FreeType sec bug - Chrome exploited
https://sourceforge.net/projects/freety... ( FreeType )
New Chrome 0-day Under Active Attacks – Update Your Browser Now (thehackernews.com)
Če je ranljiv še kaki drugi razširjen softver, pa bi bilo dobro vedeti.
CHANGES BETWEEN 2.10.3 and 2.10.4
I. IMPORTANT BUG FIXES
- A heap buffer overflow has been found in the handling of embedded
PNG bitmaps, introduced in FreeType version 2.6.
https://cve.mitre.org/cgi-bin/cvename.c...
If you use option FT_CONFIG_OPTION_USE_PNG you should upgrade
immediately.
CVE-2020-15999
  • spremenil: MrStein ()
image/png .......(prikaz!!)?
Oddelek: Izdelava spletišč
181617 (1508) Ziga Dolhar
Omejitev hitrosti CD-roma v Linux
Oddelek: Operacijski sistemi
111509 (1271) Pithlit
Fonti v linuxu
61433 (1404) Phoebus
manjka ukaz emerge
251818 (1588) Brane2
Word pisave v OpenOffice(Linux)?
Oddelek: Programska oprema
121495 (1372) der_Alte
