Kako najti ime datoteke pri chkdsk
techuser ::
Pri disk checku s pomočjo chkdsk sem dobil te podatke:
CHKDSK is verifying files (stage 1 of 3)...
176384 file records processed. File verification completed.
530 large file records processed. 0 bad file records processed. 0 EA records processed. 44 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)...
Correcting error in index $I30 for file 70417.
The index bitmap $I30 in file 0x11311 is incorrect.
Kako naj vem, katera datoteka je 70417? Hvala.
filip007 ::
To je samo popravljen vnos, saj ne rabiš te datoteke.
Zero games, zero talk.
techuser ::
Aha potem je vredu, samo kako pa lahko ugotoviš katera datoteka je bila to za katero je popravljen vnos?
Problem z ramom ali diskom? Prosim za nasvet.
111596 (1498) Duhec
CHKDSK in Deleting index entry
Oddelek: Operacijski sistemi
222629 (2217) Hayabusa
težava z računalnikom (počasno delovanje, brenči...)
162397 (2051) legendary
chkdsk /f problem
201936 (1743) bluefish
Par problemov z XPji
343112 (2358) Mercier
