Forum » Znanost in tehnologija » JWST - James Webb Space Telescope
BT52 ::
Vir do Slotech novice pred iztrelitvijo
Čudovito izpeljana izstrelitev težko pričakovanega JWST teleskopa. In zdaj nas čaka napeto spremljanje sekvenc razpiranja, ter ohlajanja v teh 3-6 mescih. Upajmo, da bomo lahko dobili prve slike.
Najboljši vir za spremlnjanje potrjenih izpeljanih sekvenc https://twitter.com/NASAWebb
The Insane Engineering of James Webb Telescope by Real Engineering
Engineering Panel of the James Webb Space Telescope
twitter Donald McDowell 29.12
twitter by Marcia Smith 30.12
twitter by NASA Webb Telescope 30.12
Great work by Bill Gray using data from optical observers: orbit for the JWST upper stage is 173 x 2280262 km x 4.8 deg, which has a C3 of -0.35 but an apogee outside the Hill Sphere, so per his estimate it will end up in a 1.00 x 1.05 AU x 0.3 deg heliocentric orbit
To add perspective, I just confirmed with NASA that the DESIGN life of #JWST is 5 years, not 10, and the life-cycle cost of $9.7 B incl 5 yrs of ops not 10. Great if there's fuel for ops beyond 10 yrs, but fuel is not the only determinant and every yr of ops needs more money.
Due to the precision of our launch and our first two mid-course corrections, our team has determined that Webb should have enough fuel to allow support of science operations for significantly more than a 10-year science lifetime!
DamijanD ::
Ščit je najbolj problematičen, a ne? Sama ogledala so bistveno bolj fiksna in tam skoraj nič ne more it narobe (če ne odpovejo motorčki)
mojsterleo ::
Že vemo kaj bo zadeva sploh počela tam gori?
Sem bral ocene, da ima potencial 100x večji kot Hubblov space telescope.
Kolikor je jasno, bodo opazovanja v IR spektru svetlobe za razliko od vidne/uv, kot to izvaja Hubble. Torej kakšnih blazno impresivnih slik ne bo, bodo pa zbrani podatki verjetno izjemni, sploh glede na velikost ogledal teleskopa in delovni temperaturi ki bo bojda -230C. Trenutno je ogledalo pri -45C.
BT52 ::
V bistvu gleda dlje v preteklost.
Ir gre dlje od vidnega spectra.
Plus največja prednost zraen tega, da dobiš večji spekter za analizo afmosfer odaljenih planetnih sistemov. Z pomočjo sipanja svetlobe določamo, če ima planet recimo vodno paro v atmosferi. Ker vodna para absorbira IR zelo dobro in se lahko podrobneje deducijsko določi "Goldilocks zone".
Največja prenost pa bo verjetno bolj natačna določitev starosti vesolja oz mogoče kako dodatno spoznanje o inflacijski teoriji.
Več pa ti ne znam povedat. Mogoče kdo na področju lahko pove kaj več.
Infrared observations are important to astronomy because recently formed stars and planets are often hidden behind masses of dust that absorb visible light. Infrared light can penetrate these obstacles.
"Infrared light will go around the dust grains instead of bouncing off, so we can see that with the Webb telescope. And that's one of our top goals - to see how stars grow, with their young planets,"
- spremenilo: BT52 ()
xseki ::
Na redditu veliko folka že paničari. Prišlo je do zamud.
- spremenilo: xseki ()
msms ::
Vse je ok, namenoma bojo jutri zategnili 5 ščitov. To je zelo pomemben korak morajo vse preverit, bo pa jutri pomemben dan.
BT52 ::
NASA si jemlje čas. Recimo včeri je tempteratura malo poskočila na motorjih pa ustavili in rotirali modul, da jih ohladijo.
Danes prva plast potem pa načeloma kako hitro bo šlo.
Njih ne bodo pregnali, če gre kaj preko 80% zmogljivosti ustavijo konje in premislijo. Samo potrpežljivo.
BT52 ::
Če kaj hvalim SpaceX je to, da ne šparajo s posnetki. NASA škrtari na veliko.
