Forum » Igre » Sniper Elite 5
Sniper Elite 5
Sniper Elite 5 is coming
Rebellion dropped a lot of Sniper Elite news in its 2019 development update today. Not only did it confirm that Sniper Elite 5 is in development, it announced a remastered version of Sniper Elite V2 and a standalone Sniper Elite for VR devices. Check out the remaster in action above.
https://www.pcgamer.com/sniper-elite-5-...
Torej Sniper elite 5
Kaj več trenutno ni znanega samo to, da delajo na naslednji Sniper Elite igri.
- spremenil: oo7 ()
Sniper Elite 5 igra izide enkrat leta 2022
Igra se bo dogajala leta 1945 v Franciji.
Sniper Elite 5 takes aim at PC (via Steam, Epic, and Windows), Xbox One, Xbox Series X/S, PS4, and PS5 sometime in 2022. And yes, the game will also be an Xbox Game Pass Day 1 release.
Sniper Elite 5 - Reveal Trailer
Expansive Campaign - real-world locations have been captured using photogrammetry to recreate a living, immersive environment, and multiple infiltration and extraction points and kill list targets provide a whole new perspective on each mission. Take on the Nazi plot solo or work with a partner, with improved co-op mechanics allowing you to share ammo and items, give orders and heal each other.
Advanced gunplay physics and traversal - use ziplines, slide down slopes and shimmy along ledges to reach the perfect vantage point, or to sneak past a sharp-eyed lookout. Factor in rifle stock and barrel options along with gravity, wind and heart rate while you line up your sights on the target.
High calibre customisation - use workbenches to customise and upgrade virtually every aspect of your weapon. Change scopes, stocks, barrels, magazines and more. Rifles, secondary weapons, and pistols all have a huge variety of options. On top of that you can select the ammo to suit your target, from armour-piercing right down to non-lethal.
Invasion mode drop-in PVP - invade another player's Campaign as an Axis sniper and engage in a deadly game of cat and mouse, providing a new dimension to the challenge as you stalk your prey. Alternatively, as Karl you can call for assistance and have a second sniper drop in to help you out of a tricky situation.
Tense adversarial multiplayer - customise your character and loadout and earn XP, medals and ribbons as you take on competitive 16 player battles that will really test your sharpshooting skills. If co-op's more your style, you can team up with up to 3 other players against waves of enemies in Survival mode.
Enhanced kill cam - more realistic and grisly than ever, the trademark X-ray kill cam returns, showing you the true destructive power of each shot. Bones deflect bullets unpredictably, ripping a new path through enemy bodies. SMGs and pistols can also trigger kill cams, including multiple shots in dramatic slow motion.
Sniper Elite 5 igra izide 26 maja 2022 za Xbox One, Xbox Series X|S, PlayStation 4, PlayStation 5 in PC .
Sniper Elite 5 PC - minimum system requirements
Processor: Intel Core i3-8100
Graphics card: With a minimum of 4 GB of memory
DirectX: 12
RAM: 6 GB
Disk space: 85 GB
DirectX: 12
RAM: 6 GB
Disk space: 85 GB
nekoman ::
Zelo dober trailer igre, ko bom imel kdaj tak računalnik, da jo lahko igram, jo zagotovo bom:)
Do takrat pa si lahko predstavitve samo ogledam:)
Misliš sniper elite?
Comp ima 4 gb rama...
Glede na zahteve bi lahko tudi Sniper elite 2 in Sniper elite 3 in v bistvu Sniper elite 4 na minimum.
Sniper Elite 4 minimum requirements
Memory: 4 GB
Graphics Card: NVIDIA GeForce GTX 660
CPU: Intel Core i3-2100
File Size: 40 GB
OS: 64-bit Windows 7, 64-bit Windows 8.1 or 64-bit Windows 10
nekoman ::
A se nadaljevanja Sniper elite med sabo razlikujejo zelo, mislim glede zgodbe pa to?
Glede zahtev, grafike ipd. mi je jasno da se.
V vsaki igri igraš istega sniperja.
Zgodba je v vsaki igri drugačna pač imaš cilj, ki ga izvršuješ preko misij v igri.
