Forum » Pomoč in nasveti » Torrentleech invite
Torrentleech invite
-RS6- ::
Če slučajno koga zanima, so registracije trenutno odprte.
SPRING2023 Invitation Code
Spring is here! Apart from the nice, warm temperatures, what about an invite giveaway??))
Use invite code SPRING2023 in the sign up form http://www.torrentleech.org/user/accoun... and enjoy your new account! As cherry on top, you'll find your account with 15GB upload credit to help you start your epic journey! HURRY UP! For the first 10k people only!
- spremenil: -RS6- ()
Trubar ::
Ima kdo invite za torrentleech? V zameno lahko dam mojblink invajrt. :)
Ref exchange link:
https://my.okx.com/en-eu/join/35464995
https://www.kucoin.com/r/rf/Hu6Rx2
ducy ::
Kaj nudiš v menjavo?
Po pravici, sem želel le preveriti če imajo določen SW.. oz, kaj se da kaj dobit glede 3D CAD, itd...
Žal, nimam kaj ponudit... kote le "velik hvala" ;)
- spremenil: ducy ()
twom ::
Tudi jaz bi se priporočil za torrentleech..., razen mojblinka (pa včasih partisa) nimam drugega...
Skyman ::
Ce kdo rabi
FLREFUGEE Invitation code
A few hours ago, FileList announced that it will close its gates forever, leaving lots of people without a place they can call "home". For a very limited time, use code FLREFUGEE and come be part of our family!
On top of that, you will get 15 GB of upload to help you start your journey!
Welcome aboard, and we hope you will feel like home
TL Staff
TL Staff
Jarvice ::
Ima kdo prosim invite?
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
Jarvice ::
Tudi jaz :)
muhac ::
Samo omenim, če daste nekomu svoj invite, s tem garantirate za njegovo početje.
In, če bo počel neumnosti (cheatanje ratia recimo), bodo bannali tudi vas.
To velja več ali manj za vse privatne torrent site, recimo meni na kraj pameti ne bi prišlo, da dam invite nekomu, ki ga ne poznam osebno...
- spremenilo: muhac ()
Jarvice ::
Res je. Dosti je neodgovornih ljudi.
Ampak kako pa prit noter, če ne od nekoga, ki te invajta?
Drugače pa ni zdaj več 1024/256 interneta, da bi bilo treba goljufat, tako da glede tega ne bi smelo bit problema.
Samo H&R ni treba delat.
yayo ::
Pa ratio pod 0,4 ti da ban. Meni je čudno kako tistih par fajlov, ki sem jih pri TL pobral vedno ostaja na 0/0. Praktično je nemogoče dvigniti si količnik, ker so zelo hitro vsi leacherji na 100%, ko se pa kasneje pojavi kak novi ga algoritem usmeri drugim seederjem, ki so verjetno hitrejši ali geografsko bolj blizu leecherju. ?
Jarvice ::
Problem je, da moraš izklopit DHT/LPD/PEX in tako si težje dvigneš ratio.
yayo ::
havala za hint. Sedaj tudi skušam nastavit outside seeding za popularne public tracker torrente. Vendar sem noob, ker mi je vedno vse laufalo brez problemov pa mi ni bilo nikoli potrebno se učiti fines.
Bici_ ::
pe3c ::
mihec87 ::
Na TL koristi freeleech torente pa jih seedaš vsaj tistih 10dni oz čim dlje da dobivaš točke z katerimi kupuješ upload... Drugače pa če je problem prostor na disku, v torrent napokaj 100 torrentov ki so večji od 10mb in farmaš točke(če je manjši od 10mb ne dobiš nič točk) za vsak torrent 0.04točke/h.
yayo ::
jaz sem gor več kot leto pa ne vem, če je kdo od mene 10mb pobral. Power userji imajo vsi najete seedboxe pa leecherje vedn k njim usmerja, ker imajo veliko hitrejši prenos. Tako, da ratio vzdržujem izključno s TL pointi in seedanjem (v prazno) freelech torrentov, ki sem jih pobral na drugih trackerjih pa jih "prilagodil" TL releasom.
