Vlada 2018 - 2020
Vlada 2018 - 2020
Timurlenk je izjavil:
Pa če dodam še svoje - ni velike razlike, če namesto minimalca prejemaš 10 EUR bruto več lmao.
Tudi 27 tisoč je manj kot 33 tisoč.
Iz Srbije in Bosne pa naši kapitalisti uvažajo ljudi, ker so pač pripravljeni delat za 500EUR na mesec.
Točno tako. Zakaj pa naj bi prišli?
Pa še oni vse manj, saj raje delajo za 100 EUR manj doma,
https://www.serbianmonitor.com/en/vuksa...
40 000 din = 337 EUR
25 000 din = 211 EUR
ali pa za 1000EUR več 20 km severno od Maribora.
Saj pravim, da bi ostrejši pogoji upokojevanja zdaj prišli še kako prav. Plačna inflacija tudi prihaja, čeprav počasi.
Timurlenk ::
Glede krize - ponavljati se začenja obdobje 2008.
The IMF does not pull any punches in its latest post on the IMF blog. It is really worried that so-called 'leveraged loans' are reaching dangerous levels globally. These loans, usually arranged by a syndicate of banks, are made to companies that are heavily indebted or have weak credit ratings. They are called "leveraged" because the ratio of the borrower's debt to assets or earnings significantly exceeds industry norms. The level of these loans globally now stands at $1.3trn and annual issuance is now matching the pre-crash year of 2007.
"With interest rates extremely low for years and with ample money flowing though the financial system, yield-hungry investors are tolerating ever-higher levels of risk and betting on financial instruments that, in less speculative times, they might sensibly shun." says the IMF. About 70% of these loans are in the US; so that is where the risk of a credit crunch is greatest.
A section of the U.S. Treasuries yield curve just inverted for the first time in more than a decade.
An inverted yield curve is often a harbinger of recession. Že za zadnjih nekaj "kriz".
Plačne inflacije ne bo, ker bo prej nova kriza.
Demokracija je zdej v drugem planu, to je vendar jasno.
V pomoč:
https://www.merriam-webster.com/diction...
Oziroma prevedeno:
http://bos.zrc-sazu.si/cgi/neva.exe?nam...
Ne trdim, da do recesije ne bo prišlo, ampak od tega, da imamo pogoje, ki "pogosto" vodijo v recesijo do "zanesljivega zloma čez 2 leti" je kar dolga.
Timurlenk ::
- Asian share markets started the week on a cautious footing on Monday after weak economic data from China and Europe added to evidence of cooling global growth and reinforced anxiety over the impact of international trade frictions on business and profits.
The market's retreat also reflected a worsening global economic outlook, with the latest evidence of slackening momentum coming from China and Europe.
The survey showed euro zone businesses ended the year in a gloomy mood, expanding their operations at the slowest pace in over four years
https://www.channelnewsasia.com/news/bu...
maco-maco ::
Bivše skupne bratske republike vsako leto zgubijo po nekaj % delovne sile. Večkrat pa kar cele družine.
Ispred zgrade u kojoj se nalazi Konzularna kancelarija Ambasade Slovenije u BiH u Banjaluci
Take slikce se kar pogosto pojavljajo in veselo jih retweeta JJ. Sicer nisem siguren, če je to zaradi navdušenja.
Šarec pa je tak ljudski a odločen Pahor. No, najbrž.
Kaj?
  • spremenilo: maco-maco ()
Timurlenk ::
Kako je kapitalizem rešil bivše skupne bratske republike, pa tudi Slolvenijo
jernejl ::
Smrekar1 je izjavil:
Šarec ima očitno nekaj, kar je elektorat iskal v politiki. Kaj točno to je ne vem, najbrž karizma.
Šarec ima gospodarsko rast. In deluje prociklično, ker meče dodaten denar med ljudi sedaj, ko se gospodarstvo pregreva. Normalno, da je ljudem to povšeči.
