Breaking news:
Russian propagandist Skabeyeva acknowledges that Crimea is not Russia.
Verjetno omenja preluknjane (civilne) tovornjake, ki sem jih lepil par dni nazaj. Ampak tam je bil Alternative Warhead za GMLRS, wolframove krogle namesto podstreliv.
Cluster munitions, no panic thread 🫂
Key points in English:
1. The issue of cluster munitions being used against Russian forces in Ukraine is still a major problem, despite previous discussions. More details have emerged showing the severity of the situation.
2. Cluster munitions are causing devastating casualties among frontline soldiers as well as damaging civilian infrastructure in the rear.
3. An incident in Tokmak resulted in heavy losses of vehicles and drivers. The military decided not to publicize this to avoid giving justification to the enemy. But some war correspondents published videos that may have revealed more than they should have.
4. Russia should have tried harder to block the supply of cluster munitions to Ukraine by declaring they wouldn't be used by Russia and pressuring European countries where they are banned. But instead Russia boasted about having huge stockpiles.
5. Much of Russia's cluster munition stocks are obsolete and degraded. Reversing the rhetoric now is difficult.
6. Cluster munitions are especially deadly and gruesome. Without proper medical care, survival is unlikely. The enemy has learned to cut off routes for reinforcements and retreat, leaving soldiers trapped and dying in horrific ways.
7. Counter-battery warfare is lacking. The problem needs to be acknowledged and solved at the highest levels. Bold rhetoric about striking back hard is not helping soldiers dying in the field.
8. The scale of casualties from cluster munitions is likely already in the hundreds or thousands over the past couple weeks. Precise figures should not be publicized to avoid aiding the enemy.
9. Solutions require decisions above the level of individual generals. The problem of cluster munitions needs to be addressed through action, not bluster.
Zdaj ko je led prebit bi lahko Američani dali kasetne rakete za himarse. Itak so baje predvidene za uničenje tako,da je dvojni plus.
Servants of Hell: Fanatics of the Regime or Well-paid Liars? Special Report on Russian Propaganda
100% nova veja v vojski. Operater drona! :D Verjetno ne bo imelo niti starostne omejitve niti fizične.
Destroyed Russian 2S3 Akatsiya 152.4 mm self-propelled gun. The distance from front is ~11,5km, which is one of the farthest confirmed distance for FPV strikes. Author claims 14,5km total distance. By "Birds of Madyar".
(47.6414840, 37.1334954)
Ko smo se zadnjič pogovorajali o minah in dronih.
Je to termo kamera? JE to možno?
Prej nekaj takega
Jup, obstajajo termo kamere tudi za potrošniške drone:
https://www.dronefly.com/thermal-infrar...
Sicer par k $, ampak za vojaščino relativno poceni.
V drugih novicah, Challenger 2 s cope cage :D
https://twitter.com/Jeff21461/status/16...
rationlibe00 je izjavil:
Russia's central bank hiked its main interest rate by 3.5 percentage points to 12% Tuesday after the ruble hit a 17-month low the previous day.
Ups, škoda ker senkcije ne delujejo ;((
To je bilo pričakovano in isto bi storila ECB ali Federal Reserve v Ameriki.
Ruska centralna banka torej ponuja 12% (letne) obresti na rubelj. Če torej kupiš 100 rubljev zdaj, boš imel 112 rubljev za eno leto. Vprašanje je torej sedaj, koliko bo rubelj padel proti dolarju, v enem letu.
Recimo da pade 5%. Potem nekdo zasluži (še vedno) whooping 7% na depozit.
Nabiullino (Ruska centralna banka) obresti na rubelj ne stanejo "nič", ker jih printa.
Rusi torej upajo, da se bo našel nekdo, ki bi začel kupovat rublje. Oziroma vsaj, da jih bodo nehali prodajati tako, kot jih sedaj.
Ruska centralna banka lahko dvigne obrestno mero iz 12% na 15 ali 17%. Dejansko denarja že pri 12% ni mogoče izgubiti. Nekdo z dosti denarja si izračuna dnevno obrestno mero. Dnevno si izračuna, koliko rubljev je dobil kot obresti. Potem to preračuna v dolarje in ima dejansko izračunano dolarsko obresto mero.
Če je ta obrestna mera tam nekje zdravih 7%, je to smiselno početje.
Na to sedaj računajo Rusi.
