V Sloveniji verjetno odkrili novo različico SARS-CoV-2
schurda ::
Prosim moderatorja, da zbriše večino komentarjev.
I want to know God's thoughts, the rest are details. (Einstein)
HulkHogan ::
schurda je izjavil:
Izbrisati je treba novico ker navajanje narodnosti v povezavi s korono ni nič drugega kot rasizem, širjenje nestrpnosti, blood libel... potem nas bojo pa na ulicah napadali kot sedaj azijce.
Pozna kdo koga, ki je že fasal Slovenca?
Samo vprašam.
90% države. Temu virusu je ime JJ...
  • predlagalo izbris: schurda ()
antonija ::
Miki N je izjavil:
Samo vprašam.
Lokalni forumski trolli vsako jutro; ce majo sreco celo z vazelinom.
klemenSLO ::
Miki N je izjavil:
Samo vprašam.
Kot mi je znano se brisi naključno sekvencirajo. Informacija o tem, če je tvoj bris bil sekvenciran pa ne pride do tebe.
Wrop ::
Sekvencirajo naključno ter vse na intenzivni + še v nekaterih drugih primerih ((morebitno) ponovno zbolelih).
poweroff ::
Tole sem predlagal za novico, pa se nikomur ni zdelo vredno spisati (jaz se na to področje sicer ne spoznam): https://sciencenorway.no/covid19/norweg...
Norwegian experts say deadly blood clots were caused by the AstraZeneca covid vaccine
"Our theory that this is a powerful immune response which most likely was caused by the vaccine has been found. In collaboration with experts in the field from the University Hospital of North Norway HF, we have found specific antibodies against blood platelets that can cause these reactions, and which we know from other fields of medicine, but then with medical drugs as the cause of the reaction", the chief physician explains to VG.
Norveški znanstveniki trdijo, da ravno cepivo povzroča strdke:
"We have the reason. Nothing but the vaccine can explain why these individuals had this immune response", he states.
VG also asks how Holme can know that the immune response is not caused by something other than the vaccine.
"There is nothing in the patient history of these individuals that can give such a powerful immune response. I am confident that the antibodies that we have found are the cause, and I see no other explanation than it being the vaccine which triggers it", he responds.
Brez zamere, ampak to se mi zdi vredno novice.
sudo poweroff
HulkHogan ::
poweroff je izjavil:
V "dark ages" so tudi eni mislil da je vredno novice odkritje da nismo v centru vesolja. K sreči se je take krivoverce na hitro pozdravilo takšnega zmotnega mišljenja.
belimato ::
Eppur si muove.
GenZNPC ::
GenZNPC je izjavil:
Ze nekaj casa nisem vprasal, ce so ze potrdili balkanski sev? Baje tudi en kraski se naj bi pojavil, ta je se hujsi od angleskega in predvsem agresivnejsi.
Ne seri. Dosti brezveznega blebetanja brez kredibilnosti.
Kje pa skrivas kredibilnost za svoje blebetanje? V javnih medijih in manipuliranih studij s strani politike?
skibidi
rusilec ::
V Izraelu, kjer je cepljenih največ, imajo zaradi tega in še enega učinka cepiva (vnetje srčne mišice), smrtnost zaradi cepljenja okoli 400x večjo od smrtnosti virusa. Linkov ni, tole je edino, kar sem našel na "uradnem" internetu:
https://med.over.net/forum5/viewtopic.p...
acam ::
rusilec je izjavil:
Ce nek neberljiv post random neizobrazene mamice na MED OVER NET forumih pravi tako, potem mora biti res! You got them, the pharma is trembling in fear!
Si "diplomiral" iz spammanja linkov iz facebooka in youtuba na spammanje lazi iz kategorije teorije zarot na med over net forumu :))
Slo-tech je postal zalost, pogresam dobre stare case filozofiranja Thomasa in zanimivih diskusij. To je sedaj conspiracy boomer facebook 2.0, samo se bolj izoliran od realnosti. Vsaka tema je takoj zaspamana z desetinami objavami norcev, ki na vsak nacin poskusajo siriti svojo verzijo norosti.
HulkHogan ::
acam je izjavil:
Večina ljudi postane jeznih in depresivnih ko se pojavi kdo ki podre njihove peščene gradove.
Največji borci za raznolikost bi radi cenzurirali vse ki si drznejo misliti drugače od njih samih.
acam je izjavil:
Ali pa slepo slediš ukrepov vlade, ki jih sprejme premier nepriznane fakultete v tujini ?!?!?!
On je ziher strokoven.