Sploh za pokojnine je pravi čas ZDAJ
Bomo videli, pri pokojninskih reformah je imela večinoma prste vmes desnica, zadnja reforma je bila sprejeta - oh groza - pod Janševo vlado. Od "levih" je nazadnje poskusil Pahor in leta 2011 pogorel pred ljudstvom.
ZaphodBB ::
Kapitalizem je kadar vse vzvode v družbi nadzoruje država, da občani ne morejo nič sami?
Vazelin ::
Šarec ima predvsem srečo, da lahko tala bonbončke gospodarske rasti zadnjih let.;) upam, da jih ne bo talal preveč, ker v morebitni krizi bomo potem jebali ježa vsi zaradi ozke skupine ljudi, ki od teh bonbončkov imajo korist.
Samo DDV bo pustil krizni.:)) Blefer za moje pojme. Ja, država si ne more privoščiti spusta DDV, ker tako levo desno talaš milijardice, dragi Šarec ;) So pa slovenci hlapci in očitno hočejo imeti dvignjen ddv, da lahko učiteljice, uradniki namesto njih več zapravljajo.
  • spremenilo: Vazelin ()
A mi imamo vlado!? Kaj točno pa ta dela?
Do sedaj ni bilo od tega absolutno in popolnoma nič.
Šarec je pa kot vsi. Vzel si je čas za premislek. Očitno ni še nič premislil.
Vazelin ::
Ne smeš delati preveč. Moraš ohranjati status quo. Če delaš preveč je nezadovoljstvo. :D
ZaphodBB ::
feryz je izjavil:
Prijatelj, verjami mi, da za občane ni nič bolj strašljivega kot učinkovita vlada, ki dela.
Vazelin ::
Dejstvo je, da je bil Šarec medijsko forsiran, s strani vplivnih medijev. Šarec dela po agenti lastnikov teh medijev, ki predstavljajo slovensko buržoazijo, npr. Petrič (kateri bo kot po naključju lahko celo gradil drugi karavanški predor, ko so izključili turke>:D). Šarec ne bo naredil ničesar takšnega, s čimer bi razjezil svoje lastnike, ker ve, da ga lahko drug dan zamenjajo za novega, bolj uslužnega. Hence, Šarec je zaščitnik nekaj vplivnih ljudi, ki imajo denar.
Jaz si tule ne slepim. Dokler ne spusti DDV na predkrizno raven je zame navaden blefer. Jaz bi tudi raje sam zapravljal tistih par 100 eur, ki mi odtegne višji ddv letno, nameto tega pa moj denar zapravlja soseda učiteljica
Podlo in svinjsko je, da se odpravlja krizne ukrepe, za DDV pa kao še ni čas in je še kriza.:)) Prekleti buržoazi. Zaradi krize sem še kar ob 1 PS4 letno
Vazelin ::
Morda pa dvignimo ddv še za par %. Pa kaj, če socialci ne bodo imeli več za hrano. Važno da bo še za dvig ali dva v JS v naslednjih letih in za preplačilo, npr. prijateljskih poslov v Karavanškem predoru.
Danes sem totalno ra*pizden. Tak dan ;)
ADIJOOO1 ::
Umetno vladna forsirana anketa.
maco-maco ::
Ljudje podcenjujejo učinke pomanjkanja spanca.
Kaj?
Šarec ima očitno nekaj, kar je elektorat iskal v politiki. Kaj točno to je ne vem, najbrž karizma. Zaenkrat mu kar gre, bomo videli kako bo z reformo zdravstva in pokojnin.
Sploh za pokojnine je pravi čas ZDAJ, ne čez dve leti. Manjka nam delovne sile, malo ostrejši pogoji upokojevanja bodo za gospodarstvo zdaj blagodejni, brezposelnost ne bo porasla, morda bo kdo kak mesec več iskal službo, morda še to ne. Čez dve leti bo lahko že drugače, tudi javna blagajna zna biti malo bolj prazna.
Bomo videli, upam na najboljše.
Welcome to the club.