Seveda to ni početje za navadne kekce. Denar namreč moraš shraniti pri zakladnem računu Ruske centralne banke.
Ne verjamem, da si bo nekdo na zahodu to upal storiti. Imate pa polno Kitajcev, Kolumbijcev, raznoraznih, ki bi bili veseli, če bi kje dobili obresti 12%. Seveda je potrebno dnevno preverjati in obrestno mero in tečaj dolarja.
Sevda pa si je Nabiullina naložila težak nahrbtnik na hrbet. Zdaj bo imela polno finančnih kekcev na vratu, ki bodo dnevno merkali, koliko zaslužijo. Morala bo vzdrževat tečaj rublja tako, da je razlika med obrestmi in padajočim tečajem rubljem "zdrava". Če bo dopustila, da bo rubelj padel 12% (letno), ji bodo kekci pobegnili prvo sekundo. Potem bo pa 100% prosti pad rublja.
To še lahko dodamo. ;)
Dvigovanje obrestnih mer s strani centralne banke ima lahko tako pozitivne kot negativne učinke, odvisno od okoliščin in ciljev, ki jih centralna banka želi doseči. Tu so nekateri razlogi, zakaj dvigovanje obrestnih mer lahko velja za negativno:
Upočasnitev gospodarske rasti: Višje obrestne mere lahko zmanjšajo potrošnjo in investicije, saj se dražja izposoja upočasni. To lahko vodi do nižje gospodarske rasti ali celo recesije.
Povečanje stroškov izposoje: Dvig obrestnih mer povečuje stroške izposoje za podjetja, ki se zanašajo na izposojo za financiranje poslovanja. To lahko zmanjša njihovo sposobnost za naložbe in rast ter privede do zmanjšanja zaposlovanja.
Ovira za stanovanjski trg: Višje obrestne mere lahko povečajo stroške hipotekarnih posojil, kar lahko zmanjša povpraševanje po stanovanjih in vpliva na stanovanjski trg.
Negativni vpliv na zadolženost: Dvigovanje obrestnih mer lahko prizadene tiste, ki so že zadolženi, saj se lahko njihovi mesečni obroki povečajo.
Negativen učinek na delniški trg: Višje obrestne mere lahko zmanjšajo privlačnost naložb v delnice, saj se drugi donosi na trgu povečujejo.
Nevarnost deflacije: Če se obrestne mere dvigujejo v obdobju, ko je inflacija že nizka, lahko to poveča nevarnost deflacije (pada cen) in s tem ohromi gospodarstvo.
Vendar pa je treba opozoriti, da dvigovanje obrestnih mer ni nujno vedno slabo. V nekaterih primerih je dvig obrestnih mer potreben za obvladovanje inflacije, stabilizacijo gospodarstva in preprečevanje pretiranega tveganja, ki bi ga lahko prinesla prehitra rast. Vsaka odločitev o dvigovanju obrestnih mer se sprejme na podlagi analize trenutnih gospodarskih razmer, inflacije, zaposlovanja in drugih dejavnikov, pri čemer centralne banke upoštevajo tako pozitivne kot negativne učinke ukrepa.
ViperR ::
Kitajci definitivno nimajo nič od visokih obrestnih mer v rusiji, saj so izpostavljeni valutnemu tveganju, hedgat to tveganje pa je forward rate, ki je razlika med obrestnimi merami v državi. Na koncu ne profitiraš nič. Razen, če že sedaj posluješ v rusiji, sam pol že itak hedgas svoj posel..
Poglejmo samo lansko norijo z plinom, letos tega ne bo več, prav tako ne strašenja, da bomo zmrznili:
https://tradingeconomics.com/commodity/...
Russian oil and gas budget revenues almost halved in the first half of the year
MOSCOW, July 5 (Reuters) - The Russian budget's oil and gas revenues fell by 47% to 3.38 trillion roubles ($37.4 billion) in the first half of the year from the same period in 2022, finance ministry data showed on Wednesday, as tax returns fell because of lower prices and sales volumes.
Proceeds from oil and gas sales are crucial for Russia's commodity-oriented economy and for the financing of what it calls its "special military operation" in Ukraine.
https://www.reuters.com/business/energy...
Nehaj lagat in raje priznaj, koliko veveric si požrl čez zimo :D
I stumbled upon this old video and decided to re-share it with you.
Russian propagandist Skabeyeva says that some restaurants in Great Britain started serving squirrels because of the food shortage in the country.
