Forum » Šport » UFC - tema
UFC - tema
Naslednji vikend UFC 306
14 september 2024
Bantamweight Sean O'Malley (c) vs. Merab Dvalishvili
Women's Flyweight Alexa Grasso (c) vs. Valentina Shevchenko
Featherweight Brian Ortega vs. Diego Lopes
Lightweight Daniel Zellhuber vs. Esteban Ribovics
Flyweight Ronaldo Rodríguez vs. Ode' Osbourne
Women's Bantamweight Irene Aldana vs. Norma Dumont
Lightweight Ignacio Bahamondes vs. Manuel Torres
Women's Strawweight Yazmin Jauregui vs. Ketlen Souza
Flyweight Edgar Chairez vs. Joshua Van
Bantamweight Raul Rosas Jr. vs. Aori Qileng
14 september 2024
Nobenega komentarja? Sem se bal, da se bo glavna borba odvijala na način, kot se je. Dvalishvilijev slog je izrazito neugoden za O'Malleyja. Ne vidim, da bi ga kdaj lahko premagal.
Chandler se bo na UFC 309 ponovno pomeril z Oliveiro. Vsi pogovori z McGregorjem so pričakovano padli v vodo. Tip se zaradi tega ni boril že dve leti, kariero si uničuje zaradi nastopaškega klovna.
Zigerion ::
Vrhunski event z vidika show-a. Tale Sphere je res čudo. Drugače pa prvi trije fight-i Rodriguez vs Osbourne, Ribovics vs Zellhuber in Lopes vs Ortega so bili res klasa, se splača pogledat če ste gledali samo oba champion fight-a, ki pa sta bila precej nezanimiva.
Ne pozabit še prej na UFC 308 - Magomedov, Rakič, Volkov, Chimaev, Whittaker, in pa Holloway vs Topuria - zna biti zanimivo (UFC 307 razen Pereire malo manj).
Kaj nas še čaka letos od glavnih UFC borb :)
Vse borbe še niso dokončno znane in se jih bo še dodalo sploh proti koncu leta.
5 oktober
UFC 307: Pereira vs. Rountree Jr.
Light Heavyweight Alex Pereira (c) vs. Khalil Rountree Jr.
Women's Bantamweight Raquel Pennington (c) vs. Julianna Pe?a
Bantamweight José Aldo vs. Mario Bautista
Women's Bantamweight Ketlen Vieira vs. Kayla Harrison
Middleweight Roman Dolidze vs. Kevin Holland
Welterweight Stephen Thompson vs. Joaquin Buckley
Women's Strawweight Marina Rodriguez vs. Iasmin Lucindo
Middleweight César Almeida vs. Ihor Potieria
Women's Strawweight Carla Esparza vs. Tecia Pennington
26 oktober
UFC 308: Topuria vs. Holloway
Featherweight Ilia Topuria (c) vs. Max Holloway
Middleweight Robert Whittaker vs. Khamzat Chimaev
Light Heavyweight Magomed Ankalaev vs. Aleksandar Rakić
Middleweight Sharabutdin Magomedov vs. Armen Petrosyan
Featherweight Lerone Murphy vs. Dan Ige
Welterweight Geoff Neal vs. Rafael dos Anjos
Lightweight Mateusz Rębecki vs. Myktybek Orolbai
Bantamweight Said Nurmagomedov vs. Daniel Santos
Middleweight Abusupiyan Magomedov vs. Brunno Ferreira
Heavyweight Kennedy Nzechukwu vs. Justin Tafa
Welterweight Rinat Fakhretdinov vs. Nursulton Ruziboev
Bantamweight Farid Basharat vs. Victor Hugo
Light Heavyweight Ibo Aslan vs. Raffael Cerqueira
16 november
UFC 309: Jones vs. Miocic
Heavyweight Jon Jones (c) vs. Stipe Miocic
Lightweight Charles Oliveira vs. Michael Chandler
Middleweight Bo Nickal vs. Paul Craig
Bantamweight Jonathan Martinez vs. Marcus McGhee
Women's Flyweight Veronica Hardy vs. Eduarda Moura
Women's Flyweight Viviane Araújo vs. Karine Silva
Light Heavyweight Nikita Krylov vs. Azamat Murzakanov
Middleweight Chris Weidman vs. Eryk Anders
7 december - UFC 310
Light Heavyweight Anthony Smith vs. Dominick Reyes
5 oktober
26 oktober
16 november
Občutek imam, da se bo za Miočića grdo končalo. Jones bi si zaslužil dostojnega nasprotnika.