In other news:
Vlada se menda ne bo spuščala v pokojninsko reformo. (vir)
Ter:
Poslanci podprli višjo porabo države (vir)
Kaj pa ste pričakovali kot ste volili janšo (pol za, pol proti) ? Čudež?
  • spremenil: MrStein ()
MrStein je izjavil:
In other news:
Če nekaj citiraš moraš zadevo dati v navednice, tako: "Vlada se menda ne bo spuščala v pokojninsko reformo."
To je dobeseden citat iz članka zgoraj in edina referenca na pokojninsko reformo. Heh.
Ter:
Jup in če bereš dlje od naslova boš ugotovil, da bomo kljub povišani porabi še vedno imeli večji proračunski presežek kot smo si ga zadali. Povedano drugače, gre nam tako dobro, da lahko povečamo tako porabo kot tudi presežek, ki ostane.
A kaj, ko to ni tako udarno, kajne? Je treba stokati kako nas bodo spravili na kant.
Heh. Če mi gre plača gor za 400EUR/mesec in povečam svoje izdatke za 200EUR/mesec se ne bližam bankrotu. Nekateri žal ne razumete.
  • spremenil: Smrekar1 ()
Lahko obračaš koliko češ. Pokojninske reforme ni.
Ko pa jo bom videl, bom drugačnega mnenja. Prej ne.
Timurlenk ::
ZaphodBB je izjavil:
Država je zgolj vzvod za kapitaliste.
ZaphodBB ::
Aha kapitalisti so potem družbenopolitični delavci?
scipascapa ::
Smrekar1: te uradne številke so larifari....število folka na minimalcih je 2x več. ko ste ravno omenili ddv...
nazaj na 20% kdaj?
poglejte malo te cifre:
https://www.zurnal24.si/slovenija/sarec...
scipascapa je izjavil:
Aja? Dokaži. Ne rekala-kazala, pokaži študijo, ki pokaže te rezultate in obrazloži zakaj je bolj kredibilna od uradnih številk.
Veliko sreče.
nazaj na 20% kdaj?
Verjetno bo še kar trajalo.
DDV je največji posamezni vir davčnih prihodkov.
Navedel pa je, da je v tem letu otroški dodatek prejemalo približno 18.600 otrok tujcev. Skupno število otroških dodatkov je približno 304.000, kar pomeni, da otroci tujcev predstavljajo 6,1 odstotka od skupnega števila upravičencev.
Po podatkih OZN v Sloveniji živi 244.800 migrantov, ki niso bili rojeni v Sloveniji
1. januarja 2018 je imela Slovenija 2.066.880 prebivalcev
-> davki od dela tujcev subvencionirajo otroke slovenskih staršev
Hvala za ta podatek.
https://www.stat.si/StatWeb/news/Index/...
scipascapa ::
Zakaj bi dokazoval? Ogromno jih prejea manja kot 640 neto, recimo 560-570 potem pa razliko in te kao štejejo, da prejemajo minimalno, a realno še nižjo.
Vsi zaposleni (večina) v Mercatorju, Tušu, Šparu, Leclercu, Merkur ipd so na minimalcih, pa vse snažilke, smetarji itd....
Timurlenk ::
Lahko tako rečeš. Kapitalisti financirajo stranke in politike, nastavljajo politike in potem ti politiki seveda delajo v imenu tistih, ki jih financirajo in nastavljajo.
looser ::
ampak to ni celotna zgodba, po mojem...
ker sicer bi se ne-kapitalistični pol zavzemal za odpravo držav (s pripadajočimi mehanizmi)...
te definicije in analogije z nekaterimi poklici iz manj uspešne preteklosti so precej, tako, nedodelane...
Timurlenk ::
looser je izjavil:
Saj se. Kaj pa so zasebna "trgovinska" sodišča, ki jih vzpostavljata CETA in TTIP? Hkrati je pa precej bolj simpl podpirati državo s policijo, ki bo tepla nezadovoljno prebivalstvo, kot pa neposredno nadzirati svojo zasebno milico, ki bo tepla nezadovoljno prebivalstvo.