Sniper Elite 2 se dogaja v Nemčiji bolj proti koncu vojne.
Sniper elite 3 se dogaja v Afriki
Sniper Elite 4 se dogaja v Italiji
Sniper Elite 5 se bo dogajal v Franciji
Sniper Elite 5 ponuja presenetljivo veliko svobode v polodprtem svetu
https://hop.si/2022/05/01/sniper-elite-...
- spremenil: oo7 ()
silak ::
Jaz kupujem tu, pa do sedaj je bilo brez problema..https://www.instant-gaming.com/en/10620...
Kinguin ne velja za legalnega, čeprav jaz sem v preteklosti tam kupil nekaj iger in nisem imel nikoli težav.
Na YT so videi, enega sem našel, kjer očitno reče, da je samo reuse the same kot sniper elite 4, in da je za to kar ponuja predrago..
Tako da nebi šel v prednaročilo, ker bo verjetno zelo hitro kakšna akcija, če je to kopija SE4.
Sniper Elite 5 Interview: France, Invasion Mode, and Going Bigger
https://halfglassgaming.com/2022/05/sni...
Do zdaj preigral dve misiji. Igralnost je enaka kot v prejšnjih igrah edino sedaj imaš tudi skill tree.
Pokrajina je zelo lepa in mape so kar velike.
Stopnje so res ogromne. Umetna pamet je bolj slaba drugače pa vredu igra. Sem opravil tretjo misijo.
Ima kdo obcutek, da je peti del kot Commandos v 3D
. Vsaj tretja misija se lahko igra kot Commandos.
Na yt je speed run tretje mape. Manj kot 4 minute. Jaz sem rabil vec kot to da sem sploh zacel streljat iz startne pozicije....
Vem.
Tretja misja me je spominala na Comanndose.
Počaka da se obrne, laufaj, fentaj, odnesi v zaboj....
Save
Pojdi po naslednjega.
Druga misija je imela na vrtu supper, kot so imeli commandosi corake v zemllji/snegu in če je opazil korake je sledil...
Zato imam občutek kot da bi igral commandose.
Save
Te misije se spominjam: jaz sem jih na kocu enega po enega davil z nožem.
Je šel pa res relativno optimalno
Še eno neumno vprašanje. ALi je imel še kdo občutek v prvi misiji da je ozadje od HBO Chernobyl (2019) It's not 3 roentgen its 15000
ZiedRieke ::
Ima kdo obcutek, da je peti del kot Commandos v 3D. Vsaj tretja misija se lahko igra kot Commandos.
Čist enak filing sem dobil, kot da bi igral Commandose, sploh 3 misija, ko dejansko moreš igrati 100% stealth, nemoreš mimo enemijev drugače kot da počasi "čistiš" mapo in skrivaš trupla.
Da ne odpiram nove teme.
Napovedana nova Sniper Elite igra katera izide enkrat drugo leto.
Sniper Elite: Resistance - Reveal Trailer | Xbox Game Pass, Xbox Series X|S, Xbox One, PC, PS5 & PS4
In a gripping new story that runs parallel with Sniper Elite 5, Harry Hawker, agent of the Special Operations Executive (SOE), takes the lead for the first time as he discovers an insidious new Wunderwaffe - something so powerful, it guarantees the Nazis will win the war.
V prvih petih igrah se je igralo kot lik Karl Fairburne tokrat prvič kot Harry Hawker.
Sniper Elite: Resistance igra izide 30 januarja 2025 - PlayStation 5, Xbox Series X|S, PlayStation 4, Xbox One, PC Steam, Epic Games Store in Microsoft Store.
| » | AtomfallOddelek: Igre | 4969 (1794) | Predsednik11 |
| » | Sniper Ghost Warrior ContractsOddelek: Igre | 3692 (1655) | oo7 |
| » | Sniper elite 2Oddelek: Igre | 8167 (4111) | oo7 |
| » | Sniper elite 4Oddelek: Igre | 3954 (2414) | oo7 |
| » | Sniper Elite 3Oddelek: Igre | 8897 (6539) | bambam20 |
