Global warming
Global warming
Thomas ::
50+ stopinj razlike. med Luno in Zemljo, zaradi vrtenja.
Double_J ::
Sem malo pregledal na hitro vse objekte z lunami vred. V osončju imamo samo 4telesa, kjer lahko študiramo vpliv atmosfere, ostalo je praktično samo plin ali samo skala. Uradno velja za zemljo, venero, mars, da atmosfera segreva, za luno Titan velja, da ohlaja, vendar samo zato, ker je ogromno smogu v vrhnjih plasteh, drugače bi tudi segrevalo.
Dve šivanki...
Thomas> 50+ stopinj razlike. med Luno in Zemljo, zaradi vrtenja.
Razlika v povprečju med 2,4 urnim dnevom in 24urnim dnevom je manj kot par stopinj.
Razlika med 24 urnim in 48 urnim dnevom tudi.
Torej spremembe v hitrosti rotacije ne morejo pojasniti sprememb v temperaturi (ker sprememb v hitrosti rotacije nimamo).
Double_J ::
Zelo pravilen pogled... kdor meni da atmosfera(CO2) ohlaja, pa bo dobil Venero brez atmosfere z okoli 1000K, bližji Merkur pa pri 340K.
The sunlight is mostly at wavelength of~ 0.6nm = 600nm, which is not absorbed efficiently in CO2 , so the sunlight scatters its way through the clouds and eventually makes it to the surface. It warms the surface and the surface then radiates in the infrared. However, the CO2 absorbs the infrared radiation and it does not all escape into space, but much of it is trapped between the surface and the CO2 layers in the atmosphere. The end result is that the surface heats to 730K - only at this high temperature is it possible for the energy to escape at the same rate it is absorbed by the surface. By Wien's Law, at this temperature much of the energy is shorted than the CO2 absorption at 4000 to 5000 nm, so it can escape and stop further heating of the surface
Dve šivanki...
  • spremenil: Double_J ()
Thomas ::
Pust ti Venero še mau. Absolviraj najprej rotacijo, sicer si samo citator (warmerskih linkov).
Double_J ::
To Venero naj bi stalno pustili, ne vem komu na ljubo? Ker pač nimaš procesa, ki jo dela za 500K toplejšo? "Vulkani" ter "Trenje" ja, to je ta domet.
Dve šivanki...
imagodei ::
Thomas> "50+ stopinj razlike. med Luno in Zemljo, zaradi vrtenja. "
Zakaj zaradi vrtenja, če pa si se malo višje gor strinjal, da je atmosfera buffer?
- Hoc est qui sumus -
Thomas ::
Če ne zastopiš Zemlje, tudi Venere ne boš JJ.
imagodei - later pojasnim detaljno kar sprašuješ.
Double_J ::
Ti predvsem ne zastopiš prenosa temperatur, ki je nekaj podobnega kot ujemanje pravih frekvenc pri radiju.
"Migriranje planetov" ali kaj že, ogreva Venero za več kot 500K. To lahko verjamejo samo ljudje, ki nimajo pojma. Plimske sile aha...
Dve šivanki...
Thomas, lej en lep primer, da najprej tam ugotovimo,če veš kako sevanje deluje, pa gremo potem primerjat kasneje ta primer z atmosfero, oziroma naloga čisto lepo rešljiva, najprej moramo to rešit, da se naprej pogovarjamo.
Maš kvader, ki je povsod razen iz ene strani popolno izoliran. Na tisto stran, kjer ni izoliran stalno deluje vir sevanja z spektrom sončne svetlobe. In sicer z 100 enot energije. Vmes postavimo magično ploščo, ki pusti skozi x% sončeve in y% IR svetlobe, ki jo kvader nazaj oddaja, ostalo pa vse absorbira.
Označimo Ea,Ez,Es, energije, ki prijahajo z sonca/vira svetlobe, zemlje in atmosfere.
Maš 3 enačbe za ravnovesje:
Es=Ea/2+Ez*y
Ez=Es*x+Ea/2
Ea=Es*(1-x) + Ez*(1-y)
Rešitev tega sistema, ti da, da če je x večji od y, torej da če pusti magična ploščica več skozi, bo Ez večja, več eneergije pomeni, da bo tudi toplejša?