ZaphodBB ::
A sindikatov in revolucionarjev pa nič ne financirajo kapitalisti? Syriza ni bila pravi socializem?
To, da sta tako Mesec kot Tsipras izdala revolucijo zavoljo lastnih interesov ju retroaktivno izbriše kot velika upa Revolucije?
https://publications.europa.eu/en/publi...
4. mit
Več sreče prihodnjič.
Timurlenk ::
A to je una fora, ko bi whitehouse.gov razložil, kako ameriška vojska ne počne zločinov v državah po svetu
Truga ::
tako je, eni ljudje se izkazejo za navadne laznjivce.
ZaphodBB ::
Truga je izjavil:
Hecno, da se je to do sedaj zgodilo še z vsemi komunističnimi revolucionarji. Kako naj vem, da ti nisi isti?
Vazelin ::
Evo v Tarči bo. Govorili bodo o tem kako bo slovenski del karavanškega predora dražji od avstrijskega, čeprav so gor višje cene storitev in ostalega. :))
Kako svinjsko se shilla Petriča (ki je eden finest F21 članov čistko tako mimogrede, "nepomembno":))). Baje turki niso dovolj okej. Zna pa Petrič, pa čeprav ni enega predora skopal.
Raje ne pomišljam kakšna mafija obvladuje te posle pri nas. Šivilja zna tudi imeti svoje prste globoko v marmeladi - je le šefica infrastrukture. Kar naenkrat so turki problematični :D
Haha vse skupaj je prav un blast from the past (predvsem by lds 90s)
Vazelin je izjavil:
Hja, cena za "socialni mir"...
Vazelin ::
https://siol.net/novice/slovenija/drzav...
Ma ne no. Pa ravno en od tistih svetohlincev, ki so v tistih strankah, ki podpirajo visoke in pravične davke:)) Pod Bratuškovo smo se baje počutili varne, ko je višala davke. In potem ti ravno taki utajujejo:))
Next please. Cesar je gol.
Kako mi gre to na bruhanje.
poweroff ::
Saj so zaenkrat samo neka ugibanja. Morda celo laži.
Je pa lepo povedal:
"Če bi se izkazalo, da je prišlo do kakšnih napak, je jasno, da bom, tako kot vedno, tudi tokrat prevzel odgovornost,"
Meni se sicer to bere bolj kot:
"Če bi se izkazalo, da je so me dobili, je jasno, da bom, tako kot vedno, tudi tokrat prevzel odgovornost,"
sudo poweroff
Vazelin ::
Upam da so samo ugibanja, ker od Vilfana si ne bi mislil, da je "tak"
:D
drvo ::
Zakaj pa si od Vilfana ne bi mislil, da je "tak"? Ker je igral košarko?
Saj je že prej imel neke mutne posle z nekimi " Ljubljanskimi travniki". Baje.
Vazelin ::
https://www.24ur.com/novice/slovenija/p...
Tako opevan projekt, ki je ogrožal celo obstoj Šarčeve koalicije, se lahko izkaže za blamažo, opozarjajo svobodni sindikati. Ker je država zgolj dvignila višino minimalne plače, s 638 na 667 evrov, ni pa spremenila davčne zakonodaje, bodo delavci ne le v višjem dohodninskem razredu, celo nižje otroške dodatke bodo dobili. Se država dela norca iz najbolj ranljive skupine zaposlenih?
1. V višjem dohodninskem razredu je samo, kar je nad mejo. Ne bo naenkrat celoten znesek obdavčen po višji stopnji.
2. Nižji otroški dodatki zaradi par evrov razlike? A bejžno, je nekdo le ugotovil, da neka fiksna meja, do katere dobiš vse, s parimi evri več pa le še polovico, ni najboljša. Navijam za to, da se priliko izkoristi in naredi rampo med prehodi, ne da do x € imaš 500 € dodatkov, za x+1 € pa 0 € dodatkov.
