Novice » Znanost in tehnologija » V Sloveniji verjetno odkrili novo različico SARS-CoV-2
Uizi ::
Le čigav klonček je acam. Kdo se skriva za koprivo
Janša bed, ukrepi bed, jaz sem kul, vsi ste neumni! Sadge.
- predlagalo izbris: Markoff ()
showsover ::
Uff, Messiah, to si popušil, kar lepo skesano priznaj :)
Uizi ::
Tekme še ni konec, sam TO je vzel za posvet v kleti.
Markoff ::
Še vedno verjameš v propagando?
Imunost je primerljiva s tisto po cepljenju.
Propaganda:
https://www.researchsquare.com/article/...
https://www.ucsf.edu/news/2021/01/41969...
Tvoji propagandni viri?
Ze dolgo ne zivim vec v Sloveniji in je bil Slo-Tech zmeraj neka povezava z rojstnimi kraji in jezikom zame. Je moj nivo izobrazbe malo previsok in prevec specificen, da bi bil pripravljen zapravljati cas za branje izmisljotin tukaj glede stvari, ki so moja ekspertiza.
Te nič ne moti, da se spuščaš tako nizko na intelektualnem nivoju, da bereš to slotek greznico in sodeluješ v nadaljnjem nižanju nivoja razprave?
- spremenilo: Markoff ()
49106 ::
Jasno, da ne. Poglej datum registracije.
Lupčki oziroma ljubezen vedno zmaga.
Jaz sem proti (prisilni) kleti in proti nesorazmernim ukrepom. A nisi ti tisti, ki se oglaša iz brloga?
- spremenilo: 49106 ()
ajdov2 ::
Propaganda:
https://www.sciencedirect.com/science/a...
These results confirm other recent studies showing that patients who had COVID-19 in the first wave of infections have a significantly lower risk of a later positive PCR test.However, the emergence of a small number of reinfections in December, eight months after the first wave peak, is a cause for concern, suggesting that immunity may begin to wane in some patients around this time. Nonetheless, even with the limited number of reinfections, prior infection still confers a protective effect of 94% over the time of the study. This is equivalent to or better than the protection reported in recent vaccine studies.
https://www.medrxiv.org/content/10.1101...
Conclusions: Reinfection is rare. Natural infection appears to elicit strong protection against reinfection with an efficacy >90% for at least seven months.
https://www.thelancet.com/journals/lanc...
Protection against repeat infection was 80·5% (95% CI 75·4–84·5). The alternative cohort analysis gave similar estimates (adjusted RR 0·212 [0·179–0·251], estimated protection 78·8% [74·9–82·1]). In the alternative cohort analysis, among those aged 65 years and older, observed protection against repeat infection was 47·1% (95% CI 24·7–62·8). We found no difference in estimated protection against repeat infection by sex (male 78·4% [72·1–83·2] vs female 79·1% [73·9–83·3]) or evidence of waning protection over time (3–6 months of follow-up 79·3% [74·4–83·3] vs ≥7 months of follow-up 77·7% [70·9–82·9]).
Protective effectiveness of prior infection was 78.5% (95% confidence interval 72.0 to 83.5), and against symptomatic infection was 83.1% (95% confidence interval 75.1 to 88.5). Protective effectiveness increased over time.
Uizi ::
Ne. Ovce ne živijo v brlogu.
- spremenilo: Uizi ()
uvodV?? ::
zeleni ::
Tak nizka smrtnost pa še vedno strašijo s tem kak bomo vsi pocrkali. Dovolj je tega zapiranja, ki nima smisla.
Treba je živeti s tem, kot z gripo. Poznam par ljudi, ki so preboleli, pa razen par dni glavobola ni nič. Izjeme v bolnišnicah bodo pa vedno. Naj se ne izgovarjajo da ni postelj.
Ti si egoističen idiot. Nizka smrtnost? Umrlo je veliko ljudi, ki so imeli pred sabo še deset let in več. Sosed, ki je vsak dan pospremil vnuka v šolo, delal v delavnici, na vrtu. Okrog hiše je naredil več kot ta mladi.
V treh tednih je padel v komo iz katere se ni več zbudil.
In poznam še nekaj takih primerov. Umirajo večino starejši, kar je logično, ampak tudi ti boš enkrat na temu, da boš končno rešen službe in mogoče boš še poln planov, pa te bojo kar pustili umreti, čeprav bi te lahko rešili. Kako bo to?
Mlajši res preživijo bolje, pa vseeno ne vsi in mnogi s posledicami.
A res ne poznaš nikogar? Greš kdaj iz hiše? Verjetno si se spravil v lockdown že sam pred leti.