Se strinjaš z tem izračunom? Da lahko gremo naprej se pogovarjat, kako atmosfera vpliva, ker ne vem če sploh tole sevanje v osnovi zastopiš, brez da kake atmosfere zraven dajemo.
Thomas ::
Ne, ne strinjam se. Ti dej kar eno realno ploščo z njenimi realnimi prozornostmi za različne valovne dolžine. Distribucijo prozornosti. Albedo kot funkcijo lambda, naprimer. Potem pa lahko delaš izračun.
Na kar ene za ušesa privlečene vrednosti, se nima smisla sklicevati.
Fer?
Thomas> Na kar ene za ušesa privlečene vrednosti, se nima smisla sklicevati.
Hihi.
Tvoja simulacija za ušesa privleče en kup vrednosti in deluje samo za planete brez atmosfere.
Thomas ::
Moja simulacija ne krši nobenega fizikalnega zakona. Tako kot tudi tvoja ne, ki je ni.
Double_J ::
Fizikalnih zakonov ne moreš kršiti.
Dve šivanki...
:)) Poglej kdaj kakšen sci-fi film;)
O.
  • spremenil: Okapi ()
Tist je drugač, tam majo heisenbergov kompenzator.
kitzbrado ::
Tvoja simulacija je se vecji priblizek kot Azgardov primer. Dokler namrec ne vpeljes toplotne prevodnosti, delas velik priblizek (v tvoji simulaciji toplotno prevodnost zelo priblizno predstavlja masa pod dano povrsino).
Pa to seveda ne pomeni, da je s tvojo simulacijo ali z Azgardovim primerom kar koli narobe. Samo zavedati se je treba, kaj so priblizki.
Thomas ::
Približki so dveh sort. Potencialno nevarni za to, da bi simulacija kršila kakšen fizikalni zakon, oziroma dala fundamentalno napačen rezultat in taki, ki bistva v ničemer ne spremenijo.
To pa že presega okvire tele teme - zdaleč.
kitzbrado ::
Ce mislis, da Azgardov primer krsi kateri koli fizikalni zakon, potem povej katerega krsi. Sicer spada njegov priblizek v isto skupino priblizkov kot tvoj.
Double_J ::
Ni ne vem kaj za pričakovati. Morate vendarle vedeti, da se pogovarjete z nekom, ki trdi da sončeva gravitacija ogreva Venero 2x bolj, kot svetloba.
Dve šivanki...
Kot je kizbrado rekel, povej kaj je narobe, ko je jype par tedno nazaj dal napačen dokaz za svojo trditev, sem mu našel, da ima narobe, ko si ti dal svojo simulacijo, smo jo veliki pretehtali in se strinjali.
Tud v tem primeru najdi napako, ali pa se strinjaj.
SomethingEls ::
Thomas ::
Rad bi vedel za konkretno snov, skozi katero deluje takoimenovana topla greda. Hipotetična seveda "obstaja", jasno. Ampak skozi katero obstoječe steklo ali karkoli, moram greti kaj in s čim, da se bo spodaj bolj ogrelo, kakor če tega stekla ni?
No lepo, da se končno strinjamo, da teoretično obstaja Thomas, dolgo sem čakal.
Vprašanje je samo skozi kaj. Za vir in za Zemljo, da oddajata različne valovne dolžine se že ve.
In ta skozi kaj je čisto lahko CO2, naprimer. Trdiš da ne prepušča skozi več sončeve, kot prepušča skozi IR sevanje od kvadra/zemlje?
Azrael ::
CO2 + nekaj 100% ne dela.
Pozimi zaprt prostor nek vir toplote (lahko tudi Sonce) nič bolj ne ogreje, če je le ta prezračena ali pa zatohla.
Nekoč je bil Slo-tech.
imagodei ::
Offtopic: Viš, Azrael, zato imamo sklone, ki jih je fino pravilno uporabljat - predvsem rodilnik/tožilnik. Kaj je zdaj tu prav:
"Pozimi zaprt prostor nekega vira toplote (lahko tudi Sonce) nič bolj ne ogreje, če je le ta prezračena ali pa zatohla. "
ali kontra:
"Pozimi zaprtega prostora nek vir toplote (lahko tudi Sonce) nič bolj ne ogreje, če je le ta prezračena ali pa zatohla. "
Verjetno to drugo... Ampak se res ne ve natančno, ker na koncu potem še govoriš nekaj v ženskem spolu, čeprav niti vir (toplote) niti prostor nista tega spola.