She implies that all the money went towards weapons for Ukraine, and now Britons must eat squirrels.
Kaj vse smo lani nabavili, ker je cias skakal, da bomo pomrznili, sem nabavil kamin, 10 metrov bukovih drv, boljšo klimo za gretje, nekaj ir panelov, pelete smo iskali za 10EUR, potem pa luftal, ker je bilo prevroče, letos smo naročili še toplotno črpalko z zalogovnikom :D
Je pa res, da ima kmet, ki prodaja drva novi traktor, dvignil ceno lani iz 130EUR na 280EUR za paleto drv, ker se baje v Ukrajini streljajo in mu bukovina bolj počasi raste, kolega, ki prodaja toplotne črpalke, pa novo mrcino od avta.
Me pa zanima kdo bo prvi nalepil račun, da familija v UK plača 20 000EUR za elektriko.
ViperR je izjavil:
Ne, čakaj, to ni res. Odpreš zakladni račun, kupiš za 500 mio € rubljev ali več. Naslednji dan ti pripišejo obresti (dnevne). Pretvoriš to v dolarje (ali evre). Zračunaš si dnevno obrestno mero. Množiš s 365, ter dobiš letno OM.
Mogoče malo merkaš, koliko bi dobil pri ZDA:
https://www.federalreserve.gov/releases...
Če pri Rusih dobiš 7%, je to v redu.
Če pa dobiš *MANJ*, potem pa seveda rublje prodaš, ter odideš iz Rusije. Naloga Nabiulline pa je, da razliko med padcem rublja in obrestno mero drži nad 5,33% koliko dajo Američani.
Težavo vidim samo v tem, da kateri dan izračunaš, da si dobil manj kot 6%, hočeš prodat za 500 mio € rubljev, ter tečaj strmoglavi za 50%. Kar se ne bi smelo zgoditi, samo se lahko.
Lesoto je izjavil:
velik kabum, video
A Ukrainian drone from the 79th Air Assault Brigade drops a 40mm HEDP grenade on a Russian UR-77 Meteorit, causing a catastrophic payload explosion.
Ta stvar vozi sabo 700kg eksploziva.
Pa dron preživel.
Neverjetno!
jernejl ::
Stvar ni tako preprosta. Če nekje obstaja "free money", začnejo ljudje delati arbitražo in ta free money izgine, še preden je dobro začel obstajati.
Recimo, da bi zaradi razlike OM ljudje začeli množično menjavati evre v rublje v velikih količinah. Zaradi velikega povpraševanja bi vrednost rublja glede na evro hipno zrastla, tako da bi jih moral kupiti po višji ceni (razen če si slučajno prvi, ki se je tega spomnil). V nadaljevanju bi se pa zgodba obrnila. Potem bi vsi ti z množico (dodatno natisnjenih) rubljev, ki so jih dobili kot obresti, želeli nazaj kupovati evre. Zaradi velikega povpraševanja po evrih bi evro proti rublju pridobil vrednost. Na koncu bi ugotovil, da boš moral glavnico v rubljih prodati po slabšem tečaju, kot je bil ob nakupu rubljev, in zaslužek od obresti bi šel po zlu.
Tako približno pravi teorija. V praksi se sicer lahko vmes zgodi še kaj drugega nepovezanega, kar lahko vpliva na to, ali bo taka operacija na koncu dobičkonosna ali ne (kaj pa vem, recimo nenaden in nepričakovan konec vojne, ki bi vrednost rublja potisnil navzgor). Ampak da bi pa to počel samo zaradi razlike obrestnih mer in pričakoval kak omembe vreden dobiček, je pa le malo preveč naivno.
Sc0ut ::
Čeje to legit, potem lahko Ukrajinci s krimskim mostom delajo kaj hočejo :) :) :)
https://twitter.com/Heroiam_Slava/statu...
Zgleda je še vedno vse v meglo zavito
https://twitter.com/2uwmp/status/169167...
  • spremenil: Sc0ut ()
https://twitter.com/nedalalamari/status...
Russian Defense Minister Sergey Shoygu: We do not use cluster bombs in Ukraine for humanitarian reasons...
But is their use on civilians in Syria humane?!
Russia is a deceptive terrorist state, don't believe them.
This video is from the city of Haritan in Syria.
Russia used cluster bombs.