Ja na tem bi lahko delali. Samo to je to tista čista usmerjenost v totalno znanost in uspehu misije. Kar je po eni strani konec koncev edino odgovorno, ter realno dosegljivo. Vsak kilogram in MB je zlata vreden. Ne morem jim oporekat tega. Upajmo, da večja raketa ali neki podobnega rešilo oz sprostilo morebitne limite (razen fizikalne). Mogoče upgrade deep space networka ala globalStarlink ali neki podobnega. Ker misije se bodo širile vse do Kuiperjevega pasu.
Super, zdaj na nekem vesoljskem objektu, ki je milijon km od zemlje, boš porabil 30% energetskih resourcov, da boš streamal video za par freakov...
msms ::
Sončni ščit razgrnjen v celoti. Najtežji del je za nami. Sedaj skoraj več nima kaj it narobe.
Ales ::
nirburu ::
msms ::
Nimajo kamer, če je kdo gledal danes prenos je lepo povedala merijo na tisoče parametrov iz katerih pol nato poustvarijo sliko JWTja.
xseki ::
Čestitke!
https://twitter.com/NASAWebb/status/147...
#NASAWebb is fully deployed!
With the successful deployment & latching of our last mirror wing, that's:
50 major deployments, complete.
178 pins, released.
20+ years of work, realized.
Next to #UnfoldTheUniverse: traveling out to our orbital destination of Lagrange point 2!
BT52 ::
To mi nič pove. Edine prave ISO mere so koliko olimpijskih bazenov in nogometnih igrišč obsega. :D
bojsi ::
Še en zanimiv video, če morda kdo še ni videl... Nisem vedel, da je noter tudi aktivno hlajenje določenih komponent, ki morajo biti na 7 kelvinih:
The insane engineering of James Webb Telescope
https://jwst-docs.stsci.edu/ - tale link je danes zaokrožil po netu, user dokumentacija za JWST. Pa veselo študiranje.
V-i-p ::
Za eno teniško igrišče.
DamijanD ::
Zdaj premikajo ogledala z ogromno hitrostjo 1mm/dan (At full speed, it takes about a day to move all the segments by just 1 millimeter. It's about the same speed at which grass grows!)
Sistem je narejen tako, da naenkrat lahko premikajo samo en segment in da se stvar ne segreje preveč, to delajo v kratkih intervalih...
- spremenilo: DamijanD ()
Na kakšni tirnici bo James Webb, da se izogne smetem v vesolju, ker je res popolnoma izpostavljen poškodbam. Vse te "smeti" o katerih je govora v orbiti, kdaj padejo nazaj na zemljo?
xseki ::
Če sem prav razumel bo JWST v L2 (Lagrange point 2). Torej tam ni teh smeti. Smeti so problem v "Low Earth Orbit" (LOE) in "Mid Earth Orbit" (MEO), JWST gre dlje.
Glej kje je zemlja in kje je L2.
JWST s svojimi opazovanji že dejansko prispeva k novim vprašanjem glede nastanka vesolja.
Odkrili so na primer nove galaksije velikosti Mlečne ceste, ki bi naj, glede na svojo lokacijo, obstajale manj kot milijardo let po velikem poku.
Po sedanjem razumevanju nastankov galaksij bi za kaj takega potrebovale precej več časa.
Prav tako so v območju "zgodnjega vesolja" odkrili spajanje velikih črnih lukenj, česar si po tradicionalnih teorijah tudi ne znajo razložiti.
Torej, JWST je do sedaj prinesel nekaj novih odgovorov in precej novih vprašanj.
Lowink ::
Mogoče je bla svetlobna hitrost počasnejša na začetku, ko se je pojavilo dovolj mase je postala konstanta, recmo, da se je kritična masa pojavila v krajšem času kolkor trenutno veli redshift.
| » | Kitajski vesoljski postaji priklopili drugi modulOddelek: Novice / Znanost in tehnologija | 10849 (8173) | mr_chai |
| » | Dobili smo prve posnetke teleskopa James Webb v polni ločljivosti (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 13372 (9732) | cias |
| » | Posnetki Jamesa Webba ostri, kolikor je fizikalno možnoOddelek: Novice / Znanost in tehnologija | 9204 (3636) | predi |
| » | Danes v vesolje potuje teleskop James Webb (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 26458 (18676) | BT52 |
| » | Teleskop Webb poleti 18. decembraOddelek: Novice / Znanost in tehnologija | 14864 (9834) | BigWhale |
