Forum » Problemi človeštva » Vojna proti moškim, drugič.
- spremenil: gruntfürmich ()
Unknown_001 je izjavil:
Hm, pred unim kamnitim cvetom pri Jasenovcu še nisem fotkal bicikla. Lahko bi.
Lejga... v Krško je majstr pršu pa nč povedu da b ti vsaj za pijačo dal.
mislim da je to stara slika. verjetno je pol zavil k buršiču da je imel mir...
Unknown_001 ::
gruntfürmich je izjavil:
mislim da je to stara slika. verjetno je pol zavil k buršiču da je imel mir...![]()
Ah... drugič ga bom kr v zasedi počakal.
Begabt
Ahahahahahahahaah. Polepšal si mi dan.
Nasmejal pa sem se ja... to bi pač feministke nardile pa jype tudi :P
Unknown_001 ::
Begabt
2019bosuper ::
60k women march on Trelew for annual summit
Chernobyl 1986 colorizedNobene ženske ni blo vmes. Pa v Fukušimi tudi ne.
Fantje, čustveno labilni, pa niso sposobni nadzirat reaktorjev.
2019bosuper ::
- spremenil: D3m ()
louser ::
2019bosuper je izjavil:
Nihče ni, ampak ženske so manj nesposobne od moških.
Zakaj pa potem že celo zgodovino živimo pod zlobno patriarhalno vlado? Če so bolj sposobne od moških bi pričakoval obratno, podobno kot boljši tenisač premaga slabšega.
Slabši tenisač brez problema premsga boljšega, če mu meče polena pod kolena. Ali pa podre cel hlod na noge.
FormerUser ::
New Ethiopian Prime Minister Abiy Ahmed has released the names of his cabinet members, revealing that half of his government's ministerial posts will now be run by women. Speaking about his new cabinet before Parliament, Abiy declared that women are "less corrupt than men" and having more women in power would help improve stability and sustain the government's goals of peace and reformation.
The autonomous region of Rojava, as it exists today, is one of few bright spots - albeit a very bright one - to emerge from the tragedy of the Syrian revolution. Having driven out agents of the Assad regime in 2011, and despite the hostility of almost all of its neighbours, Rojava has not only maintained its independence, but is a remarkable democratic experiment. Popular assemblies have been created as the ultimate decision-making bodies, councils selected with careful ethnic balance (in each municipality, for instance, the top three officers have to include one Kurd, one Arab and one Assyrian or Armenian Christian, and at least one of the three has to be a woman), there are women's and youth councils, and, in a remarkable echo of the armed Mujeres Libres (Free Women) of Spain, a feminist army, the "YJA Star" militia (the "Union of Free Women", the star here referring to the ancient Mesopotamian goddess Ishtar), that has carried out a large proportion of the combat operations against the forces of Islamic State.
Obstajajo tudi raziskave IMF in World Bank, ki pravijo, da moški, ki dobijo finančno pomoč za modernizacijo kmetij, ta sredstva zapijejo, ženske jih pa pogosto uporabijo dolgoročno finančno pozitivno ter vedno vsaj vzdržno.
- spremenilo: jype ()
Spajky ::
FormerUser je izjavil:
T... New Ethiopian Prime Minister Abiy Ahmed has released the names of his cabinet members, revealing that half of his government's ministerial posts will now be run by women.Ah zato je šel naš Pahor pred dnevi dol pogledat, če so tudi lepe ...
Gagatronix je izjavil:
Hahahahahaha :)) Sej nc cudnga da je Etiopija v takm kurcu k je.Do zdaj je bila, zdaj pa ne bo več, ker bo vpliv "hahaha" moških znatno zmanjšan.
xmetallic ::
Tisto, ko izveš, da ima tudi Etiopija bolj naprednega predsednika vlade kot je naš:
Aha. Sposobnost se po novem meri v tem koliko žensk pristaviš k napajalnemu koritu. S to izjavo si dokazala, da bi ti ženske na nek položaj postavila samo zato ker so ženske, ne pa zato, ker so dejansko sposobne za opravljanje dela na tem položaju.
Obstajajo tudi raziskave, ki pravijo, da moški po navadi ne zanosijo in ne koristijo porodniške, zato so bolj primeren predvsem pa stabilen kandidat za vodilni položaj v nekem podjetju. Podjetje potrebuje stabilnost, dedication, nekoga, ki bo posvetil svoj čas podjetju. Ne nekoga, ki bo vsake 3 tedne na bolniški, vsake tri leta pa na porodniški.
