Porazno delovanje mreže na Win računalniku
joze67 ::
Router Orbi RKB750, dva satelita.
Računalnik: matična Asus Prime B550M-A WI-FI z Intel Wi-Fi 6 AX200, zunanji anteni, Win 10
Telefon: Oppo Find X3 Pro
Računalnik in telefon sta povezana na satelit v sosednji sobi.Na telefonu Orbi app meri nekje med -51 in -48 dBm. Na ZeroPi , ki je fizično priključen na router, teče iperf3 strežnik.
Če na računalniku izvedem
iperf3 -c a.b.c.d -i 1 -t 10 k -4
dobim tole žalost
$ iperf3 -c a.b.c.d -i 1 -t 10 -4
Connecting to host a.b.c.d, port 5201
[  4] local a.b.c.R port 64541 connected to a.b.c.d port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  1.00 MBytes  8.39 Mbits/sec
[  4]   1.00-2.01   sec  1.75 MBytes  14.5 Mbits/sec
[  4]   2.01-3.01   sec  2.25 MBytes  18.9 Mbits/sec
[  4]   3.01-4.01   sec   896 KBytes  7.34 Mbits/sec
[  4]   4.01-5.01   sec   768 KBytes  6.29 Mbits/sec
[  4]   5.01-6.01   sec   384 KBytes  3.13 Mbits/sec
[  4]   6.01-7.01   sec  1.25 MBytes  10.5 Mbits/sec
[  4]   7.01-8.00   sec   640 KBytes  5.31 Mbits/sec
[  4]   8.00-9.00   sec   384 KBytes  3.14 Mbits/sec
[  4]   9.00-10.01  sec   640 KBytes  5.23 Mbits/sec
[  4]   0.00-10.01  sec  9.88 MBytes  8.28 Mbits/sec                  sender
[  4]   0.00-10.01  sec  9.88 MBytes  8.28 Mbits/sec                  receiver
iperf Done.
[  4] local a.b.c.R port 64652 connected to a.b.c.d port 5201
[  4]   0.00-1.01   sec   256 KBytes  2.08 Mbits/sec
[  4]   1.01-2.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   2.00-3.01   sec   640 KBytes  5.22 Mbits/sec
[  4]   3.01-4.01   sec   512 KBytes  4.16 Mbits/sec
[  4]   4.01-5.00   sec   640 KBytes  5.32 Mbits/sec
[  4]   5.00-6.00   sec   896 KBytes  7.32 Mbits/sec
[  4]   6.00-7.00   sec   896 KBytes  7.33 Mbits/sec
[  4]   7.00-8.00   sec   768 KBytes  6.30 Mbits/sec
[  4]   8.00-9.01   sec  1.25 MBytes  10.5 Mbits/sec
[  4]   9.01-10.01  sec  2.12 MBytes  17.8 Mbits/sec
[  4]   0.00-10.01  sec  8.00 MBytes  6.71 Mbits/sec                  sender
[  4]   0.00-10.01  sec  8.00 MBytes  6.71 Mbits/sec                  receiver
iperf Done.
(in to še zdaleč ni najslabše).
Če to isto izvedem s telefonom, dobim
[  4] local a.b.c.T port 49314 connected to a.b.c.d port 5201
[  4]   0.00-1.00   sec  30.8 MBytes   258 Mbits/sec
[  4]   1.00-2.00   sec  20.0 MBytes   168 Mbits/sec
[  4]   2.00-3.00   sec  20.0 MBytes   168 Mbits/sec
[  4]   3.00-4.00   sec  31.2 MBytes   262 Mbits/sec
[  4]   4.00-5.00   sec  31.2 MBytes   262 Mbits/sec
[  4]   5.00-6.00   sec  28.8 MBytes   241 Mbits/sec
[  4]   6.00-7.00   sec  30.0 MBytes   252 Mbits/sec
[  4]   7.00-8.00   sec  21.2 MBytes   178 Mbits/sec
[  4]   8.00-9.00   sec  27.5 MBytes   231 Mbits/sec
[  4]   9.00-10.00  sec  30.0 MBytes   252 Mbits/sec
[  4]   0.00-10.00  sec   271 MBytes   227 Mbits/sec                  sender
[  4]   0.00-10.00  sec   268 MBytes   225 Mbits/sec                  receiver
iperf Done.
To v moji knjigi odstrani vse pomisleke o kakovosti mreže (ne da bi bila dobra, ampak očitno zmore delovati solidno). Po drugi strani forumi niso polni bentenja čez vgrajeno mrežno kartico v Asusovi plošči.
Kakšen nasvet, kaj naj pogledam, da bo računalnik igral v isti ligi kot telefon?
aleksander10 ::
Katere driverje uporabljaš za to wifi kartico? Lahko je v njih problem.
