Forum » Problemi človeštva » Volitve 2018, drugič
jb_j ::
imagodei ::
SimplyMiha je izjavil:
Ali pa zgradiš okoli Afrike zid in počakaš stoletje ali dva - garant bi ljudje preživeli in se postavili na noge. Plemenske vojne gor ali dol, to so v preteklosti že storili.
Ja, poglej na primer ljudstva, ki so bila do nedavnega izolirana od sveta; amazonska, otoška itd. Še kar se pobijajo med sabo, najnaprednejši izum pa je pihalo, iz katerega izstrelijo strupene puščice.
Bi še rad postavil ta zid?
Se delaš butastega ali tak zares si? Danes sem govoril o tem, da je predkolonialni Afriki šlo bistveno boljše, kot pa Afriki po obsežni kolonizaciji.
Dejstvo je, da so imeli več kot dovolj časa in pogojev za razvoj civilizacije. Še največ časa so meli, glede na to, da naj bi človeštvo izviralo sredi Afrike. Obilica življa, plodne prsti, rudnin in drugih surovin. Le kaj jim je manjkalo?
Pojma nimam, mogoče ni vprašanje, kaj jim je manjkalo, ampak česa so dobili preveč? Morda preveč pohlepnih belcev? Lej, Wikipedia je kar dober začetek za izobraževanje. History of Africa, Metallurgy @ Wikipedia:
The first metals to be smelted in Africa were lead, copper, and bronze in the fourth millennium BC.[31]
Copper was smelted in Egypt during the predynastic period, and bronze came into use after 3,000 BC at the latest[32] in Egypt and Nubia. Nubia was a major source of copper as well as gold.[33] The use of gold and silver in Egypt dates back to the predynastic period.[34][35]
By the 1st millennium BC, iron working had been introduced in Northwestern Africa, Egypt, and Nubia.[36] According to Zangato an Holl, there is evidence of iron-smelting in the Central African Republic and Cameroon that may date back to 3,000 to 2,500 BC.[37]
In Central Africa, there is evidence that iron working may have been practiced as early as the 3rd millennium BC.[40] Iron smelting was developed in the area between Lake Chad and the African Great Lakes between 1,000 and 600 BC, long before it reached Egypt. Before 500 BC, the Nok culture in the Jos Plateau was already smelting iron.[41][42]
Točno to: nič. Polenili so se, si utrgali banano in poležavali v senci, zadovoljni s statusom quo. Niso čutili potrebe za razvoj, zato se niso razvijali kot njihovi daljni evropski in azijski sorodniki, katerih okoliščine so jih prisilile v inovativnost ter kreativnost.
Bejž no? Ignorace is a bliss.
- Hoc est qui sumus -
vostok_1 ::
https://www.nrcs.usda.gov/wps/portal/nr...
J.A. ima srednjo do shitty. Pa še omejeno vode.
It's not that good.
Čile pa od južne amerike ima solidno klimo in delujoč tržni sistem.
"Prosperira" je seveda v kontekstu tamkajšnje regije.
There will be chutes!
It came from the lab.
SimplyMiha ::
Takšne neumnosti pa še ne. Smrtnost je bila veliko višja, pričakovana življenjska doba precej krajša. Sramovati bi se moral, da sploh pišeš takšne neumnosti!
Kar pa zadeva metalurgije, Egipt v bistvu ni del Črne Afrike. Pa ajde, Nubija je, samo jim je Egipt izdatno pomagal. In kaj imajo sedaj od tega? Kje je Wakanda? Ne reci, da so jih zatrli belci z mušketami.
vostok_1 ::
PS. Hehe, šele sedaj sem opazil. Regija boljše rodovitnosti v afriki je nekje tam v okolici kjer so naši prvi predniki tavali.
Coincidence? I think not.
Those poor fucks, ki so zašli proti zahodu in jugu. If only they'd know.
- spremenil: vostok_1 ()
Ne jih ne. Ampak ravno v tem je eno izmed jeder problema: da ko jype "bruha žveplo" ti ne poštekaš, da to počne izključno zato, da ti pokaže, kako izgledajo tvoji argumenti
Moje argumente lahko citira in pove, kaj mu ne paše.
