V ZDA Pfizerjevo cepivo proti covidu-19 dobilo redno dovoljenje
8 / 12
HappyPills ::
Most COVID-19 vaccines target the spike protein in the virus in a defined way that is low risk. New vaccine technologies like mRNA are safer and designed in more scientifically targeted ways than older vaccines. Overwhelmingly, vaccinated people are showing protection against severe COVID-19 cases and hospitalizations. This would likely not happen if ADE were occurring, because it is an acute and very serious condition that would cause significant medical alarm.
Unchancy ::
Massacra je izjavil:
Da se vrnem še malo na denga virus.
Dengue vaccine is a vaccine used to prevent dengue fever in humans. Development of dengue vaccines began in the 1920s, but was hindered by the need to create immunity against all four dengue serotypes.
In December 2018, Dengvaxia was approved in the European Union.
In May 2019, Dengvaxia was approved in the United States as the first vaccine approved for the prevention of dengue disease caused by all dengue virus serotypes.
Leta 1920 so začeli raziskovati cepivo zoper denga mezlico, EU je prvo odobrila 2019.
100 let raziskav. Pri sars-cov-2 pa pol leta in 1 leto za odobritev s strabi FDA!
Vse jasno? Pohlep
On April 6, 1924, eight U.S. Army Air Service pilots and mechanics in four airplanes left Seattle, Washington, to carry out the first circumnavigation of the globe by air. They completed the journey 175 days later on September 28, after making 74 stops and covering about 27,550 miles.
Približno sto let kasneje traja da enkrat obkrožiš Zemljo:
ISS: 90 minut
Concorde leta 1995: 31 plus ur
Jok odpade! >:D
Tup tup tup :))
Adijo mod Rdeči Kmeri.
  • spremenil: Unchancy ()
Mr.B -> Se en ki ne razume, zakaj je bilo vsako leto novo cepivo za gripo... Ampak ja osnove.
"Vaccines currently in use provide protection against IAV subtypes H1N1 and H3N2 and one or two IBV subtypes."
Ti si tisti, ki ne razume kaj pomeni vsako leto "novo" cepivo proti gripi!
"Novo" pomeni, da se glede na projekcijo, kateri tip virusa gripe bo prevladoval, izdela ustrezno cepivo za to sezono. Zgolj zoper 4 (pod)tipe virusa A in B.
Poznamo pa zgolj 4 tipe virusa gripe:
IAV and IBV circulate in humans and cause seasonal epidemics, and ICV causes a mild infection, primarily in children. IDV can infect humans but is not known to cause illness.
Torej 4 cepiva, ki se izmenjujejo, glede na pretežno verjetnost, kateri tip bo prevladoval
(obstajajo seveda že tudi večvalentna cepiva, ki predstavljajo določeno zaščito zoper več podtipov: H1N1, H3N2 in enega ali oba podtipa IBV).
To je to. Ni novo NOVO cepivo vsako leto!
Kaj mi sedaj potrjuješ, da za 4 tipie virusa "iste" gripe od nastanka cepiva do DANES le ta ne delujejo. Ampak čudežno bodo delovale proti COVID varianti, ki mutira na vsake pol leta ter nekaj vrjant glede na geografsko lokacijo. Dobro zate. Ker odziv po cepljenu na grip in na covid je no nisem opazil bistvene razlike. Neki prebolijo gripo brez simptomov, nekateri z manjšimi glavoboli in vročino, nekateri morajo konkretno ležat, nesrečni pa morajo iti v Bolnico kaj šele na intezivni odelek.
Da odkrivanje tople vode in metanje statistike, ter se taji skrivati za nerazumevanjem vsebine. Poikusi še 1x.
Kumbaja ::
maldic je izjavil:
lol, jaz ne vsiljujem mnenja. Zato meni ni treba dokazovat nicesar. Vsak naj se sam odloci. Tvoj primer pa je drugacen. verjetno se bos strinjal, da si proti antivaxerjem in da si za cepljenje. Torej, ce zelis, da te bodo bralci uposteval tukaj, ti moras dokazat, da si boljsi od nasprotno mislecih. Razumes. Pa ne podcenjevat inteligenco uporabnikov na slotech, ker lahko hitro ugotovijo, ce kdo zavaja. Zato lahko najvec storis, ce si iskren.
Seveda vsiljuješ mnenje, ravno včeraj si prodajal neresnico, da o bogih prodajalcih vitaminov z 10k prometa.
Vse jasno? Pohlep.
Mah, kaj to. Prvi antibiotik je bil odkrit leta 1928, pred tem pa milijone let nič, zdaj pa imamo v samo 100 letih antibijotikov kot blata.
Vse jasno?
  • spremenilo: Kumbaja ()
Massacra ::
Kumbaja je izjavil:
maldic je izjavil:
Vse jasno? Pohlep.