Lesoto je izjavil:
Ni treba it v Sirijo, imaš cel kup videov s Harkiva. S kasetnim strelivom so zasipavali ruskogovoreče Ukrajince, ki jih s SVO bojda rešujejo
Ruski liberali:
Zato sem trenutno vesel, da so v Rusiji na oblasti Putin in njegova klika. Ruska korupcija dela za Ukrajino.
še en ukrajinski morski dron, od blizu & počasi, video
Zadaj ima zgleda 2 šmela oz. nekaj podobnega, za obrambo.
  • spremenilo: Pac-Man ()
jernejl je izjavil:
Ne, čakaj, to ni res. Odpreš zakladni račun, kupiš za 500 mio EUR rubljev ali več. Naslednji dan ti pripišejo obresti (dnevne). Pretvoriš to v dolarje (ali evre). Zračunaš si dnevno obrestno mero. Množiš s 365, ter dobiš letno OM.
Ne, čakaj, to ni res. Govoriš tako, kot da bi bil rubelj bitcoin in pač kot kdo kupi ali proda, tečaj divje niha.
Ni tu nobene arbitraže in ni tu nobenega free moneya.
Ruska centralna banka ima nalogo regulirati tečaj rublja (podobno kot ima to nalogo ECB v Eurozone, preko bank, članic Eurozone). Ruska centralna banka ima dve skrbi:
a) eno sladko
b) eno besno grenko
Sladka je ta, če vrednost rublja narašča, potem tujcem RNB prodaja dodatne naprintane rublje. Če bi folk začel množično kupovati rublje, bi bila Nabiullina neskončno zadovoljna. Stabilizirala bi tečaj rublja s pomočjo tujega denarja, ki ga nekdo depozitira pri njeni banki
Ubijalsko grenka pa ta, če bi vsi želeli uiti iz rublja, bi naenkrat vrednost rublja neskončno padla. Ruska centralna banka bi moral skašljati tuje valutne rezerve (dolar, evro) in pokupiti te viške rubljev.
Za Ruse je edino scenarij (b) grenak, ker morda toliko rezerv niti nimajo. Če pa Rusom *zmanjka* tujih rezerv za regulacijo vrednosti rublja *in* vsi želijo prodati rubelj, pa se zavrtijo v hiper inflaciji.
Pri teh 12% obrestni meri se gre za to ali tujci zaupajo Ruski centralni banki, da jih ne bo zafrknila okrog tečaja. Mimogrede, centralnim bankam ni preveč za zaupati glede tega, ker recimo Švicarska narodna banka je lepo zafrknila s tečajem in to bo ostalo v večnem spominu ljudem, ki so vzeli kredite v švicarjih. Čeprav, sicer, švicarska narodna banka je dala več signalov, da se bo tečaj franka spremenil. Samo folk ne bere Financial Times dnevno.
Trenutno je tečaj na:
https://finance.yahoo.com/quote/RUB=X/
96,9500 RUB za 1 USD. Kar pomeni, da je zdravilo pomagalo, samo je pa treba vedeti, da je to še en as, ki ga je odšpilala Nebiullina. Počasi ji bo zmanjkalo asov in rokavov.
jernejl je izjavil:
a) eno sladko
b) eno besno grenko
Kolko misliš, da bi mogel zahod vložit, da jim najprej pokupi Rublje in potem sesuje valuto, ko bi prodjali. So to take cifre, da ne gre in se ne splača?
ViperR ::
Če ne delaš arbitraže si brutalno izpostavljen nihanju rublja, če kupiš rubelj in ga ne hedgas. To je gamble. To nihče ne počne.
Ne vem, Ruska narodna banka več nima podatkov ne o tem, koiko rezerv je kupila in koliko prodala. Načeloma pa sesuvamo njihovo valuto tako, da nimamo posla z njimi. Potem vrednost valute pada.Oni pa *vseeno* morajo kaj kupiti v Ameriki/EU. Če drugo ne, oligarhovski otroci rabijo Apple in oligarhovske ljubice rabijo Guccija, brez katerega ne morejo.
To za njih postane neskončno drago.
Kupovati z namenom, da boš nekoč prodal in jih zafrknil, ne bo šlo. Nabiullina ti bo prodala wc papir z lepimi slikcami, ima pečat izrezan iz krompirja in štanca rublje.
Ob koncu transakcije, boš ti štel wc papir, s katerim ne moreš nič (pardon, eno stvar pa lahko), ona pa bo preštevala devize, za katere lahko kupi vse.