Lahko pa trola.
Saj jaz mu ne odrekam pravice trolanja. Zgolj opažam zatečeno stanje.
yero7 ::
V predkolonialni Afriki so bili genocidi normalen vsakdan. Se tebi zdi to boljše kot kolonizacija?
imagodei ::
Afrika ima dokaj bedne klimatske pogoje. In to je precejšenj faktor njihovega neuspeha. Definitivno pa je so selitve pripomogle k diferenciaciji. Človek v domačem okolju ni nikoli tako angažiran kot izven njega.
Klima je bolj slab izgovor. Poglej južno Afriko, idealna klima, vendar je bila neposeljena vse dokler niso prišli Nizozemci in Britanci.
Aja, neposeljena je bila? Jaz sem pa mislil, da sta bila Mapungubwe in Veliki Zimbabve v južni Afriki.
V resnici so bila v južni Afriki tudi kraljestva, ki jih "civilizirani" Portugalci niso mogli kar tako zradirat: Rozwi Empire @ Wikipedia
SimplyMiha ::
Ti govoriš o Zimbabweju, jaz govorim o območju južno od Zimbabweja. Kje so bila tam kraljestva? Tam so živela nomadska plemena Khoikhoi, skratka bušmani. Nobenih kraljestev, kaj šele Wakande; do prihoda Evropejcev so jih ogrožali edinole Bantuji, ki niti niso prišli daleč v Južno Afriko. Njihova populacija je bila tako majhna, da je bilo celotno območje praktično neposeljeno, pa še nomadski način življenja je pomenil, da nikjer niso dolgo bivali. V blagi klimi so mirno pasli živino in mulili trav'co, nobenih ambicij - pač preprosti ljudje, ki so živeli od zemlje in z zemljo, ki jim ideja Wakande niti enkrat ni padla na pamet. Samo pred bojevitimi plemeni so bežali, dokler niso bili potisnjeni ob morje.
Saj ne, da so bila bojevita plemena kaj dosti naprednejša - očitno jim je bilo ljubše vsevprek s sulico štihat ter klat, ubijanje je bilo del njihove kulture. Imeli so kakšno kraljestvo tu pa sam, a to je bilo samo nekaj vplivnih samodržcev z vojsko bosonogih suličarjev, katerih potomci še danes z mačetami sekajo še žive otroke in ženske. Ujetnike so imeli le toliko, da so jih kasneje zaklali - življenjska doba ujetnikov teh bojevitih plemen se je precej podaljšala, ko so pogruntali, da jih lahko prodajo trgovcem z ljudmi.
Ne miroljubni pastirji ne večni klavci niso prišli daleč na civilizacijski lestvici, pa so bili v Afriki vse odkar so se prva ljudstva začela seliti. Zakaj so jih prehitela ljudstva ob Nilu, Evfratu, Gangesu, daljnem Amurju itd.?
Razvoj je prišel šele z Arabci in Evropejci, sicer z nekajstoletnim zamikom, pa vendar. Ali bi brez prihoda kolonialcev danes že lahko delali pilotske izpite, da so lahko prevažali sopihajoče turiste?
- spremenilo: SimplyMiha ()
looser ::
Ne obremenjuj se, imagodei te malo provocira s kolektivno belo krivdo, pač ne more iz svoje (zindoktrinirane) levičarske kože...
Če bo v kapitalizmu dan, bo rekel, da je noč.
Provocira? Zgolj navaja dejstva. Ki pa jih mirno ignorirate, ker se ne skladajo z vašimi rasističnimi blodnjami.
Zahodna propaganda je denansko vredna vsakega miljona...
- spremenil: Poldi112 ()
vostok_1 ::
Vazelin ::
Skoraj sem si bruhnil v usta, ko sem videl Fištro odstranjevati radar. Dno dna. Populizem najbolj izprijene oblike. Upam da mariborčani odnesejo na volitvah tretjerazrednega klobučnjaka.