Daniel ::
Sam od tam redko kdaj kaj potegnem, pa imam ratio 7,92. Je pa verjetno lažje, če imaš namensko škatlo za take zadeve, ki dela 24/7. Nedolgo nazaj nabavil Intel N100 in gor postavil TrueNAS, prej pa vse preko RPI in SSD diska. Z dvema SSD diskoma, malim ventilatorjem, 2,5G mrežno, PCIx Sata kartico, in 512 GB NvME zadeva troši 11W. To je, ko je procesor brez obremenitve.
- spremenil: Daniel ()
mihec87 ::
Ja je kar kriza uploadat.. moj najstarejši je 180dni, uploadano skupno od vseh(20+) pa cca 110gb(večina na 5 FL bluray filmih...
sivkrokar ::
Brez seedbox-a (ali kake podobne domače zadeve) se na TL ne da narediti ratia.
Z seedboxom pa je preprosto: rutorrent + autodl-irssi. V "filters" se nastavi:
General->Minimum size->20GB
P2P->Match Releases->*FraMeSToR
To je to. Lahko se doda še auto delete pravilo, da je zadeva v celoti avtomatizirana.
Potem pa za domačo rabo ali preneseš iz seedboxa ali pa potegneš direkt iz TL na pc ter brišeš H&R z presežnim uploadom.
yayo ::
Za tiste, ki ne veste, invite gre na e-mail naslov. Enkrat je en tu prosil pa sem mu preko osebnega sporočila napisal, da naj mi da svoj e-naslov, da ga posredujem TLju. Vse tiho je bilo, niti hvala ne potrebujem več ni odgovoril.
Jarvice ::
S seedboxom res leti upload na TL.
1TB v dveh dneh.
1TB v dveh dneh.
borut1300 ::
Zdravo.
Sedaj so registracije odprte od danes naprej za 10k registriranih. Kdor še ni registriran se lahko sedaj.
Lp,
Borut
Lp,
Borut
Skyman ::
Bici_ ::
Hvala.
A je priporočljiva uporaba vpn-ja za te tuje trackerje?
- spremenil: Bici_ ()
Bici_ ::
Assass1n ::
Zdravo.
Lp,
Borut
Much obliged!
Jarvice ::
Za torrentleech je priporočljiva uporaba seedboxa, ker si z domačo povezavo težko dvigneš ratio.
Uporabiš SFTP za prenos podatkov iz seedboxa na svoj računalnik in je to to. Ni potrebe po VPNju.
bemfa ::
Časi ko je blo težko dvignit ratio so že zdavnaj mimo. Vse kar je nad 14gb je itak FL. Je pa treba spoštovat pravila (torrent settingi, odpret port, seed time, ...) Za povprečnega janeza je vse kar presega klik download gumba že preveč.
- predlagal izbris: Jarvice ()
Jarvice ::
Na nekem slo trackerju se je dalo dosti lažje dvignit ratio kot pa na tl.
Sem vedno downloadal torrente, ki sem jih sam hotel imet in se je ratio normalno dvigoval.
Še nikoli nisem rabil downloadat torrente namensko samo z namenom dviga ratia. Primer torrentleech.
bemfa ::
Sej pravim... ni težko, ampak za povprečnega slovenskega jamrača je preveč.
Jarvice ::
Težje je kot pa kak slo tracker. To hočem povedat. In, da si olajšaš zadevo, nabaviš seedbox + SFTP in si brez skrbi.
Da pa hočeš obrnit temo v nekulturno pa itak tvoj nick vse pove.
| » | infire (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Omrežja in internet | 134418 (1229) | Stefo |
| » | torrenthr.org (strani: 1 2 3 4 5 6 )Oddelek: Loža | 87811 (3645) | anketar |
| » | Kickass šu po gobe.. (strani: 1 2 )Oddelek: Loža | 28333 (20899) | PrimozR |
| » | Torrentz.eu umolknil (strani: 1 2 )Oddelek: Novice / Avtorsko pravo | 23715 (17790) | BorutK-73 |