- spremenilo: xmetallic ()
Unilseptij ::
Kje to piše, zakaj je to samo po sebi umevno, iz česa to sledi? Res je, da to kar praviš, torej popolnoma vse podrediti službi, večinoma bolje uspeva moškim. Je pa tudi res, da je veliko takih moških dejansko psihopatov (bilo je že precej napisanega o tem) in jaz močno dvomim, da je komurkoli v dolgoročnem interesu, da družbo vodijo psihopati, četudi to kratkoročno prinaša dobiček.
Unknown_001 ::
Ženskam se slabo piše.
Ti sploh veš, čemu je Tinder namenjen? Če bi vedel, se ne bi čudil.
Begabt
2019bosuper ::
Tinder je ultimativni indikator za ženske če so kaj vredne.
Unknown_001 ::
Ti si zih še vedno junfr.
Begabt
2019bosuper ::
Na žalost ne.
PS: a se dobi kakšen gejmerski stol ki ima v sredini sedala luknjo da mi po seksu ni vedno treba sredeti postrani?
xmetallic ::
Unilseptij je izjavil:
Zato ker ženske praviloma želijo imeti otroke. Podjetje pa potrebuje nekoga, ki bo, kot si že sam ugotovil, svoje življenje podredil službi. Upravni odbor si pač ne more privoščiti, da enega izmed 4 vodilnih 16 mesecev ni v službo. Čez dve leti se pa zgodba ponovi z drugo nosečnostjo, pa še tretjo. Če se je ženska pripravljena podrediti službi in se odpovedati nosečnosti, ter seveda to črno na belem podpisati (za to je najprej potrebno spremeniti zakonodajo) potem ne vidim težav, da je tudi taka oseba v upravnem odboru. Nekdo, ki bo vsakih par tednov na bolniški, 3x po 16 mesecev na porodniški pa ni oseba, ki bi ji zaupal tako pomembno funkcijo kot je vodenje podjetja. Zdej pa v ta primer dodaj dve ženski. Štirje v upravnem odboru, dve od teh sta ženski, in obe hkrati na porodniški. Pa se pejt vodenja korporacije ko polovice vodilnega kadra ni v službi.
Unilseptij ::
Za primer, novozelandska premierka si je čisto lahko privoščila porodniško... pa se država začuna ni sesula v tistih par mesecih.
- spremenilo: Unilseptij ()
2019bosuper ::
SimplyMiha je izjavil:
Želijo si otroke, ko je že prepozno.Krivda je seveda na strani xmetallica, ki propagira potrošniški patriarhat.
Zakaj bi imele otroke če imajo lahko 30 mačkov ali pa posvojijo čokoladkota iz sirije?Saj nimajo otrok.
Unknown_001 ::
Begabt
Guys... eno vprašanje. Kakšna bi bila vaša reakcija, če bi vam ženska sporočila, da je verjetno nepričakovano zanosila."V baraki mamo še par stvari k smo mel mejhne froce, če rabš."
FormerUser ::
Ne le Etiopija....
Tudi Ruanda je zelo visoko na listi držav z velikim številom žensk v parlamentu, potem ko se butasti dedi poklali med sabo. Tudi to je eden od receptov za bolj miroljubno in enakovredno družbo.
Znan je primer, ki ga je opisal Robert Sapolsky, ko je opazoval združbo pavijanov v Keniji kjer so se najbolj agresivni samci po naključju zastrupili s tuberkulozno okuženim mesom in pocrkali, pavijani na tistem področju so še sedaj med najbolj miroljubnimi.
To potrjujejo tudi ugotovitve mnogih humanitarnih organizacij, če dajo sredstva v roke ženskam bo sita vsa družina, če moškim, jih bodo velikokrat zapili, zakockali ali zakurbali.
Unknown_001 ::
Predstavljaj si, da si 20 let mlajši.
Begabt
FormerUser ::
Ti pa s to izjavo dokazuješ, da smatraš ženske za manj sposobne čeprav prav nobena študija tega ne potrjuje torej gre izključno za tvoje predsodke. Dokazuješ tudi to, da te nič ne moti, da se na položaj postavlja moške samo zato ker so moški kot se je to počelo vseskozi.
