Number Of Open Pipes : 0x02 (2 pipes to data endpoints)
Pipe[0] : EndpointID=1 Direction=OUT ScheduleOffset=0 Type=Bulk wMaxPacketSize=512 bInterval=0
Pipe[1] : EndpointID=2 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=512 bInterval=0
Data (HexDump) : 01 00 00 00 12 01 10 02 00 00 00 40 0C 09 82 32 ...........@...2
00 11 01 02 03 01 01 02 00 0C 00 02 00 00 00 01 ................
00 00 00 07 05 01 02 00 02 00 00 00 00 00 07 05 ................
82 02 00 02 00 00 00 00 00 .........
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes, port supports USB 1.1)
Usb200 : 1 (yes, port supports USB 2.0)
Usb300 : 0 (no, port not supports USB 3.0) -> but Companion Port 2-21-1 does
ReservedMBZ : 0x00
Flags : 0x02
DevIsOpAtSsOrHigher : 0 (Device is not operating at SuperSpeed or higher)
ReservedMBZ : 0x00
Data (HexDump) : 01 00 00 00 10 00 00 00 03 00 00 00 02 00 00 00 ................
bcdUSB : 0x210 (USB Version 2.1)
bMaxPacketSize0 : 0x40 (64 bytes)
idProduct : 0x3282
bcdDevice : 0x1100
Language 0x0409 : "AA00000000017477"
Data (HexDump) : 12 01 10 02 00 00 00 40 0C 09 82 32 00 11 01 02 .......@...2....
03 01 ..
wTotalLength : 0x0020 (32 bytes)
bmAttributes : 0x80
MaxPower : 0x96 (300 mA)
Data (HexDump) : 09 02 20 00 01 01 00 80 96 09 04 00 00 02 08 06 .. .............
50 00 07 05 01 02 00 02 00 07 05 82 02 00 02 00 P...............
wMaxPacketSize : 0x0200 (max 512 bytes)
Data (HexDump) : 07 05 01 02 00 02 00 .......
Data (HexDump) : 07 05 82 02 00 02 00 .......
--------- Device Qualifier Descriptor (for Full-Speed) --------
bDescriptorType : 0x06 (Device_qualifier Descriptor)
bcdUSB : 0x200 (USB Version 2.00)
bMaxPacketSize0 : 0x40 (64 Bytes)
bNumConfigurations : 0x01 (1 other-speed configuration)
bReserved : 0x00
Data (HexDump) : 0A 06 00 02 00 00 00 40 01 00 .......@..
------------ Other Speed Configuration Descriptor -------------
bDescriptorType : 0x07 (Other_speed_configuration Descriptor)
bmAttributes : 0x80
Data (HexDump) : 09 07 20 00 01 01 00 80 96 09 04 00 00 02 08 06 .. .............
50 00 07 05 01 02 40 00 FF 07 05 82 02 40 00 FF P.....@......@..
wMaxPacketSize : 0x0040 (64 bytes)
bInterval : 0xFF (ignored)
Data (HexDump) : 07 05 01 02 40 00 FF ....@..
Data (HexDump) : 07 05 82 02 40 00 FF ....@..
bmAttributes : 0x02
BaselineBESL : 0
DeepBESL : 0
bmAttributes : 0x00
6F 00 o.
30 00 30 00 30 00 30 00 31 00 37 00 34 00 37 00 0.0.0.0.1.7.4.7.
37 00 7.
Port Chain : 2-21-1
Properties : 0x01
CompanionIndex : 0
Product ID : 0x3282
Self powered : no
Used Endpoints : 5
Class : SCSIAdapter
Service : UASPStor
Enumerator : USB
Problem Code : 0
Class : DiskDrive
Service : disk
Mountpoint : H:\
Is Hub : 0x00 (no)
ReservedMBZ : 0x00
Flags : 0x03
ReservedMBZ : 0x00
idProduct : 0x3282
bcdDevice : 0x1100
03 01 ..
bmAttributes : 0x80
bReserved : 0x00
bReserved : 0x00
bReserved : 0x00
bReserved : 0x00
bmAttributes : 0x02
BaselineBESL : 0
DeepBESL : 0
bmAttributes : 0x00
6F 00 o.
36 00 6.
128 GB:
Port Chain : 2-6-1
Properties : 0x01
CompanionIndex : 0
Product ID : 0x3282
USB Version : 2.1
Self powered : no
Used Endpoints : 3
Class : USB
Service : USBSTOR
Enumerator : USB
Problem Code : 0
Address : 1
Class : DiskDrive
Service : disk
Mountpoint : H:\
Is Hub : 0x00 (no)
ReservedMBZ : 0x00
Flags : 0x02
ReservedMBZ : 0x00
idProduct : 0x3282
bcdDevice : 0x1100
03 01 ..
bmAttributes : 0x80
bReserved : 0x00
bmAttributes : 0x80
bmAttributes : 0x02
BaselineBESL : 0
DeepBESL : 0
bmAttributes : 0x00
6F 00 o.
37 00 7.
| » | BSOD 0x00000124Oddelek: Pomoč in nasveti | 1994 (1435) | s1m0n |
| » | Problem z ramom ali diskom? Prosim za nasvet.Oddelek: Strojna oprema | 1579 (1481) | Duhec |
| » | navijanje dellaOddelek: Navijanje | 1573 (1465) | MecH |
| » | wpasupplicant in SD LJOddelek: Omrežja in internet | 2150 (1964) | r5r |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2190 (1999) | mtosev |