ADIJOOO1 ::
Predsednik Pahor se je posvetoval z uglednimi pravnimi strokovnjaki glede možnih sprememb volilne zakonodaje v skladu z odločbo ustavnega sodišča
Ljubljana, 16. 1. 2019 | sporočila za javnost
Predsednik Republike Slovenije Borut Pahor se je danes, v sredo, 16. januarja 2018, posvetoval z uglednimi pravnimi strokovnjaki glede možnih sprememb volilne zakonodaje v skladu z odločbo ustavnega sodišča, ki je ugotovilo, da je 4. člen zakona o določitvi volilnih enot za volitev poslancev v državni zbor, ki določa območja volilnih okrajev, v neskladju z ustavo.
V pogovoru je bilo jasno ugotovljeno, da je zakonodajalec dolžan spremeniti volilno zakonodajo tako, da parlamentarne volitve ne bodo nikakor ustavnopravno vprašljive.
Iz razprave je bilo razvidno, da ima zakonodajalec glede tega v osnovi dve možnosti. Prvo, da preoblikuje volilne okraje v skladu z odločbo Ustavnega sodišča in drugo, da ukine okraje in na ravni volilnih enot uvede prednostni glas, ki bo zagotavljal odločilen vpliv volivcev na dodelitev poslanskih mandatov.
Predsednik republike razpiše volitve v državni zbor, glede katerih ne sme biti nikakršnega dvoma o njihovi legitimnosti ali ustavnosti. Zato bo jutri predsednik Pahor v pogovoru z vodji parlamentarnih strank in poslanskih skupin poskušal doseči dogovor o nadaljnjih korakih, ki bodo zagotovili ustavno skladne spremembe volilne zakonodaje.
Posveta so se udeležili: dr. Franc Grad, dr. Igor Kaučič, dr. Ciril Ribičič, dr. Jurij Toplak, dr. Rajko Pirnat, dr. Jadranka Sovdat, generalni sekretar Vlade RS Stojan Tramte in direktor služb Državne volilne komisije Dušan Vučko. Udeležbo sta, zaradi nujne zadržanosti, opravičila dr. Saša Zagorc in dr. Matej Avbelj.
http://www.up-rs.si/up-rs/uprs.nsf/obja...
"z odločbo ustavnega sodišča, ki je ugotovilo, da je 4. člen zakona "
Kdaj je to ugotovilo?
Vazelin je izjavil:
klasika levičarjev.
me pa še nekaj zanima; kako levaki plačujejo davke. ker namreč verjetno je možno v slovenskem zanič pravnem redu različno tolmačiti davčne stopnje, zato me zanima če levaki vzamejo zase najvišje davke kar jih je možno da jih plačujejo?
ali nimajo s tem težav ker je profit itq hudičevo delo in so vsi reveži brez možnosti vplivanja na davke?
poweroff ::
Ne. Levičarji kradejo kot srake, švercajo in poslujejo na črno, ko pa potrkajo davčna, policija in sodišče, se pa v SDS včlanijo in organizirajo javna rajanja pred sodiščem. :))
sudo poweroff
zdravstvo želijo narediti čisto javno ali kako?
https://www.rtvslo.si/zdravje/novice/le...
bo treba res v tujino k zdravniku?
https://siol.net/siol-plus/kolumne/kam-...
dice7 ::
Ali si zelis se vec Stozic ali kaj?
Še enkrat : so kje objavljene konkretne številke? (glede tega nesrečnega povišanja minimalne plače)
Master_Yoda ::
Dobra novica dobili bomo "Ministry of truth" /s
Dovie'andi se tovya sagain.
Vazelin ::
Hahaha saj ne da ni bil Cerar tja okrog 2014 top populist, z žico pa še top hinavec. :))
ADIJOOO1 ::
Kaj čaka minister Prašiček ne bo odstopil ?
11 / 51
Šarec in odstop vlade, drugič (strani: 1 2 )
6918964 (17456) bluefish
Cerar ni več predsednik vlade! (strani: 1 2 3 4 5 )
22864538 (57779) Jupito
