Tablica 7' namesto nexus 7 (2013)
DamijanD ::
Fotru počasi odpoveduje (sicer odlična) tablica nexus 7 in bi rad novo. Kaj bi bilo kaj primernega novega - android?
Han ::
Če želi približno enako velikost, npr. 8,4" Huawei MediaPad M5. V osnovi je gor Android 8.0, ki se posodobi na 9.0.
Jakob_X ::
Jaz imam Xiaomi Mi Pad 4 in je kar dobra zadeva. Če želi slovenščino potem ni ok saj moraš unlockat in naložit EU ROM kar pa traja saj moraš za unlock zaprositi.
xiaomi-mi-pad-4
urosh ::
Se en glas za MediaPad. Ocetu sem nabavil sicer 10 - Mediapad M5 lite, pa je ultra zadovoljen. Zadeva leti. Ni pripomb.
Mavrik ::
DamijanD je izjavil:
Jaz sem mojo prejsnjo tablico tudi zamenjal z MediaPad M5 8.4" in je odlicna naprava - dober zaslon, dovolj RAMa za gladko delovanje in stereo zvocniki. Edino za slusalke rabis (prilozen) adapter.
a kaksne manjše (pod 10") Windows tablice so še aktualne te dneve, pomožnosti v nizjem cenovnem rangu?
§|\| /\ |<E ::
teclast T10 126€
https://www.gearbest.com/tablet-pcs/pp_...
Specification
General
Brand: Teclast
Material of back cover: All Metal
Battery Capacity(mAh): 8100mAh, Li-ion polymer battery
G-sensor: Supported
Skype: Supported
Youtube: Supported
Speaker: Built-in Dual Channel Speaker
MIC: Supported
Google Play Store: Supported
Office 365: Support (Not Downloaded)
WIDI: Supported
Hardware
OS: Android 7.0
CPU Brand: MTK
CPU: MTK8176
Core: 1.7GHz,Hexa Core
GPU: IMG GX6250
Storage
RAM: 4GB
ROM: 64GB
External Memory: TF card up to 128GB (not included)
Network
Support Network: Dual WiFi 2.4GHz/5.0GHz
WIFI: 802.11 ac
GPS: Yes
Bluetooth: 4.0
Display
Screen type: Capacitive (10-Point)
Screen size: 10.1 inch
IPS: Yes
Screen resolution: 2560 x 1600 (WQXGA)
Camera
Camera type: Dual cameras (one front one back)
Back camera: 8.0MP
Front camera: 13.0MP
Video recording: Yes
Connectivity
TF card slot: Yes
Micro USB Slot: Yes
Mini HDMI: Yes
3.5mm Headphone Jack: Yes
Media Formats
Picture format: BMP,GIF,JPEG,JPG,PNG
MS Office format: Excel,PPT,Word
Additional Features
Additional Features: Alarm,Bluetooth,Browser,Calculator,Calendar,GPS,Gravity Sensing System,HDMI,OTG,Wi-Fi
Package Contents
Tablet PC: 1
USB Cable: 1
English Manual : 1
SIM Pin: 1
Dimensions and Weight
Product weight: 0.5530 kg
Package weight: 1.1000 kg
  • predlagal izbris: Han ()
DamijanD ::
Hvala za predloge. Nekako zgleda da bo MediaPad M5 8.4" naslednja (7" tako ali tako praktično ni). Me pa zanima naslednje a se jo sploh dobi kje v sloveniji? Povsod najdem samo 10" različice... Oziroma alternativa ali lahko preko amazona tudi kupiš na firmo?
Tablica za nezahtevno uporabo (strani: 1 2 )
5210179 (6727) kanarin
Tablica - pomoč prosim :)
335853 (4922) Han
Ask Tomson (strani: 1 2 3 4 … 7 8 9 10 )
48391291 (65217) bluefish
Nova tablica
162598 (2266) Tamutka
