[Debian] monitor sshd auth.log
HotBurek ::
Pozdravljeni.
Za namen monitoringa sshd na strežniku sem spisal skripto. Sprva pogleda in izpiše obstoječe loge, potem pa v loop-u bere za novimi vnosi. Prebere vse vrstice znotraj istega dne.
V primeru napačnega gesla se lahko izvede ukaz "ip ban". Hkrati se IPji hranijo v iplist.txt file.
V safesource se vnese "varne IPje".
print screen
 authmonitormini
authmonitormini
koda
#!/usr/bin/python3.4
import time;
import os;
import datetime;
import traceback;
import sys;
import subprocess;
import ipaddress;
import codecs;
# database path
pathdat = "~/authmonitormini";
# declarations
logpath = "/var/log/auth.log";
loopcount = 0;
loopcountlimit = 1000000;
linecount = 1;
movesecond = False;
safesource = ["1.1.1.1", "2.2.2.2", "3.3.3.3"];
iptablescmd = "/sbin/iptables -I INPUT -j DROP -p tcp --dport 22 -s ";
pathiplist = "/iplist.txt";
last = datetime.datetime.min;
clear = lambda: os.system("clear");
clear();
# header
print("# Monitor " + str(logpath));
print("# " + str(time.strftime("%Y-%m-%d")));
print("# " + str(time.strftime("%H:%M:%S")));
print("# safesource=" + str(safesource));
print("");
# start loop
while(loopcount < loopcountlimit):
    try:
        # check if log file
        if os.path.exists(logpath):
            # read all log file
            logfile = open(str(logpath), "r");
            for line in logfile:
                line = str(line);
                line = line.strip();
                if line.find(":") > 0:
                    _month = line[:line.find(" ")];
                    _day = line[:line.find(":")];
                    _day = _day[_day.find(" ") + 1:_day.rfind(" ")];
                    _day = int(str(_day));
                    _timeh = line[:line.find(":")];
                    _timeh = _timeh[_timeh.rfind(" ") + 1:];
                    _timems = line[line.find(":") + 1:];
                    _timems = _timems[:_timems.find(" ")];
                    _timehms = str(_timeh) + ":" + str(_timems);
                    timelast = datetime.datetime.strptime(_timehms, "%H:%M:%S");
                    if last <= timelast:
                        movesecond =True;
                        last = timelast;
                        _printlineall = "";
                        _ip = "";
                        _debug = True;
                        _line1 = "\033[97m" + " | " + str(linecount) + " | " + str(_month) + " " + str(_day) + " " + str(timelast.strftime("%H:%M:%S")) + "\033[0m";
                        _line2 = "";
                        _line3 = "";
                        _searchtext1 = str("Failed password for invalid user");
                        _searchtext2 = str("Failed password for");
                        _searchtext3 = str("Did not receive identification string from");
                        _searchtext4 = str("Connection closed by");
                        _searchtext5 = str("Received disconnect from");
                        _searchtext6 = str("Disconnecting: Too many authentication failures for invalid user");
                        _searchtext7 = str("Accepted password for");
                        # Failed password for invalid user
                        if line.find(_searchtext1) > 0:
                            _line = line[line.find(_searchtext1) + len(_searchtext1):];
                            _line = str(_line).strip();
                            _user = _line[:_line.find(" ")];
                            _ip = _line[_line.find("from") + 4:_line.find("port")];
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _ipAddress = ipaddress.ip_address(_ip);
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                if _ip in safesource:
                                    _line2 =  "\033[93m" + " | warning invalid user " + str(_user) + " | " + str(_ip) + "\033[0m" + "\033[96m" + " | safesource" + "\033[0m";
                                else:
                                    _line2 = "\033[93m" + " | warning invalid user " + str(_user) + " | " + str(_ip) + "\033[0m";
                                _printlineall = str(_line1) + str(_line2);
                            else:
                                _line2 = "\033[93m" + " | warning invalid user " + str(_user) + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            linecount = int(linecount) + 1;
                            time.sleep(0.400);
                        elif line.find(_searchtext2) > 0:
                            _line = line[line.find(_searchtext2) + len(_searchtext2):];
                            _user =_line[:_line.find(" ")];
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                execstring = str(iptablescmd) + str(_ip);
                                    _line2 = "\033[91m" + " | faild password user " + str(_user) + " | " + str(_ip) + "\033[0m" + "\033[96m" + " | safesource" + "\033[0m";
                                elif _debug:
                                    _line2 = "\033[91m" + " | faild password user " + str(_user) + " | " + str(_ip) + "\033[0m";
                                    _line3 = "\033[92m" + " | debug" + "\033[0m" + "\033[94m" + " | " + str(execstring) + "\033[0m";
                                    _printlineall = str(_line1) + str(_line2) + str(_line3);
                                else:
                                    fileexists = False;
                                    if os.path.exists(str(pathdat) + str(pathiplist)):
                                        fileexists = True;
                                    if not fileexists:
                                        iplistfile = open(str(pathdat) + str(pathiplist), "w+");
                                        iplistfile.write(str(_ip) + "\n");
                                        iplistfile.close();
                                        _line3 = "\033[92m" + " | exec" + "\033[0m" + "\033[94m" + " | " + str(execstring) + "\033[0m";
                                        # RUN IPTABLES COMMAND
                                        os.system(execstring);
                                    else:
                                        newip = True;
                                        iplistfile = open(str(pathdat) + str(pathiplist), "r");
                                        for ipline in iplistfile:
                                            if str(ipline).strip() == str(_ip):
                                                newip = False;
                                                break;
                                        if newip:
                                            iplistfile = open(str(pathdat) + str(pathiplist), "a+");
                                            iplistfile.close();
                            else:
                                _line2 = "\033[91m" + " | faild password user " + str(_user) + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            time.sleep(0.400);
                        # Did not receive identification string from
                        elif line.find(_searchtext3) > 0:
                            _ip = line[line.find(_searchtext3) + len(_searchtext3):];
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                    _line2 = "\033[93m" + " | warning no id | " + str(_ip) + "\033[0m" +  "\033[96m" + " | safesource" + "\033[0m";
                                else:
                                    _line2 = "\033[93m" + " | warning no id | " + str(_ip) + "\033[0m";
                            else:
                                _line2 = "\033[93m" + " | warning no id " + "\033[0m" + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            time.sleep(0.400);
                        # Connection closed by
                        elif line.find(_searchtext4) > 0:
                            _ip = line[line.find(_searchtext4) + len(_searchtext4):];
                            if _ip.find("[preauth]") > 0:
                                _ip = _ip[:_ip.find("[preauth]")];
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                    _line2 = "\033[97m" + " | info connection closed | " + str(_ip) + "\033[0m" +  "\033[96m" + " | safesource" + "\033[0m";
                                else:
                                    _line2 = "\033[97m" + " | info connection closed | " + str(_ip) + "\033[0m";
                            else:
                                _line2 = "\033[97m" + " | info connection closed | " + "\033[0m" + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            time.sleep(0.400);
                        # Received disconnect from
                        elif line.find(_searchtext5) > 0:
                            _ip = line[line.find(_searchtext5) + len(_searchtext5):];
                            if _ip.find(":") > 0:
                                _ip = _ip[:_ip.find(":")];
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                    _line2 = "\033[97m" + " | info received disconnect | " + str(_ip) + "\033[0m" + "\033[96m" + " | safesource" + "\033[0m";
                                else:
                                    _line2 = "\033[97m" + " | info received disconnect | " + str(_ip) + "\033[0m";
                            else:
                                _line2 = "\033[97m" + " | info received disconnect | " + "\033[0m" + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            time.sleep(0.400);
                        # Disconnecting: Too many authentication failures for invalid user
                        elif line.find(_searchtext6) > 0:
                            _ip = line[line.find(_searchtext6) + len(_searchtext6):];
                            if _ip.find("from") > 0:
                                _ip = _ip[_ip.find("from") + len("from"):];
                                _ip = _ip.strip();
                            if _ip.find("port") > 0:
                                _ip = _ip[:_ip.find("port")];
                                _ip = _ip.strip();
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                    _line2 = "\033[91m" + " | to many auth fail | " + str(_ip) + "\033[0m" + "\033[96m" + " | safesource" + "\033[0m";
                                elif _debug:
                                    _line2 = "\033[91m" + " | to many auth fail | " + str(_ip) + "\033[0m";
                                else:
                                    fileexists = False;
                                        fileexists = True;
                                    if not fileexists:
                                        iplistfile.close();
                                    else:
                                        newip = True;
                                                newip = False;
                                                break;
                                        if newip:
                                            iplistfile.close();
                            else:
                                _line2 = "\033[91m" + " | to many auth fail | " + "\033[0m" + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            time.sleep(0.400);
                        # Accepted password for
                        elif line.find(_searchtext7) > 0:
                            _line = line[line.find(_searchtext7) + len(_searchtext7):];
                            _ip = _ip.strip();
                            _validip = False;
                            try:
                                _validip = True;
                            except:
                                _validip = False;
                            if _validip:
                                    _line2 = "\033[95m" + " | accepted user " + str(_user) + " | " + str(_ip) + "\033[0m" + "\033[96m" + " | safesource" + "\033[0m";
                                else:
                                    _line2 = "\033[95m" + " | accepted user " + str(_user) + " | " + str(_ip) + "\033[0m";
                            else:
                                _line2 = "\033[95m" + " | accepted user " + str(_user) + "\033[91m" + " | exception invalid ip " + str(_ip) + "\033[0m";
                            time.sleep(0.400);
                        # print
                        if len(_printlineall) > 0:
                            print(_printlineall);
                else:
                    print("warning=No \":\" in line.");
                    print("skip=" + str(line.strip()));
                    time.sleep(2);
        else:
            print("warning=No log file at " + str(logpath));
            print("");
            loopcount = int(loopcountlimit);
            time.sleep(10);
    except Exception:
        error = traceback.format_exc();
        print("exc=" + str(error));
        print("");
        time.sleep(10);
    time.sleep(1);
    loopcount = int(loopcount) + 1;
    # move last one second ahead
    if movesecond:
        last = last + datetime.timedelta(0,1);
        movesecond = False;
print("");
print("# End");
root@debian:/# iptraf-ng
Please resize your window
Primoz ::
apt-get install fail2ban
There can be no real freedom without the freedom to fail.
program za pomoč pri tiskanju 200+pdf dokumentov
253018 (2070) HotBurek
Fake traffic generator
Oddelek: Omrežja in internet
192999 (2195) HotBurek
Pošljite nam vašo najboljšo kodo
Oddelek: Programiranje
122727 (1972) AndrejO
[python] project euler problem
151626 (1178) Spura
linux logon ascsii art slika
Oddelek: Operacijski sistemi
371936 (1590) CaqKa
