Forum » Operacijski sistemi » outlook 2016 in .vcf
blze ::
Pozdrav.
Iz Windows live mail sem izvozil stike v .vcf. V mapi imam 600 stikov. Kako najlažje uvozim v Outlook? Namreč če dam uvoz potem moram vsakega posebej klikat kar pa je zamudno.
Na internetu sem našel ukaz v cmd kako ti združi vse vcf v en sam vcf. To sem naredil in mi res združi vse vcf v enega, ko pa grem na uvoz v Outlook in najdem združen vcf mi samo en kontakt uvozi in sem spet na začetku.
Mora obstajati varianta kako vse naenkrat uvozit.
Hvala za pomoč.
Lp, Blaž
Hvala za pomoč.
Lp, Blaž
uživejte
blze
blze
nsa_ag3nt ::
https://www.howtogeek.com/175795/how-to...
https://support.microsoft.com/en-us/hel...
Open Windows Live Mail.
Click Contacts folder, and then click Export.
Select Comma separated values (.CSV).
In the CSV Export window click Browse and select the Desktop folder.
Type WLMContacts in the file name and then click the Save button.
Click Next and select all the fields that you want to export, click Finish button and wait for the export process to be completed.
Note: The most common fields are First Name, Last Name, Email address and Telephone. If you are not sure about the information just select all the fields.
Note: This process can take some time, depending on the number of messages that you are exporting.
Close Windows Live Mail.
Open Excel, select File, and then click Open.
Select the Desktop folder, and choose to show All Files.
Select and open the WLMContacts.csv file that you created in step 5.
Select File, and then click Save As.
In the Save As dialog, change Save as type: to CSV (Comma delimited) (*.csv), and then click Save.
Click Yes if asked to replace or overwrite the existing file.
Click Yes if asked to keep the CSV format.
Close Excel.
Open Outlook, select Contacts and click File.
Select Open & Export and click Import/Export.
In the window that opens, select Import from another program or file and click Next.
Highlight Comma Separated Values and click Next.
Click the Browse button and select the Desktop folder.
Select the file WLMContacts.csv, and then click OK.
Note: You can select some additional options to replace, duplicate, or do not import duplicated contacts.
In the next window highlight your Contacts folder and click Next.
Click Finish in the window that opens.
Za emaile
http://emltooutlookpst.blogspot.com/201...
Close Excel.
Za emaile
https://gizmodo.com/c/goodbye-big-five
- spremenilo: nsa_ag3nt ()
Leowillson ::
There are multiple option available to Import/Export VCF files into outlook file format but if you need a reliable solution which can easily Import/Export multiple VCF contacts at a time them opt VCF to outlook conversion. This tool Magnificent tool allows bulk conversion (multiple contact files of outlook can be transferred to vCard and multiple vCard data transfers to outlook).
More Info :-http://www.completeconverter.com/outloo...
- predlagal izbris: kloko ()
| » | Šifrirana mapaOddelek: Operacijski sistemi | 2830 (2301) | amigo_no1 |
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3703 (3093) | fr!Xy |
| » | Unencrypt...Oddelek: Pomoč in nasveti | 1636 (1529) | solatko |
| » | encryption keyOddelek: Operacijski sistemi | 1543 (1378) | poweroff |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2605 (2561) | Tea Time |
