Counter strike GO terminal
Jerry000 ::
Živ. Zanima me ker ne najdem na spletu, kakšne so komande ko igraš nek custom map iz workshopa, da ni botov sem našel, ampak za restart igre pa nikjer ne najdem in morem vedno ven iz igre in nazaj v igro.
Torej:
Remove bots - bot_kick
m0f0x ::
Če je to rešitev na tvoje vprašanje, potem slabo iščeš.
mp_match_restart_delay
*mp_match_restart_delay [Seconds]
**This command sets how long it takes, in seconds, for a match to restart. This countdown is used at the end of a match, not when the mp_restartgame command is used.
mp_restartgame
*mp_restartgame [Seconds]
**This command will restart the game. If you specify a number as a parameter, this amount of seconds will be counted down before the restart happens.
https://totalcsgo.com/commands/multipla...
https://dathost.net/blog/2016/08/13/csg...
Survarium
Oddelek: Igre
123609 (1851) oo7
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485655 (4203) Gray_Warden_
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
7110020 (8442) Tilen
Trojan W32.IRCBot.F
61683 (1582) Tear_DR0P
Pomoč pri MySQL in PHP...
Oddelek: Programiranje
162400 (2268) darh