Take izjave so žaljive za vse, ki so zgubili očeta, mamo, dedka ali babico. Vedi, da je tudi kak otrok ostal brez starša, ko bi se to dalo preprečiti.
Povej to takemu v obraz, če boš šel kaj iz hiše.
Običajno se ta diversifikacija sevov samo še pospešuje. Še pred koncem leta utegnete biti udeleženih v (danes) bizarnih pogovorih tipa " Si fasal Belokranjca? Ti ne, mam kar Primorca."
Jansini strokovnjaki pravijo, da je bodicasta ograja in dodatki policajem, najbolj poceni resitev.
Na žalost se je celo izkazalo za resnično.
Prištej zraven še zdravstvo, predvsem zdravnike...
CoolBits ::
Medtem v tujini...
https://thetruereporter.com/eu-report-t...
https://www.lifesitenews.com/news/briti...
ravno takšni ste največji egoisti.
acam ::
Medtem v tujini...
Kaksni viri, takoj je ocitno, da so popolnoma so vredni zaupanja. Nekaj danasnjih top novic iz teh cudovitih in objektivnih virov:
"Holocaust survivor claims the horror nowadays is worse!"
"Get your FREE Trump Coin! This coin is a symbol of President Trump's victory and success."
"Trump Is Living Rent-Free In Biden’s Head, And This Clip Proves It [WATCH]"
"“MISS ME YET?” Trump Goes On Hilarious Rant During Wedding Reception At Mara-Lago [WATCH]"
"David Nino Rodriguez Explains Why February 1 Is The Day It All Starts! February is going to be GOOD, he did his own research!" (LOL, nothing happened, vseeno na vrhu strani clanek iz 31.1.)
Nesposoben si kriticno sprejemat informacije, dokler pasejo v tvoj pogled na svet (vaccines bad, trump good). Zato gledas samo te joke spletne strani z novicami, ki ti polnijo mozgane z 100% neumnostmi in kjer je verjetnost, da bos prebral karkoli, kar bo zahtevalo razmisljanje, 0%. Lazje je ziveti v zablodah kot pa sprejeti da je resnicen svet kaoticen.
You are a joke.
But at least you have your free trump coin!
Ko le požegnane, "proper" MSM strani z odobrenimi novicami ne bi bile joke.
antonija ::
Ce najdes en post od zafrustriane mamice na forumu, pa ne najdes trohice podpornih informacij na netu, potem imas dve moznosti:
1. Mamica je top-shit mastermind ki je razkrinkala svetovno zaroto in bo v naslednjih 15 minutah po njo prisel crn helikopter in jo prepeljal v Guantanamo, post bo pa skoraj takoj izginil iz foruma. Vse sledi o njej in o njenem pisanju bojo nemudoma izbrisane, vsako nosljanje strogo sankcionirano. Top-level 007 need-to-know shit.
2. Mamica kotali bucke.
Obe moznosti imata verjetnost vecjo od nic, ampak ena od njiju je zeloooo blizu nicle, druga pa precej blizu 100%.
Isto velja za vse druge "alternativne resnice" ki jih najdete: ce ni poleg zajetnega kupa podpornih informacij, potem sta samo dve moznosti:
1. Razkrinkali ste svetovno zaroto, za katero se celoten svet (~8 milijard ljudi) trudi da _vam_specificno_ prepreci, da to dokazete. Elita bo v naslednjih minutah izbrisala iz neta vsako sled o tej "resnici", in Epsteinala vse vpletene.
2. Nasedli ste na neumnost.
Podobno kot zgoraj imata obe opciji verjetnost razlicno od 0. In pravtako podobno kot prej ima ena od moznosti verjetnost zelo zelo blizu 0%, druga pa zelo zelo blizu 100%.
Zdaj se je pa treba odlocit, kako preckati tole vodo: ali iti po mostu, za katerega vemo da bo 99.997% zdrzal naso pot, ali pa skociti v vodo, za katero vemo da so nase moznosti za prezivetje zelo zelo blizu 0%.
Takolele:
Zdaj se naj bi pa vsak po "zdravi kmecki pameti" odlocil, katera od moznosti se mu zdi bolj smiselna.
P.S.: Lokalni forumski trolli se vedno precej glasno in javno opletajo s tujim kurcem po koprivah, po nobenega se ni prisel crn helikopter, tudi vse njihove "informacije" so se vedno dostopne in seveda se vedno brez trohice podpornih podatkov.
A gremo cez most, al bomo raje poskusili preplavati na drugo stran? Decisions, decisions....
