mklink ne dela - ni dovolj privilegijev - Windows Server 2016
Šmorn ::
Na strežniku nam teče service pod uporabnikom, ki sem ga samo za ta namen naredil v domeni. Ta service ne more direktno dostopati do network shareov. Zamislil sem si, da bi naredil symbolic link do network sharea v lokalni mapi. Uporabniku sem dodal pravice za dostop do network sharea. Naredil sem tudi GPO, ki naj bi temu service uporabniku omogočil ustvarjanje symbolic linkov (Computer configuration -> Windows settings -> Security settings -> Local policies -> User rights assignment -> Create symbolic links). Zdaj pa s tem uporabnikom še vedno ne morem ustvarjati symbolic linkov. Javlja da nima dovolj privilegijev. Katerega sem zgrešil? Nočem, da ima uporabnik administratorske pravice.
nsa_ag3nt ::
https://superuser.com/questions/402390/...
You need to run mklink from an elevated shell (Right-click the Command Prompt shortcut, Run As Administrator).
If you are running mklink from an elevated shell, check the permissions on the directory and make sure there aren't any explicit Deny permissions set for the Administrators group.
Note: Make sure you're not trying to create a link where a directory containing files already exists, and are not accidentally creating a recursive set of links.
https://gizmodo.com/c/goodbye-big-five
Šmorn ::
Hvala. Dela in si zapomni.
win srv 2003 - file sharing
Oddelek: Operacijski sistemi
192572 (1737) Eureka
NTFS simbolični link
Oddelek: Igre
51060 (893) Cold1
Microsoft pravi, da mu Ubuntu predstavlja konkurenco (strani: 1 2 3 )
Oddelek: Novice / Android
11315208 (11657) noraguta
Kam so izginile Network Connections
61018 (978) bbobst
2 linux vprašanji (strani: 1 2 )
524974 (4536) ShowDown