SimplyMiha ::
A ta bluzator, ki trdi, da je bilo Afričanom pred kolonializmom bolje?
Ta vaša propaganda tudi ni vredna počenega groša. Dejstvo je, da so Afričani zmožni in tudi izvajajo takšna grozodejstva, ki niti padla ne bi na pamet najhujšemu zahodnemu tiranu. Žalostno pa je, da teh grozodejstev niti videti nočete, medtem ko se deroč mečete ob tla za vsako rasistično opazko; če že, pa njihova primitivna dejanja, ki so jih počeli že dolgo pred kolonializmom, opravičujete. Če to ni sprevrženo, ne vem, kaj je!
Daleč od dogajanja in blizu koritu je lahko biti človekoljuben.
Zdaj pa samo še čakam, da rečeš, da morajo biti sužnji hvaležni gospodarjem, ker jim dajo za jest.
vostok_1 ::
Nov župan sheffielda, UK.
This is going well...
kje je pa problem?
Ne maram gangsta subkulture, ki običajno vodi v še večjo degradacijo družbe.
Nima respekta.
In stavim, da v privatnem življenju tudi zavrača angleško kulturo in se navdušuje nad svojo preteklo.
Razumem, pa da tebi take vrednote ne pomenijo veliko in jih ne boš pogrešal. Vsaj dokler te ne bodo stlačili v kak geto, ker nisi njihov.
Bosman v primerjavi je kulturen človek, ki ceni intelekt pred nekim poceni postavljanjem.
Če bana Trumpa ne samo da ima kulturo, ima tudi jajca.
vostok_1 ::
Daj ne seri.
Sicer sem sam že pred 15 leti glasoval PROTI vstopu v NATO, nisem imel pa najmanjšega pojma, kakšne so alternative. Če bi znova razpisali za referendum, bi prav tako glasoval PROTI članstvu v NATU, a neko resno alternativo je do sedaj ponudila le Levica.
A lahko kaj več o tej alternativi Levice?
tryhard ::
Ne in ne. Obstaja zgolj vzhodna kitajsko komunistična propaganda. Zahodna obstaja zgolj, če verjameš kitajski Partiji.
Ni. Je izrednega pomena.
Južna afrika nima tako idealne klimatske pogoje kot kaka severna italija ali francija. Upam se trdit, da znatno slabše. Še vedno je dol suša in vprašanje koliko rodovitna zemlja.
Pr nas je umetno zalivanje bonus. Dol pa nuja.
No potem pa nam razloži kako je možno da je v Zimbabveju ki je bila nekoč Afrika včasih bilo pridelane dovolj hrane še za izvoz pod belci (Ian Smith) zdaj pa so uvozniki in shithole =) Kdo je kriv za to če ne ljudje tam doli!!!!!! Ne pozabimo nekoč so Rodeziji rekli košara kruha... Razmere tam so idealne zapridelovanje marsičesa
to je pa dejstvo, južni del zemlje je večinoma bolj reven kot severni
(z izjemo Avstralije in Rusije) aja še JAR (s pomočjo/uničenja kolonistov)
Kako lahko sploh komentiras take debilizme, kot trditev, da je bila juzna Afrika neposeljena do prihoda kolonialistov. Komu pa so pokradli zemljo in nad kom izvajali genocid?
xmetallic ::
Sam kazes, da si rasisticni ignoramus.
Afrika je imela velika mesta, ki so jih kolonialisti pozgali do tal. To, kraja zemlje, genocidna politika in zatiranje lokalnega prebivalstva je super vplivalo na Afrisko nativno populacijo.