ZA večino članov "strokovnih skupin" pa do zdajšnje vlade sploh slišali nismo. Kar o "strokovnosti" veliko pove...
matter ::
Večina strokovnjakov tule pač ne more razumeti, da je vsa težava v pritisku na bolnišnice in NE smrtnost sama.
In sedaj se kaže trend (tudi glede na sosednje države) da je hospitalizacija večja kot prej in bolj hitro narašča sama hospitalizacija.
In visoka hospitalizacija pomeni, da se težje obravnava redna bolezenska stanja in posledično dodatne smrti tudi zaradi tega.
Še več jih pa ne razume, da JJ ne sprejema ukrepe, ampak jih vlada na podlagi predlogov. Vlada, ki je LEVO/DESNA!
Če tule bereš je JJ mojster za vse. Pa nisem njegov fan in odprem šampanjec ko se upokoji.
Grem basket pa bom neloke metal
matter je izjavil:
Kar je laž, ker tako hitro kot zdaj prideš na vrsto, nisi še nikoli.
Odvisno za kaj. Rakavi bolniki že šesti mesec čakajo na redno kontrolo. In upajo, da je vse ok, se pravi, da se ni kaj ponovilo.
ajdov2 ::
matter je izjavil:
Pejt na sledilnik in poglej kako so hospitalizacije naraščale jeseni in kako naraščajo zdaj, pol pa razmisli a je res večji pritisk na bolnišnice.
Invictus je izjavil:
A grosupeljskega še niso našli?
Ta je pa že od leta 1991 z nami.
Za mizo sedita hojs in janša pa se na glas smejita.
Pridruži se jima počivalšek: "kaj je tako smešno."
hojs: Zaprli bomo 2 milijona slovencev in eno zebro.
počivalšek: zakaj pa zebro?
janša: vidiš hojs, nobenega ne zanima 2 milijona slovencev.
poweroff ::
rusilec je izjavil:
Brez zamere, ampak tole na med.over.net se mi zdi čisti bullshit. Tista novica iz Norveške pa je precej bolj kredibilna in zato potrebna objave.
Ker če ne se zgodi točno tole. Dol se tišči verodostojne kritične novice, to pa potem daje zagon teoretikom zarot, ki širijo neverodostojne in lažne novice.
sudo poweroff
antonija ::
EMA je rekla:
"We have to look at the results first, I don't want to comment on this now"
Kar je edino pravilno. Ko bodo vsi podatki na voljo, se jih pogleda skupaj z vsemi drugimi znanimi podatki, potem se pa na podlagi teh odloca kako naprej.
EMA (in druge zdavstvene agencije) so precej dovzetne za podatke o porocanju nezelenih ucinkov in jih redno spremljajo. Pri izrednih odobritvah je farmakovigilanca strozja v primerjavi z dovoljenji za promet, zato agencije po svetu pridno zbirajo vse podtake in jih ves cas evaulirajo.
Hkrati bi bilo lepo omenti da gre za izjemno redek pojav:
These are rare cases – around 20 million people in the UK and EEA had received the vaccine as of March 16 and EMA had reviewed only 7 cases of blood clots in multiple blood vessels (disseminated intravascular coagulation, DIC) and 18 cases of CVST. A causal link with the vaccine is not proven, but is possible and deserves further analysis.
To je priblizno 2.5 primera v nasi drzavi ce se cepi celotno slovenijo (skupaj z mladoletniki).
Zaradi nizke pojavnosti je zelo zelo tezko ugotoviti dejanski vzrok, vsaj dokler kdo ne predlaga mehanizma po katerem naj bi se to zgodilo. Norveski zdravnik ga ni predlagal, glede na novice je naredil korelacijo med lastnostmi obolelih in simptomi. Korelacije so pa... samo korelacije:
To bo material za novico _CE_ se iskaze da trditev zdravnika drzi, da gre pri cepljenih z AZ cepivom res za statisticno odstopanje od normale. Ce kdo zdraven doda se mehanizem po katerem se to zgodi in razlago zakaj samo pri AZ cepivu, pri drugih pa ne, skupaj z rezultati poskusov kjer je to dokazal, potem bo pa celo za en znanstveni clanek.
Do takrat je pa vse skupaj rekla-kazala.
EDIT: Razen ce si imel v mislih "novico", kjer se nekriticno objavi vsako neumnost ki jo kdo izrece, potem se pa "pozabi" izdati popravke, preklicati novico in se opraviciti za neumnost, itd. Pa tudi ce bi, bi bilo verjetno ze prepozno. Se vedno najdes en kup debilov ki verjamejo da cepiva povzrocajo avtizem, kljub temu da je originalni avtor clanek umaknil in se zanj opravicil.