Tale borba se mi zdi najbolj zanimiva - Middleweight Robert Whittaker vs. Khamzat Chimaev
Se bo Khamzat poigraval s Whittakerjem kot s Usmanom ?
BaTeMaN ::
Sem že mislu, da ga bo Dana skenslal zaradi prijateljevanja z Ramzan-om Kadyrov-om.
less then zero
Zigerion ::
Verjetno zmagovalec Rakić vs. Ankalaev. Je pa rekel Pereira da potrebuje tokrat malo več pavze.
Dana ga naj končno spusti v težko kategorijo, ki si jo želi. Da ne bomo gledali nesmiselnih dvobojev, kot je Miočićev.
Bo še kje drugje prenos kot na Voyo ?
https://m.mmastreams100.com/fight/ufc/6...
Ne spremljam toliko konkurence in me je presenetilo, da je PFL pred časom kupil Bellator. UFC je dobil močnega nasprotnika.
BaTeMaN ::
Upam, da bo 16.11. res Jones : Miocic... ne vem zakaj se mi že to zdi nemogoče;. za te moje dvome je kriv sicer en drug :)
less then zero
BaTeMaN ::
Kdo je kriv ? :)
Ma lej conor vs chandler, mike tyson vs jake paul, its its its... zato...
less then zero
Khamzat Chimaev je prava žival. Samo ne vem zakaj je tako nizko rangiran v middleweight šele na 13 mestu ? Ne vidim kdo bi ga lahko premagal ???
Ilia Topuria pa je Hollowayu prvi v karieri dal KO.
Kayzon ::
All aboard on khamzat hype train choo choo!! haha
https://www.youtube.com/shorts/mmBdPoBV...
Drgac Illia ma res dobro boks tehniko,upam si celo trditi da ima celo najboljso v celem UFCju in me res veseli da je max dubu po picki ki mi je zadnje case sel ze posteno na k.
Whittaker revealed that the submission from Chimaev actually exposed an issue he's had with his teeth in the past. It turns out that was what really caused him to tap out so quickly rather than Chimaev potentially dislocating his jaw with the face crank.
"It wasn't the jaw. It was the teeth," Whittaker said. "The teeth got pushed in. I've kind of always had loose teeth and they got looser. It was the face crank. His forearm went straight on the bottom tooth. I didn't even have a moment to turn the head or anything. It was on. It is what it is.
Khamzat Chimaev res prava žival v ringu. Edini kateri ga lahko pretepajo so Ramzan Kadyrov in njegovi otroci. Ampak tam mora pustiti, da ga premagujejo drugače verjetno ne bo prišel živ iz Čečenije.
Najprej so govorili, da mu uspe zmagovati na račun slabših nasprotnikov, ampak Chimaev dokazuje, da se bi z lahkoto vpletel v borbo za naslov prvaka. Škoda, da kontantno skrivnostno boleha in da se je zdaj vrnil po več kot letu dni. Nazadnje je imel dve borbi leta 2022. Leto pred tem samo eno. Lani in letos prav tako samo eno v celem letu.
Zigerion ::
Se strinjam, plus da je menjaval kategorije med welterweight in middleweight - zato je tudi tako nizko na lestvici. Strickland pravi da ima zagotovljeno borbo za pas z DDP-jem, zmagovalec pa verjetno s Chimaev-om?
Kayzon ::
Upam d odjebejo stricklanda k je eden najbolj boring kurcev kar sem gledal pa gledam ze od konec PRIDEa dalje.
Aha vidim, da so posodobili lestvico Khamzat je skočil za 10 mest.
Middleweight
C - Dricus Du Plessis
1. Sean Strickland
2. Israel Adesanya
3. Khamzat Chimaev
Middleweight
1. Sean Strickland
2. Israel Adesanya
3. Khamzat Chimaev
To je že bolj pravilno.
Rad bi ga videl v borbi za prvaka, ampak še prej bi rad videl, da razmontira in osramoti Israela.
čEZ 1 TEDEN
Lightweight Mauricio Ruffy vs. James Llontop
Lightweight Jim Miller vs. Damon Jackson
Heavyweight Marcin Tybura vs. Jhonata Diniz
Welterweight Mickey Gall vs. Ramiz Brahimaj
Welterweight Bassil Hafez vs. Oban Elliot
arnecan1 ::
Kot pričakovano, Jon Jones je star, Stipe je še starejši.