Probaj z linux live verzijo, pa naredi enak test, pa da vidiš če imaš enak problem.
Aleksander
"A friend is someone who gives you total freedom to be yourself. (J.M.)"
Poskusi s starejšini šoferji za Asus wifi mrežno.
Koneckoncev lahko v skrajni sili uporabiš dodatno zunanjo usb wifi kartico.
joze67 ::
Gonilniki so prišli s sistemom. Windows zadovoljni.
Sem jih sedaj zamenjal z Intlovimi. 22.160.0.4 in 14. avgusta letos. Ni spremembe sploh.
Sem naredil Live Ubuntu in (netrivialno) uspel namestiti iperf3. Tam dela telefonsko hitro.
Najdi starejše.
joze67 ::
Evo, 21.70.0.6 iz januarja 2020. Začelo se je obetavno:
[  4]   0.00-1.01   sec  8.50 MBytes  70.6 Mbits/sec
[  4]   1.01-2.01   sec  6.12 MBytes  51.2 Mbits/sec
[  4]   2.01-3.02   sec  6.25 MBytes  52.3 Mbits/sec
[  4]   3.02-4.01   sec  6.75 MBytes  56.7 Mbits/sec
[  4]   4.01-5.00   sec  7.75 MBytes  65.8 Mbits/sec
[  4]   5.00-6.00   sec  7.12 MBytes  59.7 Mbits/sec
[  4]   6.00-7.01   sec  8.50 MBytes  71.1 Mbits/sec
[  4]   7.01-8.01   sec  6.75 MBytes  56.5 Mbits/sec
[  4]   8.01-9.01   sec  7.62 MBytes  63.9 Mbits/sec
[  4]   9.01-10.00  sec  6.12 MBytes  51.7 Mbits/sec
[  4]   0.00-10.00  sec  71.5 MBytes  60.0 Mbits/sec                  sender
[  4]   0.00-10.00  sec  71.5 MBytes  60.0 Mbits/sec                  receiver
in potem, čez nekaj časa
[  4]   0.00-1.00   sec   256 KBytes  2.09 Mbits/sec
[  4]   1.00-2.01   sec  0.00 Bytes  0.00 bits/sec
[  4]   2.01-3.01   sec  0.00 Bytes  0.00 bits/sec
[  4]   3.01-4.01   sec   256 KBytes  2.10 Mbits/sec
[  4]   4.01-5.01   sec   128 KBytes  1.05 Mbits/sec
[  4]   5.01-6.01   sec   256 KBytes  2.10 Mbits/sec
[  4]   6.01-7.00   sec   384 KBytes  3.19 Mbits/sec
[  4]   7.00-8.01   sec   256 KBytes  2.08 Mbits/sec
[  4]   8.01-9.00   sec   384 KBytes  3.16 Mbits/sec
[  4]   9.00-10.00  sec   256 KBytes  2.10 Mbits/sec
[  4]   0.00-10.00  sec  2.12 MBytes  1.78 Mbits/sec                  sender
[  4]   0.00-10.00  sec  2.12 MBytes  1.78 Mbits/sec                  receiver
Sedaj smo spet nazaj na 61.3 Mbits/sec. Tako dihanjesem opazil že prej (samo meril sem samo s speedmetrom, ki je prekompleksen za ta problem).
sej bos slej k prej ugotovil, da bo najceneje in najbolj optimalno potegnat ethernet kabl do tega pcja, to mrezno pa zabrisat v smeti.
Na Asus strani so za wifi (win 10 x64):
Version 22.80.1.1
2021/10/27
ter
Version 21.70.0.6
2020/06/08
Sistemski bios je zadnji ?
Version 2803
2022/04/29
V nastavitvah za mrežno kartico (device manager) imaš na high performance (ter v system power plan), tam poglej če se da kaj nastaviti.
Ker ponavadi dela wifi na Linux slabše kot na win in ne nasprotno.
  • spremenilo: sbawe64 ()
tony1 ::
iloveboobz je izjavil:
Daleč najboljši nasvet. In najenostavnejši.
Danes je svet nekoliko izgubil razsodnost z vsemi temi ipadi, ki so začeli modo, da eth porta sploh nimaš; celo v resnejših laptopih nimaš eth porta in ga moraš skonektati na docking station... Če hočeš odzivnosti in performance je kabel še vedno najboljša rešitev.
sploh ker bo v tem primeru switch za 10e hitrejsa zadeva kot fancy router za 250. Zica all the way, če je le mozno. Za stacionarc skor ni izgovora.
joze67 ::
sbawe64 je izjavil:
Version 2803
2022/04/29
2423
Note 2 : Do NOT update the BIOS by yourself if it's not necessary. Update failure could lead your device not to boot/start up.