Predstavljaj si, da si 20 let mlajši.Takrat sem dejansko bil v situaciji, ko nisem imel s čim pomagat, tako da sem zgolj ponudil splošno pomoč.
xmetallic ::
Tudi moški si želi otroke, če je normalen, celo skrbi za njih, tako da tudi ni neomejeno na voljo službi.
Res je. Vendar moški zagotovo ne bodo na bolniški zaradi nosečnosti. Malo verjetno je da bodo na porodniški, čeprav je tudi to možno.
Sploh je nekaj najbolj normalnega, da človek ima še življenje poleg službe.
Res je. Vendar pa na svetu obstajajo ljudje, ki ne želijo imeti družine, ljudje, ki živijo za delo. Taki prehitijo tudi moške, ki so bolj družinske narave.
Nerazumna in zgrešena je tvoja logika, ki favorizira psihopatsko vedenje. In tvoj "upravni odbor" seveda sestavljajo enake sorte tiči, izbrani po enakih zgrešenih kriterijih, zato je čisto logično, da samo naprej propagirajo enak nesmiselni vzorec in si zraven še izmišljajo razloge, da je to zato, ker so ženske manj sposobne.
Nisem trdil, da so ženske manj sposobne za v upravni odbor. Trdil sem, da so manj dostopne, da so manj časa na voljo (ni nujno, je pa zelo verjetno), da bodo slej ko prej šle na bolniško zaradi otroka, ali porodniško (ni nujno, je pa zelo verjetno).
Logika je čisto razumna. Lastnik podjetja želi, da podjetje konstantno deluje s 100% močjo, kapaciteto, you name it. Dol visi lastniku za tvoje otroke, nosečnost. Če nisi primeren kandidat ne kandidiraj za tako delovno mesto, oz. če se naknadno ugotovi, da nisi sposoben slediti tempu boš pač odstavljen s položaja.
Državo vodi malo več ljudi kot samo ena oseba. Število ljudi v upravnem odboru lahko prešteješ na prste ene roke, eventuelno dve. Primerjava ni na mestu.
SimplyMiha ::
xmetallic ::
Eh, lažeš. Tega nisem napisal. Trdim pa, da mora določen položaj zasesti najbolj sposobna in najbolj primerna oseba ne glede na spol. Ti pa trdiš, da mora v parlamentu sedeti 50% žensk samo zato ker so ženske. Lahko jih je tudi 80%. Dokler so tam zaradi svoji dokazanih sposobnosti in znanj, ne pa zaradi svojega biološkega spola, me prav nič ne bi motilo. Ko pa začnete na razne položaje, parlamente, upravne odbore vsiljevat ženske just because diversity, mi gre pa na kozlanje. Competence > diversity.
Vseeno ima časovno omejen mandat. Če ga ne more opravljati vsaj polovico, je morda bolje, da funkcijo prepusti komu drugemu.
Ima jo komu prepustiti. Podpredsednik. Na mnogih delovnih mestih pa te možnosti nimaš.
FormerUser ::
Glede na to, da so intelektualne sposobnosti med oba spola enakomerno porazdeljene, ne vidim nobenega razloga zakaj bi se morali bati, da za ženske kvote ne bi našli ustrezno sposobnih kandidatk.
xmetallic ::
Če so sposobne ne potrebujejo kvot. Če potrebujejo kvote, da pridejo v parlament, potem niso sposobne.
FormerUser ::
V družbi kjer bo vladala resnična meritokracija kvote ne bodo potrebne, dokler pa živimo v andro-centričnem svetu, kjer pravila pišejo moški, sebi na kožo, pa definitivno so.
SimplyMiha ::
- spremenilo: SimplyMiha ()
FormerUser ::
Moški pišemo pravila? Od kdaj pa? Kolikor vidim, so ta pravila bolj pisana vam na kožo.
Kam ti to gledaš? Ti je ravno kolega xmetallic razložil, da podjetja preferirajo osebe, ki so po cele dneve v službi, pa čeprav ne delajo drugega kot surfajo po netu in to je pač bolj napisano na kožo moškim, ki imajo doma partnerice, ki poskrbijo za vsa domača opravila in otroke.
| » | Velika Britanija: žrtve posilstev bodo morale policiji predati mobilne telefone (strani: 1 2 3 4 5 6 )Oddelek: Loža | 74577 (70127) | vostok_1 |
| ⊘ | Šeriatsko pravo (strani: 1 2 3 4 … 11 12 13 14 )Oddelek: Loža | 160849 (152528) | HODL |