Double_J ::
On tako samo nekaj ponavlja kot papagaj. Najbrž kot Thomas trdi, da če sonce ugasne, bo njegova gravitacija Venero vzdrževala pri 500K.
CO2, seveda enako seva v vesolje, zaradi trkov molekul. Samo pri višji povprečni temperaturi(frekvenci), saj na ta način šele dovolj prepušča sevanje, da se ogrevanje ustavi.
Vakum bo prepuščal vse odbite frekvence. CO2 pa jih bo pa nekoliko dvignil, ker ima pač takšne lastnosti, da bolje prepušča višje frekvence.
Dve šivanki...
Azrael ::
In trdiš, da ima stvar izkoristek preko 100%.
Samo tako lahko greje. Tako kot teoretično obstaja grenhouse efekt, obstaja tudi Perpetuum Mobile. Samo dovolj zagnojeno teorijo moraš postaviti.
Double_J ::
Kako jih bo pa dvignil... ja dokler bodo prenizke, jih ne bo dovolj prepuščal v vesolje, da se sistem nebi ogreval. Tako se sistem ogreva, frekvence se višajo, dokler ne pridemo do točke ravnovesja.
Osnove. Noben perpetum mobile, kar pride not gre tudi ven. Nič več!
Dve šivanki...
Azrael ::
V obeh primerih rabiš samo neko "teoretično" snov (ki baje 237% ziher mora obstajati) in stvar funkcionira.
kitzbrado ::
Še vedno ne razumeš. Poglej si, kaj je napisal Azgard zgoraj. Ni razloga, da taka snov, koje je v njegovem primeru, ne bi obstajala (ali taka, kot je v mojem primeru).
Obenem pa taka snov ne implicira perpetuum mobilea.
Double_J ::
Po tvoje tudi, ko obložiš hišo imaš perpetum mobile, kar iz nič energije, je topleje.
Dve šivanki...
Azrael ::
Sicer ne vem ali se samo delate norca, ampak vedno vsi AGWF lajnate eno in isto.
Redno prikazujete v svojih "teorijah" in "poljudnih ", "poenostavljenih" itd primerih, grelec v neki izolaciji.
Jasno, da bo grelec bolj topel. Ampak od kdaj je Zemlja grelec? Grelec je zunaj, vmes je izolacija.
Dvoje enostavnih vprašanj:
1. Zakaj se kamenje v puščavah ali na ekvatorju na Zemlji segreje manj, kot na Luni? Če ozračje po vaše greje?
2. Zakaj soba s slabim zrakom (veliko CO2), ne rabi bistveno šibkejši grelec da se v njej vzdržuje ista temperatura, kot v taki, ki je prezračena? Če CO2 gretje ojačuje?
Double_J ::
1.Ker na luni neprestano sonce sije na kamen 14dni.:|
2.Sej rabi, če si dolgo v sobi je treba manj greti kot na začetku.:O
Kaj je tko težko razumeti pri tem, da bo CO2 nekoliko povišal frekvence, ki bodo ubežale v vesolje kot vakuum? Ja menda jasno, višje frekvence se lažje prerinejo ven, skozi CO2 pa se je logično težje prebiti, kot skozi vakuum. Sonce pa to dela seveda zlahka.
Dve šivanki...
gani-med ::
Zakaj take razlike v temperaturnih tekordih Zemlje in Lune?
Najprej zato, ker ima Luna albedo okoli 7% Zemlja pa 30% zato Zemlja odbije več toplote, kot Luna, ker prejme manj energije se manj segreje.
Poleg tega Lunina površina rotira (nasproti Soncu) počasneje od Zemljine. Tisti del Lune, ki dosega rekordne temperature, je precej dlje časa izpostavljen (pravokotnemu) snopu žarkov s Sonca, kot katerakoli puščava na Zemlji in se zato tudi bolj ogreje.
