NVIDIA Lovelace (GPU 5nm)
FlyingBee ::
Najprej preskok v proizvodnjem procesu potem pa v arch.
New Sphincter Kvartet:
Buggy ::
Novi Nvidia driver 531.61 stare tezave...dodali podporo za 4070, dolgotrajni problemi ostajajo isti. NV epic SW team razmislja sirse: RT_hog, DLSS3.0_fake frame, seznam napak pa je vedno daljsi
Open Issues
Toggling HDR on and off in-game causes game stability issues when non-native resolution is used. [3624030]
Monitor may briefly flicker on waking from display sleep if DSR/DLDSR is enabled. [3592260]
[Halo Wars 2] In-game foliage is larger than normal and displays constant flickering [3888343]
[GeForce RTX 4090] Watch Dogs 2 may display flickering when staring at the sky [3858016]
Increase in DPC latency observed in Latencymon [3952556]
Applying GeForce Experience Freestyle filters cause games to crash [4008945]
Event Viewer logs nvlddmkm error at the end of the OCCT video ram test when memory is full [4049182]
[Surface Book/Surface Studio] Dedicated GPU stuck at lowest clock speed when notebook is running off of battery [4063597]
After updating to R530 drivers, certain GeForce RTX 40 series notebook models may randomly experience a TDR/black screen [4024853]
[Solidworks] Models may not render properly when "Enhanced Graphics Performance" is enabled from the application settings [4050712]
Small checkerboard like pattern may randomly appear in Chromium based applications [3992875]
...z novimi driverji pri meni v DR 2.0 stuttering fest na 3080...na starih je ok...well done NV.
  • spremenil: Buggy ()
Meizu ::
RedDrake je izjavil:
Smo pa daleč prišli v teh 20 letih.
Takrat je bil cutting edge po $400, danes je 400-500% več.
Inflacije je bilo v tem času cca 70%, s tem da je top range AMD CPU leta 2002 stal $420 (;(() danes pa stane $699 kar je, glej glej ravno toliko kot je inflacije.
Jasno je, kdo nas nateguje ...
Evo končno nekdo, ki pove kako je.
mahone ::
Takrat je bila povprecna neto placa 130-140k sit? Geforce 3 Ti 500 se je prodajal pa za dobrih 120k SIT. ATI je imel 8500 za 70k SIT
  • spremenil: mahone ()
Meizu ::
Kupna moč in cena na trgu ni glih primerljiva.
mahone je izjavil:
No vidis, zato ker nas lahko.
Furbo ::
A ima kakšna 4080 ali 4090 4 ali več let garancije?
Ena Gigabyte vem da ima, morda še kaka druga firma?
Senior Dev ::
Gigabyte Gaming OC imajo 4 leta. So kar solidne karte, neki srednji kakovostni in cenovni razred.
yayo ::
Ravno gledam, Gigabyte 2070 Super katero sem kupil maja 2020 in prodal leto kasneje je v garanciji do konca januarja 2024. Je potrebno registrirat za podaljšano garancijo. 3080 Suprim X od MSI pa le dve leti, "ker je kupljena v tujini" (Amazon.de) Mrš! ;(
Meizu ::
Tisto je samo garancija, če jo uveljavljaš pri prodajalcu. Za dejansko polno garancijo moraš vedno preverit pri samem proizvajalcu.
Nvidia tudi za serverske karte daje samo 3 leta garancije ... kr grozno.
yayo ::
Meizu je izjavil:
Sem, MSI ima neko kurčevo politiko, če ne kupiš lokalno.
"Depending on territory regional differences may apply. Please inquire with the original shops"
Original shop ja Amazon, Amazon pravi dve leti.
  • spremenil: yayo ()
Meizu ::
2 leti je zakonski minimum v EU, manj ne smeš dajat. Več pa tudi ne rabiš. Torej kupiš neko drugo opcijo.
NVIDIA GeForce RTX 4060 Ti 8 GB menda enkrat konec maja.
Kr naj imajo 8GB grafično za 500€.
Dvomim, da si bodo upali msrp postavit nad 399$. 449$ je zagotovo zgornja meja. Če bi moral stavit, bi rekel 429$.
  • spremenil: DarwiN ()
Meizu ::
Še vedno, 429usd za 8GB rama, naj si jo vtaknejo v analno odprtino. Brez vazelina.