To pa potem sprozi vse mogoce teorije zarot in druge debilizme, ki smo jim prica tudi v tej temi.
Zato je iMO bolj smiselno da bi z objavo novic pocakali dokler ni dejansko znano ali je to novica ali napaka/laz zdravnika.
  • spremenilo: antonija ()
HulkHogan ::
rusilec je izjavil:
Kontrolirana opozicija. Zato pa te takoj napadejo z 5G ko rečeš da zdravstvo in politika ne delata v dobro ljudi ampak samo copy/pastajo Bil Gejtsove napovedi apokalipse.
OmegaM ::
Verjetno imam virozo, ampak je v tem času zagotovo COVID :D
Ni nam lahko, bo pa boljše!!!
  • spremenilo: OmegaM ()
snq819 ::
FastWIND je izjavil:
Mikeobiolog Dr. Miha Vberšek pravi:
Ali se pa lotite in končno že naučite ljudi, da mi ne bodo dihali za ovratnik v nabito!!! polni trgovini. V času, ko sam ob devetih zvečer ne smem na sprehod.
Po opažanjih sodeč, take osebe precej hitro vzpostavijo razdaljo, ko tisti nekdo parkrat zakašlja v svojo masko. In morda še pripomni, da se že cel dan čudno počuti.
Looooooka ::
Med tem, ko zapiramo fitnese, gostinci po Sloveniji gladko furajo biznis naprej na črno.
Malce se zapeljite po vaseh in se vprašajte zakaj je toliko avtomobilov pred "zaprtim" lokalom.
So precej logični razlogi zakaj pri nas "ukrepi" ne delujejo. Nekaj na papir napisat brez mehanizma, ki bi to uveljavljal je zguba časa in enako bo s tem 10 dnevnim lockdownom. Po možnosti bodo tujci lahko mirno hodili v državo. Absolutno polovičarstvo furamo na vseh nivojih že eno leto vmes se pa spet zadolžujemo, ker očitno prejšnje kredite z lahkoto odplačujemo...
Da fiaska s cepljenjem sploh ne omenjam. Kmalu bomo najslabši na balkanu.
HulkHogan ::
Looooooka je izjavil:
Glede na to da smo izkoreninili gripo bi rekel da ukrepi delujejo.
HulkHogan je izjavil:
Če pa so pa vsakega, ki je imel gripo in prišel h zdravniku jokat, spoznali za okuženega s covid-19.
antonija ::
WizzardOfOZ je izjavil:
Ne ga niso. Jaz in moja druzina smo bili na 7 testiranjih zaradi simtomov prehlada/gripe, pa je bil test vsakic negativen, posledicno ni nihce od nas kategoriizran kot oboleli za Covidom.
Sej se vsi strinjamo da je zdravstvo ob tejle pandemiji naredilo kar nekaj brc v temo, ampak lagat pa res ni treba.
Ne nabijaj.
Po telefonu so diagnosticirali Covid, ko je kdo poklical, da ima vročino. Zgleda telepatska diagnoza...
antonija ::
Ne nabijaj. Ce so ze kaj naredili preko telefona so te narocili na testiranje.
Nope, kar diagnoza Covid in 14 karantena, ko je še bila...
Tebi marsikaj ni jasno. JJ ne da svoje janezka za vsako frčafelo...
antonija ::
Nope, diagnoze covida in karantene ni preko telefona. Pozitiven test in/ali rizicen kontakt je razlog za karanteno.
darkolord ::
Lansko leto je bilo res prek telefona.
antonija ::
Lansko leto sem tudi jaz fasal samoizolacijo preko telefona, ker je imela hcerka pozitivno vzgojiteljico v vrctu, jaz sem se pa slabo pocutil. Sicer sva kaksen dan kasneje oba imela negativen rezultat testa, tako da ubistvu vse kar so naredili preko telefona je bilo narocilo na Metelkovo in pa samoizolacija.
To ne pomeni, da sva jaz ali moja hcerka bila klasificirana kot obolela za Covidom.
Kriticen stik se pa lahko komot oceni preko telefona.
belimato ::
Vsi delajo na črno, vsi po lokalih, a smrti daleč od napovedanih 90000 doktorja? Torej očitno stroka ni ravno na mestu, rada pretirava in straši, drugače nekaj ne štima?
poweroff ::
darkolord je izjavil:
Ja, to se vsi spomnimo teh zgodb. In če potem nekdo, ki je zagovornik cepljenja in znanstvenega pristopa h bolezni taka očitno preverljiva dejstva zanika, to ruši kredibilnost celotnemu znanstvenemu pristopu h bolezni.
antonija je izjavil:
Ne razumeš problema.