CO2 is the elixir of life.
imagodei ::
Plus, tla oddajajo toploto atmosferi (atmosfera pa, ko je toplejša od tal, nazaj tlem).
gani-med ::
Atmosfera je hladnejša od tal in ker toplota vedno potuje v smeri od toplejšega k hladnejšemu,
lahko atmosfera dirrektno tla le hladi, ne more jih greti.
Res pa je, da se lahko določeni infra fotoni iz atmosfere vrnejo nazaj proti tlem in jo tako dodatno ogejejo.
S tem dodatnim zapoznelim sevanjem se lahko poveča temperatura tal.
Topla greda, tista zelenjavarska, deluje. Ugotovili smo tudi, da ne zaradi nekih magičnih lastnosti stekla, ampak ker je zaprta. Če bi steklo pobarvali črno, bi grela še bolj, samo bi bila notri tema in to za zelenjavo ni najbolj ugodno.
Atmosfera deluje na v bistvu enak način - deluje kot steklena sfera, ki obdaja (zapira) vso Zemljo. Je pač bolj redko steklo, ampak zato toliko debelejše.
Različne kombinacije in koncentracije plinov v atmosferi vplivajo na učinkovitost te atmosferske tople grede (steklene kletke okoli planeta).
Bo držalo (in če ne, zakaj ne)?
O.
Okapi> Atmosfera deluje na v bistvu enak način
Nope.
Atmosfera je tako kot steklenjak, ki ima okna, skozi katera od zunaj normalno vidiš not, odznotraj so pa videti črna in neprozorna.
Ker od zunaj sonce večino energije zmeče zemljinemu površju (v obliki vidne svetlobe), zemlja pa večino energije izseva v infrardečem spektru, za katerega atmosfera ni prepustna.
Atmosfera se tako greje bolj, kot bi se, če ne bi imela te lastnosti. Temu "ekstra gretju" rečemo učinek tople grede. Bolj topla atmosfera seveda pomeni, da mora planet sevati z višjo temperaturo, da se lahko ohlaja, saj mora do višje temperature ogreti tudi atmosfero, ki dejansko izseva večino energije v vesolje.
gani-med ::
Steklenjak deluje zaradi preprečevanja konvekcije, gibanja toplega zraka v višine.
Toplota potuje v smeri proti manjši temperaturi in če zraku ta tok navzgor preprečujemo, bo zaradi zadrževanja toplote na tistem mestu dlje časa bolj toplo.
Obstajajo tudi posebno izdelana stekla, ki sončne žarke prepuščajo v eno smer, v drugo jih pa odbijaj nazaj (v steklenjak) in tako še povečajo toplotno učinkovitost steklenjaka.
V atmosferi pa dejansko ni takih ovir, ki bi preprečevale gibanje molekul, da se s konvekcijo prosto dvigujejo.
@Okapi
Ne atmosfera ne deluje enako kot rastlinjak, nima to kaj veliko povezave. Sama atmosfera, kot nek izolacija okoli Zemlje HLADI z konvekcijo površje. Efekt tople grede, torej preko sevanja je tisti, ki jo segreva.
Tak da čisto komot pride do tega, da je neto učinek atmosfere da HLADI Zemljo.
Ampak za toplogredne pline se pa ve da GREJEJO.
Sam tok, ker se posplošuje efekt tople grede na efekt atmosfere skupaj. Ampak, to kako vpliva atmosfera na Zemljo nima veze z GW, ker se količina atmosfere nekako ne spreminja in je ta del enak.
Thomas ::
Da se kamen na Luni segreje toliko bolj, ker se greje 14 dni je podobno, kot da če 14 dni greješ praznen železen lonec, da bo bolj topel kot po 20 minutah. Relativno hitro doseže maksimum! Termometer recimo, že v par minutah.
Tako da podaljšano gretje, ni in ne more biti razlog za nek kamen, da se segreje na 120.
Da je kakšna velika razlika v albedu Zemlje in Lune, ter bi to bila razlaga, tudi ni res. Saj so kamni na Luni temnejši in svetlejši od zemeljskih kamnov. Niso kar vsi Lunini kamni svetlejši ali temnejši. Tudi to je čisto deplasirana razlaga.