Vse jasno?
Ne tumbaj, če ne veš, kako je na področju antibiotikov.
Koliko jih je bilo na novo registriranih v zadnjih 30 letih?! In kaj so superbakterije? Kaj ja MRSA?
Massacra ::
HappyPills je izjavil:
Ena pripomba: v spomladanskem valu so začeli zbolevati (cepljeni) mlajši v veliki meri in pristajali v bolnicah. Ti načeloma ne doživljajo resnejšega poteka (redko kateri).
Ogromno je faktorjev, ki jih eni pač (namenoma) izpuščate ali pozabljate.
Ko bodo jeseni/pozimi okužbe (ponovno) vdirale v DSOje in bolnice,pa bomo videli, kakšno bo stanje pri starejših zbolelih (in cepljenih).
  • spremenilo: Massacra ()
Kumbaja ::
Kumbaja je izjavil:
maldic je izjavil:
Vse jasno? Pohlep.
Vse jasno?
Pa kaj v 30 letih. V zadnjih 100 letih so bili registrirani vsi antibiotiki kar jih poznamo. pred tem pa MILIJONE LET ni bilo nobenega.
Prospekt ::
Vse jasno? Pohlep.
Pocakaj, da zves kaksne racunalnike so imeli leta 1920 in kaksne imamo danes. Pure pohlep. Eni ste res zabiti kot žebelj.
Kaj ko bi dal linke ter povzetek iz tistih virov... Da ne bo v statistiki priülo do izraza, da so necepljeni..... No sej ves kako so se te podobne "zdrave pameti" zakljucile.
Lokalna firma: 80% folka prot cepljenju. En njihov sodelavec pristal na ventilatorja, še en na intenzivni. Instantno so se vsi prelevili v podpornike cepljenja.
Dejstvo: večina anticepilcem se bo šla cepit takoj ko jim covid zjebe nekoga ki jim je blizu. Pol bo pa cepivo v momentu mana z neba.
Massacra ::
Prospekt je izjavil:
Vse jasno? Pohlep.
Ti sploh nw razumeš, zakaj je testiranje cepiv za humano obravnavo dolgotrajno (4. faze kliničnih študij). In to primerjaš z računalniki. Res si zabit kot žebelj
Pithlit je izjavil:
Nič ne vemo, kakšne pridružene bolezni sta imela ta dva (in morda kompromitiran imunski sistem)! Ne vemo, a sta bila predebela, a sta cugala itd. In ne vemo, koliko jih dela v tej firmi.
Pithlit je izjavil:
Meni je cepivo zjebalo dva blizu, ena oseba v letih, je imela par tednov po cepljenju zastoj srca (nepriznano, "goli slučaj", itd.), in je po velikem naključju še živa, druga, mlajša, si je par dni po cepljenju želela umreti in ne gre po novo dozo.
Na drugi strani pa je ena oseba v letih uradno umrla od covida.
50:50 ? Ne še...
Massacra ::
Mr.B je izjavil:
Linke do kakšnih podatkov? Starostno strukturo hospitaliziranih po tednih? Morda ima sledilnik ta podatek? (sem iskal, a takšnega grafa ne najdem).
Conini ::
c3p0 je izjavil:
Pithlit je izjavil:
50:50 ? Ne še...
Prejšni teden smo imeli enega tukaj, ki je vehementno trdil da jih pozna več, ki so v bolnici, pa čeprav so bili cepljeni in to od cca 50, ki jih je bilo takrat v bolnici zaradi covida.
In baš on pozna ravno tiste, ki so bili cepljeni. :))
Folk, teh izmišljenih tralala zgodbic smo se naveličali.
Jaz sem podal realno stanje, že večkrat povedano. Take it as you will.
Kumbaja ::
ja ja, verjamem, da si že tako daleč, da lastnim pravljicam verjameš.
Jaz pa poznam enega, ki se ni hotel cepit in ga je čez tri dni povozil avto. Vseh ostalih, ki so se cepili pa ni povozilo.
zmist ::
Bellator je izjavil:
Ker tvoj račun ni registriran pred dobrim mesecem? Zanimiv poba si.
Ampak ne govorim samo po covid temah. Kar dela ogromno razliko med nama.
HappyPills ::
Res? Daj link s temi podatki da si preberem, me zanima kaj je na tem. Morda je pa res kaj s cepivi. Kar pogumno, sem odprt do znanstvenih virov.
zmist ::
c3p0 je izjavil:
Pithlit je izjavil:
50:50 ? Ne še...
Ti imas pa res sreco, da poznas osebno toliko primerov.
Mimogrede, sta obe osebi morda brali antivax propagando? Ker prvo je od prestrasenosti morda frslok, druga pa je dobila psihosomatske simptome in ze cutila, kako se nanjo magnetno lepijo avtomobili, kako ji iz glave rastejo antene in jo Gates doggy styla, ko je dobila rahlo vrocino po cepljenju. Ker to bi zelo dobro razlozilo zadevo.