Ko boš pa wc papir prodajal, kdo pravi, da bo Ruska narodna banka wc papir (nazaj) pokupila. Mogoče pa ga ne bo in boš popušil pri tečaju. In bo rubelj nivelirala *kasneje*.
Močnejši je tisti, ki ima devize-at-hand. Zato Ruse bojkotiramo. Oni naj wc papir kar imajo in ga naj rabijo, kot se za namen spodobi.
Za vse rusofile tukaj - kako si Rusi predstavljajo obseg "novega ruskega imperija". Vključno s Slovenijo!
Piše "Naučili vas bomo ljubit domovino (rodinu)"
Karkoli že mislijo s tem.
To pa je kar sprememba da je Ukrajina uradno začela govorit o napadih na Krimski most.
Zdaj pa kaj je vzrok za to spremembo, so zgolj manj zadržani al jim je morda celo uspela kaka dobra eksplozija da so se odločli pohvalit :)
Nit, bivši angleški oficir
https://twitter.com/ThreshedThought/sta...
Time for another brief update as to what has happened in the last two weeks in Ukraine.
That image by the way is from a thread months ago - but the basic strategy hasn’t changed.
That’s the mark of a good strategy - when it doesn’t change every 10 minutes and when resources are lined up behind what you hope to achieve.
(Take notes Russia, please)
Lonsarg je izjavil:
Verjetno je problem ta, da Ukrajinci imajo premalo uspehov v protiofenzivi v smislu, da jim gre prepočasi. Imajo še avgust in ajd recimo september, pa za september nisem prepričan, da imajo cel september. Če se vlije dež, bodo obstali v blatu (podobno kot sicer tudi Rusi).
Plan je bil, da bodo do sedaj že pri Melitopolu. Ali Berdjansku. Ali vsaj nekje odrezali komplet oskrbo.
Mogoče pa Ukrajinci pripravljajo kakšno presenečenje, pa se bodo borili tudi v rasputici. Ampak problem je, da bodo omejeni samo na poti, kar je velik setback. Operativna pavza bi (zopet) omogočila Rusom, da se (še bolj) vkopljejo.
Zato bodo Ukrajinci neumorno napadali logistiko. Vendar bi napadu na logistiko moral slediti operativni napad. Kar sicer sledi, samo pač Ukrajincem gre to prepočasi od rok.
Zda so začeli z akcijami, da specialci napadejo ponoči, zajamejo oficirje, ki jih potem zaslišujejo. Pri Kozači Laheri je to dalo rezultat napredovanje par km na dan.
Mimogrede, klaster municija dosega nenormalno dobre rezultate, pobijajo cele zaledne čete v enem šusu.
Lonsarg je izjavil:
Jaz sem mislil, da se pripravljajo na zimo in zmrzal ter megla, so le bolje opremljeni od Rusov, ki bodo zmrzovali v rovih. Dobili bodo Abramse in Challengerje, ter rečeno je bilo, da bodo do zime natrenirali pilote in dobili F-16, iz tujine se bo vrnilo tudi na tisoče izšolanih specialcev.
Nakar preberem, da bodo do takrat izšolali samo 6 (šest) pilotov. Lahko, da je kaka finta zahoda in Ukrajincev, da zmedejo Ruse.
Lonsarg je izjavil:
Vse je to v redu. Problem je, da s kamionom ne morejo dobesedno 1 meter izven ceste. S tankom tudi ne. Z oklepnim transporterjem tudi ne. Potem so važne samo še asfaltne ceste. Te žile je pa bistveno lažje braniti.
Lahko pa gredo peš, pa z bagiji. Že s Humviji ne morejo, ker je pretežak in se bo pogreznil v blato. Ne vem, rasputica je dala vetra Hitlerju, Rusom ko so na začetku napadli Ukrajino.
Ne vem, lahko pa napadajo Ruse z droni in artilerijo. Ker sigurno bodo pa eni rovi, če ne celo večina neuporabni, ker bo v njih 1,5m vode.
Ne vem. Bomo videli.
Lonsarg je izjavil:
Do Tokmaka imajo še 10km, samo peklenskih kilometrov. Sedaj je prišla pomagat še najboljša 82 brigada, ki so ji do sedaj šparali v rezervi, ti imajo najboljše zahodno orožje, ki so jim ga dostavili.