Takolele:
zmaugy ::
Ampak napovedi se pa kar ne uresnicijo ne?
https://fee.org/articles/sweden-saw-low...
Opevana Švedska vs Norveška, Finska, Danska.
1317 mrtvih na milijon (Švedska) proti:
120 mrtvih na milijon (Norveška)
147 mrtvih na milijon (Finska)
414 mrtvih na milijon (Danska)
(teden ali dva nazaj)
Biseri...
neumnosti.
neumnosti.
CoolBits ::
Saj lažeš samo sebi, drugim nemoreš več.
- predlagalo izbris: Uizi ()
zmaugy ::
A res? Pa še vedno si nepismen? V enem letu trolanja bi se ti pa vsaj to lahko popravilo...
Biseri...
neumnosti.
neumnosti.
- spremenilo: zmaugy ()
PersonaRuda ::
Gleda se celo leto. In tako Švedska, Norveška, Danska in Finska je med leti 2015-2020 umrlo podobno število ljudi. Torej ta COVID ni naredil nobene katastrofe ali razlike v več mrtvih od prejšnjih let, niti za +20% ni povečal smrti, kaj šele +200% ali pa kot so v Sloveniji napovedovali +350% več smrti oz. 90.000 mrtvih. To se ni zgodilo. Kot tudi se ni zgodilo, da bi v skandinavskih državah umrlo bistveno več ljudi od prejšnjih let.
Ta podatek je najbolj važen in edini kot merilo.
Mikeobiolog Dr. Miha Vberšek pravi:
Ali se pa lotite in končno že naučite ljudi, da mi ne bodo dihali za ovratnik v nabito!!! polni trgovini. V času, ko sam ob devetih zvečer ne smem na sprehod.
Po opažanjih sodeč, take osebe precej hitro vzpostavijo razdaljo, ko tisti nekdo parkrat zakašlja v svojo masko. In morda še pripomni, da se že cel dan čudno počuti.
To žal deluje le na tistih 17%, ki še premorejo nekaj možgan...
PS: Mikeobiologom ne zaupam ;)
- spremenil: MrStein ()
zmaugy ::
PersonaRuda je izjavil:
V prometu v Sloveniji umre manj kot 200 ljudi na leto. Ukinimo vse CPP, ker je to zanemarljiva številka v primerjavi s stroški kontrol, prometnih znakov in mučenjem ljudi zaradi omejitev hitrosti.
Biseri...
neumnosti.
neumnosti.
Med tem, ko zapiramo fitnese, gostinci po Sloveniji gladko furajo biznis naprej na črno.
Malce se zapeljite po vaseh in se vprašajte zakaj je toliko avtomobilov pred "zaprtim" lokalom.
So precej logični razlogi zakaj pri nas "ukrepi" ne delujejo. Nekaj na papir napisat brez mehanizma, ki bi to uveljavljal je zguba časa in enako bo s tem 10 dnevnim lockdownom. Po možnosti bodo tujci lahko mirno hodili v državo. Absolutno polovičarstvo furamo na vseh nivojih že eno leto
Že eno leto? A si se zatipkal? Polovičarstvo imamo od leta 1990, pa še prej.
Ampak hej, naš "way of life" pa ja ne bomo opustili, al'?
(komu ne paše, lahko kadarkoli gre v Avstrijo - ko naenkrat 100 km/h postane varna hitrost na regionalkah...)
VeganCyclist ::
Dokler bo kultura folka taka kot je, je vse brezveze. Greš mal po mestu, na vsakem vogalu južni bratje brez mask v objemu, rokovanju in kušvanju. V štacunah drug gravž, folk prešlata vse! Zadnjič nisem mogu vrjet, ena ženska je v roke prjela čisto vsak avokado v Hoferju. Vsak. Men je to za pokozlat. Pa mularija, vzame štručke ven, jih mal okol nos in jih potem da nazaj. Potem folk baje polno pije po ilegalnih lokalih. Tko pravjo kolegi. Vsak ve saj za eno beznico, ki je odprta. Potem so parkirišča polna folka s piksnami pira, gorske koče so polne, izletniške točke,... Sploh ne vem kva filozofirate. Slovencu je nacionaln šport, da nategne oblast. Potlačen in zatiran, na skrivaj za vogalom hitro da masko dol in šlukne piksno pera in si misl, kako je Janšo zajebal.
PersonaRuda ::
NE! Prepovejmo vožnjo z avtomobili, avtobusi, vlaki, tovornjaki in več nihče ne bo umrl v prometni nesreči. Vsako življenje šteje!
