WiFi ne deluje
WiFi ne deluje
bigbug ::
Pozdravljeni,
na HP prenosniku mi lučka za WiFi sveti oranžno. In wifi ne deluje. Sistem je win 10.
Računalnik je bil v "spanju" pred tem je vse delovalno normalno. Po vklopu pa ne več. WiFi sem z gumom izklopil in ponovno vklopil in še vedno sveti oranžno.
bobby ::
restart računalnika?
Sleep ni restart,..
bigbug ::
Restart sem tudi naredil nic drugace. Sem ga tudi izklopil vzel baterijo ven, itd
bobby ::
potem imaš pa ali posebej tipko za vklop povezabe (BT-WIFI-OFF)
Najdi to tipko.
Lahko, da boš moral pritisnit najprej tipko, ki ima napisano Fn, jo držat, potem pa pritisnit tipko na tipkovnici, ki ima WIfi znak.
če pa na netu točno najdeš kater model prenosnika sploh imaš, bi bilo pa še toloko bolje, da vsaj vemo, kater model imaš
floyd1 ::
HP support pravi:
1) Disconnect the Battery & Adapter then press & hold the power button on Notebook for 30 seconds then turn on the unit and check if the Wireless light turns on.
2) Go to Device manager then uninstall the wireless drivers from Network Adapter and restart the unit and check if the light turns on.
3) Please update the Bios & Wireless driver from HP website.
4) Click start in search type Recovery Manager then click on it select Yes on User access control then select I need immediate help then select Driver & application recovery select the wireless driver and install it then restart the unit.
5) If you are comfortable reseating the wireless card which will be on the back panel off your unit you could try this steps as well.
bigbug ::
V device manager-ju se mi wifi pokaze pod skritimi torej sivo obarvan.
V lastnostih je navedeno "Currently, this hardware device is not connected to the computer (Code 45)"
Na spletu sem nasel, da je potrebno na novo naloziti driverje.
V device managerju sem odstranil intel dual band wireless AC-8265 oz driverje.
Sedaj mi wifi ne pokaze niti pod skritimi komponentami. Sem restartal in nic. Nalozil driverje....nic
Sem sel pod dodaj strojno opremo in nic ne najde.
Kaksen nasvet?
solatko ::
Menjaj wi-fi kartico. Dobit moraš ravno tako Intel-ovo.
Delo krepa človeka
Han ::
Kloniraj disk in na sveže namesti Windows 10. Če še vedno ne bo WiFi, je zelo verjetno kartica fuč.
TamDen ::
Pozdravljeni,
na ženinem prenosniku naenkrat ni več interneta.
WiFi se vzpostavi, nakar piše:
Ni interneta, zavarovano.
Pojavi se obvestilo:
"MODEM" nima zaščite.
(to omrežje wifi uporablja starejši varnostni standard. Priporočamo, da se povežete v drugo omrežje).
Kako rešiti problem?
floyd1 ::
Reset routerja in modema - ven iz elektrike in ponoven priklop. Plus restart računalnika.
  • spremenil: floyd1 ()
bigbug ::
Potem se mi bolje splaca vzet eno za USB.
Katero predlagate?
frke ::
Kateri HP prenosnik imaš?
Nekateri starejši HP prenosniki imajo fizičen gumb za wifi.
Meni je na Windows 7 pred leti pomagalo, ko sem namestil HP Wireless Assistant.
Ampak ne vem, če to obstaja za Wini 10.
Jaz bi tudi posodobil vse driverje in bios iz HP support strani
bigbug ::
HP 470 G3
solatko ::
Poglej še na routerju, da nimaš slučajno na USA, potem ti vrže kartico ven zaradi BT protokola. Če se je kdo igral z nastavitvami routerja. Obnaša se kot da kartice sploh nimaš priklopljene.
Delo krepa človeka
bigbug ::
Zanimivo...
Danes sem vklopil računalnik in je WiFi deloval normalno.
Potem sem ga izklopil in kasneje ponovno vklopil in ponovno ne deluje.
TamDen ::
floyd1 je izjavil:
Najlepša hvala za nasvet,
problem rešen :)
buttcrack ::
Sicer ni enak problem, ampak da ne odpiram nove teme...
Telefon/android mi preko wifija zelo slabo vleče oz. odpira strani, z gappsov sploh ne prenaša appov. Medtem ko tv, yt, torrenti delajo BP. Gre pa za t2 innbox router.
Kaj bi lahko štekalo?
WiFi ne dela po posodobitvi firmware FritzBox
151435 (1047) Vuli
Počasno kopiranje (strani: 1 2 )
7915904 (13318) iloveboobz
SecureW2; Žična in brezžična povezava na istem laptopu (strani: 1 2 )
Oddelek: Omrežja in internet
579865 (9211) ArchNem
Kateri sata driver je pravi za TOSHIBA SATELLITE L40-Q17???
146194 (3017) Leoon
Instalacija XP ne najde diska
Oddelek: Operacijski sistemi
416557 (5420) fredyjetle