Če se spomnimo, GTX 1070 je imela 8GB VRAM-a in je sredi 2016 stala 379$. Sicer je bilo vmes nekaj inflacije, ampak je profitno naravnana strategija nVidie dokaj očitna. Glede tega je bila RTX 3060(Ti) z 12GB korak v pravo smer, brez kriptomanije bi navadna verzija stala tam 330$.
RX 580 je imel 8 Gb RAMa in si ga dobil za dobrih 200 EUR.
Sicer pa ni zgolj nVidija izkorisila priloznosti. Mleko, kruh, olje in mnogi drugi prehrambeni proizvodi so se v kratkem casovnem obdobju podrazili za 50%, istocasno pa drzave omejujejo uvoz za zascito lokalnih kmetov. Zal bo kup spekulantov mastno zasluzilo.
  • spremenilo: tikitoki ()
Samo mleko in kruh rabiš, grafične pa pač ne. Pa še pri hrani se začenja poznati, da so pretiravali s dvigom. Problem je ker vsakič, ko proizvajalc dvigne, vskoči še trgovina in tudi ona dvigne % marže. Potem pa folk zaradi dvojne cene manj kupi in roba ostaja. Kar naenkrat je polno akcij -40%, -50%.
Tudi Nvidia in AMD bosta dobila reality check, če ne bo kakšen AI boom spet pobral ves silicij.
  • spremenil: Magic1 ()
Senior Dev ::
Za nove AAA naslove je 8GB res malo premalo, ampak moramo razumeti da te naslove igra manj kot 10% vseh igričarjev. Za 90% pa je 4GB VRAMA več kot dovolj. Na Steamu si lahko pogledate da je 70% igralcev na 1080p ločljivosti. In naslednja, ki sledi ni 1440p kot bi si mislili, pač pa 720p. Toliko o tem šponanju in merjenju tičev okoli rama.
Seveda pa to ne pomeni, da je brezveze igrat Hogwarts Legacy ali kaj podobnega na 4K. Pač se je treba sprijaznit, da ti bo igra požrla 20 giga grafičnega spomina in imel boš kar lep latency na 50 fps. Izkušja zanič četudi imaš RTX 4090.
mailer ::
Na koncu koncev se bo folk začel spraševat če je res problem v grafičnih ali dejansko v igrah.
Počasi je folku že konkretno jasno, da je v grafičnih problem. Za nezahtevne igre ne rabiš nove grafične, je 5 let stara čist ok. Zakaj bi kupil grafično za 500EUR+, če igraš "nezahtevne"/stare igre?
PS5 ima šfoh grafično moč pa ima na razpolago 12GB spomina. Nove igre so začele prihajat za izključno nove konzole in so programerji rekli klinc gleda 8GB. Nvidia pa kar vztraja.
Seveda je lahko tudi v igrah problem, sploh s hitenjem in prepustijo, da trg testira.
Senior Dev ::
Problem je v igrah. Spacajo skupaj nekaj na hitro ker so že 3x preložili release in potem zadeva teče zadovoljivo samo na RTX 4090, včasih še to ne.
GenZNPC ::
Danes paca vsak bumbar igro skup v nekem dragndrop enginu, ni cudno da modeli pozirajo nenormalne kolicine rama.
Oz. ene igre konkretno vec kot druge, pa tega ni nikjer videt, ker je v spominu neoptimiziran balast.
Saj je vsepovsod isto. Vedno vec featurjev, ampak vse nekam na pol narjeno.
skibidi
Otroci, starate se.
Vprašajte se drugače: kateri je bil zadnji popoln špil? ;)
Sej je dost jasno, kaj se dogaja. Nvidia ima skorajda monopol in namerno ponuja čim manj VRAMa za čim višji dobiček. Povrh tega planned obsolescence VERJETNO sploh ni teorija zarote od AMD boysov. Danes kartice "zdržijo" vsaj 5 let in Nvidiji pride še kako prav, če bo že prej zmanjkalo VRAMa in bodo ljudje prisiljeni kartice nadgradit čez 3 leta namesto 5.. To avtomatsko pomeni PRECEJ višji dobiček za Nvidijo.
No, po drugi strani pa obupani AMD nima kaj ponudit in se takorekoč bori za lastno eksistenco na dGPU trgu, zato bo na kartice "zlepil" čim več VRAMA in bo to njihova največja in edina prednost, poleg nižje cene, seveda.