So danes na VAl202 rekli pri poročilih, da so ruski telegrami, predvsem tisti iz kateerih dobivajo največ novic! :D (čudno ne!) zaskrbljeni.
Finta je, da morajo tudi Rusi, ki bežijo, bežati preko minskih polj, to se seveda vse snema kje gredo.
We are fine without wings.
Bila je neka slikca, kje imajo Rusi največ obrambnih struktur. V Zaporožju je to ravno Tokmak. Zdaj, kako bodo to obvladali, je na Ukrajincih. Samo Rusi natanko vedo, da je Tokmak vozlišče. Kako se bodo tega lotili, je težko reči. Osebno bi se Tokmaka ognil, ter jim zablokiral vse vpadnice. Potem bi šel naprej, Tokmak pa oblegal. Problem je dostava municije in hrane. To, če so vse oskrbovalne poi zaprte, je vprašanje dni, da se obleganci predajo.
Jaz se ne bi spustil v ulične boje, to lahko traja do novega leta. Davil bi jih dokler se Rusi od lakote ali pomanjkanja streliva ne predajo.
PacificBlue je izjavil:
Glas razuma?
To lahko razumeš kot pritiskanje NATA, da Ukrajinci dajo rezultate od sebe. To je bilo za pričakovati. NATO je dostavil orožje, natreniral ekipe, dostavil strelivo in še ga dostavlja, oprema se tudi še dostavlja. Samo nek rezultat mora biti, tako ali drugače.
Ni se to preveč za sekirati (zaenkrat). Zaskrbljujoče bi bilo, če bi ZDA odtegnila podporo.
Zdaj, kaj MMC misli, je nekaj čisto drugega.
Glas razuma?
Glas razuma je, da se Rusi poberejo domov in nehajo napadati, klati in si želeti tuje ozemlje. Naj začnejo že enkrat skrbeti zase in svoje ljudi, tudi tam za Uralom in da bo človeško življenje Ruse vredno več kot kila krompirja in liter olja. Glas razuma je tudi, da gre Putler v penzijo in da oligarhi razdelijo denar med ljudi. Glas razuma je tudi, da pustiš opoziciji na volitve, da pustiš novinarjem, da delajo svojo delo. Glas razuma je tudi sprejeti kritiko in nehati obtoževati vedno druge, da so krivi.
Glas razuma?
Nerazumno. Razumno je popolnoma poraziti Ruse in jih nagnati iz Krima. Rusija je ze enkrat izgubila krimsko vojno in potem je bil dolgo mir. Razumno je, da se iz zgodovine ucimo. Rus razume batine.
Pa saj valjda veste, da raputica ni čez celo ozemlje Ukrajine. Dejansko jo je najmanj na jugu, razen ravno na meji med Krimom in ostalimi ukrajinskimi pokrajinami, kar bo hudo problematično za oskrbovanje
Rusov na jugu.
https://twitter.com/HoansSolo/status/15...
"Iran began to actively increase oil supplies to China, displacing Russian oil with discounts", - Bloomberg, citing Kpler data
China's purchases of Iranian oil reached a 10-year record, while Russian oil supplies fell to their lowest level since the beginning of the year.
Lesoto je izjavil:
Rusov na jugu.
Iz tvojih ust v božja ušesa. Problem vidim samo v tem, da so Rusi napadali v Bakmutu, ki je po tvojem zemljevidu v zelenem, pa jim je oklepna mehanizacija ustala ujeta v blatu. In so potem napadali peš. Ukrajinci pa so na začetek operacij pozimi čakali, da zemlja pomrzne.
Rovi so sigurno dobesedno neprimerni za bivanje, ker je do pasu vode.
Videli bomo.
Let me add a small comment to this excellent thread.
A Ukrainian unit that fought in Kharkiv and Kherson and now operates near Robotyne explained that the fighting is very different from the two previous campaigns. How?
In the south, there is less Russian soldiers density than in Kharkiv or Kherson. Russian strategy relies on mines and artillery to hold the front. Once those are gone, I expect Ukrainian armor brigades to roll all the way to the sea of Azov
BTW this may explain why Russians are defending outside their main defensive line, something that puzzles many people.
They wanted to make sure that Ukraine never reached it because they don't have enough troops to properly defend it. It is important for them that Ukrainians get bogged down into mine fields and never attempt to breakthrough.
180,000 Tungsten Balls moment.
