Forum » Pomoč in nasveti » Kam so izginile Network Connections
bbobst ::
Internet imam preko kabla ,torej modem in v kompu mrežno kartico,vse dela normalno.
Ko sem zadnjič nalagal sistem,sem konfiguriral mrežno kartico (IP,Gateway in ostalo ) pod
Pontrol panel --- Network Connections kjer je bila ikona za omrežje ,potem pa z desnm klikom na Propertis in tako naprej.
Sedaj pa je skrivnostno izginila ta ikona ,tako da ne vem kje nastavljati zadeve.Ja kar izpuhtela.
Ali obstaja kaka čudna fora za tale pojav ?
Ziga Dolhar ::
Start menu -> properties -> start menu -> customize -> advanced -> scrollaj dol do network connections ...
https://dolhar.si/
Ziga Dolhar ::
Pojdi v Device manager in poglej, če je tam kartica ustrezno nameščena [in ni onemogočena].
https://dolhar.si/
bbobst ::
Ziggga se enkrat preberi prvi post,kjer sem napisal,da mi internet ,ki ga imam preko mreže deluje in s tem deluje tudi mrežna.
Sicer pa sem nekaj zbrskal na netu,kar je pomagalo:
>There are a couple of things that will make your network connections
folder become blank:
>Netman.dll has become unregistered.
>1. Start, run, regsvr32 netman.dll. Click OK, should get a succeeded
message.
>Your Network Connections service has been disabled or cannot be
started:
>1. Start, run, Services.msc, click OK.
>2. Set Network Connections service to a manual startup type and make
sure it can be started.
>Additionally, make sure your system isn\'t in a selective startup.
The above steps may require a reboot.
message.
started:
| » | Zaflešan Linksys wrt160nlOddelek: Omrežja in internet | 1620 (1357) | Spc |
| » | Msn TEŽAVA...!!! čudna zadevaa...Oddelek: Pomoč in nasveti | 2251 (1876) | d3n!5 |
| » | Težave z DHCPOddelek: Omrežja in internet | 2374 (1911) | Cokolesnik |
| » | pohitritev dsl ali kabelskega neta v win xpOddelek: Omrežja in internet | 2177 (1915) | BlueRunner |
| » | pocasni zagon winXPOddelek: Operacijski sistemi | 2746 (2201) | Lunik |
