Forum » Strojna oprema » Na zunanji disk ni mogoče kopirati ali ustvariti mape, disk: STEB8000402
Rias Gremory ::
Ola,
na zunanji disk ni mogoče kopirati oz. ustvariti mape.
Disk je Seagate STEB8000402 8TB, USB 3.0, sicer priklopljen na USB 2.0 vrata. Kupljen je bil manj kot leto nazaj preko spleta (Nemčija). SMART podatke bom prilepil ko pridem do Windows mašine (beri: Linux se ne razume z drekastim kontrolerjem). Skoraj zagotovo pa disk ni bil prižgan več kot teden.
Z GPartedom lahko naredim ext4 filesystem brez napak. Z ddjem mi je tudi uspelo zapisati nekaj GB ničel (dd if=/dev/zero of=/dev/sdc).
Še relevanten dmesg izpis:
OS: Bunsenlabs (distro ki bazira na Debian stable), 4.19.0-22-amd64
Matična: ASUS M4A785TD-V EVO
Kaj probat?
[Oct 4 14:37] usb 1-4: new high-speed USB device number 6 using ehci-pci [ +0.205161] usb 1-4: New USB device found, idVendor=0bc2, idProduct=331a, bcdDevice= 9.15 [ +0.000007] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ +0.000004] usb 1-4: Product: Expansion Desk [ +0.000003] usb 1-4: Manufacturer: Seagate [ +0.000003] usb 1-4: SerialNumber: [REDACTED] [ +0.001046] scsi host8: uas [ +0.001464] scsi 8:0:0:0: Direct-Access Seagate Expansion Desk 0915 PQ: 0 ANSI: 6 [ +0.002914] sd 8:0:0:0: Attached scsi generic sg2 type 0 [Oct 4 14:38] sd 8:0:0:0: [sdc] 15628053167 512-byte logical blocks: (8.00 TB/7.28 TiB) [ +0.000007] sd 8:0:0:0: [sdc] 4096-byte physical blocks [ +0.000352] sd 8:0:0:0: [sdc] Write Protect is off [ +0.000005] sd 8:0:0:0: [sdc] Mode Sense: 53 00 00 08 [ +0.000495] sd 8:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ +0.000378] sd 8:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes) [ +0.079824] sdc: sdc1 [ +0.003166] sd 8:0:0:0: [sdc] Attached SCSI disk [ +14.029036] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null) [ +18.491356] bl-file-manager[16311]: segfault at 0 ip 00005652e6c28166 sp 00007ffcc7a74890 error 4 in thunar[5652e6bbd000+7a000] [ +0.000020] Code: 83 c4 08 c3 55 48 89 fd 53 48 89 f3 48 83 ec 08 e8 8f ff ff ff 48 89 ef 48 89 c6 e8 a4 5d f9 ff 48 8b 53 08 48 39 50 40 74 0b <48> [Oct 4 14:52] sd 8:0:0:0: [sdc] Synchronizing SCSI cache [ +0.250010] sd 8:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK [ +0.064809] usb 1-4: USB disconnect, device number 6
Kaj probat?
Vuli ::
ajej, To je Seagate Expansion, veliko sreče. Jaz sem imel težave 5TB varjanto in nikoli več.
Rias Gremory ::
iloveboobz je izjavil:
na kakšnem drugem pcju, da izločiš to.
Cjao, zdaj se počutim butasto, da tega prej nisem poskusil. Sem namreč prebral, da Seagate vgrajuje buggy SATA-USB kontrolerje, ki naj bi bili polno podprti le na Windowsih.
Sedaj sem probal na Win 10 mašini. Takoj ga je zaznalo, edino "mountalo" ga ni, ker je bil gor ext4. Z stock Windows programom sem naredil NTFS particijo. Seveda je šlo takoj brez problema gor 5GB, skoraj 200MB/s.
Vglavnem, glavni osumljenec je kontroler v ohišju, tj. SATA-USB most.
Rias Gremory ::
Še malo konteksta za koga iz prihodnosti:
ALL Seagate USB enclosures have disabled ATA Pass Through (SMART access/temperature/sleep/etc.) with any recent Linux/USB3
Cannot perform SMART data and Self-Test on external hard drive
No SMART access to Seagate devices under Linux if UAS is used
Smartmontools USB Device Support
ext bere na windows DiskInternals Linux Reader
https://www.diskinternals.com/linux-rea...
- spremenilo: sbawe64 ()
| » | Mount read-only JE ali NI read only?Oddelek: Programska oprema | 2896 (2706) | poweroff |
| » | [Linux] loop naprava in virtualni diskOddelek: Operacijski sistemi | 1870 (1673) | poweroff |
| » | Linux Read only file system ??Oddelek: Operacijski sistemi | 1983 (1942) | 2g00d4u |
| » | Interno telefoniranje anlog>isdnOddelek: Pomoč in nasveti | 1607 (1557) | Brainstorm |
| » | dostop do interneta preko ISDN bazne postajeOddelek: Omrežja in internet | 1140 (1102) | Matri[X] |
