Mozilla Firebird - kako prpraviti do RES default browsera?
Caboose ::
Jaz sem odkril precudovit browser Firebird, ki je svetlobna leta pred IE-jem. Seveda ima možnost set as default browser in mnogo bolj prijazen vmesnik, ampak taeli SADB ne dela tako kot more. Ko npr. klikem na HL v ircu mi še vedno odpre IE, ali pa kak link v win okolju. Kako se tega znebiti? Kako FB pripraviti do res default browsera ?
hvala za odgovore!
If you can't explain it simple, than you dont know it good enough.
Damjan Jagar ::
To se tudi meni dogaja in tudi mene zanima rešitev.
http://jagar.si
McHregec ::
mIRC + Mozilla več tukaj.
Destroyer Of The Worlds.
Damjan Jagar ::
Solved. Hvala.
http://jagar.si
Caboose ::
This works for normal links, but it hates when the URL has anything right next to it. For instance in the topic.. you may get:
Topic is 'http://www.opensource.org/sco-vs-ibm.ht...
in which case, you'll get an error when clicking because it snags the ' as well.
If you come up with a fix for this, let us all know :)
res dobra.. anybody ? >:D
Skankulja ::
ignorante bastards ;)
2.Fixed default browser issue.
Neumen človek se zmede ob slehernem glasu razuma.
Caboose ::
jaz placevat za tole ne mislim.. payable irc... omfg :\
Skankulja ::
omfg... you know what... you don't realy have to... ain't that something or what.:\
NLB Klik dela na Androidu
Oddelek: Mobilne tehnologije
3913723 (6196) Gogyto
mirc + firefox
Oddelek: Omrežja in internet
51363 (1165) jackorsen88
ipv6 for g33k`s (strani: 1 2 )
7715113 (11669) Kami
Za glodanje: nek čuden virus ie/mirc virus
274095 (3206) Predator
programi za ADSL
111214 (989) NiggerBob