Lahko bi pa tudi uporabil:
friendbreez: "Nič ne vemo, kakšne pridružene bolezni sta imela ta dva (in morda kompromitiran imunski sistem)! Ne vemo, a sta bila predebela, a sta cugala itd. In ne vemo, koliko jih dela v tej firmi. "
Mimogrede, veliki dusebrizniki, a ste kdaj pomislili, kako antivax deluje na ljudi in kaksno kolateralno skodo s svojimi egoisticnimi izpadi povzrocate? Samo retoricno, seveda ne, dol vam visi za vse razen vas.
  • spremenilo: zmist ()
maldic ::
Ce nekdo ve, da je nekaj skodljivo, pa vseeno skusa prepricevat vsak dan druge v to, morda za denar ali kaksno nagrado, je to nekaj najbolj nizkotnega kar obstaja. Se posebi ce zarad tega stevilni izgubijo zivljenje. Pa morda najvec tisti starejsi za katere ideologijo se kao borijo? Te osebe zgleda nimajo kancka socutja do zrtev. Jih tudi zgleda ne zanima, ce so iz njihovih vrst? Po mojem mnenju so morda sociopati ali pa morda kaksna druga psiholoska motnja. Jih pa ne morem obsojat, ker morda niso krivi, da so taksni.
Vemo, da lazejo. Vedo, da lazejo. Vemo, da vedo, da lazejo. Vedo, da vemo, da lazejo. Vemo, da vedo, da vemo, da lazejo.
  • spremenilo: maldic ()
Unchancy ::
maldic je izjavil:
Končno introspekcija antivexxerja. Vsak začetek je težak inu nepopolen. Od tukaj do spremembe vedenjskih vzorcev te čaka še dolga pot posejana s pastmi hitrih testov ampak verjamemo vate.
Na koncu se boš otresel antivexx ideologije in boš postal človeško bitje.
maldic ::
Zgleda so placani po kvantiteti ne pa po kvaliteti. To je vas problem, ker naredite vec skode kot koristi. Kdo za vraga bi se zelel taksnim pridruzit? Sej morda to ni vas glavni cilj, ampak zgolj nabijanje za placilo ali pa morda kako nagrado, obljubo. Ce bi vas res brigalo za ideologijo, bi to poceli s srcem, posteno, iskreno pa morda brez koristoljublja.
maldic ::
Skodo delate ljudem, ki so na vasi strani. Ampak vas ocitno to ne zanima.
Mr.B je izjavil:
Bo šlo.
maldic ::
Premislite, ce se vam splaca. Dost starejsih vas podpira. Ce bo kaj narobe z njimi, jih lahko izgubite. Tisti, ki pa se ne zelijo spikat, pa lahko ze zdaj od njih zgubite podporo. Ampak vazn, da bo se za 1 leto placilo?
Unchancy ::
maldic je izjavil:
Kot kaže smo priča razgrnitvi poslovnega modela antivexxerja. A na letni osnovi ti plačujejo? V rubljih?
maldic ::
ne meci vsa cepiva v isti kos, tudi nekateri avtomobili ne dobijo dovoljenja za iti na cesto. Za izredno odobrena pa je nekaj vec tveganja. Ampak ne, vi pravite, vzemite izredno odobrene avtomobile z nekaj vec tveganja? Ce ga ne vzames si anti avtomobilist?
Unchancy ::
maldic je izjavil:
Na forumu je članek kjer piše da je Pfizerjevo cepivo dobilo odobritev za redno uporabo.
https://slo-tech.com/novice/t789414/0
Aja saj pišeš v to temo buhteljček. Ampak ne veš tega.
maldic ::
Ok, si pogledal zgodovino proizvajalca, ce je do zdaj imel kaksne tezave s spornostjo izdelkov in odskodninami? kaksen sloves imajo?
Unchancy ::
maldic je izjavil:
Ok, si pogledal zgodovino proizvajalca, ce je do zdaj imel kaksne tezave s spornostjo izdedlkov in odskodninami? kaksen sloves imajo?
Ne menjaj teme buhteljček moj slastni.
maldic ::
Kdo jim je odobril? Imajo kaksno povezavo? jaz razumem, da ti lahko ustvaris dva accounta in z enim accountom pohvalis drugega in ga odobravas?
maldic ::
Ugotovili so, da je cepivo 91-odstotno učinkovito pri preprečevanju pojava simptomov in praktično 100-odstotno učinkovito pri preprečevanju smrti.
Ce je to res, se bo kmalu pokazalo v drzavah z nad 80 procentno cepljenostjo. pa lahko primerjamo z njihovimi sosednjimi drzavami, kjer je cepljenja bistveno manj.
maldic ::
Drugac pa vi ste pisali za spikanje ze zdavnaj preden so odobrili tole, tko da je to le izgovor. Tko da moj komentar, kjer sem primerjal z anti avtomobilizmom je kar na mestu.
