Forum » Kaj kupiti » Ohišje za računalnik
acookook ::
Imam eno vprašanje na kerega še vedno ne najdem odgovora (ja mam ocd)pred časom sem postal na forum od msija odgovora pa še ni. Where to connect (probably the case LED on/off button) cable. MSI MAG Vampiric 011C case? By building this PC only one cable has remained unconnected. There is button by the front panel IO which fully works(HDD LED, ON status led, Power on, Reset, mic, headphones and all 3 USB ports work ), but just this one button doesn't . I don't know exactly where to connect it. Both manual and a video on youtube do not specify where should I connect it. I'd like to send and image, but because they are not allowed: It's a small white connector with a black and grey wire. There is no beeper and the are only 4 fans inside (2 on the GPU, 1 on the back of chassis and 1 CPU cooler)
| ⊘ | SpaceX reusable rockets (nova tema)Oddelek: Znanost in tehnologija | 6440 (5620) | BigWhale |
| » | temp data loggerOddelek: Elektrotehnika in elektronika | 3739 (3159) | maticm |
| » | Matrox Orbital LCDOddelek: Hlajenje in modifikacije | 1757 (1589) | hmale |
| » | Submersed CoolingOddelek: Hlajenje in modifikacije | 3327 (3003) | Tomi |
| » | Zvok z vecih cd-romov?Oddelek: Zvok in slika | 2572 (2343) | Justy |