Thomas ::
Razlog, zaradi katerega se "črna ploščica" na Luni segreje bolj kot na Zemlji je ta, da na Zemlji je moč Sonca na kvadratni meter največ okoli 1 kW. Sonca plus domnevnega dodatnega sevanja zraka. 1 kW - max.
Na Luni pa je to skoraj 40% več.
Ne glede na to kakšno atmosfero ima planet, solarna konstanta (moč na kvadratni meter) - se zreducira. V vakuumu je največja.
imagodei ::
gani-med> "Atmosfera je hladnejša od tal in ker toplota vedno potuje v smeri od toplejšega k hladnejšemu,
S tem dodatnim zapoznelim sevanjem se lahko poveča temperatura tal. "
No, na splošno tole seveda velja in atmosfera (okoliški zrak) ne ogreva tal, pač pa kvečjemu preprečuje hitro hlajenje.
Okoliški zrak NI vedno hladnejši od tal. Poznamo tudi gibanje zračnih mas. Ena vrsta megle, npr. nastane, ko gre pas toplega zraka preko hladnih tal.
Thomas ::
Tudi satelit se lahko segreje na precej več, če kroži v orbiti, kot če leži na tleh.
V prvem primeru ga atmosfera ne zasenčuje, če pa leži na tleh ga pa.
V tem je poanta - atmosfera neto zasenčuje, ne da poskrbi za "dodatni IR rikoše".
Premislite!
gani-med ::
Lunino površje se bolj segreje iz preprostega razloga, ker prejme več sončne energije na kvadratni meter. Tu je še kako pomemben albedo, saj pove, koliko energije se je že takoj odbilo in ni bilo porabljene za segrevanje. Luna ima manjši albedo od Zemlje za cca 23% in to je zelo važen faktor.
K večjemu dotoku energije pa prispeva tudi kot, pod katerim sonce sije.
Na Zemlji je Sonce v zenitu zelo kratek čas, precej krajši kot na Luni. Material na Luni je slab prevodnik in zato rabi dlje časa, da se segreje.
Za lažjo predstavo; lunine kamenine imajo slabšo toplotno prevodnost od vode.
Verjetno pa je kdo že kdaj računal ali celo poskušal, koliko časa je potrebnega, da se na 100 stopinj (iz sobne temperature 25 stopinj) segreje naprimer 100 litrov vode.
Če predpostavimo, da sonce greje s 1000W/m2, bi teh 100 litrov vode segreli na 100 stopinj približno v 8 urah, nič prej, v tem času pa sonce ne bo več grelo s 1000 W/m2 ampak vedno manj in 100 l vode je na ta način pravzaprav nemogoče zavreti, vsaj na Zemlji ne, ki se učinkoviteje hladi, kot Luna, kjer je Sonce dovolj časa v zenitu.
gani-med ::
Znano dejstvo je pa tudi, da se sateliti bolj ohladijo, če rotirajo. Temu se reče pasivno hlajenje.
Tudi astronavti so že dostikrat pritoževali, kako vroče je postalo v kabinah, ko je odpovedalo električno hlajenje, aktivno hlajenje in je bilo treba preklopiti na pasivnio hlajenje, na rotiranje plovila.
Thomas> Ne glede na to kakšno atmosfero ima planet, solarna konstanta (moč na kvadratni meter) - se zreducira. V vakuumu je največja.
Halo? Temu vendar ja nihče ne oporeka.
A vendar - atmosfera lahko komot povzroči, da je temperatura trdnih tal pod njo višja, kot bi bila temperatura tal pod vakuumom.
Thomas ::
Zemljina atmosfera tega gotovo ne povzroča. Pod Zemljino atmosfero se tla ne segrejejo toliko, kakor od Sonca obsijan satelit v orbiti.
Zato kakršnekoli akrobacije že delate z "rikošet IR" žarki in "toplo gredo" - bluzite big time.
Thomas> Zemljina atmosfera tega gotovo ne povzroča.
No, tega ne vem, ampak vsekakor nič ne kaže na to, da bi.
Zagotovo pa zemljina atmosfera dvigne temperaturo tal napram isti atmosferi, v kateri ni vodne pare, metana in CO2.
In zagotovo atmosfera, v kateri je več vodne pare, bolj segreje tla pod njo, kot zemeljska, če je vir energije isti.
  • spremenilo: jype ()
169 / 386