Bom ju3 vseeno pogledal, kako je z nadgrajevanjem tega čuda.
Sicer smo ta hip na 35.8 Mbits/s 8-)
35mbit je bil standard na single band wifi-n pred 10 leti...
joze67 ::
Ko si na 3.5, ali na 0, je 35 precej. Žalostno je, da je na drugi strani solidna 1G/1G linija in bi s tem WiFi6 moralo leteti, pa če peš ne gre.
kabel vstekat, pa bo gigabit all day everyday, brez pardona.
joze67 ::
Vem. Ampak ni moje stanovanje, služba pa ne toliko stabilna, da bi mirne duše investiral par k CHF v napeljavo omrežja, potem pa čez par mesecev bežal nazaj v RS.
Power mgmt naredi 0 razlike. Sedaj sem spet nekje med 0 in 2 Mbps.
  • spremenilo: joze67 ()
tony1 ::
Štekam.
Kaj pa če bi poskusil z dvema kitajskima powerline adapterjema? Sam sem bil z Mercusys powerline adapterjema (imata lahko tudi vgrajen wifi... čeprav v tvojem primeru to ni uporabno) zelo zadovoljen, pa tudi cenovno so zelo ugodni... Mislim, da je v web vmesnik adapterja vgrajeni bandwith test na drugo stran bajte (dobrih 10 m) rutinsko kazal 700 mbit/s...
  • spremenil: tony1 ()
crniangeo ::
ali ima ta wifi kartica tudi bluetooth? nekako imam v spominu eno poodobno zadevo, da je wifi speed bil slab zaradi bluetootha, in si moral nekaj spremeniti v nastavitvah, da je vse bilo ok :)
probaj tole, lahko da bo pomagalo.
https://answers.microsoft.com/en-us/win...
Convictions are more dangerous foes of truth than lies.
crniangeo ::
daj odstrani še ai suite 3 če ga imaš slučajno nameščenega :)
Najbolje probati s čistim Windows. Kaki softver imaš nameščen? Recimo Cisco AnyConnect ima težave z AX200 (ga močno upočasni).
joze67 ::
crniangeo je izjavil:
Ima BT, ampak zaenkrat še nisem šel po tej poti.
tony1 je izjavil:
Imam seveda tudi Devolo Magic Lan 2, ki pa tudi ni bil neka dobra rešitev. Imam pa v načrtu zanj naslednje. Sedaj, ko imam Orbi, lahko glavni Devolo adapter prestavim k satelitu - ta pa je v tem delu stanovanja, kjer se dogaja večina stvari. Zaradi lepot švicarskih priključkov pa moram najprej dobiti podaljšek... pa ugasniti NAS ipd.
Kar sem naredil do sedaj je, da sem po vrsti odinštaliral vse gonilnike, ki so se nabrali za kartico - z opcijo brisanja datotek (pomembno). Potem sem namestil zadnje gonilnike in sedaj imam skoraj konsistentno hitrost nad 100 Mbits/s. Kar je zaenkrat (predvsem konsistentnost) zadovoljivo.
MrStein je izjavil:
SW: Windows 10 V21H1, TinyWall, ProtonVPN ... potem pa se že konča.
Nimam.
tony1 ::
Držim pesti, da bo ostalo tako.
Če boš kupoval nov powerline adapter sem sam z Mercusys zelo zadovoljen.
joze67 ::
No, da delim še kasnejše ugotovitve.
Pomembno izboljšanje je prinesla antena. nekoč sem nabavil zunanjo anteno, ki je priromala tudi do tega računalnika. Izkaže se, da na 2.4GHz nekaj dela, na 5 pač ne. Ko sem zamenjal z Asusovo anteno, se je končno vzpostavila povezava na 5GHz in jasno je bolje.
Druga stvar je ProtonVPN. Mislil sem, da split tunneling pomeni, da se za izbrane naslove in aplikacije VPN zaobide. No, dejansko je seveda najbolje, če VPNja sploh ni. Potem, le ne dela. Sprejemljivo pa je tudi, če je split tunneling ugasnjen ali, enako dobro, če NAS ni naveden med izjemami.
Zaenkrat je ok, hvala vsem za prispevke!
Domači VPN (strani: 1 2 3 )
Oddelek: Omrežja in internet
12733198 (19046) Daniel
Kateri router za VPN ?
4710123 (8807) SeMiNeSanja
sistem za domači server (strani: 1 2 )
7315096 (14394) [SkA]
Postavitev domačega omrežja (strani: 1 2 )
5322048 (20582) Vanadium
T2
162138 (1519) ljusmir