Čeprav 7600 serija ima menda kljub temu le 8gb.. 16gb bi bilo absolutno preveč, vmesne izbire pa nimajo, I guess. Je pa precej možno, da mal kasneje ponudijo tudi 16gb različice 7600XT.
DamijanD ::
pegasus: tetris
Damijan, potem moraš pogledat nov film Tetris. Sicer ne vem, kolk je dober, ampak če si fan ...
pegasus je izjavil:
Otroci, starate se.
Dober primer je WoW: Burning Crusade. Nihče ni razmišljal o tehnikalijah, igralo pa ga je na milijone igralcev naenkrat in tudi takrat, ko so imeli na voljo druge "PC master race" alternative.
Drug primer je Mass Effect trilogija, kjer je štimalo skoraj vse.
Več ne bom našteval (Witcher...), ker so okusi različni. Marsikdo poreče tudi Fortnite oz. Minecraft...
FlyingBee ::
Očitno gremo na 3 leta
Nvidia's forthcoming 3nm GPUs, anticipated to be crafted via the TSMC 3nm chip procedure, will not be hitting the market until 2025, as reported by insider sources.
Ali pa 2 leti in 3 mesece... Od oktobra 2022 do januarja 2025. ;)
FlyingBee ::
Možno, je pa bolj verjetno spomladi 25.
DarwiN je izjavil:
Star Wars Jedi: Survivor dela ok na 8 GB kartici, če ima več ? toliko bolje…
8GB je zunaj skoraj 9 let.. vmes je prišel dlss in Rt… nehaj… Če naložiš kvalitetne teksture pač pokurijo ram..
Če hočeš da si nategnjen kupiš prenosnik z mobilno verzijo 40x0 kartice in pričakuješ enake rezultate, da si ravno karica je bolj -10 verzije. Tako da 4090 je bolj 4080 ki je bolj 4070 ki je bolj 4060.
RTX 4070 12 GB je DOE moraš biti resnično off da nebi izbral 6950 XT z koliko dodatnih iger za cca 50€ več.
RTX 4060 je DOE za/če 400$ ker pride RX 6700 (Non XT) za 340€ oziroma XT je +40€. in to je toliko kot RTX 3060 Ti , ki si jo kupil zaradi RT v imenu.
V bsitvu se nobenemu ne hiti...
DOE - Depends On Experience ?
Se strinjam. Če te ne motijo random BSODi, potem je Radeon odlična izbira. :)
Sicer pa, če je 8gb res samo še za v smeti, potem se bodo kartice slabo prodajale in bo cena padala, plus rabljena roba bo šla za đabe. Jaz z veseljem vzamem 4060Ti za ~300EUR. Nismo vsi gamerji, sploh pa ne razvajenci s first world problemi. Zame so medium in ultra detajli isti šmorn. :D
Pa poglej Steam chart, koliko ljudi še naprej veselo uporablja tudi 6Gb GPUje. Včasih je manj več! (upam da Huang ne ukrade tega mojega slogana :D).
DarwiN je izjavil:
Da malo sem pa moral dati veselja...
DarwiN je izjavil:
O čem ti to govoriš? Moja stara radeonka je včasih vključila blower in to je bilo to v 8 letih, dela pa še danes.
Trenutna navi je stabilana kartica, navadno račune prekriža izpad elektrike, sicer računalnik dela ali spi 24/7.
Nekateri nVidia fani so to tudi sami pogruntali in je sedaj poglaviten argument RT performance, FYI.
Malo sem v šali pretiraval, zato tudi smiley. Ampak hkrati je tudi dejstvo, da ima Nvidia bolj dodelane driverje in software sploh.
Vprašaj ChatGPTja:
AMD has been known to have more frequent driver issues...
Nvidia, on the other hand, has generally been more consistent with their driver releases...
Case closed. :D
Sem vprašal o fanbojčikh, pa je tudi izvrgel:
In some cases, fans of one brand may engage in negative behavior towards fans of a competing brand, including making false or exaggerated claims about the quality or performance of the other brand's products.
Pol pa nehaj izkazovat simptomov fanboyizma. Isti si kot tiki. ;)
Samo logično pomisli. Kako naj ima AMD primerljiv software z Nvidijo, ko je AMDjev tim sestavljen iz treh nesojenih študentov, Nvidija pa ima zadaj celo armijo.