Tega mu ni bilo potrebno (Stipeta mislim), razen če je v to šel za denar. Jon Jones je bil favorit, tako na stavnicah kakor med strokovnjaki. Od Stipeta so pričakovali čudež, kakor proti Ngannou. S to razliko, da tisto ni bil čudež, samo mediji in Dana White so takrat podcenjevali Stipeta v prvi borbi. To danes bi bilo večje presenečenje, če bi padel Jones.
BaTeMaN ::
Prvo beden box, pol beden UFC, dobro Chandler pa Olivko sta bla ok,.. pol pa najbolj dolgočasna dirka moto GP.
Kako zanič vikend. :)
less then zero
arnecan1 ::
Stipe je senca stare slave. Počasen.
No, saj tudi Jonesu se poznajo leta, ampak 1/2 manj kakor Stipetu. Ali Mike Tysonu, če smo že pri tem.
Stipe je 5 let starejsi. 42 proti 37 ni zanemarljivo in "posteno".
- spremenil: kow ()
5 let v tem primeru ni nič. Stipe je bil "kripl" že, ko je samo spremljal borbe med občinstvom. Enkrat so se že delali norca, da je komaj prišepal do sedeža.
BaTeMaN ::
Sem prejle videl tole... plačila UFC 309 in nenadoma je vse popolnoma jasno zakaj je bilo kot je bilo...
JJ 6.292.000
SM 4.232.000
CO 1.071.000
MC 1.056.000
JJ 6.292.000
SM 4.232.000
CO 1.071.000
MC 1.056.000
less then zero
14 DECEMBER
Welterweight Colby Covington vs. Joaquin Buckley
Featherweight Cub Swanson vs. Billy Quarantillo
Flyweight Manel Kape vs. Bruno Gustavo da Silva
Light Heavyweight Vitor Petrino vs. Dustin Jacoby
Bantamweight Adrian Ya?ez vs. Daniel Marcos
Light Heavyweight Navajo Stirling vs. Tuco Tokkos
Lightweight Michael Johnson vs. Ottman Azaitar
Lightweight Joel Álvarez vs. Drakkar Klose
Featherweight Sean Woodson vs. Fernando Padilla
Featherweight Miles Johns vs. Felipe Lima
Women's Flyweight Miranda Maverick vs. Jamey-Lyn Horth
Bantamweight Davey Grant vs. Ramon Taveras
Women's Strawweight Josefine Lindgren Knutsson vs. Piera Rodriguez
Rumor: Jake Paul Could Be Fighting a Major UFC Star in 2025
Jake Paul reportedly gearing up to take on Conor McGregor in 2025.
The bout is rumored to take place in India in either July, August, or September.
https://gamerant.com/jake-paul-conor-mc...
18 januar
UFC 311: Makhachev vs. Tsarukyan 2
Lightweight Islam Makhachev (c) vs. Arman Tsarukyan
Bantamweight Merab Dvalishvili (c) vs. Umar Nurmagomedov
Light Heavyweight Jiří Procházka vs. Jamahal Hill
Lightweight Beneil Dariush vs. Renato Moicano
Middleweight Kevin Holland vs. Reinier de Ridder
Light Heavyweight Johnny Walker vs. Bogdan Guskov
Bantamweight Payton Talbott vs. Raoni Barcelos
Heavyweight Jailton Almeida vs. Serghei Spivac
Middleweight Zachary Reese vs. Sedriques Dumas
Lightweight Grant Dawson vs. Carlos Diego Ferreira
Women's Bantamweight Karol Rosa vs. Ailín Pérez
Bantamweight Rinya Nakamura vs. Muin Gafurov
Bantamweight Ricky Turcios vs. Bernardo Sopaj
Flyweight Tagir Ulanbekov vs. Clayton Carpenter
Ja saj vidiš, da so tudi čisto nori na skriptiran WWE.
Pa kaj amerika ima res rada ta garbage?
Zigerion ::
Eh, nažalost je Tsarukyan out - poškodba hrbta. Main event je po novem Makhachev vs. Maicano
BaTeMaN ::
Moicano je 20 - 5 - 1
Islam je 26 - 1 - 0
Upam, da disco brazil zmaga :) kako sem naiven spet
Islam je 26 - 1 - 0
less then zero
| » | Floyd Mayweather Jr. vs. Conor McGregor (strani: 1 2 3 4 )Oddelek: Šport | 51515 (45163) | Jst |
| » | Boksarski dvoboj leta z zamudo zaradi težav s spletnim prenosomOddelek: Novice / Avtorsko pravo | 12848 (9744) | Vazelin |
| » | UFC 200Oddelek: Šport | 3892 (3306) | leiito |
| » | Steven Seagal(Ai kido) & MMAOddelek: Loža | 6749 (6174) | solatko |