CoolBits ::
Russia got richer even as the war in Ukraine raged on last year, while the West shed trillions of dollars of wealth
https://www.businessinsider.com/war-in-...
Glas razuma?
Smo videli kako je pomagalo,da se je pri Krimu gledalo stran. Če nagradiš diktatorske agresorje dobiš še več agresije.
Rusija pogumno stopa po poti Venezuele, odlično.
Solovjov je ostal brez dveh hiš v Italiji, zdaj bo pa ostal še brez izpravnega avta, hihi. Video:
https://twitter.com/yasminalombaert/sta...
Russia’s chief propagandist, Solovyov, called the Mercedes company a “Nazi piece of sh*t" and threatened to ruin the concern.
The German company Mercedes-Benz, which has withdrawn from the Russian market, also decided to disconnect Russian dealers from its software completely.
Russian propagandist Vladimir Solovyov threw a tantrum and threatened to "ruin" the concern.
He made these statements on the air of his program on Russian TV.
The German company restricted Russians' access to online systems that are used to perform maintenance and identify problems.
Thus, the key problem for Russians after the decision of Mercedes-Benz concern to disable the software in Russia, as well as due to the shortage of components, will be increased repair time.
Propagandist Solovyov threw a real tantrum. He called the company "Nazi piece of sh*t" and threatened to ruin the concern. He also said that Mercedes-Benz has allegedly "destroyed its reputation" by such actions.
flajšter, pa bo kot nov
https://twitter.com/anno1540/status/169...
The Rusospigs ran over an anti-tank mine with a tank
1/ An apparently leaked memo attributed to former Russian minister Dmitri Rogozin reports major shortcomings in the Russian army's equipment, including artillery far inferior to Western equivalents, a shortage of 152 mm shells, inadequate communications and obsolete UAVs.
7/ The first category is "Organisation and conduct of counter-battery warfare", in which he says that Russian counter-battery radars cannot detect long-range Western-supplied artillery and Russian artillery batteries don't have the range to fire back. Specifically:
8/ "a) Obsolete artillery reconnaissance means of the Zoopark radar, ACP, AZK in terms of range do not correspond to the technical characteristics of the enemy's artillery systems: M777, "Paladin", "Krab", and all the more so "MLRS", "MARS";
9/ "b) the absence of counter-battery firepower from the combined barrel artillery at the firing range of Western artillery systems. The use of only long-range 152 mm shells (of which there is an acute shortage).
10/ "Often the use of BM-21 and Uragan missiles, the accuracy of which is negligible;
b) [sic] Consideration is currently being given to the establishment of separate teams in each regiment (brigade) using [DJI] Matrice 300 quadrocopters ..."
13/ He writes that there is "[a lack of?] stability, secrecy and promptness of the transfer of official information, and under certain conditions, a complete loss of communication." Specifically, he notes of the Azart:
14/ "(a) ... The technical specifications do not correspond to the declared data, there is no base radio station, retransmission is possible only through the same radio station, arranged as a repeater.
15/ "So, in a brigade (regiment), to create the smallest system of communication in defence, you need to put at least 20 radios as repeaters.
ANTI-CENZURA ::
Rusi naj strmoglavijo Putina, Ukrajina gre v EU in bo mir v Evropi.
Velki ::
Kot rečeno vojna se bo končala na diplomatski način (ne glede na to če je zmenjeno ali ne...), druge rešitve na kratki rok ni. Mislim da nas bodo počasi preko medijev pripravili na to. Ali to ali pa še nadaljnjih par sto tisoč mrtvih. Verjetno (ne trdim več nič ker danes je vse mogoče) je Putin vseeno dovolj priseben da ne bi šel napadat NATO članice, ker sem skoraj prepričan da ve da bi bil ob glavo. Upajmo da bo le razum prevladal.
  • spremenil: Velki ()
Ne rabi NATO napadat, ce bo vztrajal bo fasal miljon mrtvih Rusov ze v Ukrajini, kaj vec od miljona mrtvih pa njegov rezim ne prezivi.
Diplomacija bo zgolj detaljni zakljucek, sama vojna pa se bo koncala na bojiscu, ker je jasno da gresta obe strani do konca. Dokler ni dosezen nek pat polozaj in katerega vojasko vec ne more nobena stran bo pac vojna, pa ce to traja se eno leto ali pa 10
  • spremenil: Lonsarg ()
508 / 1556