- spremenil: PersonaRuda ()
zmaugy ::
Ne, ne, CPP so brezvezno zatiranje človekovih pravic zato, da jih je enih par, ki se ne znajdejo in bi se jim itak kaj zgodilo, zaščitenih.
Medtem pa število prebivalcev narašča. Ukinimo CPP! Dol s tiranijo CPP!
/s
/s
Biseri...
neumnosti.
neumnosti.
PersonaRuda ::
Ne, ne, CPP so brezvezno zatiranje človekovih pravic zato, ker jih enih par, ki se ne znajdejo in bi se jim itak kaj zgodilo, zaščitenih.
/s
NE! Prepovejmo vožnjo z avtomobili, avtobusi, vlaki, tovornjaki in več nihče ne bo umrl v prometni nesreči. Vsako življenje šteje!!!
zmaugy ::
/s
Kaj nas briga tistih manj kot 200 na leto. SVOBODA na cestah!!! Dol z zapornicami na železniških prehodih, potovanja so tako dolgočasna!
Biseri...
neumnosti.
neumnosti.
PersonaRuda ::
/s
Ne! Vsako življenje šteje! Ukinit vse, da rešimo čisto vse!
zmaugy ::
Ne dokler se število prebivalcev na Zemlji povečuje!!!!!
/s
/s
Biseri...
neumnosti.
neumnosti.
PersonaRuda ::
zmaugy ::
/s
Vsako življenje šteje. Neglede, če se prebivalstvo povečuje!
Življenje itak sploh ne obstaja!
/s
Biseri...
neumnosti.
neumnosti.
zmaugy ::
All houses matter!
Biseri...
neumnosti.
neumnosti.
PersonaRuda ::
Od Corone je umrlo do sedaj 2,8 milijona ljudi. A vsako leto umre v prometu približno 1,35 milijona ljudi. Temu je potrebno reči STOP. Zgledovat se je potrebno po ukrepih kot to počnemo pri korona-paniki. Vsako življenje šteje. Ukinimo vožnjo z avtomobili, avtobusi, vlaki, tovornjaki, kolesi, skiroji... in vsako leto bomo s tem rešili približno 1,35 milijona ljudi. Vsako življenje šteje. Dovolj je bilo smrti v prometu.
According to the World Health Organization, road traffic injuries caused an estimated 1.35 million deaths worldwide.
VeganCyclist ::
SloTech. Ura je 5 popodne. Folk ze nazgan.
PersonaRuda ::
VeganCyclist je izjavil:
Upam, da si sedaj povezal in ugotovil, da so korona-paničarji že eno leto non stop nažgani, glede na to, da imajo identične ideje pri tej koroni s prispodobo prometa, katerega sem dal opis.
Zdaj je tudi malo bolj logično, zakaj imamo nelogične ukrepe. Krivi so pijani korona-paničarji, katerim je odpovedal razum.
zmaugy ::
Tvoj razum ne obstaja. Ker tudi življenje ne obstaja. All houses matter. Ukinimo CPP!!! You can never take away my freedom!
/s
Biseri...
neumnosti.
neumnosti.
PersonaRuda ::
Klasika pri tebi, ko zmanjka argumentov, začneš preusmerjati temo na čisto druge stvari. Že videli. In jaz tukaj ne mislim sodelovati.
zmaugy ::
Lažeš! Kradeš! Bolhe ješ!!
/s
Biseri...
neumnosti.
neumnosti.
Uizi ::
Zakaj ne smem avta vozit iz zadnjih sedežev? Zakaj moram bit v avtu privezan kot žival? Mi lahko kdo to pojasni prosim?
zmaugy ::
Preklete pizde so se zarotili proti nam, ki hočemo voziti svobodno. Zakaj ne smem biti nudistični voznik?! Pa lepo cukat pivce med vožnjo! Ampak ne, ker zatirajo svobodo in nas hočejo nadzorovat, gnoji reptilijanski!!!
Pa omejitev 130 na avtocesti? Faking dolgčas, jaz hočem vozit vsaj 200 na avtocesti!
Fašisti!!!
Pa še tole - zakaj mi niso dali na izbiro 4G čipov v cepivu?
/s
Biseri...
neumnosti.
neumnosti.
| » | Kako so razvozlali genski zapis koronavirusa?Oddelek: Novice / Znanost in tehnologija | 10019 (6114) | lama56g |
| » | Kaj vemo o britanskem sevu SARS-CoV-2Oddelek: Novice / Znanost in tehnologija | 9108 (6299) | Mr.B |
| » | Sledi za novim koronavirusom vodijo do netopirjev in luskavcev (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 21566 (18659) | carota |
