Forum » Programiranje » Powershell skripta
Powershell skripta
Blisk ::
A ima kdo idejo zakaj tole ne dela?
Imam en velik log fajl in bi rad, da se naredi en txt fajl, ko najde stavke, ki sem jih zapisal v moj kontrolni fajl.
Naprimer v mojey my.txt je tole
"error path not found"
"wrong disk selected"
"backup size 0Mb"
ko najde katerikoli stavek od teh treh mora narediti error.txt
-a---- 17.11.2019 13:28 0 Cannot bind argument to parameter 'Pattern' because it is null.
-a---- 17.11.2019 13:28 0 Cannot overwrite variable Error because it is read-only or constant.
"backup size 0Mb"
$file = "E:\B\LOG.txt"
$pattern = Get-Content "E:\B\my.txt"
$error = "E:\B\error.txt"
$content = Get-ChildItem $file | Select-String -Pattern $pattern
if ($content) {New-Item $error -Force
else{Remove-Item -Path E:\B\error.txt -Force}-a---- 17.11.2019 13:28 0 Cannot bind argument to parameter 'Pattern' because it is null.
- spremenil: Blisk ()
| » | KeyloggerOddelek: Programska oprema | 4056 (2783) | Blisk |
| » | program za pomoč pri tiskanju 200+pdf dokumentovOddelek: Pomoč in nasveti | 3057 (2109) | HotBurek |
| » | Zanimiv ...hm... problemOddelek: Programska oprema | 3514 (3009) | poweroff |
| » | Postavitev mySQLOddelek: Programiranje | 2880 (2458) | M01O |
| » | Arhiviranje serverja s TAR - incremental in FTP na drugo lokacijo in email report - SOddelek: Operacijski sistemi | 2002 (1913) | Daedalus |