Pithlit je izjavil:
A te niso starši naučili, da je lagati grdo?
Seveda poznam kar nekaj cepcev, recimo čez prst 50. Ampak niti enega, ki bi se šel cepit zaradi svojega zdravlja ali zdravja drugih.
Popolnoma vsi so se šli zaradi papirja. Za karkoli ga že kdo potrebuje.
LightBit ::
maldic je izjavil:
Pfizer je Microsoft za zdravila. Pri taki paleti zdravil to ni presenetljivo. Tudi za pse cepiva proti steklini delajo.
maldic ::
se enkrat, si pogledal zgodovino, ce so kaksne spornosti in odskodnine? Da to ni presenetljivo? Kaj bos to tudi za korono potem se zgovarjal, da ni presenetljivo?
Unchancy ::
maldic je izjavil:
Oče, Sin in Sveti Duh. Drugače pa preberi članek ki ga komentiraš. Boš izpadel manj butasto.
maldic ::
Ni dovolj prebrat clanek. Si kaj preveril ce je res? Ali samo prebral in zadeva zakljucena? Verjames kar tako, ker je nekdo odobril, pa ne ves nic o njih. Sej tudi nekateri troli tukaj odobravajo in spodbujajo druge v spikanje, ceprav se sami ne bodo.
Unchancy ::
maldic je izjavil:
Ostajam pri prejšnjem odgovoru. Piškotek.
LightBit ::
maldic je izjavil:
Uporaba Microsoftovih izdelkov tudi ni sporna kljub zlorabi monopolnega položaja.
maldic ::
Ne vem kaj ti zdaj omenjas racunalniske zadeve. Tukaj je govora o koroni in spikanju. Aha, dobra logika, ce je microsoft u redu so tudi cepiva. Dobr da vemo. Hvala za tvoj prispevk h kvalitetni debati. Ocitno se vedno nisi preveril zgodovino izdelkov in poslov ali pa se delas, da ne ves.
49106 ::
Zakaj sploh odgovarjaš farmatrolu?
Forum >> teme -- Unchancy
V ZDA Pfizerjevo cepivo proti covidu-19 dobilo redno dovoljenje (strani: 1 2 3 4 5 6 7 8 )
Odgovornost za stranske učinke cepljenja (strani: 1 2 3 4 5 6 7 )
Težko je dobiti transparentne podatke o cepivih (strani: 1 2 3 4 ... 40 41 42 43 )
Hitri test covid cena (strani: 1 2 3 )
Fake vs real news
Visoka precepljenost in učinek zaščite (strani: 1 2 3 4 ... 195 196 197 198 )
Unchancy ::
Tudi ti nimaš nobenih argumentov Mesija? FDA je registrirala Biontech Pfizer cepivo za redno uporabo.
Ne joči Peter.
maldic ::
A nisi pisal v podporo tudi pred odobritvijo? Ne vem zakaj zdaj to tako poudarjas. Ti bi pisal tudi v primeru brez odobritve. Zakaj ze? Ti pa se, ugibam, ne bos spiknil? Drugac pa razisci, ce je ze bilo kaj odobreno pa se je kasneje izkazalo za ne tako pametno odlocitev.
Unchancy ::
maldic je izjavil:
Skoči na glavo s hruške.
maldic ::
Ja, to si ze povedal veckrat. Se ponavljas kot papagaj. Kaj je potrebno normo komentarjev izpolnit? Dejte se rajsi potrudit na kvaliteti. Boste imeli vec ucinka.
Unchancy ::
maldic je izjavil:
If I would get a $ every time antivexxers wrote “it’s an experimental vaccine” - I would be a millionaire.
LightBit ::
maldic je izjavil:
Katera večja firma pa nima spornih poslov?
49106 ::
Dober poskus whataboutisma, razen če želiš povedati, da je firme potrebno razkosati preden postanejo velike.
Če bi dobil evro vsakič, ko waxerji napišete, da cepivo deluje (nekaj trenutkov po temu pa necepljeni me ogrožate), bi bil do zdaj že najbogatejši človek na svetu.
  • spremenilo: 49106 ()
8 / 12
Covid-19: Pfizer v ZDA zaprosil za izredno registracijo cepiva, EU naročila 300 milij (strani: 1 2 3 4 )
17053081 (29720) globoko grlo
Indija prva odobrila DNK cepivo proti covidu-19
139857 (6350) Pithlit
V EU odobrili še drugo cepivo proti covidu-19
2711503 (9741) vostok_1
FDA razgrnila podatke o cepivu podjetja Moderna, v petek bržčas odobritev
4917579 (15169) gus5
