Forum » Programiranje » PHP setlocale funkcija
warlord ::
V PostNuke sem dodal modul PostCalendar, lepo prevedel vse v slovenščino, sedaj pa imam manjšo težavo s prikazom imenov dni in mesecev v slovenščini. Po malce surfanja sem ugotovil, da moram n global.php (datoteka je del PostCalendarja, ne PHP-ja) nastavit jezik v slovenščino. Načeloma brez problema, jest sem pa kljub temu uspel naletet na enega.
Tole je koda:
Težavna je vrstica define ('_PC_LoCALE','...);
A kdo za hudiča ve, kaj je treba vnest tam notr?
Hvala za pomoč.
Tole je koda:
* $Id: global.php,v 1.15 2002/12/19 20:09:09 iansym Exp $
* PostCalendar::PostNuke Events Calendar Module
* Copyright Š 2002 The PostCalendar Team
* http://postcalendar.tv
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
* To read the license please read the docs/license.txt or visit
* http://www.gnu.org/copyleft/gpl.html
// The following define is necessary for the date and time functions
// set it to the locale for this language
define('_PC_LOCALE','si_SVN');
// Defines used in all files
// new in 3.9.9
define('_PC_NOTIFY_ADMIN', 'Obvesti admina o spremebah ali novih dogodkih?');
define('_PC_NOTIFY_EMAIL', 'Admin Email naslov');
Hvala za pomoč.
| » | Patenti - Copyright, Copyleft, GNU, Apache, ... LicenceOddelek: Pomoč in nasveti | 2836 (2581) | Icematxyz |
| » | Telstra domnevno krši GPLOddelek: Novice / Avtorsko pravo | 5439 (4759) | CCfly |
| » | Projekt GNOME praznuje 10. obletnico (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 11404 (9768) | 'FireSTORM' |
| » | TV tuner pod Linux-omOddelek: Operacijski sistemi | 2018 (1780) | Skrat |
| » | MySQL in Visual BasicOddelek: Programiranje | 2160 (1962) | krho |
