Forum » Informacijska varnost » FreeType sec bug - Chrome exploited
https://sourceforge.net/projects/freety... ( FreeType )
New Chrome 0-day Under Active Attacks – Update Your Browser Now (thehackernews.com)
Če je ranljiv še kaki drugi razširjen softver, pa bi bilo dobro vedeti.
CHANGES BETWEEN 2.10.3 and 2.10.4
I. IMPORTANT BUG FIXES
- A heap buffer overflow has been found in the handling of embedded
PNG bitmaps, introduced in FreeType version 2.6.
https://cve.mitre.org/cgi-bin/cvename.c...
If you use option FT_CONFIG_OPTION_USE_PNG you should upgrade
immediately.
CVE-2020-15999
immediately.
CVE-2020-15999
- spremenil: MrStein ()
| » | image/png .......(prikaz!!)?Oddelek: Izdelava spletišč | 1617 (1508) | Ziga Dolhar |
| » | Omejitev hitrosti CD-roma v LinuxOddelek: Operacijski sistemi | 1511 (1273) | Pithlit |
| » | Fonti v linuxuOddelek: Operacijski sistemi | 1433 (1404) | Phoebus |
| » | manjka ukaz emergeOddelek: Operacijski sistemi | 1818 (1588) | Brane2 |
| » | Word pisave v OpenOffice(Linux)?Oddelek: Programska oprema | 1495 (1372) | der_Alte |