Govorim o tem, da tukaj o stranskih učinkih ni pisala ena tetka na med.over.net, pač pa je problem resno izpostavila ugledna znanstvena organizacija.
Zato se mi zdi smiselno napisati:
a) ugledni znanstveniki so opozorili na problem
b) kar zagotovo vemo je tole: XXXXX
c) potrebne so dodatne raziskave, kjer se bo ugotovilo tole: YYYY
itd.
Ker še enkrat, ni to mnenje neke tetke, pač pa znanstvenikov. In skrivanje informacij z dobrimi nameni dela samo škodo in podžiga teorije zarote.
sudo poweroff
antonija ::
https://www.ema.europa.eu/en/news/covid...
(pa siguno je se kaksna objava)
Nic ne skrivajo, podatki se objavljajo ko so na voljo. So pa to podatki ki jih lokalni mediji ne bojo objavili, ker niso dovolj senzacionalisticni. "Novinarji", jebiga.
GenZNPC ::
Zaradi novega seva v Sloveniji predlagam vladi, da se Slovenijo popolnoma zapre, da ne mores nikamor ven. Brez izjem, dokler ni precepljeno vsaj 50% prebivalcev.
Bodicasto ograjo zaradi migrantov razsirit po celotni drzavni meji.
Sem poslal Jansevim strokovnjakom predlog, kot sostrokovnjak.
Mejne prehode pa zapret in zabarikadirat. Ce hocejo Avstrijci/Nemci na Hvarsko, lahko grejo okoli ali pa z letalom preletijo drzavo.
skibidi
CoolBits ::
Zakaj nebi kar nekaj bomb vrgel na središča, hitreje in predvsem ceneje.;((
GenZNPC ::
Jansini strokovnjaki pravijo, da je bodicasta ograja in dodatki policajem, najbolj poceni resitev.
skibidi
Sakin ::
rusilec je izjavil:
Jaz pa živim tu, bil sem cepljen in ti povem da nakladaš.
Na Nach Nachma Nachman Meuman!
Markoff ::
Čisto mogoče, da jih. Ampak verjetnost, da jih fašeš v terminalni obliki, je, koliko, 1 na milijon? COVID-19 je trenutno na 3% globalne smrtnosti znanih primerov. Pri delujočih zdravstvenih sistemih. Pri nedelujočih ca. 10%, kar sta lepo pokazala Wuhan in Bergamo. Asimptomatskih prenašalcev naj bi bilo do 25% max. Plus vsake pol leta nova okužba, imunost po prebolevanju je kratkotrajna in šibka.
I'll take my chances s tem AZ blood clot sranjem any day of the week.
rusilec je izjavil:
To je nekje na ravni te "resnice":
 Odnamestimo IE za večjo varnost!
  • spremenilo: Markoff ()
ajdov2 ::
Markoff je izjavil:
Še vedno verjameš v propagando?
Imunost je primerljiva s tisto po cepljenju.
acam ::
acam je izjavil:
Tudi ljudje v bolnisnicah se mi smilijo, tudi tisti v psihiatricnih. In nisem preprican, da mi te rusijo kaj prevec gradov.
Ze dolgo ne zivim vec v Sloveniji in je bil Slo-Tech zmeraj neka povezava z rojstnimi kraji in jezikom zame. Je moj nivo izobrazbe malo previsok in prevec specificen, da bi bil pripravljen zapravljati cas za branje izmisljotin tukaj glede stvari, ki so moja ekspertiza.
acam je izjavil:
Sori, ze vec kot 10 let ne zivim v Sloveniji in mi je relativno malo mar za vase klovne in ukrepe, ker se me ne ticejo. Mi pa veliko pove o tvojem intelektualnem nivoju, ko je vrhunec tvojega odziva na nepoliticen post poskus diskreditacije prek asociacijemz random slovenskimi politiki.
  • spremenilo: acam ()
ajdov2 ::
Zakaj pol pametuješ o naših ukrepih, če ne živiš tukaj, ne poznaš zadeve in trdiš da se te ne tiče??
acam ::
ajdov2 je izjavil:
Kje pametujem o vasih ukrepih?
Uizi ::
@acam takle mamo v našem peskovniku, če si pameten se ne vračaj. :))
49106 ::
Le čigav klonček je acam. Kdo se skriva za koprivo
  • predlagalo izbris: Markoff ()
Kako so razvozlali genski zapis koronavirusa?
2210050 (6145) lama56g
Kaj vemo o britanskem sevu SARS-CoV-2
199198 (6389) Mr.B
Sledi za novim koronavirusom vodijo do netopirjev in luskavcev (strani: 1 2 )
9022352 (19445) carota