FlyingBee ::
verjetno se jim v prodaji tudi kaj pozna
FlyingBee ::
Mr.B je izjavil:
DarwiN je izjavil:
RTX 4070 12 GB je DOE moraš biti resnično off da nebi izbral 6950 XT z koliko dodatnih iger za cca 50EUR več.
RTX 4060 je DOE za/če 400$ ker pride RX 6700 (Non XT) za 340EUR oziroma XT je +40EUR. in to je toliko kot RTX 3060 Ti , ki si jo kupil zaradi RT v imenu.
saj bo... AMD sponsored title! star-wars-jedi-survivor-receives-first-patch-on-pc-today-respawn-entertainment-issues-apology-message
https://www.techpowerup.com/308060/star...
part of W1zzard's conclusion was very unkind: "We're now paying $70 to beta-test an unpolished turd that they call an AAA game—not the first time this year. I'm starting to wonder if these companies aren't slowly eroding their customer base by delivering broken products over and over again."
recimo, da je 12gb vrama dovolj
Ja 12GB bo dovolj za nekaj časa. Že zato, ker imajo konzole nekaj takega dodeljeno. Če menjaš na dve leti, potem sploh ni problema. Sam 8GB bo(je) pa problem zelo hitro, če ne furaš samo old stuff. Samo na PC načeloma pričakuješ boljše teksture, kot na konzolah... V primeru 4070(Ti) boš imel v najboljšem primeru iste. Tudi stari mački programerji odhajajo v penzijo oziroma na vodstvena mesta. Mladi pa uporabljajo razne "knjižnice", kar je daleč od optimalnega in kuri plac na veliko. S tem da se spomin na grafični lahko uporabi še za marsikaj, tudi RT ga ekstra pobere.
Ni mi pa jasno, zakaj rudarske grafične ne preplavijo trga. 3000 serija še kar drži ceno. A še upajo na BTC to the moon, elektrika pa dol?
DarwiN je izjavil:
Vprašaj ChatGPTja:
Case closed. :D
Tak, sam hiso moras dobro zavarovati pred pozarom in je nVidija idealna:)
Magic1 je izjavil:
Dobro vprasanje. Nekateri so prodali rudnike, vleiko pa jih ocitno caka na cudez.
DamijanD ::
Če ste zelo spretni in imate opremo, se da 3060ko z 8GB predelati na 3060 z 12GB
Zakaj bi 8GB kupoval, če je 12GB 20€ dražja? Bolje bi bilo, če bi se 3070 ali 3080 dalo nadgradit. Druga verjetno niti ni problem.
mailer ::
DamijanD je izjavil:
Oprema stane večkratnik kartice.
Sploh ni težava oprema. Možnost da boš vse uničil brez izkušenj, je blizu 100%. To so 8 ali 10 plastni PCBji in so res žur segret.
DamijanD ::
Itak itak, mišljeno bolj kot šala kot pa neki resni predlog.
Mr.B je izjavil:
Mimogrede, marsikomu dol visi za Ray Tracing.. DLSS je tisto, kar predstavlja večjo prednost. Takorekoč gratis fps-ji.
Je HArdwareUnboxed naredil zanimivo analizo DLSS2 vs FSR2. Rezultat je sicer težko kvantificirat in je do neke mere subjektiven, ampak je vseeno vse po pričakovanju. Seveda se AMD s svojo SW rešitvijo ne more kosati proti Nvidijini HW rešitvi. Šokantno, kaj? FSR je zunaj predvsem zato, da se naredi meglo češ, saj pa mi tudi ponujamo upscaling. Enim je bolj všeč DLSS, drugim pač naš FSR.. Isti šmorn. :)))))
Ampak v realnosti je DLSS jasno daleč spredaj. Rezultat HU analize: (vidiš na tabeli kje kaj rdečega?)
55 / 80
Nvidia predstavila RTX 4070 (strani: 1 2 )
6516497 (11173) FlyingBee
Nvidia še pred izidom umaknila in preimenovala RTX 4080 12 GB (strani: 1 2 3 )
10118981 (14628) FlyingBee
Cene nVidia kartic na trgu danes (strani: 1 2 )
7815229 (12089) ziga1990