Osebno sicer mislim, da so za trenutno stanje krive tudi domace, skorumpirane politicne elite. Sam bodimo resni. Belci in kolonizacija so bili za crni kontinent katastrofa.
xmetallic ::
In v tistih predelih juzne amerike, kjer je uspeval, je zacuda uspevala tudi civilizacija, drugje pac ne
Banane ne rastejo v Sloveniji pa jih vseeno lahko ješ. Tam nekje sredi Evrope tudi nimajo velikih izvorov pitne vode pa jim voda vseeno priteče iz pipe. Skratka, vse te blodnje kako so Afričani depriviligirani zaradi podnebja so natanko to, blodnje. Morda ne morejo hrane proizvajati za celo prebivastvo lahko pa bi jo kupili. Namesto da posedajo pod drevesi in čakajo, da bo UN spet odvrgel paket hrane naj se spravijo delat pa bodo tudi oni lahko kupovali hrano od drugod. Če bi Afričani pokazali zagnanost, predanost, da si želijo samooskrbe bi jim na pomoč priskočile tudi druge države. Če pa samo posedajo v senci ne morejo pričakovati, da se bodo ostale države ukvarjale z njimi.
- spremenilo: xmetallic ()
xmetallic ::
https://www.theguardian.com/cities/2016...
Za vse neuke rasiste. Berete na lastno odgovornost, ker je tezje govoriti debilizme, ce ves, da so lazi.
xmetallic ::
Izven konteksta uletavas v debato in pametujes; pojdi srat kam drugam
Zmanjkalo argumentov? Komentar je kar v kontekstu. Ti si začel nabijat kako sta podnebje in klima odločili faktor razvoja civilizacije. Še enkrat naj te spomnim, da smo v letu 2018. Poznamo milijon načinov kako uspešno pridelovati hrano, gensko prilagajati hrano, poznamo tudi sisteme namakanja in sisteme za razsoljevanje morske vode. Vsi potrebni dejavniki za uspešno poljedelstvo. Zgodbice, da je Afrika v pi.di zaradi podnebja boš lahko pripovedoval svojim vnukom.
Še zdaj čakam da nekdo ki trdi da podnebje odigra glavno vlogo razloži tole
Dobro v puščavi in na Antarktiki je res težko ampak v večini Afrike ni puščava!
dice7 ::
Le kje so bili ti nacini v predkolumbusovi ameriki, kamor se je komentar navezoval
Zeitgeist ::
Kdor voli Levico pojma nima kako svet funkcionira in deluje. Po celem svetu je ideologija levice vodila u stagnacijo in revščino splošne populacije. Na svetu ni niti ene države, ki bi z takšno ideologijo bila uspešna. Naša stranka Levica je skupek enih populistov, ki točno vejo na katere note morajo igrati in kakšne izjave dajati, da prepričajo te naše leve simpatizerje, ki sanjajo utopičnost. Ja marksizem, socializem. lepo za slišat. večkrat preizkušeno v praksi in vedno znova failed. Viva la Revulocion.
dice zakaj se sploh ukvarjaš z očitno možgansko defektnim organizom? Kot rečeno, pusti, da narava in družba z njim naredita svoje.
MisterM ::
Na evropskih tleh je bila trgovina poglaviten razlog za razvoj in napredek civilizacij. Sredozemsko morje je dokaj enostavno za navigacijo in plovbo, vsaj v primerjavi z oceani. Sumerci, Egipčani, Feničani, Grki, Rimljani, itd. so vsi imeli trgovske flote, obale sredozemlja pa so bile polne različnih ljudstev, s katerimi so trgovali. Primerjaj to z Afriko in Ameriko, ogromnimi celinami, kjer je brez dobrih in razvejanih cest trgovina skoraj nemogoča, pa ti kaj kmalu postane jasno, kako so lahko mediteranske civilizacije uspevale in cvetele dolgo pred ostalimi.
imagodei ::
Takole selektivno lahko prirediš katero koli zgodovino hočeš, ne samo Afriško. A "divjaki" v Severni in Južni Ameriki so tudi narobe živeli?
Jaz ne pravim, da so bili to napredna ljudstva, tik pred 1. industrijsko revolucijo; ampak trdit, da je Afričanom kar koli manjkalo oziroma še huje, da so jih beli Evropejci rešili (pred kom? Samim sabo?), v tistem zgodovinskem kontekstu, je pa pretenciozno in naphano z "white supremacy" odnosom.
