Forum » Programiranje » MYSQL variabla v query
BRBR ::
SET @a=200.50; SELECT a.*,(@a:=@a+EUR) AS end_value FROM ....
A ne obstaja neka fora, da tistile set start value poturiš kar nekam v query, tam nekje zraven 'a:=' ?
BRBR ::
Videti je blizu, samo sproducira stolpec "@a:=200.50", v celoti z value tega stringa "@a:=200.50"
kar je surplus
kar je surplus
- spremenil: BRBR ()
kljuka13 ::
Res je, ustvari se nov stolpec. Potencialno - če res želiš - bi lahko okoli tega zavil še en SELECT, kjer bi izbral vse razen tega stolpca.
Naj pa vsekakor omenim, da dokumentacija MySQL tvoje idejo odsvetuje.
Prav tako:
Previous releases of MySQL made it possible to assign a value to a user variable in statements other than SET. This functionality is supported in MySQL 8.0 for backward compatibility but is subject to removal in a future release of MySQL.
Prav tako:
The order of evaluation for expressions involving user variables is undefined. For example, there is no guarantee that SELECT @a, @a:=@a+1 evaluates @a first and then performs the assignment.
| » | Kako napisat SQL query?Oddelek: Programiranje | 1634 (840) | HotBurek |
| » | Pomoč pri izdelavi MySQL poizvedbe... (strani: 1 2 )Oddelek: Programiranje | 8439 (6806) | urli |
| » | sqlOddelek: Programiranje | 1302 (1007) | Miha 333 |
| » | SQL stavek?Oddelek: Programiranje | 1301 (1206) | milc |
| » | sql injection [PHP + mysql]Oddelek: Informacijska varnost | 2451 (2176) | Lion29 |