Hvala za potrditev moje trditve.
The greatest trick the Devil ever pulled was convincing the world he didn’t exist.
MisterM ::
Zakaj Afričani niso razvili trgovine? Na severu so jo in veliko trgovali z Evropo in Arabskim polotokom.
Zakaj indijanci niso zgradili cest? Malce si poglej ogromni teritorij S. Amerike .
Še dandanes je ogromen strošek graditi ceste, pred prihodom kolonistov v Ameriko pa tam tudi konj ni bilo.
Pri Južni Afriki in Severni Koreji si pač preskočil stoletja. S tem, da se je v prvi apartheid končal (tudi) zaradi vseh bojkotov, Kim pa misli, da je A bomba edini način, da se ga ljudje vsaj bojijo, če ga že spoštujejo ne.
Od kje ti ideja, da je Kim razvil A bombo za kontrolo lastnega prebivalstva?
MisterM ::
V očeh lastnega prebivalstva je Kim zaradi jedrskega projekta celo zvišal ugled, ostalim narodom in voditeljem pa je to le povod za strah.
Nisi odgovoril na vprašanje.
imagodei ::
Aja, aja, zdej razumem. Na napačnem koncu Afrike so bila kraljestva. Spet ni po tvojem standardu.
Mhm. Prvič, spet ne izpolnjujejo tvojih standardov, kako bi morali živet; ker z iPhonom v eni roki in ultrabookom v drugi roki, po dolgih stoletjih podobnega klanja v Evropi je tako lahko metat vrednostne sodbe o "primitivnih ljudstvih". Kot drugo, ni treba iti daleč v belsko preteklost, da najdeš popolnoma enake odvratne metode pobijanja, mučenja. Ubijanje je bilo del naše kulture, višek nedeljske zabave pa javne, krvave eksekucije, gnijoča trupla v kletkah, razobešena v opomin in vonj po zažganem mesu, ko so v ognju očiščevali duše čarovnic. Pa ni treba sploh tako daleč nazaj. Palestina, Srebrenica, holokavst... Civilizirani Britanci so v Indiji v drugi polovici 19. stoletja zgolj zaradi zaslužka izstradali ljudstvo; okoli 5 milijonov jih je umrlo od lakote.
Saj pravim, genocid nad južnoameriškimi in severnoameriškimi indijanci, izstradanje milijonov do smrti, holokavst, metanje atomskih bomb nad civilno prebivalstvo, zapiranje Palestincev v koncentracijska taborišča - to so dosežki belske "civilizacije" samo v zadnjih stoletjih. To je verjetno tisto pravo, česar Afričani, v svoji primitivnosti niso sposobni?
MisterM ::
Poldi, nikjer nisem trdil, da je Kim jedrski projekt fural za kontrolo lastnega prebivalstva. Dvomim tudi, da v državi, kjer se je nujno prikloniti kipom velikih vodij, jedrski projekt kakorkoli potreben za boljši nadzor nad rajo. Kako pa nanj gledajo lastni državljani, boš moral pa njih vprašati. Nekaj dodatnih vernikov je s tem projektom gotovo tudi dobil.
Maribornr1, žal ti ne morem biti v pomoč pri tvojih čajankah z naciji in belimi supremacisti. A ker ste tako fejst in vas v intelektualnem krožku združujeta želja po znanju in argumentiranje trditev, boste v lokalni knjižnici gotovo našli raziskave uglednih zgodovinarjev, ki so preučevali razvoj civilizacij na različnih kontinentih.
KAVINSKY ::
Severne afrike ne gre ravno primerjati z preostankom celine. Kulturno, antropološko in zgodovinsko je zelo različna od preostanka celine. Potem je podvprašanje; če ni -zakaj ni nobena druga afriška kultura gradila takih struktur oz. zakaj ni vzhodna obala trgovala z bližnjim vzhodom / indijo?
Je verjetno bolj kriv nomadski način življenja. Preživljali so se z lovstvom in nabiralništvom. Južna Amerika je pa druga zgodba, kjer so gradili ceste, piramide in mesta.
